Results 1 to 12 of 12
    Sep 16 2009
    RI
    How do I add Sirius to my 05 A6?
    Just picked up a 2005 A6 3.2 with navigation and when I go to select Satellite on the radio the screen states that satellite radio is not installed. What do I need to buy to get it active?
    Thanks in advance.
    Senior Member Four Rings bryzf1's Avatar
    Nov 24 2007
    New Mexico
    Re: How do I add Sirius to my 05 A6?
    I just went thru this recently. I looked up the 800 for Sirius online and told them that I want a subscription for my car. They asked the id# that's below channel 1 iirc and they sync'd it up and it was working w/in a matter of minutes.
    Senior Member Four Rings 8520's Avatar
    Feb 07 2008
    00 6mt A6, 95 5mt del sol
    Quote Originally Posted by 05A632 View Post
    Thanks in advance.
    If your car doesn't already have the sirius tuner itself, you will need to get that, and the antenna, and then install and activate it.
    -dre
    Sep 16 2009
    RI
    Thanks. Where can I purchase the tuner and antenna? How much do they run?
    Sep 16 2009
    RI
    Is it part number: 4E0 910 593D ???
    Dealer wants like $550
    Feb 07 2008
    You can usually find oem sirius tuners on ebay.
    You need to find out if your car is "sirius prepped" though.
    -dre
    May 03 2011
    1988 BMW M3, 1986 Porsche 944 Turbo, 2007 VW Touareg, 2003 S6
    Hartsdale, NY
    So I've just realized that the Sirius tuners are ridiculously cheap.
    I'm operating under the impression that my car is wired for SAT...it's a 2003 S6 with a shark fin and this is my radio:
    http://i233.photobucket.com/albums/e...s/IMG_6624.jpg
    Is there a good reason not to get it, even if I don't activate right away?
    May 03 2011
    Hartsdale, NY
    So I installed the Sirius tuner I bought a few weeks ago.
    Piece of cake (mounted it on the bracket) but have a question.
    My concern with Sirius has always been the sound quality. Sounds like a low bit rate mp3 file from my LimeWire days.
    Does the sounds quality improve with a subscription (I'm still in "preview" mode) or a "better" package or is that it?
    Not sure how I feel about spending even $15/month for this quality.
    thanks!
    Dave
    Feb 07 2008
    Quote Originally Posted by danspach View Post
    thanks!
    Dave
    In my experience, Sirius sound quality is garbage no matter what subscription you have. It does sound better than the preview channel (184) but still not great.
    -dre
    May 03 2011
    Hartsdale, NY
    Greeeeeeeat.
    Thanks for the response. Guess I should have trusted my gut. Anytime I've heard it (in a rental car) it sounded tinny and shallow.
    Thought by now they would have advanced the state of the art.
    Feb 07 2008
    It's weird to me. Some factory cars with factory Sirius that I've heard sound just fine, but most don't. From what i understand it's all the same signal, so I can only guess that certain radios are auto-eq'd in a way that makes it sound not as bad.
    -dre
    May 03 2011
    Hartsdale, NY
    I might need to tweak it with the tone controls then. Anything with higher frequencies (the cymbals on the "Metal" channel)....sound terrible....talk sounds ok but was hoping for something more than the "Book Channel" out of this addition.
    Thanks for the suggestion.
    (If that doesn't work, I'll buy an exhaust system and listen to myself pounding on the V8 instead.)
