Results 1 to 39 of 39
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    01.5 A4 1.8T and 06 VW Passat 2.0T
    Orlando, FL
    Why does my car shake when I apply brakes
    At about 30-35 mph when applying the brakes my car shakes the shit out of what seems to be coming from the passenger side wheel well. Any idea what could be going on here? Control arms?
    Tyler
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HIDs|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Senior Member Two Rings yung_wallace B5's Avatar
    May 11 2009
    richmond VA
    Re: Why does my car shake when I apply brakes
    warp rotor?
    Oct 08 2005
    Orlando, FL
    shouldnt be, replaced all 4 rotors with Adams slotted/dimpled not long ago.
    FYI the front rotors are S4's
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    how long ago? go thru any puddles while the brakes were hot? maybe there was some rust or something on the hub so they arent sitting flat. either that or your guide pins might be sticky.
    Oct 08 2005
    Orlando, FL
    Prob about 2-3 months ago maybe? Puddles that cant be avoided, yes. So you guys dont think its a bad control arm? As some of you may know I had to use S4 uprights, think maybe their could be an issue with the passenger one?
    Feb 13 2004
    2007 Honda Element SC
    Silicon Valley, CA
    I got brakes once on my Z28, tracked the car the next day and warped them. Check those rotors.
    Kevin - Moderator, Audizine
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Euro LED Tail Lights, Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, Eurocode Alu Kruez, Hotchkiss F/R Swaybars
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Oct 08 2005
    Orlando, FL
    that sucks man! I dont track my car nor do I ever intend to. I spiritly drive once in awhile and their was a time where I had to mash on them with 4 people in the car while they were still kinda new, IDK if that may have had anything to do with this shaking issue over what little time Ive had them on the car? I will check them first thing tom though!
    Senior Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Yeah most of the time when there is vibrations when braking coming from the front its a warped rotor(s). Is it worse when stopping from a higher speed?
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Apr 27 2009
    Pittsburgh
    Check your bearings. Different pressure on the wheel thats bad wheel will cause the car to shake. Usually its more common when you turn to put more pressure the bad wheel it but when mine was bad, breaking sometimes made it worse. Though that is a long shot, my first guess would be bad/warped or improperly installed rotors.
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by kevin12 View Post
    Yes and no, sometimes it doesnt even shake. Other times from about 50 mph down to 30 mph it shakes and sounds like something is knocking from the passenger wheel well. On the highway not so much, but I havnt been on the highway lately. I will Friday though, suppose I could see what happens and report back.
    I shoulve also noted that my brake reservoir is cracked and some fluid has leaked out and is possble that their is air in my brake lines. Will be ordering a new reservoir asap! But could this have anything do with the possible warping??
    May 12 2008
    Flagstaff AZ
    has this been happening since you put rotors on? if so did you reinstall the hub centric rings correctly?
    Oct 08 2005
    Orlando, FL
    No hasnt happened since day 1, this has happened over a period of a few months. I didnt install them Shawn did (A4ringedONE8T) from 1552. Ill be going back down in a lil while to get more work done so Ill have him check it out! Was hoping to get the issue resolved before I drive 2 hrs in case I needed to order something.
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    if none of the above works.. long shot.. but.. some coated rotors + NOT breaking them in correct = gets the coating sludged unevenly on the rotor, causing the vibration. also.. do u hear any noises..or just vibration.
    OEM is sexy.
    San Jose, CA
    if i was you i would check out the rotors. and also make sure your lugs are torqued down to 90lbs.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    tire titty?
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by kastro View Post
    What kinda noises? I hear cricket like noises when driving along, but thats just the pads rubbing. When applying the brakes I hear the pads going over the slots. Thats the only noises I hear coming from the rotors. Otherwise I just get this terrible shaking from the what feels like the passenger wheel well.
    Oct 08 2005
    Orlando, FL
    I will make sure everythings torqued down as well Ado.
    I doubt it could be a tire titty.
    Oct 08 2005
    Orlando, FL
    Just got back from Eurotechnik, Brake fluid was at the min line so we topped it off. The shaking/vibration happens when the rotors heat up. That a case of warped rotors?
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Quote Originally Posted by 20A4Audi1.8t01 View Post
    Well if you had air in the lines the peddle would pratically go to the floor so that's def not your problem and you said it was only at the min so you're okay there. Warping occurs when brakes over heat but they just wouldn't make noise/vibrations only when heated up. So it's hard to say you just need to pull the wheel and rotor off and take a look it. It's not really a hard to thing to do and it would definitely give us more insight to the problem.
    Current:
    Oct 08 2005
    Orlando, FL
    Ill have to take it back up their, they were pretty packed with cars in the garage today. I dont have a proper jack nor tools.
    May 06 2008
    minnesota
    my car does the same thing too. except mines come from the front driver side. i think its warped. im going to be getting some new rotors tomorrow so if anything changes ill let you know.
    Oct 08 2005
    Orlando, FL
    thanks man eagerly waiting! bugs the shit outta me! Your steering wheel shakes too?
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Check the temp of the wheel after driving. Is it hotter than the others? Could be a seized caliper.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    What do you mean heated up? Is it only when you're doing multiple 80-0 stops or just after you've been driving a while it starts to wobble?
    Also, warped disks don't happen:
    http://www.stoptech.com/tech_info/wp...rakedisk.shtml
    Jack up the front of your car and give the tires each a good shake, rule out your suspension components. I'd guess it's a TRE or control arm... does your car pull to the side or still go straight?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by Kyle H View Post
    When the rotor heats up after Ive been driving and braking for awhile it starts to shake. The car does pull very little to the right, almost cant even tell. Had it aligned when the Coils went on prob bout 3 months ago as well.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Well it sounds like the problem occurred between 3 months ago and now... It could be a siezed caliper on the pass. side, that would cause it to pull to the right and would probably shake from the torque of it trying to stop... I still think it's something in your suspension or maybe driveline (cv joint, wheel bearing?)
    because racecar.
    Oct 08 2005
    Orlando, FL
    could be a wheel bearing, I would hope it wouldnt be a damn cv joint as I had both axles replaced (rebuilt) with new cv boot kit about 3 years ago or so.
    This never has happend since the S4 brakes with Adams slotted/dimpled rotors went on about 3 months ago.
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    The disc itself isn't warped but the surface can become uneven due the brake pad build up in different spots hence causing the vibration. Most people just call this warping whether you want to get technical or not lol.
    But it could be a suspension component seems weird that it only happens after driving for awhile though.
    Don't think its a bad wheel bearing either though. I've never had one really pull the car badly. It usually hums and gets louder as you turn to that side. Plus if its the original bearing that means it wasn't installed wrong so premature failure is out on that one. They also just don't suddenly fail either, they slowly get worse. Meaning something you would start to notice and then feel the progression.
    My guess is uneven rotor wear or when the caliper is being heated up from driving it that its causing it to seize.
    Current:
    Oct 08 2005
    Orlando, FL
    True well cross the wheel bearing off the list. I got the S4 uprights with about 80k on them. Hope all it is is just a "warped" rotor.
    Apr 22 2007
    15 Fiesta ST, 73 Porsche 914 AEB 1.8T CTB5356, 16 Infiniti Q50 3.0tt, 02 Triumph Tiger 955i
    Modesto, Ca
    Items for Sale
    Take it to a brake shop that can turn the rotors on the car. They will tell you if its bad or not. You should be out the door with freshly turned rotors for under $100.
    GL
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Quote Originally Posted by andyrew View Post
    GL
    Agreed. If you can't really take a look at it yourself then this is definitely what I would do
    Current:
    Active Member Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I would guess it is a suspension problem. Worn links, bushings, bearings, etc can all cause this to happen.
    If it were a hydraulic brake problem the car would have pulled to one side due to uneven pressure.
    Rotate the tires front to back and see if it still happens. Check the suspension out and use a pry bar to flex the bushings and links. Something is very wrong somewhere.
    Jim
    I Do Werk.
    Aug 04 2009
    Arevalo
    i had this problem with my a4 and what it was on mine was the upper control arm bushing... but generally it's the rotors or wheel bearing..
    Oct 08 2005
    Orlando, FL
    I see, it seems like its coming from the axle area but could very well be the control arms. I have been procrastinating, I will get it checked out soon and take everyone's insight!
    Aug 13 2008
    Indiana
    Usually if it's related to pushing the brakes then its warped rotor's. Mine however pulls a different way every time I hit the brake. I'm not really sure what that means. I also think my rotor's are warped. I will be turning my rotors and changing: control arms, sway bar links, and a CV shaft tomorrow. I'll let you know if I find anything else obvious and if it goes away.
    -Nic
    Oct 08 2005
    Orlando, FL
    Thank you eagerly waiting!
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by somebody5788 View Post
    any news?
    Mar 09 2004
    nw michigan.
    Don't bother touching the rotors unless you can feel the brake pedal pulsing. It is most likely worn bushings in the steering or suspension.
    Jim
    I Do Werk.
    Veteran Member Three Rings stack's Avatar
    Oct 27 2008
    a4 b5 1.8tqm
    queens ny (maspeth)
    you prob got warped rotor thickness varation
