Results 1 to 10 of 10
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Items for Sale
    Leaking washer fluid
    I have need leaking washer fluid for some time. Pulled the fender liner and tank to find out it was pretty dry.
    Seems to be coming from the headlight washer deal. Cant find any DIY, do you guys have any insight?
    Ill keep looking also
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Registered Member Two Rings
    May 20 2009
    Georgetown, Ky
    Re: Leaking washer fluid
    My experience with the headlight washers went something like this.
    I sprayed the washers and lost bother pop up covers, they just flew off. I bought new ones but didn't care to have washed headlights anyway so I pulled out the drivers side headlight and clamped the line. This caused the fluid to back up and the auxiliary washer pump split, leaking out all the fluid. Then i learned how to pull the reservoir, unplugged the aux pump and sealed up the leak. All good now but what a pain for a few hours.
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    the pump on the lower tank always cracks and that caused a leak in mine but when i wrecked my car i picked up a new one and replaced it and it was simple as hell but it helped that i had the whole front end of my car off haha
    Veteran Member Three Rings RaudiA6's Avatar
    Mar 23 2009
    02' A6 2.7T Qtip
    Dirty jERSEY
    slow, i have the same freaking problem, my leak seems to be coming from the hoses leading to the headlight washers, on both sides..as far as i can imaginei think i only need to replace the hoses, you should check yours out aswell
    The C5 Union
    Mods: K&N Drop-in/Carbon fiber wrapped interior/Silver Body Black Roof/ Tinted LED tails/98% De-chromed/Yellow fogs/10k HIDs
    --Talon
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Items for Sale
    have you recently had your front bumper off?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Mar 23 2009
    02' A6 2.7T Qtip
    Dirty jERSEY
    if regarding me, no i havent, i just looked up under from the ground and i can see where its originating from
    The C5 Union
    --Talon
    Feb 05 2008
    Waterloo NY
    Items for Sale
    well anyone in general really, because i had the same problem and wound up having to remove the bumper again so i could tighten the few clamps i had to loosen in order to remove the bumper. They were tight, just not tight enough i guess lol now the leak is gone
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Aug 15 2009
    Goodrich, MI
    I had the same issue. I pulled the resevoir and used silicon sealant between the rubber gasket and the resevoir body for each of the three gaskets, then added a touch of silicon sealant between the gasket and the two pumps and the sensor. I let it sit up a couple of days before adding fluid and the problem has gone away.
    PITA!
    Bob
    Mar 23 2009
    02' A6 2.7T Qtip
    Dirty jERSEY
    thanks guys ill check it out, get some sealant on there
    The C5 Union
    --Talon
    Senior Member Two Rings madman1234509's Avatar
    Mar 20 2009
    2002 A6 2.7t 6mt
    mayfield ny
    my actual headlight washer leaked. i think it was a bad o-ring on the inside of it. so until i take my front bumper off i pulled the wheel liner, unbolted the tank quick, unplugged the pump for the headlight washers then pulled the hose and plugged it with a pipe plug until i need to take my front bumper off for something to replace the headlight washer
    C5 Union
    Vast Stage2+
    (SOLD) '02 a6 black sport pkg 6MT, EVOMs intake, Custom 3" DPs, Custom 2.5" w/ borla mufflers & test pipes, RS4 clutch and PP, Samco TBB, Forge007 DVs, ER SMIC's, VAST w/m, dynotune digital boost gauge,
    5% tint, In.pro chrome mirrors
    '08 Black crew cab/short bed F-350 6.4l twin turbo. 5" exhaust, 6" tip. AFE intake, Spartan custom tuned. 35X12.5R20. 2.5" lift.
    600hp/1200ftlbs
