Results 1 to 40 of 63
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    Any way to aim headlights higher?
    Hey guys, I noticed that my headlights could probably use some re-aiming a bit higher for better night visibility. I realize it's probably because my car is so low, but I know on past cars I was able to turn a knob on the headlight assembly to aim them higher. Anybody tried yet?
    2012 Q7 3.0T: graphite, prestige, S Line Plus, adaptive air suspension
    Senior Member Three Rings A4DK's Avatar
    May 13 2009
    Oakland, CA
    Re: Any way to aim headlights higher?
    I dont see any on the B8. My B6 had it though. What I have noticed is when I turn the car on, the lights adjust themselves upwards and then back down. So maybe its VAGcom controlled now a days?
    I could also imagine this is true as the US and EU lighting standards are different, so having it controlled by electronically would make it easier to change for other markets.
    The only way to get rid of a temptation is to yield to it. - Oscar Wilde
    2011 A6 3.0T - Prestige - S-line - Sport
    Gone but not forgotten.
    2011 S5 6MT - Prestige - Sports diff - Brilliant Red
    2009 A4 2.0TQ - P+ - Sport - Aruba Blue
    2002 A4 1.8T - Executive - Brilliant Black
    Veteran Member Four Rings Nght&Day-B8's Avatar
    Aug 05 2009
    Miami, Fl
    I too noticed when i lowered my car the beam is shorter than it used to be, and i also realized the lights adjusting.. never was sure the purpose of it though
    Jul 10 2009
    northeast
    i'll ask the audi technician i'm seeing tomorrow if the auto leveling sensor can be adjusted.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by macuser View Post
    Thanks, I'd appreciate that!
    Veteran Member Four Rings A4Ber's Avatar
    Feb 13 2007
    2010 Audi S4 Phantom Black
    San Francisco, CA
    I saw the knob today when i changed my bulbs! I will try to get a pic for you later. It is similar to the one i had on my b7.
    2010 Audi S4 Phantom Black Prestige 6MT
    Current Mods: JHM Short Shifter, A.W.E. exhaust, Stratmosphere Intake, Ecodes with 6000K, Höen Endurance Fogs, Diffuser Painted
    News: Thinking about sellin my HRE p41 et35 and new mods next Friday~
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by A4Ber View Post
    Sweet, thanks!
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Items for Sale
    Blake, there is a white hex screw on the top of the headlight housing that will adjust the up and down. I did mine about a month ago and the auto-leveling still works great.
    My current rides...
    Audi
    Jetta
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Jacon View Post
    Thanks so much! Do you happen to remember which way to turn for UP or how many revolutions you made, by chance?
    Aug 05 2009
    Miami, Fl
    x2, i dont want cross-eyed headlights.. how many turns and to which way if your facing the car head on?
    Jan 05 2009
    B8 A4 6MT P+
    Items for Sale
    I made three revolutions for each light and that got me from my current height, to roughly a stock level. The beam terminates about 200ft in front of my car (rough estimate) after adjusting the lights. Unfortunately I cannot remember which way I turned the screw (IE clockwise or counter-clockwise) but if you line the car up against a garage roughly 30ft away, you should clearly observe whether the light is going up or down based on which way you turn the screw.
    My current rides...
    Audi
    Jetta
    Mar 02 2007
    Fresno, CA
    Do you remember if you turned clockwise or counter clockwise?
    Jul 10 2009
    northeast
    Thanks Jacon. My headlight beam pattern is alittle high. The audi tech told me to just bring it in for service and their computer would fix it. I will try to adjust my lights your way first.
    Did you turn the screw clock wise or counter clockwise? Thanks again
    Veteran Member Three Rings Sin_city_Rings's Avatar
    May 09 2009
    Washington, DC
    Good looking out, as i noticed mine are a lower height as well, which direction to turn would be helpful!
    2008 Deep Sea Blue S5 6MT
    PAST: '12 A4, '08 A5, '09 Sline A4, '07 Sline A4
    Mar 02 2007
    Fresno, CA
    Just lower your car and that should take care of the problem!
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Hm, interesting. I wonder if I'll need to raise mine too after I lower my car. Too bad the system doesn't auto level to horizon....or does it? Considering it self-tests up-and-down as well as side-to-side on boot-up.
    Ryan - flickr
    Jan 05 2009
    B8 A4 6MT P+
    Items for Sale
    *UPDATE* - It will be a white 6mm hex screw on top of the ballast. Clockwise will raise the beam and counter-clockwise will lower the beam
    Quote Originally Posted by Ryan_T View Post
    The system will auto level to horizon but only so far from what I can gather. You'll need to have the car on level ground when you adjust the beam. Once the 'control' beam is set, the auto-leveling will handle any future cases in which the car's height might change. I should also note that you should adjust these beams with around 1/2 tank of gas and no extra weight in the trunk.
    My current rides...
    Audi
    Jetta
    Aug 27 2008
    League City, TX
    I came across a "range" setting in Vag-Com when poking around -- didn't try to adjust it however -- wonder if that would do the same thing without having to twist screws...
    The mechanical method would be easier, just wondering if it's do-able electronically as well...
    Aug 05 2009
    Miami, Fl
    i think ima play safe and do two full turns instead of three if the auto adjust will do its work after..
    Mar 02 2007
    Fresno, CA
    Thanks so much for the information, Jacon!
    Jul 10 2009
    northeast
    =) soon enough. i havent done any research on the subject yet. i'm a complete noob to this whole modding thing.
    Mar 02 2007
    Fresno, CA
    Feel free to ask any questions you might have!
    May 09 2009
    Washington, DC
    Lets just start off by saying im one of the types that if 1 or 2 is enough 3 or 4 is better....
    So last night i did 4 full turns and WOW what a difference! No oncoming flashes as of yet.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Sin_city_Rings View Post
    Sweet, I'll try 3 and see how that works!
    Established Member Two Rings radioactive's Avatar
    Aug 23 2009
    Chicago, IL USA
    Where exactly is that white screw..? I see two of them in my car.One is on the top of the whole headlight dome but in a angle and other one in right in the front.
    Mar 02 2007
    Fresno, CA
    I just finished adjusting mine. We'll see if it makes a difference when the sun goes down!
    Aug 05 2009
    Miami, Fl
    I did two awhile back, and i think one more full turn would of done the job best. So three turns is pretty spot on
    Mar 02 2007
    Fresno, CA
    I'm afraid 3 rotations were too much. I was lighting up signs on freeway overpasses! Good news is that nobody high-beamed me. I'm going to dial them back 1 full rotation and see if that's better.
    Aug 05 2009
    Miami, Fl
    oh man, then maybe 3 is too much.. try half a turn back? i know two turns wasnt too much of a difference.
    Jan 05 2009
    B8 A4 6MT P+
    Items for Sale
    I'm a tad lower than you are, so this would make sense
    My current rides...
    Audi
    Jetta
    Mar 02 2007
    Fresno, CA
    I dialed them back 1 full turn today and tested tonight on the freeway... now they're the perfect height!
    Aug 05 2009
    Miami, Fl
    Ive noticed my driver headlight is a tad lower than the passanger one, even though i did two full even turns. Is this normal or should i nudge it up a bit more? My guess is its like that because its a left hand driver vehicle?
    Jan 05 2009
    B8 A4 6MT P+
    Items for Sale
    Quote Originally Posted by Nght&Day-B8 View Post
    yes...dont touch them. Generally the driver's side is lower to keep the beam away from on-coming traffic. Your eyes are not deceiving you....they are set like that from the factory.
    My current rides...
    Audi
    Jetta
    Mar 02 2007
    Fresno, CA
    Damn, I got hi-beamed twice last night so maybe they're still aimed a little too high. I might try lowering them a half turn to see how much difference it makes. If visibility is reduced, they're going back up!
    Oct 27 2009
    '15 MBZ E400 Cab/'13 Subaru Outback 3.6R
    Miami, FL | Boone, NC
    Would someone mind taking a picture of this hex screw? As many of you may know, I swapped my halogens for xenons a couple weeks ago and my lights need some adjusting...
    I remember seeing two white hex screws on the top of each housing. I can't check again now because I am out of town for a week.
    I made sure to mark my headlight levels on my garage before I changed my lights. The new drivers side light lined up PERFECTLY with the old halogen, but the passenger side is a bit low...
    Active Member Two Rings XCC Motorsports's Avatar
    May 12 2009
    2005 Audi S4
    AZ
    Anyone have pictures? I need to see which hex screws that need to be adjusted.
    |B6 Audi S4|*Milltek Non Resonated Exhaust - Evotech ECU - H&R Coilovers - Matte Black Upper & Lower grille - 10% 3M Window Tint*
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Just look there is only one white one per headlight. Right on top.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at David@audienthusiasts.com I don't frequent this forum very often.
    www.audienthusiasts.com
    Nov 06 2009
    2017 RDX Black on Black AWD
    NYC / DC/MD/VA
    Do you guys mean these White Screws on top?
    -cW
    Nov 06 2009
    Yep but.. You've got 2? Hmm must be because I have adaptive. The one we share is the one on the right. Guessing it's the height adjustment since we both have it.
    Oct 27 2009
    lol - I knew I saw two white hex screws on top of each headlight...
