Results 1 to 16 of 16
    Senior Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Radiator cooling fan staying on
    Well my parents came and got me up this morning saying my radiator cooling fan is staying on. It comes on at low speed, idles, revs up to high speed, then goes back down to low speed, then shut off. It's been doing this intermittently and stays on for a minute or two. The car hasn't been driven in over 9 hours, and it's 75 degrees here and wet with no sun. I also started the car and shut it off and it's still doing this. Any idea what's wrong?
    Thanks
    Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Four Rings 500HPS5's Avatar
    Jul 04 2004
    OG B6 A4, B8.5 S5, C7 S6
    OC
    Re: Radiator cooling fan staying on
    It is the FMIC
    Oct 27 2008
    Montgomery TX
    say what?
    Stage 2+
    Senior Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM
    Long Island
    same thing happened to my cousins 2005 A8 and he replaced the thermostat, water pump, and timing all at the same time, but i think the culprit was the thermostat
    Instagram: @vishisingh8
    2005 Audi A4 1.8T Quattro - 6 Speed Manual - Light Silver Metallic
    REVO Stage II, TT225 Injectors, 034 High Flow Cat, Forge TIP, Forge 007, Boost Brothers FMIC, Magnaflow 14851, K&N Drop-In, CiM Boost Gauge, H&R Springs, Koni FSD's, RS4 Sway Bar, Akebono Brake Pads, 18" RS4's, Blackout Grilles, 5000K HID's, Smoked Tails, S4 Grille, Cupra R Lip, Pioneer AVIC D3, EuroPlate, ..
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    might have water in the ecu or the radiator fan control unit is bad or has water in it. could be coolant sensor as well.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Senior Member Four Rings JEENYUS's Avatar
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    if you look on the front of your car (under the hood) it states:
    CAUTION! RADIATOR FAN MAY TURN ON AT ANYTIME. KEEP HANDS CLEAR!
    it reads more or less as that. I would talk to the dealer and see why, it might just be hot as hell. I would check that out and see. sometimes the car just does that to cool off.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    OBS: i doubt that it is water, it gets so hot and these car (well at least mine) can handle a lot of water before anything ever happens...
    <<<<proof of this
    Active Member Two Rings FLultrasport's Avatar
    May 10 2009
    2004 A4 1.8T
    columbia, south carolina
    i had the same thing hppen to me you might want to disconnect your battery before it kills it, i took it into the dealer and they said the engine coolant temp sensor was broken so the car thought the engine was over heating even tho it wasnt on, luckily i had a warrenty on it so i didnt have to pay that much but i dunno what it will be like for
    Jul 04 2004
    OC
    On the real it is the green coolant temp sensor, about $16 to fix.
    May 10 2009
    2004 A4 1.8T
    they swapped out a few parts tho i think i dont know what all is involved with it
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Quote Originally Posted by 400HPA4 View Post
    I second this..
    BetaAlphaTau member #5
    Meth Injected Built Bottom Fun
    ~Josh~
    Aug 26 2005
    This is a common symptom of water in the ECU compartment. You should remove the cover and visually check for water inside, doing so will either rule out the possibility, or reveal the cause of the fan running erratically with a cold engine and the ignition OFF.
    Oct 27 2008
    Montgomery TX
    If there is water in the ecu how bad is that?
    Stage 2+
    Aug 26 2005
    Quote Originally Posted by ConroeA4 View Post
    If visual inspection confirms water inside the ECU box, it depends on how much water and how long it has been leaking into the ecu compartment. The parts typically damaged are the several relays and fuses inside. The engine ECU itself is high enough, above the relays, to not get wet. The relays and fuses need to be replaced, and the cause for the water leak into the ECU box identified and fixed for sure.
    Senior Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    When I removed the fuse for the radiator fans (cannot remember why at the time), the fans kept on running as long as the car was. You would think they would stop, but it was the opposite. Maybe check that fuse?
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    New Member One Ring
    Oct 13 2012
    Humble
    Hi guys! I'm new here and new to this car stuffs.. At first I wasn't really interested with cars, it's only now that I become interested. So please be good to me. LOL Actually, I think I'm experiencing your problem now with those radiator cooling fan. I didn't know it has something to do with the thermostat. I thought of just replacing it and buying this dual cooling fan oe style for radiator. But I'm glad of all the information I got from this. Thanks! There's a lot to learn!
