Piggie Pipes and O2 Sensors: How to avoid a CEL and Information
This guide is designed for individuals who gut ALL FOUR CATS / ONLY 2 CATS (PRE-CATS)
There have been numerous threads lately asking how one can avoid a CEL with the piggie pipe route. I will explain a method that will work for everyone if they do indeed go this route. I will also try and explain the logic behind the modification.
Let’s talk about what Piggie Pipes are. The stock exhaust has two CATS on each downpipes. The front most CAT is the pre-cat (closest to the motor) while the one further down is the main CAT. CATS are very restrictive components to an exhaust, but they help reduce emissions that are mandated by law. The cats in the exhaust act like sponges, slowing down the airflow in the exhaust. Think of it as placing a sponge under a stream of water from your faucet. The stream of water is absorbed and slowed by the sponge. This is exactly the job of a catalytic converter.
Now when we remove the cats, creating "Piggie Pipes," the air is less restricted and therefore flows quicker. In simple terms, the O2 sensors are designed to measure the speed of the airflow through the cats. If we remove the cats, the increased airflow will trigger the CEL, because the computer is sensing the CAT is not doing its job.
How can I get Piggie Pipes but avoid a CEL?
The trick to eliminate a CEL is to use O2 spacers also known as O2 foulers. To make this procedure more simple, I have decided to post this information based off the VAST O2 Spacers. I have found that you only need two total (1 per side) in order to avoid a CEL with either 2 CATS gutted or ALL 4 Cats gutted.
You will need to put the spacers in the main cat bungle on each downpipe. The reason we use spacers is to try and mimic the equation that was present with stock cats. The O2 sensor is set to read a certain air speed. By removing the CATS we greatly increase that speed, which causes a CEL that I explained before. By moving the O2 sensor farther away from the bungle with a spacer it will reduce the airflow to the sensor, therefore giving us a similar equation as if we had cats. One VAST spacer per side is enough to produce the same results as if we had cats.
To solve the problem we simply screw in one spacer per side to the main cat bungle and then screw the O2 sensor into the end of the spacers.
You might also have to loosen the zip ties holding the O2 sensor wire to the transmission to free up some slack to properly insert the O2 sensors. I also recommend coating the threads of the O2 sensor and O2 spacer with Anti-Seize to prevent them from rusting in place.
That's it! Say good-bye to the CEL.
What will I gain from Piggie Pipes?
By doing the Piggie Pipes you will expect to gain around 10-15hp. The increased air-flow will allow the engine to rev faster. You will notice quite a difference during pulls. The sound increase is also another great product of piggie pipes.
Application with Aftermarket Downpipes
It is also to my knowledge that this modification will also work for gutted aftermarket downpipes. However, some aftermarket downpipes have different angles for the O2 bungles. For example, the design of FI downpipes makes it hard fit in normal O2 spacers. If you are having this problem you can purchase 90 degree foulers as shown below.
Applied on FI downpipes thanks to Greg (mad70sx)
Any questions please feel free to ask. If there is something I missed, didn’t explain clearly or if you have another insight please do not hesitate to post. I am not an expert, just a person trying to help this community.
Enjoy!
Re: Piggie Pipes and O2 Sensors... How to avoid a CEL
I'm considering the piggies with just the pre-cat removed. CEL possibilities is the main thing holding me back at this point.
Anyone running just the pre-cat removed? If so any CEL issues? Also, how complicated is the install. Will likely not DIY, what kind of shop would be best to install these?
Yes but if you look at the pic he posted these Dp's are modified for the man cat and you wouldn't need to do any thing here. You can see the 02 was already moved.
If you had these Dp's (in the pic) with the main cat you would be all set. the 02 is already moved for you.
If you don't have haters, then you're not kicking enough ass.
AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
And lastly for the grammar police that are bound to step in
I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
here look and see the original locations and then the moved location. The pic below is actual piggie modified Dp's with main cats. these will not get a cel if done this way if you have the cats in.
Notice how the 02 bung location on these is behind the cat. This will pass Ca emissions and not get you a CEL if you have the cats in
Here is one of the kickers. You can make the Dp's obviously your elf if you move the bungs and not get a CEL. But placement will effect your mileage.
As joey said if you put your spacers in on catless Piggies you will be fine. This will only work real well on piggies.
Remember joey has laid this out VERY well. you want to create a spacing of the 02 sensor or mimic the speed/volume of air normally passed by the 02 with cats. This is why when you try this on aftermarket Dp's it will work but for only a little while. Using the stock Dp's helps keep every thing in its location all that's left for you to do is to get the spacing rite............well not anymore JOEY did that for you
Since there was a bit of confusion in what exactly piggy pipes are I'll post my personal definition:
Anyways, "piggy pipes" essentially refers to the modification of factory downpipes for performance gain; the term migrated over from the B5 S4 section where it was a very common modification. To this end the modification (within the B6/B7 S4 performance scene) typically refers to the removal of only the pre-cat from each of the stock downpipes. This ensures continued emissions compliance, but still allows for a significant performance boost (due to lower exhaust restriction, and more advanced timing due to lower cylinder temperatures). As an option though it is possible to have both catalytic converters removed from each factory downpipe, in order to further reduce exhaust gas restriction, and increase performance at the cost of emissions non-compliance. The extra performance gained by going full catless when having piggies made is typically too slight for most consumers to risk the emissions non-compliance; resulting in the large number of pre-cat gutted piggie users you see on AZ.
So the CELs prior to the relocation were post-cat failure codes? Could someone please elaborate on this?? I am having a similar issue and need a bit of help correcting..
Hey guys,
Sorry for the confusion but it seems the picture i used this morning was of the VAST piggies where they relocate the O2 bungles. I did not notice this at first but it is now correct for my purpose.
Please note that this information deals with STOCK piggie pipes, not the VAST ones. As it has been mentioned, VAST relocates the O2 bungles shown in Justin's post. My method will not work on VAST modified piggies since they are located farther down (past) the main cat. Please only use this guide if you have your O2 sensors located in the stock position on the main cat.
Originally Posted by joeycuccaro
Hey guys,
Explains everything haha, thanks for clearing it up I was beginning to think I was retarded.
I have straight dP's and 100 cell main cats. The main cat sensors are currently located before the main cats. I used to get the occasional CEL but I have not had one for a while. Car runs fine, although a bit rich.
Is it better to relocate the main cats sensors to the rear?
Just to let you know, I had NO LUCK with VAST spacers, and even Wayne's 90 degree spacers threw CEL's after 5K miles or so. I think it's more than that, but maybe my S4 was just picky....
Do you have VAST piggies or custom?
It's the APR DP's. BTW, I have Winter's S now. But yea, it still throws the code. Here is it. I asked JHM and it might be the bad O2 sensor. They said I can get chipped and get rid of the CEL, but they still recommended me to change the O2 sensor.
5 Faults Found:
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 001 - Upper Limit Exceeded - Intermittent
18528 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1: Too Lean
P2096 - 002 - Lower Limit Exceeded - MIL ON
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 004 - No Signal/Communication - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 004 - No Signal/Communication - Intermittent
16543 - Oxygen (Lambda) Sensor B2 S2: Response too Slow
P0159 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Anybody else do their own piggie pipe themselves with good results. I'm still wanting to try modifing the stock pipe myself. I can't see paying someone for removing the precats and welding a new bung. But if there's more to it than that, I'll send them in to jhm.
Thanks for this post Joey but I have one outstanding question after reading the other well-informed posts in this thread ...
If the pre-cats can be gutted but the car can still pass an emissions test (as Justincredible and beemercer have stated) then what is the function of the pre-cats? Has anyone reported difficulties passing a standard tailpipe sniff test with gutted pre-cats (CEL notwithstanding)?
Originally Posted by jfunkey
Go back and read justin's post again. he talks about it and explains it in there.
I must be missing something here but all I see in his post is an explanation of how you would move the O2 to behind the main cats which would allow you to pass an emissions test.
I would have expected tailpipe emissions to increase with gutted precats, which would cause a test failure. Since that appears to not be the case (once you've relocated the O2 sensor), my only guess is the ECU alters fuel/air ratio to retain factory emissions with gutted precats.
If that is the case and as Justin says, MPG will be affected, how much are we talking about here?
The pre-cats are there primarily for emissions compliance when the motor is running cold. Since they are closer to the motor they trap more heat allowing the catalytic reactions to occur, primarily the catalytic oxidation of excess hydrocarbons into water and CO2 and the oxidation of CO into CO2 (cold motors run ultra-rich and produce massive amounts of CO and unburnt HC's); the heat is necessary to reach the minimum activation energy of the various reactions. As soon as the motor reaches operating temperatures the main cat located further downstream will be at a great enough temperature for the catalysts to operate. So basically the pre-cats are there to solve an emissions issue that lasts for maybe 30 seconds in summer and 5-10 minutes in winter (my guesstimations on the times don't hold me to it scientifically).
The precat is just like a lot of emissions equipment (upstream SAI) that can be bypassed since it only really affects the motor at below operating temperatures. As long as you get your car nice and hot before going in for the sniffer you should be fine.
If you are interested I could do a writeup on how catalytic converters work, issues with AFR, issues with operating temps, etc. Basic emissions background information (I'm going to school for Chemical Engineering focusing on Environmental issues).
Great information man. You seem to be really knowledgeable and interested in the exhaust set-ups for these cars. Very nicely put.
Thanks beemercer, that's exactly what I wanted to know. I'm very interested in converting my DPs to piggies but don't want to increase my emissions in such a way that would cause me to fail an emissions test (in CA for example). As you said, as long as the engine is nice and hot, all will be fine. I generally get my engine warm before an emissions test anyway because I learned a long time ago that a cold cat won't do its job like a hot cat will. I've failed more than one test because I just replaced a cat and went straight to the emissions test without warming the car up.
I thought SAI on its own provided enough to get the main cats working properly at cold temps, but I guess auto manufacturers are always taking it a step further and had to give us precats too.
Upstream SAI is in place to provide the extra oxygen necessary for the catalytic oxidation reactions to occur. Without the extra oxygen the reactions cannot occur. BUT the reactions will not even begin to occur until the minimum activation energy is reached, and the main determinant of U (internal energy) is the temperature and pressure of the exhaust gases along with their kinetic energy. Essentially though the temperature is the only factor. So you can keep pumping in the extra oxygen, but if the gases aren't hot enough you can't overcome the activation energy and begin the reaction. It is akin to pushing a boulder up a 5ft hill to let it fall off a 50ft cliff, you need a bit of energy initially to start the reaction up, but once you reach the top of the mound it goes (unfortunately these reactions are exothermic, otherwise they would act as a post combustion chemical heat pump).
No problem, anything I can do to help. Emissions and gas flow are a great hybrid of my passion (cars) and my academic pursuit (Chemical Engineering). I'd love to work somewhere in the automotive field related to emissions or alternative fuels for ICE's. So really any questions you guys have regarding emissions, exhausts, chemistry, use of alternative oxidants and fuels, etc feel free to ask and I will do my best to give you an answer from my acedemic background (what I say may not be the standard thought in the automotive world though).
Makes perfect sense, now I have the million dollar question. If I were to removed the material in the pre cats (gutting them out) where to I need to place the O2 sensor so I wont have a cel light? There is 4 o2 sensors correct? The picture shows the pre cat 02 stock location but doesn't show if they are relocated, are they? Or is just the main cat 02 sensors relocated?
Correct, there are a total of 4 O2 sensors on the car. From what i understand VAST relocates the Main sensor bungle back to the latter position shown in the picture.
I figured out a setup, however, where if you gut all four cats you dont need to relocate and O2 sensor bungles.
