Originally Posted by
audi_driver1
Having trouble understanding to what degree I want some of the bulbs? For example for the footwell lights I can purchase 90 or 32 degrees same with Map Lights I can purchase 120, 90, or 32 degrees?
What do I want, what is the difference?
Your post is a month old but I rarely ever check this thread anymore. The degrees is just the angle of light given off. For example, a 32 degree bulb is only going to put out light straight out (kinda like a flashlight), whereas a 120 degree bulb will give out light in almost all directions (like a naked 60 watt light bulb on a lamp). You need to take into account the orientation of the bulb and how much light you want to leave the housing and light up the interior of your car.
Since all the wedge and bayonet bulbs are mounted in the housings laterally, a narrow angle (32 degree) will shine mostly at the side of the housing, whereas a wider angle (120 or 90 degree) will allow more light to go out of the housing and through the plastic cover. If you want a brighter interior, get the wider angle bulbs and vice versa. I hope this helps, even if it is a month late.
