Results 1 to 23 of 23
    Aug 22 2009
    New England
    how to turn off engine without turning off music ?
    For traditional key, you can turn the ignition to "ACC" to shut the engine off while keep all the accessories on. With this new key, I don't see how to do it. When you pushed the key to stop the engine, everything is shut off including the music.
    Another interesting thing is that one day, I copied all my music to an SD card, and inserted it into the SD slot, AMI automatically started to play music. Since I didn't bring the key with me, I can't shut off the music !
    (the volume button can only mute the music)
    I have to go back to my room to get the key and push it twice (turn on and shut off)
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    Re: how to turn off engine without turning off music ?
    Quote Originally Posted by gator View Post
    i don't think you can go from ignition to just music,
    but you can NOT put your foot on the brake & push the key in just to get the ACC mode.
    AFAIK, you have to turn it off then on again
    I do this a lot...if there's a way, someone lemme know.
    Veteran Member Four Rings Bsix3.0's Avatar
    Feb 08 2009
    lots of bicycles..
    Aurora, Colo
    i think you can turn the stereo on and off just my pressing the power/volume bottom even if the key is not in the ignition. i know i can on my b6, im assuming the b8 would have the same feature..
    03 A4 3.0qt, K&N, debadged, passport 8500 hardwired, oetty front, ebay spoiler, cc mod, vht, 19" flik justices w/ spacers, rs4 rear sway, b7 sline rear valance, magnaflow 14851s ..
    -Lee
    Established Member Two Rings radioactive's Avatar
    Aug 23 2009
    Chicago, IL USA
    Yeah I am kinda annoyed with it. Every time I wait to pick up some one, I have to turn off the engine, then press the power on on the music. Also One thing I noticed is If I am connect to my Bluetooth phone and speaking, it wont get disconnected when I push the ignition key to turn off the engine.
    2009 A4 2.0T P+ Quattro, Tiptronic
    Brilliant Red
    Vag-com Mods
    LED interior and Rear Licence plate
    Xenon Match Fog lights
    Veteran Member Three Rings Comp4k's Avatar
    Aug 10 2009
    Carlsbad, CA
    When I turn off the engine, the music stays on until I actually pull the key FOB out..... I have a B8 P+ With nav.
    Veteran Member Four Rings 1_clean_Audi's Avatar
    Mar 27 2009
    Sold 2009 A4 Ibis 6MT S-line
    South Jersey
    Items for Sale
    itll turn on with out the key, just push in the volume button and you have mmi acces.
    Sold 2009 A4 S-Line 6mt
    Instagram: 1_clean_audi
    Aug 27 2008
    League City, TX
    Push and hold the volume button -- it will shut the system off. Short press mutes, long press powers off.
    Aug 22 2009
    New England
    Quote Originally Posted by Comp4k View Post
    I wish mine is working this way. but it is not.
    what about other folks ?
    Sep 13 2009
    2010 A4 2.0T
    Quote Originally Posted by radioactive View Post
    Also One thing I noticed is If I am connect to my Bluetooth phone and speaking, it wont get disconected when I push the ignition key to turn off the engine.
    assuming it's the same as ours -- when programming my parents bluetooth on their XJ , the manual said that bluetooth will stay active for 5 minutes after ignition is shut off.
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    Same with mine.
    B&O + Nav
    Aug 23 2009
    Chicago, IL USA
    Mine is a P+ only and Music turns off when I stop the engine.
    Brilliant Red
    Vag-com Mods
    Aug 02 2009
    Camarillo, CA
    same here, guess we're lucky. my bluetooth also works through the car with the ignition off and key in but transfers to my phone when the key fob is removed
    Aug 22 2009
    New England
    It sound like
    Without NAV music will turn off when engine is stopped.
    With NAV, music will stay on until key is pulled out.
    Mar 25 2009
    Pittsburgh, PA
    Quote Originally Posted by Bsix3.0 View Post
    That is correct-- that's how it is on the B8. Just hit the button- no keys required. Then just hold the button in to turn it off.
    Jun 17 2009
    2018 Allroad Premium plus; 2012 BMW K1300S; 2007 Nissan Titan
    Oakton, VA
    If you turn off the car and turn the radio on, won't it turn off when you open the door?
    Feb 22 2009
    Ottawa
    I have a 2010 with the start button, and when I turn off the engine my audi also cuts off. It's annoying, I wish it would stay on. There's often times when I park and I just want to finish listening to a podcast or something.
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    The music stays on after I turn off the car until I open the door or manually power it off.
    2012 Q7 3.0T: graphite, prestige, S Line Plus, adaptive air suspension
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    Mine works the same way. But it will only stay on for 10 minutes if it receives no user input. That time delay can be modified in the VAG-COM-activated hidden menu.
    2009 A5 3.2 6MT | Brillant Black/Black | Prem | Nav | Tech | B&O
    Sep 13 2009
    2010 A4 2.0T
    curse you, navboy...
    i'll get you for this.
    seriously though, a VAG-COM to enable this on us non-navvys would be pretty good in my books.
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Items for Sale
    It sound like
    Yes, this is what I've read in some other thread as well.
    There is no real solution for those who don't have Nav, it seems.
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    Yup - same here.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Sep 12 2009
    Torrance, CA
    Same here...it's extremely annoying.
    2011 A4: Quartz Grey Metallic P+ 6MT Sport Package
    Senior Member Two Rings holmes4's Avatar
    Apr 20 2012
    2013 Audi allroad
    Nashua, NH, USA
    In my car (2013 Prestige with Advanced Key), the radio stays on until I open the door.
    Steve
    2013 allroad - Prestige, Monsoon Gray/black, Sport Interior, Sonniboy sunshades
