Total Time:
5-15 Min.
Tools Needed:
T30 Torx to remove Headlight
T20 Torx to remove Top Gear Assembly
Phillips or 6mm Allen Key to turn adjustment screw
Blue Painters Tape (If you want..)
1. Remove Light from car. I put blue painters tape on the bumper under the light so the bumper doesn't get scratched.
2. Identify Location
3. Unscrew (T20 Torx) screw & Remove Top Gear Assembly
4. Turn Light Upside Down and pull out Gear Shaft (So dirt does not go into the housing). Wipe dirt from around opening while upside down...
5. Remove Old O-Ring and Install New O-Ring on Gear Shaft...
6. Reinstall Gear Shaft with New O-Ring... Some other post's recommend putting Graphite Lube on O-Ring at this time. I have not done this and they seem to be working OK.
7. Reinstall Top Gear Assembly (T20 Torx)... same as Step 3
8. **Optional** Carefully Turn Adjustment Screw both Left and Right to make sure it's in good. Make sure to leave adjustment screw in same place as before so height of light is not changed. Final tweaks may be needed anyways once lights are reinstalled anyways.
9. Cleanup and reinstall Headlights!!
Good Luck and preform fix at your own risk. Be careful not to break anything, it wont be my fault...
