Results 1 to 19 of 19
    Jul 07 2009
    Audi B6 A4 1.8T
    203, Connecticut
    A/C smells like vinegar (occasionally)...
    ...is it mildew? please tell me there's an easy solution!
    Established Member Two Rings Subyroo651's Avatar
    Jul 12 2009
    04' A4 Avant 1.8T
    Chicago(Suburbs), IL
    Re: A/C smells like vinegar (occasionally)...
    Change out the Cabin Air Filter. Its under the hood next to the battery and its very easy to change.
    If its not that, it could be excess moisture in the system..Not sure the best way to tackle that but someone could chime in..
    Aug 26 2005
    Yes, caused by fungus in the A/C evaporator housing due to the moisture that accumulates there. To kill the fungus, remove the intake air filter, and loosly cover the dash vents with paper towels taped to the dash. With the A/C fan running in manual mode cold/fast, spray Lysol into the fan intake, use the entire can, then shut off the fan and allow the Lysol to soak in the A/C evaporator core for awhile. Finally, remove the paper towels from the dash and replace the intake air filter. This procedure may need to be repeated several times during the summer months as needed.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t, E63 AMG
    San Diego, Ca
    Items for Sale
    sweet info. rep +1
    Jul 07 2009
    Audi B6 A4 1.8T
    203, Connecticut
    Hmm...just changed the air filter 1 or 2 weeks ago. Could it be since it's new it's giving off some weird smell?
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Chicago NW Burbs
    this might help too to clean out the whole system
    http://www.detailersdomain.com/hvaccleaner.aspx
    Jul 07 2009
    Audi B6 A4 1.8T
    203, Connecticut
    perfect; just the easy solution I was looking for :)
    Nov 02 2007
    San Diego, Ca
    Items for Sale
    so does that work better than the suggested lysol?
    Aug 26 2005
    Quote Originally Posted by ladybird View Post
    That product requires a similar if not identical application process to the procedure I described for the Lysol application, and Lysol is cheaper. Please follow up with your results whatever you decide to try.
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    I did the Lysol once and it helped, but did not go away permanently. The only difference was that I turned the heater on.
    Senior Member Two Rings mobigray's Avatar
    Nov 20 2006
    05 USP A4 1.8T, 11 Hyundai Santa Fe CRDi, 14 Q5 2.0T
    Items for Sale
    Had this problem before. I was told by the Audi tech that it is due to the way the A/C system works. He flushed the system clean at no cost for this one time, and told me to turn off the A/C a block or 2 before arriving at your destination. It has been working for me... I turn it off a few seconds before I arrive at my destination...
    My wife does not care, so after she uses my car, the smell comes back... then I have to do the process for a few times and it goes away....
    USP CLUB MEMBER # 30
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Items for Sale
    ive been having that smell for like 2 years... but i dont use A/C that often so im fine with that...
    When i changed a Cabil air filter, it got better, but i could still smell that sound.
    And it smells more like dirty socks
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Aug 26 2005
    Quote Originally Posted by mobigray View Post
    Yeah, putting the system in "ECON" mode for awhile before reaching your destination, helps dry out the evaporator core and inhibits mold growth in the evaporator housing.
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Quote Originally Posted by B6JoeA4 View Post
    I used this product about 2 weeks ago. It didn't work. I followed the instructions on the label perfectly. Also, I've learned that to keep condensation from staying in the system, I have been turning off the AC and blasting the defrosters at 72* for the last few miles of driving. Nothing has helped. Every time I start the car I get punched in the face with this smell. It only lasts until I either get the windows down or turn the AC back on for a few minutes and get the air circulating, but it's still very annoying....
    ...good thing I'm single.
    Aug 26 2005
    Quote Originally Posted by mr_esmit View Post
    Several applications may be needed initially, and repeat applications during the cooling season too.
    Sep 13 2008
    Chicago NW Burbs
    Quote Originally Posted by KPC1.8TQuat View Post
    very interesting. i used it on my dads envoy and it worked perfectly. i guess its just the way our systems work that it doesn't allow this stuff to do its job
    Aug 26 2005
    Quote Originally Posted by aaaudiprotein View Post
    The smell varies regionally, along with the different fungus types in different regions.
    Mar 20 2006
    That is funny but true. In undergrad, one of my micro-bio professors claimed that she could identify what spore family she was looking at just by smelling it.
    Nov 02 2007
    San Diego, Ca
    Items for Sale
    so if no method works, the only way to get this clean is to disassemble your evap and clean it out?
    i'm going to try the lysol technique. my vents some times smell like i just wore my shoes all day and took my shoes off, not smelly, but of worn socks. was like this from the previous owner.
