Page 1 of 6 123 ... LastLast
Results 1 to 40 of 219
Thread: Alkivar's A5
    Senior Member Four Rings Alkivar's Avatar
    May 16 2009
    '08 A5 3.2L S-line, '03 Passat GLX 4Motion, '04 GSX-R 600
    Maine aka Canada Jr.
    Alkivar's A5
    Picked up my A5 used in May 09 with just over 8k miles.
    Car is an '08 S-line with a build date of 02-02-2008.
    At the dealership:
    Photos from delivery (car came tinted):
    First night at home:
    '08 A5 3.2L S-Line Brilliant Black/Black... Build Thread
    "fuck your woods, fuck your bears, i'm machinegunning everything" - Marty
    "i used to date gold digging polish chicks, the venus fly traps of semen." - Marty
    "Listen, you can attatch F1-style suspension to a giant dildo, but at the end of the day, its still a dildo." - mdzaudi
    May 16 2009
    Re: Alkivar's A5
    Took it to a car show a few weeks later and won 2nd place best Import:
    First mods done a few weeks later were LED swaps for all interior bulbs... then I installed grocery hooks in my trunk as this car is a daily driver.
    then LED license plate bulbs from Tunerdomes (which burned out in a month)... so I replaced them with the Racing Dash ones from PYSpeed:
    I didn't like the all silver Quattro badge on the interior dash, so I popped it out and color filled the Quattro bit to make it pop more:
    installed in dash:
    I wanted carpets with the rings on them so I had them made in Germany (Luftimixx on ebay) a little pricey (€ 94 with shipping) but damn nice work:
    May 16 2009
    Re: Alkivar's A5
    I bought some R8 caps for my car, but didnt think they were shiny enough so I bought some billet caps from JCaps.
    When they arrived they still had visible tool marks from the CNC machining so I spent 4 hours sanding and polishing them. Started with 400 grit, then 600, then 1000, then 1500, then 2000, then 2500 and finally with 3000, followed by some Blue Magic aluminum polish:
    I did the same with my air conditioning aluminum lines... you should see them shine (will add photo of that later)
    May 16 2009
    Re: Alkivar's A5
    My next exterior mod was to add the carbon fiber front delete to replace the relatively boring gloss black one I ordered a few months ago. The carbon fiber definately pops on the front of this car and adds a nice touch:
    I just tinted my tails with Lamin-X (gunsmoke as I didnt want to go too dark) sorry for the poor quality photos will put something better here later:
    in daylight (you can also see my Euro reflector added to the trunk):
    May 16 2009
    Re: Alkivar's A5
    I ordered the KW V2 coilovers, but until Audi replaces my lower front control arms I'm not putting them in... til then they sit in a box:
    Brembo Gran Turismo BBK arrived today, will post pics of install once done:
    Here is my STaSIS exhaust and rear bar getting installed:
    Senior Member Three Rings jneutron's Avatar
    Mar 06 2009
    2009 A5, 2010 FX35
    CO, USA
    Re: Alkivar's A5
    Alkivar -
    Car looks great. I am following your lead and ordered some Racing Dash LEDs. Any tips for the install?
    2009 A5 [] Deep Sea Blue [] Light Grey Int [] Nav [] Tech [] B&O [] Stock S5 Wheels [] A dipstick [] STaSIS ARB [] STaSIS Exhaust [] Heon Xenonmatch [] Racing Dash LED Plate Lamp [] Rieger Rear Spoiler [] H&R 20mm F 25mm R []
    May 16 2009
    Re: Alkivar's A5
    Quote Originally Posted by jneutron View Post
    Alkivar -
    If you've ever popped out your license plate lights before then its easy, if not be careful not to open the lid too far while doing it or you might lose the wire inside the lid and have to pull the carpeted part off (I did that my first time OOPS!).
    All you should need tool wise to put these in is a flat head screwdriver and a cigarette lighter or some other heat source for the heat shrink tubing. Really they are a piece of cake, comes with a little wire adapter to make the LED module plug in to the harness. I would have preferred straight plug and play but this works. I didn't notice any polarity requirements for the cable as both of them worked on my first try.
    It comes with a large heat shrink tube to cover your wiring. I used about 6 inches of electrical tape to wrap around the connection first before heat shrinking. I find its less likely to disconnect that way.
    If you find them too bright you may want to tint the lens on them... I'm considering taking a quick spray with some VHT that my buddy has left over from doing his tails, as they stick out a bit now that i've tinted my tails.
    Mar 06 2009
    2009 A5, 2010 FX35
    CO, USA
    Re: Alkivar's A5
    Thanks for the info - I have not done this before on this car so I will heed your warnings. The lights should be here soon so hopefully I can do the install this weekend.
    Thanks again.
    PS If you are going to do the anti-roll (sway) bar yourself I just did mine and I could return the favor if you need any info.
    May 16 2009
    Re: Alkivar's A5
    Thanks again.
    no i'm having a STaSIS dealer in NH do the exhaust, rear bar and swap my rear valance all at the same time. I wanted a dealer to do it just so I have some backup on my warranty cause the dealers up here in maine are whiny little bitches
    Mar 06 2009
    2009 A5, 2010 FX35
    CO, USA
    Re: Alkivar's A5
    Ahhh yes the WBDS = whiny bitch dealer syndrome - a common affliction. Thanks again and good luck with the mods - post some picts when it gets installed.
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    Southern CA
    Re: Alkivar's A5
    debagde the rear!! clean none the less
    (Ka-La-Bre-Ah)
    May 16 2009
    Re: Alkivar's A5
    Quote Originally Posted by Calabria View Post
    with the 2.0T A5's out now... I think i'll be keeping my badging on
    May 16 2009
    Re: Alkivar's A5
    oh and LOL my car got in the newspaper...
    http://www.sunjournal.com/node/277068
    Senior Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    Re: Alkivar's A5
    nice
    those brakes are sick
    fs 19x8.5 dpe s-20
    b6 a4-sold
    May 16 2009
    Re: Alkivar's A5
    E-codes arrive:
    E-codes installed:
    Much more to come!
    Dec 22 2008
    2002 Audi A6 3.0, 2007 Audi RS
    New York, NY
    Re: Alkivar's A5
    nice car
    2007 Audi RS4
    2002 Audi A6 3.0 Quattro
    Audi Car Club of North America Member
    May 16 2009
    Re: Alkivar's A5
    I'm going black and carbon fiber on the exterior... just wish more people made carbon fiber parts for it.
    I will probably do some interior mods down the road... for now i'm primarily doing the performance stuff that is visible from the outside. I take it to shows on the weekend with my car club.
    Mar 06 2009
    2009 A5, 2010 FX35
    CO, USA
    Re: Alkivar's A5
    Alkivar -
    In your close up shot of the ARB in the post, it the ARB hangers look gold in color and have a grease fitting on them? Did you purchase these separate? My STaSIS ARB did not come with those hangers.
    May 16 2009
    Re: Alkivar's A5
    Alkivar -
    those hangers were put on by the local STaSIS dealer, I dont believe they shipped with the ARB.
    Senior Member Four Rings G Men 08's Avatar
    Feb 05 2008
    You name it..
    Re: Alkivar's A5
    very nice!!
    Run with the best, or die like the rest, Audi Quattro~SVT Mustang
    B6 A4 3.0-sold
    C5 A6 4.2-sold :(
    C4 A6 2.8-current
    B5 S4 A few mods-current
    I drive an Audi, it isn't in the shop to be repaired. It is in the shop to be maintained.
    At least thats what I tell myself in order to keep a level head!
    May 16 2009
    Re: Alkivar's A5
    did a quick shoot with a friend who's a professional photographer today...
    wallpaper size pics can be found here
    May 16 2009
    Re: Alkivar's A5
    Some of you are curious about the cutoff on the E-codes, so I took a quick picture...
    this is from my dash out through the windshield...
    Mar 06 2009
    2009 A5, 2010 FX35
    CO, USA
    Re: Alkivar's A5
    Quote Originally Posted by Alkivar View Post
    Thanks, I will give them a call.
    Veteran Member Three Rings tomlafS4's Avatar
    Nov 16 2006
    Just a bunch of bull
    Springfield MO
    Re: Alkivar's A5
    freakin A dude, your car is incredibly gorgeous. I love it
    -matt-
    May 16 2009
    Re: Alkivar's A5
    Quote Originally Posted by tomlafS4 View Post
    thanks man!
    give it time your new camaro will rock shit too... soon as people make stuff for it.
    Nov 16 2006
    Springfield MO
    Re: Alkivar's A5
    thanks man!
    haha, thanks dude! I cant wait to start modding her..
    when is your bbk gettin installed? I cant wait for those pics + the coils
    -matt-
    May 16 2009
    Re: Alkivar's A5
    waiting on AoA to authorize new front control arms to deal with shimmy at 55-70mph (they're replacing wheel #4 on Monday) after they do control arms and shimmy is gone they will go on... hopefully soon!
    Nov 16 2006
    Springfield MO
    Re: Alkivar's A5
    nice, good luck dude...looking forward to the pics!!
    -matt-
    May 16 2009
    Re: Alkivar's A5
    So car is at a different dealer for the week
    apparently my shimmy is worse than I thought...
    I put 2 brand new tires on the car a couple weeks ago... they are already worn unevenly! dealer is claiming now that I will likely need 4 new tires...
    they also tell me that one of the links for my rear ARB is broken!!! ALREADY!!! WTF?!?!?!?!
    on the other hand at least I have some new goodies for the car whenever I get it back:
    Installed:
    NOT A FUGLY WARNING LABEL IN SIGHT!!!!
    for those of you that care... apparently there are TWO different textures to the sunvisors for the 2008 model year. Be aware of that if you decide to order them...
    these are part numbers 8K0 857 551 F and 8K0 857 552 F for cars with the waffle weave/honeycomb looking headliners.
    the earlier models with the tiny pebbled surface sunvisors use part numbers 8K0 857 551 A and 8K0 857 552 A.
    Senior Member Four Rings Sandeman's Avatar
    Feb 15 2009
    2003 MB SL500
    where the horseman roams
    Re: Alkivar's A5
    looks excellent!
    May 16 2009
    Re: Alkivar's A5
    Quote Originally Posted by TTMK2_TJ View Post
    looks excellent!
    thanks!
    I had pondered getting the TTMK2 but when I tried one out at the dealer it just wasn't comfortably sized for a big guy like me.
    That and I needed more trunk space to hide the dead bodies
    May 16 2009
    Re: Alkivar's A5
    RS6 steering wheel (install pending):
    Senior Member Four Rings Sharkfin's Avatar
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    Re: Alkivar's A5
    holy gigantic pics batman
    May 16 2009
    Re: Alkivar's A5
    Quote Originally Posted by Sharkfin View Post
    been too lazy to shrink em all... then again on my 27" imac they look just fine
    besides who the hell uses dialup anymore.
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    Re: Alkivar's A5
    lol I have fast internet and I left your thread to load for at least a minute and all the pics weren't loaded and resized yet.
    May 16 2009
    Re: Alkivar's A5
    resize in progress... smaller pics should replace everything in the thread inside of an hour.
    Senior Member Four Rings UnkleGatsby's Avatar
    Jan 09 2008
    SunValley, ID | Seattle, WA
    Re: Alkivar's A5
    If you ever want to part with those wheels hit me up.
    "Fast cars, Danger, Fire & Knives," Aesop Rock
    -Maximilian
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    Re: Alkivar's A5
    They worked better now, btw nice steering wheel
    May 16 2009
    Re: Alkivar's A5
    glad you approve...
    yeah some stupid guy sold it to me for half price
    Active Member Two Rings WhiteA3's Avatar
    Feb 24 2009
    2006 Audi A3 2.0
    Re: Alkivar's A5
    Great looking car bro.
    2006 Audi A3 2.0 T
