Results 1 to 14 of 14
    Established Member Two Rings MacTiki's Avatar
    May 01 2008
    Imola 04 S4
    Sacramento Area
    Bent subframe help...
    I took my S4 to the local Audi dealership (Niello) because it was making a fairly loud clunking noise from the front right of the car during heavy braking or tight turns. I figured another control arm bushing had gone out which would be covered by warranty.
    I get a call from my service rep he tells me the sub frame is bent which caused the lower control arm bushings to go out (upper went out on both sides previously); not under warranty obviously. He ask me what I hit? I told him nothing; then it dawns on me I started to notice this noise right after I got my new wheels on. So I'm thinking the guys who put my wheels on jacked up the car by the subframe and I'm screwed cuz I had the wheels put on about 2 months ago so recourse is unlikely.
    Service rep says they tried to bend it back and they can't hes calling his body shop to see if they have something they can bend it back with.
    I'm into the problem for less than $100 so far but I have this bad feeling it could spiral out of control real quick like.
    It drives straight with no alignment issues, should I have them replace the lower bushings and just drive it?
    If it comes down to it figure I can find a used subframe at a junkyard, does anyone know if it the same as the A4?
    I replacing it as simple as unbolting the suspension/transmission dropping it and putting the used one in its place?
    I know this is a lot of questions but I am just at the beginning of this issue so I have no idea where its going, I will keep everyone updated.
    I appreciate any responses!
    Thank you in advance,
    Tiki
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Re: Bent subframe help...
    jesus...good luck.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    i dont think jacking the car up would do that. did you buy the car used?
    either way good luck
    Jan 14 2009
    2014 S4 2006 Passat Wagon 00 B5 S4 POS Honda
    pasadena md
    Items for Sale
    ok im confused how this couldnt be under warrenty. The subfame is steel and doesnt bend easily. Try another dealership. If the subfame was bent you would have alignmet issues and tire wear problems. I work at a dealership and its hard to see that the subfame is bent when its that beffy. it holds the motor and trans. i would want pics
    Dec 05 2006
    So. Cal.
    Items for Sale
    Yea, I would get a 2nd opinion.
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Quote Originally Posted by sakimano View Post
    jesus...good luck.
    what he said
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    Quote Originally Posted by MacTiki View Post
    Tiki
    jacking up car would not bend the subframe.....did they try to perform an alignment?..cause that it is one of the few ways to even tell if it is bent...or there is a HUGE bend on it where you hit something in the road/or went over a curb....tell them to put it on a lift and snap some pics of the so-called bent subframe
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Items for Sale
    i call bs. no way the subframe is bent, as stated previously, your alignment would be off and you would have tire wear issues
    Senior Member Three Rings RudeBwoi's Avatar
    Jan 05 2005
    My 2000 1.8T, Quattro 5spd
    Quote Originally Posted by chaos2984 View Post
    A bent subframe isnt a normal issue. If that was to happen its would be bc of either some sort of negligence or an accident, so I doubt a warranty would cover that. Maybe insurance, but not warranty.
    GIAC Stage 1 ::: H&R S4 Coilovers ::: V&S Short Shifter ::: B5 Rs4 Reps ::: Intake ::: N75R ::: Tints ::: 12'' Kicker Square Sub
    Need to sell this A4 asap...SOLD
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    Is ti possible they jacked at the lower control arm? That would be an easy one to bend..
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Quote Originally Posted by RudeBwoi View Post
    Gotta agree.
    Is it possible it was hit prior to you buying it?
    Did you check the VIN?
    Senior Member Three Rings deviant-customs's Avatar
    Jan 15 2009
    04 S4 07 R1 87 K5
    CO
    If it does turn out to be bent I have an extra one I don't need. The thing is beefy. I could not believe how heavy the front suspension / brakes weigh as one unit
    Don't Drink and Park. Accidents Cause People.
    Jun 18 2007
    Woodland Hills
    Any one know if there is a difference in subframe between the 6 speed and a automatic?? I bent my front subframe and found one but its from a automatic
    Jan 15 2009
    04 S4 07 R1 87 K5
    CO
    I have a 6spd subframe if you need one
