i canNOT for the love of god remove the passenger side pin. I used vicegrips and even dremeled around the pin to gain clearance for a better grip but to no avail. the door is off because i got the other pin out, but i need to remove the last pin to get to the hinge. any other tips?
Clip the vice-grips on teh pin, then wiggle it back and forth to move the pin a bit while you tap the vice-grips with a hammer. That will eventually move the pin out of the hinge. Keep at it, it will work.
so i finally got the pins out with the help of a local shop. those things are super beat up now and need replacing. Does anyone know the part number for the pin?
Did this today with a $3 bracket from Home Depot, pretty sure that's all that bracket was that Pcyc was selling.
Can you provide a part or item number from Home Depot? I think folks would very much appreciate it.
Onwards,
-abe '08 B7 Ibis White Tip Avant - PPX, PNZ, 5MK, 3Y4, 4A4, 7X1
Retired: 1980 Datsun 210 1991 Chevy Lumina (gosh I miss that car, so easy to work on, so easy to fix, awesome trunk!) 1996 Oldsmobile Aurora (before they came out with that six cylinder crap) 1993 Saturn SC2 Sold! Inherited by marriage
What switches on the light in the glove box? My works intermittently and my hinge is broken. Is it the wiring that connects to the piston?
Yep, when the piston extends it squeezes the contacts together and turns the light on. You can actually see the contacts in teh second picture three posts up.
how do you get the left side of the lid out? i got the right pin out but how do you access the left side?
The left hinge has a pin just like the right one, just clip the vice grips on it, wiggle it back and forth and tap the vice grips with a hammer to back the pin out.
I will be making these soon. Got a prototype made up and will be advertising through a vendor on here once they are done. Keep an eye out very soon for a professional fix :)
PM me if you need to know how to fix your hinges on your B6/B7 A4, S4, or RS4 glove box
2004 S4 (Tip) - Dolphin Grey metalic
looking to buy 2 used Yokohama Avid Envigors - 245/40/18 see my add:Here
Just did mine this weekend. I had a disaster but after two tries I think it's fixed.
Why would the company that uses the slogan "truth in engineering" have such a poor weak design that puts so much pressure on less than 2 square cm molded plastic?
If it breaks again I'll bite the bullet and get the part from genuineaudiparts for $180 and reinforce it prior to breakage.
2007 S4 Avant 6MT brilliant black: Hotchkis sways, AWE exhaust, JHM short shifter
for 35$ (right now) till I start getting them CNC'd I have some powdercoated pre bent pre drilled brackets with screws that I can sell. Ive only got a few sets left before im waiting on machining. Im going to be selling them through/ with HPFPupgrade (current vendor here). PM me if you are in need ;)
