Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
  1. #41
    Feb 10 2004
    2009 A4 2.0T Sedan
    Re: *Review: 08'-09' S5 Aluminum Mirror Caps*
    Felt the need to bump this thread because I found the holy grail. As I've mentioned in a few threads now, including this one, I've been trying to find a paint or vinyl option to match the polished aluminum finish found on the S cars...
    Pics to come tomorrow.
    CURRENT: '95 Ur S6 Avant | '12 A6 3.0 TFSI sedan
  2. #42
    Forum Moderator Four Rings MiracleWhips's Avatar
    Jun 02 2009
    San Francisco
    Tomorrow as in later today?????
    STaSIS ECU & 23mm RARB / AWE FMIC & Exhaust / Eurocode IP / Carbonio / 034 TIP / 20% Tint / S5 Mirrors / Rotiform MIAs 19x8.5 / Hankook 255/35 / H&R Avant Sport Springs / RS6 Pedals / Hoen Fogs /Stoneguards / ecodes / A4L Fog grills
  3. #43
    Feb 10 2004
    2009 A4 2.0T Sedan
    Yessir. Let me just say that I am extremely excited with how the parts turned out, it's a near perfect match! The materials aren't cheap, and I just hope it holds up well to the elements, rocks, etc... *fingers crossed*
  4. #44
    Senior Member Four Rings aznpxdd's Avatar
    Feb 16 2009
    2012 Alpine White BMW X1 (China)
    LA/Dongguan/Taipei
    PICS!!
    -Jeff
    2009 Ibis White A4 2.0T
    Gloss Black Grille | CF Filler Plate | 19x8.5" Dark Gunmetal VMR v701's | Black Calipers | ST Coilovers
    OSIR Trunk Spoiler| H&R 5mm Spacers | 5k DS3 HID's | Luminics Fogs | VAG-Com | Silver CF Interior | K&N Intake
    Painted Front Splitter | Gloss Black Roof | Hardwired V1 | OSIR CF Rear Valence | AWE Quad Tip Exhaust
  5. #45
    Jun 02 2009
    San Francisco
    Glad to hear that the materials are not cheap since I just invested in the real deal mirror caps.
    But I am curious what you "aluminized".
    Front splitter? side sills? shark fin?, door handles?, valve stem caps....
  6. #46
    Feb 10 2004
    2009 A4 2.0T Sedan
    One of the above items is correct...but which one? And you may have seen from one of my other posts that I'll be doing the front grille trim next. So stoked!
  7. #47
    Jun 02 2009
    San Francisco
    My guess is the side sills to match the rear valence treatment!
    That way the car will be well rounded down there!
  8. #48
    Feb 10 2004
    2009 A4 2.0T Sedan
    Damn, you're good! I'll probably get some flak for it, but I think the polished aluminum finish looks great with the white. Once I tie it all in with the front, it'll be perfection.
  9. #49
    Jun 02 2009
    San Francisco
    If you have been following my other posts, I definitely have some wierd personal issues about mods! I have been searching for the perfect plate frame to balance out the rear end, cause right now it looks off to me!
    I wish I had the ability to say @%#& it! sometimes, but I don't.
    But I agree, on white, the aluminum finish blends very well. So well it is hard to get it to photograph sometimes. thinking outside the bun will always get you flak from somebody, so no worries. Be sure to include how you attached these side sill / rock guards since you mentioned you might not use the clips.
  10. #50
    Senior Member Four Rings cory_can's Avatar
    Mar 05 2009
    (Very) Red B8 Avant, '11 Volvo XC70 T6
    Golden Horseshoe, ON, Canada
    ......Be sure to include how you attached these side sill / rock guards since you mentioned you might not use the clips.
    +1 ...I'm very interested in how you decide to do this.....rivets in my brand new car scare me!
  11. #51
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    I believe the 10' S4 and S5 have the lane assist cutouts but i hear the caps are a different shape now.
    That is correct. MY10 mirrors are mounted a little lower, and the side assist cutout is a different shape.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
  12. #52
    Veteran Member Three Rings audiblack's Avatar
    Montreal Canada
    any DIY for these housings? I was able to take off the mirror from its place but as for the housing itself, im not sure where to pull and what not. Dont really want to break anything. it comes out of place on the bottom but not sure how to do the top
    2010 S4 WHITE ON BLACK 6MT
    ......mods coming soon!
  13. #53
    New Member One Ring
    Sep 29 2009
    Cayman Islands
    Very nice!! I'm looking to get a pair for my A5, can you hook me up with the link?
  14. #54
    Jun 02 2009
    San Francisco
    Quote Originally Posted by audiblack View Post
    No DIY, I just used a few words of wisdom from Anthony who swapped his mirror housings a while ago.
    Once you get the mirror out and unhook all the cables, in order to remove the housing itself, I recall there definitely being two clips near the bottom, but above the turn indicator housings. If you stick a small screw driver and gently push towards the front of the car they should release. Also there was a torx screw which I removed closer to the inside of the car. Then just kind of wiggled and squeezed the mirror cap until it obviously started to come loose, then just kind of worked off the base that way.
    You will then need to unscrew the turn signal housing from the mirror housing.
    It is a very snug fit with little wiggle room, so you won't really bend anything provided you are careful with the two clips mention above.
    Getting the housings back on squarely took a couple tries for me, but I realized lining up those two clips once again made everything align correctly. Careful not pinch any of the mirror or turn signal wires, they can get in the way.
    The first took me about 20 minutes, the second ten. Then going back to adjust the first correctly after figuring it all out on the second took two minutes.
    Quote Originally Posted by ArekSkillz View Post
    Assuming you are talking to me.....these are OEM caps that I got from the dealer pars department. You can also get them from many audi parts retailers such as oemplus.com, but usually for a couple hundred dollars more.
    Or if you pay for my flight and put me up a couple nights in a beachfront hotel, I will gladly hand deliver a set to the Cayman Islands for you!
  15. #55
    Senior Member Two Rings audi_s5's Avatar
    Jan 04 2009
    2009 AUDI S5 A6 SLINE A3 SLINE
    WI, USA
    Quote Originally Posted by ChronoVII View Post
    do they have holes cut out for the blind spot detection system? if not, are there any out there that do?
    Yes, my 09 s5 has side assist.. Just different audi part #, check with Alex @ Europrice or local dealer for part #
    STaSIS CHALLENGE EDITION AUDI S5 - Ice Silver/Black Napa Leather, Side Assist, NAV, TECH, B&O, Carbon Inlay, STaSIS ECU Tune, STaSIS Exhaust, STaSIS Ohlins Susp Pkg/Swaybar, MTM Brembo 8 piston brakes, Dimpled OEM Rear Rotors, 20" EUR Wheels, BMC Air Filter, RS4 Pedal Kit, Clear Roadblock Bra,Hoen H11 Fogs, LED Taillights,Auto Fold Mirrors, EUR FB Steering Wheel
    A6 S-lineBril.Black,Tip,NAV,Bose,ADS,S6 Bumper/Grille/LED's
    A3 S-lineBril.Black,2.0t,DSG,NAV,STaSIS Stage II
  16. #56
    Oct 24 2008
    N/A
    Sorry to bring back this old thread, but was looking at the parts myself. Did some digging around and found the following (in case anyone need it in the future)
    Part # of MY2009 S5 Aluminum Mirror housing w/lane assist cutout
    8T0-857-527-C-3Q7
    8T0-857-528-C-3Q7
  17. #57
    Senior Member Three Rings formula1guy's Avatar
    Apr 14 2009
    B8 A4 Avant S-line,2010 A4 prem + w sport package
    Northern California
    Quote Originally Posted by akaisuzu View Post
    8T0-857-527-C-3Q7
    8T0-857-528-C-3Q7
    nice, been wondering about the lane assist cutout. Thanks for the info!
  18. #58
    New Member One Ring
    Jan 10 2010
    calabasas ca
    I have a 2011 A6 and just purchased AUDI OEM S6 Mirror caps, can someone tell me the procedure for removing and replacing the old mirrors with the new ones?
    Thank you
  19. #59
    Jun 02 2009
    San Francisco
    Quote Originally Posted by h hirsch View Post
    Thank you
    Have you checked in the A6/S6 forums?
    Might be a whole lot different than the B8 A4. (The tricks and tips for successful uninstall/install could be different)
  20. #60
    Apr 05 2004
    Ohio
    bump...can you elaborate this polished aluminum finish?
  21. #61
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by audibmi View Post
    It's a two-part paint process made by "House of Kolor".
    More here...
    http://www.audizine.com/forum/showthread.php/312047
    http://www.audizine.com/forum/showthread.php/323981
  22. #62
    Apr 05 2004
    Ohio
    More here...
    http://www.audizine.com/forum/showthread.php/323981[/QUOTE]
    Thank you for the links Anthony. I am impressed how a painted product can replicate an aluminum finish so accurately. I am assuming its the Kosmic Krome product that was used. I may consider painting the wheel arches of the new allroad (if i decide to get one later this year) this color to match the rear valence.
  23. #63
    Registered Member One Ring tokarsqi's Avatar
    Apr 21 2012
    nyc
    very good product on ebay for fracture price of oem covers...made in germany super fast shipping just got mine
    http://www.ebay.com/itm/Audi-Alu-Mat...ht_1135wt_1068
  24. #64
    Feb 10 2004
    2009 A4 2.0T Sedan
    Sorry it looks like I never replied to this. Yes it's the "Kosmic Krome", the "Aluminum" finish I believe.
  25. #65
    Apr 05 2004
    Ohio
    thanks anthony. some have used it to paint entire cars!
