Results 1 to 14 of 14
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Disconnected battery - now car wont start. Thoughts?
    Replaced front failing o2 sensor and then disconnected the battery (neg terminal) for about ten minutes to clear the code. Reconnected the battery and now car cranks strong, but doesnt start.
    Is this anything to do with the immobilizer maybe? Car worked fine before this. I started and drove it after the o2 sensor install as well.
    TIA
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Registered Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Re: Disconnected battery - now car wont start. Thoughts?
    yeah it does sound like an immobilizer issue.. good luck with a fix man... i hear the you can disconnect both cables and hold them together for 30 seconds will reset modules you can try that
    Gcc's blacksheep
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Check fuses. Sometimes a weak fuse will pop when reconnecting the battery. A immo issue would be a start and stall.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 12 2008
    Warminster, PA
    I was just reading about the cold reboot as well (holding battery cables together).
    I'll try both.
    Thanks guys
    May 19 2009
    Alabama
    Quote Originally Posted by dirtybrd View Post
    good call..... dirtybrd you are this shizzy
    Gcc's blacksheep
    Jun 12 2008
    Warminster, PA
    Quote Originally Posted by schmally View Post
    Nope. Checked the fuses...all seem good. Did the battery disconnect and cold reboot. Nothing.
    One thing. I dont hear the Fuel pump prime, though when I put my key in and turn to the accessory position.
    Is that what the immobilizer does? Kill the fuel?
    Mar 21 2006
    Lakeland, FL.
    Spark. Did you look at the fuses or check them with a testlight or voltmeter. A guy on here had a no start issue form jumping the battery backward and did this and did that looked at the fuses and they were ok, then later looked again and one was cracked just the littlest bit.
    I'm back bitches!
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Yes definitely look at the fuel pump fuse. I had that happen to me.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Jun 12 2008
    Warminster, PA
    I looked at the Instrument cluster and engine Mgt. fuses and they looked good. I guess I'll check again in the AM.
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    take a test light / volt meter and make sure you have power on both sides of every fuse, including the ones in the ecu box. sometimes you cant even tell a fuse is popped by looking at them. If you still find you don't have a blown fuse.. push on your schrader valve on your fuel rail and see if you have fuel pressure.
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
    Jun 12 2008
    Warminster, PA
    UPDATE: Re: Disconnected battery - now car wont start. Thoughts?
    Crank position sensor is the culprit.
    76 from the dealer.
    Aug 20 2007
    97 Jeep Wrangler
    ^ nice, glad you got it figured out.. was there a code?
    Mar 24 2009
    2002 A4TQM
    SF Bay Area, CA
    How did you figure out it was the Crank Position Sensor?
    Jun 12 2008
    Warminster, PA
    After much head scratching, I had it flat bedded to my local mechanic and they scanned it. I usually use the OBDII scanner from Autozone and scan myself, but someone stole it...lol.
    Otherwise, I never would have thought to look at the Crank Position sensor.
    Threw two codes, actually. Rear O2 sensor as well! (after I replaced the front one)
