Results 1 to 19 of 19
    Senior Member Two Rings gtrab's Avatar
    Mar 02 2009
    Audi A4 B8, Audi Q5 2013
    El Salvador
    How to reprogram (synch, match) a new Remote Key (FOB) control
    One of my remotes lost it's prgramation suddenly
    The battery is OK (tested), but it will not lock / unlock the doors anymore (it does start the engine, it's just lost the "remote" key function)
    1- How can I re-program my remote FOB
    2- What could have been the reason for a sudden deprogramation ??
    Thanks
    [EDIT] Now the SECOND remote is not working (not locking / unlocking the doors, but starting the engine)
    NOW I AM CONFUSED (???)
    What's going on ???
    NOW: Audi Q5 2.0T Ibis White
    19" 5-Y spoke wheels 255/50 tires | Exhaust tips | Special lower body paint work | VAG-COM customizations
    EX: Audi A4 B8 CVT deep ocean blue
    19" 5-Y spoke wheels & 255/35 Dunlop SpeedMaxx tires | S4 grille & fogs trims | S-Line side skirts & exhaust tips | "Audi collection" items | Custom paintwork | CTM ECU reprog | VAG-COM
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Items for Sale
    Re: How to reprograma new Remote Key (FOB)
    Found it...
    http://forums.audiworld.com/showthread.php?p=14741675
    I'm pissed though because there is a way to do this using only 1 key. (I MAY have found it).
    Turn on the car to accessories
    Let it sit for 10 seconds
    Turn car off and get out with the key
    Manually lock the car door
    Press lock on the key
    Now manually unlock the car door
    Press unlock on the fob
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Mar 02 2009
    El Salvador
    I tested the method described in your link before posting and it didnt work
    Now I have tested this other slightly different method and it didn't work neither......
    PLease help I'm stuck with both controls unusable
    I have to manually remove the key from the remote to open the doors
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Here are one more instruction (maybe the right one): http://forums.audiworld.com/showpost...59&postcount=2
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 18.2.0 (HEX-V2)
    Mar 02 2009
    El Salvador
    thanks rlarsen, but it didn't work...
    will keep investigating
    Jul 15 2009
    CA
    Almost all of the new keys are programmed with dealer scan tools. Check with the dealer you bought the car from, they should reprogram them for you for free. At least my dealership does. The older keys you could program them just by turning the ignition on, then pressing the unlock button and it "wakes" up the remote.
    Mar 02 2009
    El Salvador
    GOT IT !!
    After testing thousands of methods, I finally re-codded both remotes today.
    Not sure about what I did or how to describe it, I still don't believe it was so simple !! or I may be omitting something ?? the fact is BOTH REMOTES are WORKING !!
    1- VAG-COM
    46 - Cent. Conv.
    Adaptation - 10
    Channel "00" -> "test" -> "save" (to reset factory defaults)
    2- Matching (synch)
    Put spare (platic) key in ignition (the one in the glove box)
    Push to turn ON (not engine start, just push to "on" position)
    Press one button on each remote
    Start engine
    Stop engine and remove spare key
    Test remotes
    I have made so many tests -with & without VAG-COM- that now I can not assure this is the 100% correct way I reprogrammed my remotes
    Anyway, I wanted to let you all know I finally got my remotes programmed
    The procedure still needs to be duplicated by other users to be confirmed
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I though the only way to do it would be to use specialized RFID tools that only the dealer or eager people will have. Kinda scary that it can figured out by a person in their garage with vagcom.
    Is this confirmed?
    Ryan - flickr
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by Ryan_T View Post
    Is this confirmed?
    The 'old' procedure was without VCDS (see my earlier post)
    Rene Larsen
    Senior Member Three Rings jcs's Avatar
    Jul 22 2009
    09 A4 2.0TQPS, 02 Infiniti Q45, 06 Kawi ZZR600
    GTA, ON
    Yup..my sales guy said that the new key fobs will deprogram themselves after 90 days or so and if it happens, bring it in and we'll reprogram it for you. So guys, in a nutshell, to save yourself of this 'hassle' make sure you use each remote once a month to keep 'em all alive.
    Thanks gtrab for figuring out how to reprogram them though. +1 rep
    Mar 02 2009
    El Salvador
    Please remember:
    It has to be REPLICATED by others before we can CONFIRM it and spread the word
    My first thought was "OK, now let's delete the programmation and re-program again to re-confirm the method",
    but I'm so bloody annoyed after all this trial and error
    It would be great if somebody with a new remote could confirm or bust this
    (Feedback request)
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    Quote Originally Posted by jcs View Post
    I don't buy that. And I certainly hope that your dealer is incorrect, as that would just be ridiculous. I'm sure if the key needed to be used every 90 days to ensure it maintains programming it would state so in the manual.
    2009 A5 3.2 6MT | Brillant Black/Black | Prem | Nav | Tech | B&O
    Jul 22 2009
    GTA, ON
    Quote Originally Posted by HobbesA5 View Post
    I didn't buy it initially either, but since someone here just experienced it, that was the only piece in the puzzle that fit..
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    But since both of his stopped working I doubt it was related to neither being used for 90 days.
    Oct 16 2012
    uk
    Quote Originally Posted by gtrab View Post
    hello there, my dad just had to reprogramme his keys too and he was following the guides from here http://carkeyadvice.com/remote-fob-programming-guide . try taking a look at it. and see if it will work . maybe it can help you too! cheers!
    Established Member Two Rings thrill23's Avatar
    Apr 30 2016
    OEM Parts
    Miami, FL
    Quote Originally Posted by joe2012 View Post
    When I clicked the link, server error message.
    Sep 06 2016
    England
    Could you elaborate on what you've done after the reset to factory defaults procedure as I'm having the same issue and it's driving my crazy!
    GOT IT !!
    1- VAG-COM
    46 - Cent. Conv.
    Adaptation - 10
    2- Matching (synch)
    Start engine
    Test remotes
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Mar 26 2012
    Montreal
    Do the keys have to be virgin ?
