Results 1 to 17 of 17
    Established Member Two Rings DYT937 S4's Avatar
    Sep 22 2009
    Dayton Ohio
    Installing lowering springs
    My Neuspeed lowering springs just came in. Cant find a writeup on how to install them. Anybody know what tools I need besides a spring compressor and some basic steps to follow?
    Thanks
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Items for Sale
    Re: Installing lowering springs
    http://www.audiworld.com/tech/wheel.html
    coilover isntallation for A4/S4.
    have fun, it's really pretty easy to do
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Three Rings jukesandz's Avatar
    Oct 10 2008
    '00 Audi S4
    NE
    For me, it was an altogether 11 hour ordeal, but I'd never done it before. All I used were these two articles:
    http://www.audiworld.com/tech/wheel49.shtml
    and the Bentley manual to look up the torque specs. The Bentley can be downloaded from here:
    http://www.socals4.com/repair/ (Thanks to Rated S)
    Just take your time and be patient. The only special tool you need is the spring compressor. If you have friends, get help from one of them.
    Sep 22 2009
    Dayton Ohio
    Thanks that really helps. This Saturday is work on car day. Im doing piggies and springs with the help of a friend.
    Deactivated Two Rings
    Jan 25 2009
    peoria il
    Quote Originally Posted by DYT937 S4 View Post
    Then I bet sunday is work on car day too. and probably monday. lol.
    Oct 10 2008
    '00 Audi S4
    NE
    Haha Yeah, that's more than a day's worth of work, especially when you haven't done it before. Saturday and Sunday should be fine.
    Senior Member Three Rings lukeag25's Avatar
    Jul 02 2009
    B5 S4,V8 S-10, 12v CUMMINS
    Denver
    Quite simple, just pay attention and remember to re-torque your control arms at the new ride height. I don't even use a spring compressor for the rears anymore. Got it down to 2 hrs on jack stands in my driveway! Good luck and happy wrenching!
    Stg3 B5 S4
    Senior Member Three Rings jpcallmotor's Avatar
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    Done it twice before. Its really easy and straightforward, but you need a day or weekend to do it. I Just changed the suspension my MKIII Jetta VR6.
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    spring compressors and an impact gun ftw. I did the first one by hand. took a few beers to get them done but wasnt bad.
    "Grandfather in halfies? Fuck. Can we grandfather courage as well"
    -Dangles! I has them.
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    make sure you set the upper control arms to the correct ride height before you tighten everything up. I blew through a set cause mine were still set for the stock ride height.
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Senior Member Three Rings fazda's Avatar
    Apr 30 2009
    2000 Audi s4
    Edmonton AB, Canada
    did my springs earlier this year. lol the hardest part for me was getting the fucking plastic plugs back into the top of the engine bay, very easy job, had all 4 done in less than 3 hours.
    2000- Audi S4, Piggie pipes, SSAC catback, Evoms Intake, Stg2+ Vast tune, 710n's, Eibach sportline springs
    Oct 10 2008
    '00 Audi S4
    NE
    Quote Originally Posted by fazda View Post
    You put those back in? Mine were MANGLED as fuck.
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    2001.5 S4
    Fairfield County, CT
    Quote Originally Posted by jukesandz View Post
    They were fucking mangled.
    Make sure have all the tools you need or live close to a hardware store.
    If you don't have any friends, hire a day laborer for $40 + lunch.
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Quote Originally Posted by scar79 View Post
    mine were mangled beyond belief too... but i wound up buying new ones at the dealer, cost like $3 each for those stupid plugs haha!
    i was able to read the part number off one of them to read for the parts guy.
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Sep 22 2009
    Dayton Ohio
    How do i go about setting control arms for new ride height? I thought stock control arms are non-adjustable.
    Im sitting here on a laptop with my car on stands and the wheels off, neither links provided are for the S4 which would be ok if the same suspension was in the A4 or A6 but judging by the pics they dont have the same suspension...
    Jun 24 2008
    '00 S4 Tip
    What they mean is that you need to make sure to re-tighten the bolts you loosened, under a load. If you tighten them all to spec when the car is in the air, you'll tear the bushings.
    Here's what 034 Motorsport says about this on their control-arm page:
    "To ensure a long life for these control arms, when they are installed, it is IMPERATIVE that the suspension be compressed to static ride height before any suspension pivot bushings are tightened. If this is not done, bushings will tear as the twisting forces on them will be much higher than is intended."
    Sep 22 2009
    Dayton Ohio
    K thanks guys the rears are done fronts hopefully tomorrow
