Page 1 of 7 123 ... LastLast
Results 1 to 40 of 251
    Active Member Two Rings iloveturbo's Avatar
    Jul 18 2009
    2005 Audi A4
    [Project] 2.1L A4 Avant & V-Band GT3076R
    Hi all,
    I been browsing the Audizine forum for some time now. Many of the projects I read here are quite amazing and inspirational. Anyway, I figure it's only fair that I pay my share by documenting my own project. Please do keep in mind that this is a project that would take a long time and I am in no rush of things. This is my weekend car and I want to do it right.
    Project car: 2005 Audi A4 Avant (B6)
    Current Mod list:
    Oettinger front, side skirt
    S4 rear bumper
    Sportec cat-back exhaust
    KW V3 coilover
    Porsche Cayenne six pot calipers with floating type 355mm cross-drilled rotors
    320mm rear rotors with upgraded pads
    19x8.5 ET35 3pc forged wheel with step lips / 225-35-19 all around (soon to be replaced with Rays Progressiv ME 19x8.5 ET31 front 19x9.5 ET37 rims. I had them sitting in my basement for few months now)
    Phase 1 - Custom Audi A4 Tubular Manifold
    Markku custom built me a manifold, downpipe, wastegate reroute and a support brace. They are amazing quality but don’t take my word for it. Let the pictures speak for themselves.
    Phase 2 - Engine
    Issam of INA is commissioned to build up a 2.1L longblock consist of following,
    CP bore: 83mm stroke: 95.5mm Compression ratio: 9.0:1 (coated)
    Brute Rods with EDM
    MK4 TDi Crankshaft
    Supertech inconel exhaust valves (+1mm)
    Supertech valve springs and retainers
    main bearings (OEM)
    Rod bearing (Calico + 0.000in)
    SEM intake manifold (large port)
    RS4 type 70mm throttle body + Adapter harness
    phenolic spacer
    ARP main studs
    ARP head bolts
    big bore gasket
    CAT CAMS 3658
    Brand new Block
    Brand new AEB Cylinder head
    OEM Timing belt & water pump
    I have asked Issam to start a separate complete write-up of the installation process so others may benefit from it. Once again, prop to him for everything.
    Phase 3 - Fueling and tuning
    Undetermined yet.
    That's all for now. I am sure there are plenty of other things I must have missed. Feel free to correct me if i made a mistake somewhere.
    *admin please move this to project section. It doesnt allow me to start up a thread there. Thanks!*
    Veteran Member Four Rings nananana4k's Avatar
    Sep 10 2005
    A4 B6 3.0
    Re: [Project] 2.1L A4 Avant & V-Band GT3076R
    I've seen the manifold on other threads. Such a sick build.
    Senior Member Four Rings Sandeman's Avatar
    Feb 15 2009
    2003 MB SL500
    where the horseman roams
    very nice... i always thought the custom fabrication far surpass any mass production made parts.... i wasnt really a fan of the B6s, but urs is pretty mint! now i have to convince the fiance to like the avants so itll be her next car lol
    good luck man, and nice work
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Awesome!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    you are dropping some $$$, you must be in the banking industry!
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    same engine exhaust hardware as jet jockey
    cool beans!
    Need to figure out tuning to take full advantage of that hardware configuration. I'm sure Issam has something good up his sleeve...
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Senior Member Four Rings mtbrider's Avatar
    Oct 31 2005
    A4 GT2871R
    Virginia
    nice
    BetaAlphaTau member #5
    Meth Injected Built Bottom Fun
    ~Josh~
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '02 A4 1.8TQT // '05 MV Agusta F4-1000
    Mo County, MD
    B6 community is steppin' UP!!!!
    Audizine's most powerful & most respected B6 Tip
    Previous: 283.4 awhp - 287.1 ft-lbs. | 93 octane
    UPDATE New build in progress
    Apr 01 2007
    2012 MazdaSpeed3
    houston texas
    Thats fuckin awesome!
    DD - 2012 MazdaSpeed3
    2003 A4 1.8TQ
    APR stg2+, MTM injectors, Ecode FMIC, PSi testpipe, OC.T TIP, Hyperboost DV, B5S4 calipers, Goodridge SS lines, Stern firm snub, motor and transmission mounts, Podi, Vogtland Jr. Cup Kit, RS4 Rear Sway Bar, USP front and spacers front and rear
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    To anyone that is asking.Howard,Alex & Michel are all running the Stage VI turbo kit.
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
    Senior Member Three Rings Jarim's Avatar
    Nov 27 2008
    N/A
    RAw!
    Gnarly build!
    B6 A4 1.8t MODS: Custom 3" to dual 2.5" Turboback Exhaust, 034 3" Testpipe, K&N Drop-in, FMIC, Hitachi Coilpacks, 007 Diverter, Neuspeed Snub, RS4 Sway, Custom Interior, Yellow Fogs
    Registered Member Four Rings A4ringedONE8T's Avatar
    Feb 17 2005
    Sarasota, FL
    Markku's fab work is unreal!!!
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    Agtronic is bad ass. Guru's S4 and this stuff. Definitely a "go to" place. Wish I had the money and they were close for some nice stuff like that. Looks like they have a jig made for that downpipe though. Did they just make all this stuff on a spare engine (manifold, downpipe, wastegate reroute) so they could make them for anyone without the car being there?
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
    Jul 18 2009
    2005 Audi A4
    Thanks for the positive comments guys and no I am not in the banking business (yet...)
    A little background on this project. The inspiration came after seeing so many projects here trying pushing the envelope of B6, especially Michel aka JetJocky's built. I contacted Markku right away and few days later we agree to a price that he is happy with. The only condition I asked him was to give the his 110%; his masterpiece so as speak. Since time was none issue, he took all the time he needed for the custom fabrications (two~three month) and delivered just what i asked him to - true art in mechanical form.
    The turbo of choice for me is polished/v-band GT3076R .63 with a TiAL 44mm v-band WG. After seeing Jake's built for his dad, I am confident 400+whp would be attainable with GT3076R series giving the right formula.
    On the sidenote, keeping my fingers crossed. I may have a shot finishing the build before Clint (j/j... keep up the good work! don't let anyone bring you down)
    -Howard
    Apr 24 2005
    Quote Originally Posted by iloveturbo View Post
    -Howard
    LMAO I think a baby still in their mothers belly could grow up, get their drivers license and build a car before Clint
    ~David~
    Dec 03 2005
    connecticut
    Good to hear Howard. I like your attitude
    Proper engine management software and fueling will bring out the true capability of this hardware package you have put together. Have you given any thoughts into this? Sticking with motronic tuning or stand-alone engine management? Custom fuel system like Michel or factory returnless system?
    Looking forward to the outcome of these projects, Issam
    -Doug
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    -Howard
    Im at the shop right now Howard, and guess what I'm doing? .......
    Anyway, your build looks absolutely awesome, I look forward to the numbers. What software are you going to be running? I may have missed it
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    yes! this is awesome!
    ive been wanting to do something similar, but i want to keep it 1.8 just to see what power i can get out of it.
    looking forward to see how this unfolds!
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Feb 26 2006
    Earth
    Quote Originally Posted by A4 TSCHUSS View Post
    Yup,
    that was the intention but you would probably have to purchase the turbocharger and lines through us as it is not really worth it for us to just sell a manifold and downpipe.
    Not on a kit of this caliber....we do offer HTA turbochargers as well for those that are interested so if you have any questions please feel free to email me :
    iabed[at]inaengineering[dot]com
    Jul 18 2009
    2005 Audi A4
    Doug - I haven't decide it yet. Returnless system would probably work but more efforts would be required to bring out most of it. As for the factory ECU or standalone, I think I will try to keep things sensible try keeping an Audi what Audi is, factory ECU wins this time.
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Unitronic is currently working on the 830cc returnless file for the B6 through a customer of ours. I will be running that file to begin with on my car as well, and seeing where it goes from there
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
    Registered User Two Rings Agtronic's Avatar
    Jan 09 2008
    Laval, QC
    Howard, I'm so happy to see this finally come together! Can't wait to see it in action! :)
    Jul 18 2009
    2005 Audi A4
    Quote Originally Posted by Agtronic View Post
    Hey Markku! good to hear from you bro. I need to get your manifold sealed in a closed glass window display.
    Amazing weld + amazing guy = just can't ask for more
    Dec 03 2005
    connecticut
    Sounds good. I am pretty sure you are going to run into fueling limits when really trying to take advantage of that hardware configuration. Keep that in mind as you move forward.
    -Doug
    Dec 03 2005
    connecticut
    What about the return-style system on David's car? Why is Unitronic developing two separate files? Doesn't sound like a good business model to me.
    -Doug
    Jun 22 2009
    Dundalk, MD
    Because Mike is a beast and can write anything. Why not have two files? We've been plagued with nothing for the past 3 years
    Senior Member Four Rings B6Lovin's Avatar
    Jun 29 2007
    2003 A4 1.8TQM 3076R
    Cary, NC
    Probably because lots of people said they'd rather run the stock fuel system and see how far it can be carried..... there's a couple of us ready to pony up right now (just a FYI)
    also, it seems to me that the less modification needed to still safely achieve results above and beyond the current 630cc file the better (from a business standpoint anyways)
    Audizine's Quickest/Fastest 1.8L B6 A4 (lol)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jun 29 2007
    Cary, NC
    P.s. Both of you two have paypal coming when I go on lunch today. Pm me email addys for paypal
    The Awesome™
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by B6Lovin View Post
    AudiA4_18T@yahoo.com
    Senior Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    03 Audi A4 1.8T Quattro 5 spd
    Clovis, NM; Cannon AFB
    In on this build :D
    Southbend | Neuspeed | Koni
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    looks sick
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Senior Member Three Rings NetLogic's Avatar
    Jan 05 2009
    02 A4 1.8TQM Avant
    New Orleans
    Pretty cool thread Markku started about him starting his shop and so on. A long read but very cool.
    http://www.honda-tech.com/showthread.php?t=2267900
    Luke
    Feb 26 2006
    Earth
    Quote Originally Posted by Clint@R.A.I. View Post
    plagued?be real Clint....
    You did not even run the Eurodyne 1000cc file so how can you say you have been plagued with nothing for the past 3 years when there are B6 files floating around like flies.
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by Issam@034 View Post
    I did not run the Eurodyne 1000cc file because my ECU is fried, I never even got a chance to run it. We plugged it in to do a throttle body adaptation and it wouldn't wake-up. I don't like bashing anyone so I never said anything on here, Chris did say he would check out the file and I have respect for what he does.
    The B6 community only had the Revo 440cc file for the longest time, Unitronic did surface on cars like Josh's (mtbrider) and Dan's (B6Lovin) pretty early, but the files are stronger than ever now. GIAC had their 28R tune but it failed miserably. Now, the Unitronic tune has put down the best two times on B6s in this forum, replacing the outdated Revo files
    Feb 26 2006
    Earth
    I am all for Unitronic support considering we are a dealer for them but what you typed above is what I would expect from some marketing VP trying ....
    If you have respect for what he does then run the file?
    Jun 22 2009
    Dundalk, MD
    Thanks Issam
    I can't though my ECU is fried. I'm sending it back but I do want to get the car running soon and my availability for the Unitronic is unmatched here.
    Feb 26 2006
    Earth
    With Howard's permission we will be starting a new thread
    Jun 29 2007
    Cary, NC
    i think he gave you the "go" for that in post #1
    so get to typing, i wanna read allllllllll about it
    The Awesome™
    Senior Member Three Rings coran nariman's Avatar
    Jul 06 2007
    toronto
    Good stuff!!! cant wait to see what this car puts down!
    Coran
    Jul 06 2007
    toronto
    Issam. Whats considered a Stage VI turbo kit? haha
