Page 31 of 33 FirstFirst ... 212930313233 LastLast
Results 1,201 to 1,240 of 1316
  1. #1201
    Veteran Member Three Rings Aliel's Avatar
    Feb 26 2005
    '99 Audi A4 1.8TQM
    Tirana, Albania
    That is great. Quick question. How much do you lower your weights for the deload week?
    Quote Originally Posted by .Mad Hatter. View Post
    I hope to have gained. I got 290x5 on squats yesterday. I will post my last few workouts shortly. I am going to start ramping up with max singles in late July/early August to prep for a comp in Sept. Until then I am going to keep increasing my % lifts. Next week is deload, after that I up the intensity.
  2. #1202
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    Generally 50-60% of my 1RM. I also mess around with some other random movements. Maybe a little more high volume stuff; nothing terribly CNS fatiguing.
  3. #1203
    May 07 2007
    Back at it today.
    Tuesday 6.26.12
    Squat: 5x2 @ 300
    Seated DB. Shoulder Press: 6x4 @ 50
    Lat. Pulldown: 5x8 @ 100
    GHR: 5x10
    Toe Touches: 4x15
  4. #1204
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    Are the toe touches to stretch the back out?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
  5. #1205
    May 07 2007
    No they're done laying on your back from the bottom up for abz. :D
  6. #1206
    May 07 2007
    Thursday 6.28.12
    Bench Press: 5x2 @ 200
    Squat: 6x4 @ 185, 205, 225, 245, 265, 285
    Close Grip Bench Press: 5x8 @ 95, 115x4
    Triceps Pressdown: 5x10 @ 40
    Alternating Lateral/Front band raises: 5x10
  7. #1207
    May 07 2007
    Saturday 6.30.12
    Deadlift: 5x1 @ 300
    Bench Press: 6x4 @ 135, 155, 165, 170, 175, 180
    Prone Plate Loaded Row: 5x8 @ 80
    Hanging Leg Raises (toes to bar): 5x5
  8. #1208
    May 07 2007
    Also, weighed in at 144.2lbs this morning. Checked my bodyfat via calipers and it read 8.6%. Not bad even if it's lower than actual by a few points.
  9. #1209
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    a bunch of crap
    Ocean Shitty Maryland
    Damn Geoff!! Sub 10% BF!!!
    The harder I practice, the luckier I get.
    - Gary Player
  10. #1210
    May 07 2007
    I took about 9 days off as I was getting really locked up in my hips and shoulders, as well as being generally wiped. I am back at it and have modified my volume such that I shouldn't burn out. I will do 3 weeks like this, then rest, then 5-6 weeks of Westside before I compete again in September.
    Monday 7.9.12
    Squat: 5x3 @ 285
    Prone BB Row: 5x5 @ 95x2, 105x2, 110
    Seated DB Shoulder Press: 5x8 @ 45
    Back Extension: 3x12
    Toe Touches: 3x20
  11. #1211
    May 07 2007
    Back at it this week! As my logs will show I haven't done much of anything this month yet. I took a couple weeks off straight and just did some de-load stuff, I also spent a lot of time on my mobility.
    I am about 9 weeks out from a competition in September and I have adjusted my program accordingly. Man it feels good to only be in the gym for about an hour after months of 3/week @ 2hours each...fasted.
    Ok, here goes, I expect to smash through some big numbers in the coming weeks.
    7.16.12 DE Bench
    Speed Bench (Pause): 8x3 @ 125
    Close Grip Bench Press: 5x5 @ 125, 130x3, 135
    Seated DB Shoulder Press: 5x8 @ 35x3, 40x2
    Lat. Pullovers: 4x12 @ 40
    7.17.12 ME Squats
    Squat:
    95x5x2
    135x3
    185x2
    225x1
    255x2
    Belt goes on
    285x1
    305x1
    315x1
    325x1
    GHR: 4x12
    Isometric Low Back Raise: 3x30s
    Yoga Crunch: 2x20
  12. #1212
    May 07 2007
    7.18.12 ME Bench
    Pause Press:
    95x5x2
    135x3x2
    155x1
    185x1
    195x1x3
    80% (155) x11
    Triceps Rope Pulldowns: 4x12 @ 40
    Yates Row: 4x12 @ 95
    Face Pull: 4x12 @ 30
    7.20.12 DE Squats
    Speed Box Squat: 10x2 @ 165
    RDL: 5x5 @ 135, 185, 205, 225x2
    Low Back Extension: 5x8 @ 10, 25x4
    Med. Ball Crunch: 4x15 @ 5kg
  13. #1213
    May 07 2007
    7.23.12 DE Bench
    Speed Bench: 8x3 @ 125
    Close Grip Bench Press: 5x5 @ 125, 130x2, 135, 140
    DB Floor Press: 5x8 @ 45, 50x4
    Lat. Pulldown: 4x12 @ 80, 90x3
    7.24.12 ME Deadlift
    95x5
    135x3x2
    185x1
    225x1
    275x1
    Belt on
    315x1
    335x1x3
    Weighted Glute Bridge: 4x12 @ 50, 60, 70, 80
    Snatch Grip Deadlift: 3x12 @ 135
    Ab Curcuit
  14. #1214
    May 07 2007
    I tested my vertical jump today at work for funsies. 30.5". I feel like thats pretty good considering I jump exactly 0 times. Ever
  15. #1215
    Senior Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    E46 M3 'Vert
    Darien, CT/ Bristol, RI
    Yes, that's VERY good. I'm jealous haha
    Current: E46 ///M3 Convertible
    Past: 2004 Audi A4 1.8TQM: KW-APR-OEM+, 2003 Audi A4 3.0
  16. #1216
    May 07 2007
    7.25.12 ME Bench
    Pause Press:
    95x5
    114x4
    135x3
    155x1
    175x1
    185x1
    195x1
    200x1x2
    Overhead Rope Pulldowns: 4x12 @ 30, 35x3
    Prone Plate Loaded Row: 4x12 @ 70, 100x3
    7.27.12 DE Squats:
    Speed Box Squats: 10x2 @ 180
    RDL: 5x5 @ 185, 205, 215, 225, 235
    Low Back Raise: 5x8 @ 25lbs
  17. #1217
    Dec 07 2004
    a bunch of crap
    That's damn good...Now imagine if you jumped on occasion!
    - Gary Player
  18. #1218
    Senior Member Four Rings BUD-S4's Avatar
    Jul 01 2009
    B7 S4 MT6, Honda Civic Hybrid
    Hollywood, CA
    Quote Originally Posted by 94jedi View Post
    THIS. You're 5'6"? You're a beast if you're getting up that high without practice.
    Since verticals were brought up, check out this guy. Crazy SOB does a 64" vertical, I believe its a world record...
    BTW, great log man! Looks like you're making some nice progress.
    .:B7 ///S4:.
    VIDEO -> Exhaust
  19. #1219
    May 07 2007
    That's a box jump, not a vertical jump. I can probably clear about 40-50" on a box.
  20. #1220
    Jul 01 2009
    Hollywood, CA
    oooohhh. I see.
    .:B7 ///S4:.
    VIDEO -> Exhaust
  21. #1221
    May 07 2007
    Vertical would be straight legs, like a basketball dunk. We only have 30" boxes at the facility and I can get up there with one leg. They are meant to be stacked but I don't have the stones for that, lol.
  22. #1222
    May 07 2007
    7.30.12 DE Bench:
    Close Grip Bench: 5x5 @ 135x2, 145x2, 150
    Incline Chest Press: 5x8 @ 55
    Lat Pulldowns: 4x12 @ 90
  23. #1223
    May 07 2007
    Ugh, I've been sick since yesterday. Wickedly sore throat hit me hard yesterday morning and my head has felt like it was going to explode all day today. Ever since I got pneumonia 2 years ago I get like this once or twice a year and it sucks. I have been off work and training (even if I didn't feel like a bag of shit, I can't very well go lift where I cancelled my clients for the day, lol.)
    Hopefully back at it tomorrow.
  24. #1224
    Senior Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Having to skip workouts because of sickness is the worst. I only get sick when I'm short on sleep, you?
    -Matt
    FCDT Member #1
  25. #1225
    May 07 2007
    That never helps, but ive been 8 hours plus for a while now. Im exposed to a lot of people and a lot of kids...doesnt help either
  26. #1226
    Jul 30 2008
    Downtown Denver, CO
    Ahh true. I'm an engineer so i'm stuffed into a solitary hole most of the day but my girlfriend teaches kindergarteners so I have a feeling she brings home alot of germs.
    -Matt
    FCDT Member #1
  27. #1227
    May 07 2007
    Hit it again today, I was pleasantly surprised.
    8.3.12 ME Squats
    95x5x2
    135x3
    185x2
    225x1
    265x1
    300x1
    315x1x2
    Then I did a small amount of accessory work and headed home. New favorite post workout drink? Dark Chocolate Almond Milk. MMMMMMMMM
  28. #1228
    May 07 2007
    8.7.12 DE Bench
    Speed Bench: 6x3 @ 135lbs (+chains)
    Close Grip Bench: 5x5 @ 135, 145x2, 150x2
    Seated DB Shoulder Press: 5x8 @ 35, 40x3, 45
    Lat Pulldown: 4x10 @ 100
  29. #1229
    May 07 2007
    8.8.12 ME Deads
    95x6
    135x5x2
    185x2
    225x1
    275x1
    295x1
    315x1
    335x1
    355x1x2
    Single leg standing leg curl: 3x15 @ 20
    Isometric low back extension: 3x30s
    ab circuit
  30. #1230
    May 07 2007
    8.9.12 ME Bench
    Pause Bench:
    95x6
    115x5
    135x3
    155x1
    175x1
    185x1
    200x1x2
    205x1
    DB Skullcrushers: 4x10 @ 45x2, 50x2
    Seated Row: 4x10 @ 105
    DB Front Raise: 4x12 @ 15
    And for funsies because I couldn't be outdone by one of my NCAA hockey players: DB Floor Press: 60lbs x 18 reps
  31. #1231
    Veteran Member Four Rings chubbychynk's Avatar
    Jun 08 2005
    RS4 Cabriolet
    sunny meadowz
    I got pneumonia a long time ago and ever since then I have to go on an antibiotic when I get a cold (once or twice a year).
    O.D.A.M.
    "Dim sum for everyone!" - $4c@b
    "Circumcisions for everyone!" - $4c@b
  32. #1232
    May 07 2007
    Ya, it's a huge bummer. I feel like this was a cold but I took the script anyway because I couldn't afford to be off work for any longer. All is good now.
    8.11.12 DE Squat
    Speed Box Squats: 10x2 @ 210
    BB Glute Bridge: 6x6 @ 95, 115, 135, 185, 235, 255
    Low Back Extension: 5x8 @ 25
    Ab Circuit
    8.13.12 ME Squat
    It was supposed to be DE Bench but I was feeling squats.
    95x6
    135x3
    185x2
    225x1
    265x1
    Belt on
    305x1
    315x1
    340x1
    GHR: 4x12
    Pendlay Row: 3x10 @ 95, 115, 115
    How NOT to lockout a squat
  33. #1233
    Jun 21 2005
    '05 BAT B6; '06 Civic EX
    Milton, Ontario
    OP, have you done any cleans or snatches?
    They are great for overall strength and explosive power. Works the entire body as well.
    -Steve
    '05 B6 A4 Avant T3/T04E 50 trim • 4:1 diff • FX400 6-puck • PSS9 • 18x8.5 BBS RC w/ Conti Ext DW
  34. #1234
    May 07 2007
    I dont. I am fairly good at both they just dont come into play, especially when I am so close to competition.
  35. #1235
    Jun 21 2005
    Milton, Ontario
    Ah, they are two of my favourite lifts besides deadlift, squats, overhead squats and front squats.
    -Steve
  36. #1236
    May 07 2007
    Had a piss poor comp. today. 336 squat (comp PR, good to bump me to 8th in the world at my weight class in my fed. 205 bench (shit), 341 dead (super shit).
    I'm starting Bill Starr 5x5 on Monday, I just want to not think about what I have to do for 9 weeks. Will post results!
  37. #1237
    Jun 04 2007
    Austin/DFW, TX
    Geoff, are those 1 RM? What is your weight class/what did you weigh in at? They kinda inspire me to compete in a competition but my weight is kinda up there (156lbs avg).
    My 5-Speed Swap DIY
    - B6 USP
  38. #1238
    May 07 2007
    ya 1RM, I lift at 148.5, I weighed in at 146.6. My squat is ok, my bench should be at least 250 and my dead should be 400
  39. #1239
    Jun 21 2005
    Milton, Ontario
    Pretty decent weights for your bodyweight. I'm currently at 206# body weight, 5'11", back squat is 365, deadlift is 425, snatch is 180, and clean and jerk is 225. Haven't tried 1RM bench yet this year but before it was 335. You are really close to my weights! great job Geoff.
    -Steve
  40. #1240
    May 07 2007
    Thanks! The numbers aren't bad, but I expect more of myself.
    First workout today...I'm still sore and beat from Saturday.
    9.17.12
    Squat:
    5@135
    5@175
    5@205
    5@240
    5@275
    Bench:
    5@95
    5@110
    5@135
    5@155
    5@175
    BB Row:
    5@65
    5@85
    5@95
    5@110
    5@125
    DB Clean: 2x15 @ 10lbs
    Yoga Crunch: 4x15
