Page 1 of 5 123 ... LastLast
Results 1 to 40 of 193
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    Lightbulb Biketsai's DIY Auto-to-Manual Conversion
    First off Id like to say thanks to zrowcool and werewolves182 for paving the way with information and the most important, inspiration! I got lots of help from werewolves182 as well as other members allowing me to compile a solid parts list and procedure.
    Status: Finished
    Picture and information will be added frequently.
    I will be replacing the automatic transmission found in my 2001 Audi A4 1.8T AWM with a manual transmission from a 2000 5spd 1.8T A4.
    I will try to make this thread as DIY'like as possible, including random things needed/procedures. This thread will contain information pertaining to the swap and it will serve as a reference. Me and others will be adding more information as things progress.
    The swap will take place in my garage with jackstands and NO LIFT! The transmission will just be dropped out with nothing else. The subframe will be lowered so an alignment is recommended afterward. I had all parts together in about 2 weeks.
    ***UPDATE: After you finish the swap, here is the DIY for making your cruise control work!!
    http://www.audizine.com/forum/showth...Swap-%28DBW%29
    Reverse light DIY
    http://www.audizine.com/forum/showth...a-5-speed-swap
    -First off im throwing this out there to put some more emphasis on how important this is! Put the battery to starter wires on the correct post, which is the post with the 13mm nut, and the plastic spacer behind, it WILL start a fire if you try to put your battery on with the cable on the 8mm post. Ask me how I know ;)
    -To address the commonly known pilot bearing issue and where it might go, an alternator bearing will be placed inside the flywheel to act as a pilot bearing for the input shaft. This bearing has an outer diameter of 43mm and inner diameter of 15mm.For the bearing to fit, the end of the crank will be shaved down 4mm. This can be purchased from www.zorkos.com , PN#A-6941
    The 06A and 058 blocks have the same pilot bearing solution. Both cranks look the same on the end it terms of how and where the pilot bearing is mounted and the pilot bearing has the same part number. It works because all flywheels for the 1.8t are made to fit over the existing protrusion from the rear of the crank which is 43mm.
    -You will utilize the stock automatic transmission mounts, but a 2.8 drivers side transmission bracket is necessary. (PN# 8D0399113AG) Be sure to also get a transmission bracket for the passenger side from a manual car as well.
    -While the transmission is out, things that should be replaced are...
    *Rear crankshaft(main) seal-(germanautoparts.com)
    *(6) Driveshaft to transmission bolts
    -I would recommend buying the JHM $40 linkage upgrade to make installation easier.
    -The items that you will be not changing but that are still utilized.
    *Brake fluid reservoir
    *Master Cylinder
    *Starter
    *Gas pedal/pedal bracket
    -The B5 has a mounting spot for every part being added on (pedals, clutch master cylinder). As for the vacuum line that is needed from the brake fluid reservoir to the clutch master cylinder, there is a crimped nipple on the side of the reservoir that will be cut open to run the line from that to the other cylinder.
    -You can keep your stock cluster, but you need to recode it and your ECU for a manual or else you will have fault codes.
    -Most items purchased came from a junked car, germanautoparts.com , summitracing.com, Harbor Freight tools, local dealership
    Threads to reference:
    *** Another 5spd swap for more info. http://www.audizine.com/forum/showthread.php/420732
    http://www.audizine.com/forum/showthread.php?t=271678
    http://www.audizine.com/forum/showthread.php?t=294554
    http://www.a4mods.com/index.php?page...tml&category=1
    http://www.audigeeks.com/forums/index.php?topic=94.0
    http://www.cardomain.com/ride/2964519/2 (thanks djwimbo)
    http://audi-diy.blogspot.com/2007_10_28_archive.html (halfway down)
    Parts acquired:
    -$450 Complete 1.8t 5spd transmission
    -$75 Shifter box with knob and shifter surround
    -Clutch hardline that runs from the clutch master cylinder to slave cylinder
    -$50 Brake/Clutch Pedal
    - Slave cylinder
    - Clutch master cylinder
    -$50 5spd driveshaft
    -$140 (2) CV Axles for a manual transmission (I just picked up some 2.8 ones since I am 2001 MY)
    -$950 Clutchmasters FX400 clutch with steel LWFW (Ringer-racing.com)
    *(New flywheel/pressure plate bolts needed)
    -$60 2.8 Drivers side transmission bracket (dealership) PN# 8D0399113AG
    -$60 Passenger side transmission bracket from 5spd car
    -$5 (6) Driveshaft to bellhousing bolts (dealer)
    -$40 Rear crankshaft seal (germanautoparts)
    -$19 Pilot Bearing from www.zorkos.com PN#A-6941
    -$2 Two Feet of 5/16th Vac Hose for pedal-brake reservoir line
    Tools:
    -Transmission Jack
    -2' Jack stands
    -Jack
    -12pt. bolt set for the CV axles
    -17mm 12pt. socket for automatic flywheel bolts
    -T45 Torx socket to remove brake reservoir/thing behind it to access room for the clutch hardline
    -T55 Torx for Torque Converter
    -Torx Bit set
    -Clutch alignment tool (comes with clutch)
    -$25 17mm Allen/12pt Drain tool-http://www.germanautoparts.com/Audi/A4/Transmission/251/1
    -Various sockets, extensions, allens, wrenches
    -Impact wrench, air ratchet
    -Torque wrench
    -Angle Grinder
    -Power bleeder (not necessary)
    -Pump for trans fluid to go into the housing
    -Drain pan
    Fluid:
    -$12 1 liter can of Ate Type 200 Dot 4 brake fluid
    -$30 3 qts of Redline MT90
    -$10 1 qt of Redline Heavy Shockproof
    -Moly grease for input shaft
    -CV grease for CV contacts and driveshaft
    -Brake cleaner
    -Blue loctite
    My total cost of parts came out to around $2000
    ^^Shifter linkage, held on with one small bolt for the shaft, and the other is held in with an allen bolt
    ^^Shifter Box, held in by 6 nuts
    ^^Hardline, connects slave cylinder and clutch master cylinder (behind pedal), goes through false firewall bottom
    ^^Clutch Master Cylinder, picture shows hose going to brake reservoir and the hole for the hardline
    ^^Manual brake pedal and clutch, both held in by a bolt that has clips on the end
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: Biketsai's DIY Auto-to-Manual Conversion
    Day 1:
    Started off this morning at around 11am, finished this evening with dropping the auto trans. For the process, it is not too much different from the manual transmission drop. I may miss a couple steps but im sure those steps are covered in a manual transmission removal DIY, but ill try to fill ya in on what ya need to know!
    1. Got the car on jackstands slowly taking my time. Me under the car in this picture
    2. Remove exhaust, it will help if you remove everything from the turbo to the end of the driveshaft .
    3. Remove pinch bolt, disconnect CV axles completely with 17mm Allen and then 6 triple square bolts on the inside. Then remove the heatshield over the CV axles.
    4. Remove driveshaft bolts, 6 on each end, 2 in the middle (must make sure you mark the spot for those). It helped to have a friend pull the E-brake for me to freely spin the DS inbetween.
    5. Remove lower control arm closest to the rear of the car, then disconnect the 3 bolts holding the subframe on each side.
    6. Remove the few bolts holding the starter in on the passenger side of the transmission, you must do this to reveal the flex plate bolts (3 in a triangle pattern). When it is time to remove those, have a friend spin the flywheel with a flathead underneath the car and have them hold it there while you unbolt the T55 bolts.
    7. Then remove the transmission mounts, starting with the middle bolts, then 2 on the side. Then disconnect 3 electrical plugs, and also disconnect the lines where the hoses meet the radiator for the tranny fluid. Remember to unbolt the mount holding the rubber hoses to the car, those stopped me when I tried to pull the trans. Start removing bolts around the bell housing, you are going to have to find these on your own, but you should easily be able to see it all with the exhaust removed, the air cleaner out, coolant tank out, and CV axles out.
    8. I managed to be able to get a wrench through the side wheel well to access all of the top/side bolts. After all bolts are removed, you will start to disconnect transmission slowly prying it off with a transmission jack underneath. You will have to figure out some way to push down the subframe and then lift/pull/lower/pull ETC ETC. It stumped us when we got here but we somehow managed with magical powers. Be patient and be careful, it will come out somehow!
    9. I decided to disconnect the shifter cable after I lowered the transmission, it just pops off. Tomorrow im going to go and remove the center console to get the shifter box out (4 bolts)
    10. After the trans is pulled, you will have to unbolt the 6 flexplate bolts with a 17mm 12pt socket, I wedged something inbetween the wheel and the engine to prevent it from moving. After you do this, you will have to pull the flexplate off, BE VERY CAREFUL, I almost lost an eye with it popping off.
    One thing I am wondering is if I need to just make this area flush, you can see the crank protruding. Guess ill find out tomorrow
    I might have missed a thing or two, but it will seem clearer once you start.
    My friend Brian who helped me out tons!! also thanks Eric and Evan for heading out:
    soap soap soap, tons of it at the end of the day
    day 1/
    *End of day questions
    -Will I reuse my automatic transmission to bellhousing bolts? or use the new manual ones?
    Edit: Turns out that they are the same.
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Day 2/3
    Turns out that one of my transmission brackets didnt come in on Friday as planned, so I have this weekend to wait till Monday for me to put the transmission in. In the mean time I did everything else needed to be done, basically all of the stuff that the auto cars dont have.
    First I kinda removed the shifter assembly, it was a pain. You need to remove the center console to make it easier. I managed to remove the shifter box with some tearing apart and managed to get a 13mm socket into the F/R bolts for the shifter box. Lets just say I got pissed and then it all worked out! Now you can see the other stuff that you will need to put aside, you wont need that rod or the connectors anymore.
    After that I went to remove the master cylinder and the brake booster. Prepare for fluid to be spilled everywhere, but it will go out through the firewall area onto the ground. To remove the reservoir, there is one 10mm bolt, one connector, then yank it out. The other side is just pushed in. Then proceed with removing the 2 brake lines on the master cylinder. Afterwards you should then start to remove the 21mm nuts holding the master cylinder to the booster, you wont be able to remove the cylinder until you remove the booster. So after you get those nuts, there are 2 T45 bolts holding in the booster to the firewall. Remove those and on the harder side, I used vicegrips since there is no room for a wrench. Then go behind the dash and unbolt the pedal.
    With this all removed you can then install the hardline through the grommet under the booster.
    ^^^This is the clip that goes behind the clutch pedal. In order to put the pedals in, you should remove the pedal assembly, held in by one 6mm allen.
    Afterwards take off the clips that hold the rod for the brake pedal, insert the new rod and put the assembly in without the clutch pedal in. This section will all make a lot more sense once you get in there. I bolted the clutch master cylinder first to the bracket. Remember that you must use the new longer push rod for the pedal and clutch pedal. Once you have the assembly in the car, you can then clip the hardline to the clutch master cylinder (there is a grommet you must remove for that spot). Then get your vac hose for the clutch master cylinder to the brake reservoir and connect it all (on the reservoir just cut off the closed end). Afterwards just install everything back.
    Pedals in:
    Time to shave off the crank. You should leave about 2mm left sticking out on the crank. I used a 2mm allen wrench to measure. To prevent myself from overdoing the grinding, I left in 2 spacers that were originally there (about 2mm) to get things perfect. These spacers were there from the stock flexplate, you can combine two to make about 2-3mm on the crank to keep as a safety buffer. Just take this procedure slowly and get things nice and even, it doesnt have to be perfect:
    *I actually had enough room to sit sitting up in there.
    Here is the FW held on by one bolt with the bearing in.
    At the end of the day, I felt pretty good about grinding the crank down. I was very skeptical at first but it was a whole lot easier than I had ever imagined. Just saying for all those who think its sketchy.
    end/
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Last 2 days
    Torque specs for the next steps (they may differ depending on your setup)
    -FW-60ft lbs (non stretch bolts)
    -Pressure plate- 14ft lbs
    -Transmission bracket- 30ft lbs
    -Drain plug 26ft lbs
    -Fill plug 18ft lbs
    -Transmission mount center bolt-30ft lb
    -Trans mount side bolts (2)-17 ft lb
    First thing I did was bolt down the Flywheel, using non-stretch bolts with loctite they were torqued down as well as the pressure plate afterwards. Tighten these bolts slowly, snug first and then go in a star pattern to bolt them down. I used a bolt and chain and a screwdriver wedged inbetween by block.
    With the manual trans still out, I drained it keeping the transmission level using another jack on the back, I also swapped the throwout bearing at this time and lightly gave it some grease (pic from a4mods.com) I poured in 1/4 quart of Heavy Shockproof and filled the rest 2qts+ with Redline MT90. Torque down the drain/fill plugs. At this point, transmission is on the jack and ready to go in!
    Line up the transmission as close as you can without hitting the pressure plate fingers and slowly get the input shaft in. I used bolts to guide the trans into the right angle and direction. Once you get close enough, put some bolts on and start tightening them around evenly so the transmission mates up to the block. This diagram should help you out.
    Once the transmission is in, you can start to raise the subframe back up, and bolt down the transmission mounts starting at the outer 2 ones. I would allow your transmission to have all its weight down when your torque things down. Around the same time, mount up the subframe brackets and bolt them down. It helps to have a friend/jack hold the subframe up while you tighten bolts down. After you do this, put the lower control arm back in.
    Now its time for CV joints- driveshaft, front axles. I tried to torque down my driveshaft, but one of my bolts just stripped when I tried. Remember to wipe out the old grease and put in the new CV grease. On the center driveshaft bolts, remember that they have to be in the same EXACT spot! Around the same time, get the shifter linkage in. It will be tough getting the allen key into the linkage, it will just take some time. Shifter linkage, I believe its a 10mm bolt.
    I was lucky enough to have a pressure bleeder and I bled the lines in this order- Pass R, Driver R, Pass F, Driver F, slave cylinder. 1 liter of fluid was enough for me.
    Transmission in!!
    When you go to bolt in the starter bolts, MAKE SURE you do it on the right post. The 2 bigger positive cables MUST go on the 13mm post that has the plastic spacer behind it. DO NOT, DO NOT put those wires on the posts that have the 8mm post. Attach the spade connector wire as well. I learned the hard way when I went to put my battery on that you should not do this. My positive battery cable caught fire in 3 places and well, burned through all of the insulation. It didnt do any other damage than that so I just wrapped everything in electric tape. Luckily the water hose wasnt too far off but there was smoke everywhere, I almost thought I was going to lose my car and my girlfriends house.
    Here is the park relay you have to modify. It is located under the dash right above your 75x posts. You must remove the relay on spot #13, and jump the wires with spade connectors with a wire soldered inbetween on the horizontal spots. Your relay may not be numbered 53, but it must be in spot #13. You also need to pull the TCU computer out. Its located in front of the passenger seat under the carpet. Take off one panel held on by phillips and then pop the side bottom trim off with a flathead. Youll have to lift the carpet up, remove the box and remove the TCU.
    Exhaust back on, intake, upper control arms lower the car, torque down wheels, ready to go! When you go to put the battery cable back on, be sure to watch it carefully and be ready to remove it in case anything starts smoking or burning, if I had reacted quicker the fire may not have started.
    Car all together and one happy camper!
    All in all, the swap was not as bad as I thought it was going to be. The worst part was just getting the auto trans out and even that wasnt too bad. On the initial startup everything seemed fine. You wont have a clutch pedal sensor so just make sure you dont start the car in first without your foot on the clutch ahead of time. My car ran on both auto and manual coding for the ECU, you shouldnt get codes once you have it on manual. The website that helped the most was the DIY (posted on top) on A4mods.com for the clutch install. It took me from Friday to Tuesday, with nothing done on the weekends because I did not have a bracket, just to give you an idea of the time frame.
    Id like to thank all of the people that came through and helped out, Eric (eakrob), Aaron (aaronamerica), Evan, Brian, Josh, Paul (PZ.) and Tom (VRSIX) for tools/equipment, last but NO WHERE near least goes to Tim (werewolves) for helping me out when I was freaking out/stuck and when my car was on fire! The people that helped make this whole operation possible and that I cannot thank enough is my girlfriend Carly and her parents for letting me use their garage for the past couple of days!
    *I think everything is mostly there, if there is any info that is very useful I will update this as needed.
    Time for...
    Before/After
    Before:
    Well leading up to the build I was pretty worried that this was going to be a huge job. Many people gave me that doubted "good luck", which just made me worry a little more. Another concern I had was grinding the crank down, thats a pretty important piece to mess up as well! I knew the job could be done, but for some reason I just did not feel 100% assured. Ive only helped pull one Camaro transmission before which didnt really help towards this job. That just goes to show that you dont have to have any special skills, all you need is some good logical thinking.
    After:
    I never knew how important fire safety was until I had this incident, never did I think I could be capable of causing something like that. My first impression throughout the job was that I thought to myself, "thats it"? The swap was no where near as bad as I thought It would have been. I guess all the worrying made me feel like everything was easier in the end. Grinding the crank down was no where near as hard as I thought, it was actually pretty easy (just use those spacers!). I feel a whole lot better about my car altogether, it is now everything that I could have ever wanted. Now I dont have a transmission barrier so next year I will be going with a BAT of some sort! The car feels pretty good, I have not had any issues so far (knock on wood). Everyone that has driven my car says that it feels pretty good as far as all the mechanics go. I have never owned a manual car, only driven friends cars so this has taken some getting used to. I just a tad more practice and 500-1000 miles and ill be ready to rip it up!!
    Today (8/8/09) I went to my GFs house and I had a gift waiting for me!
    This thing supposedly lasts 4x longer than most extinguishers and is a whole lot smaller, ill be keeping this in my car.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Wow, you are realy doing this. Good luck
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Senior Member Two Rings Amorphic's Avatar
    Jun 05 2009
    2001 A4 1.8TQT
    BC, Canada
    wish you luck. I jumped the gun on getting a tip instead of waiting for a 5sp and i still hate myself sometimes lol. black on black 5sps are impossible to find in my area, had to settle for auto. :(
    Mar 14 2007
    Good luck again crazy man!
    Sep 21 2007
    DeSoto, TX
    You are going to love 5 speed.
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    I will help as much as I can
    1998 Audi A4 built 1.8t Quattro--Eurodyne Maestro---870cc tune---Custom Elim Gt3076---on E85 Gas---044 Bosch Drop in fuel pump---Street tuned by me---402awhp 387tq---12.1@118mph on 19" wheels
    2003 Audi Avant 1.8t Quattro 5speed--Eurodyne Maestro--k04 tuned on 630cc injectors--19" Staggered iForged Daytona Wheels
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    San Diego
    Why not upgrade to a B5 S4 6spd...Isnt the 2.8 5spd a little different from the 1.8t as well, longer gears?
    (Ka-La-Bre-Ah)
    Senior Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    longer gears make a 1.8t fall in and out of the powerband when shifting.
    you reserved 4 posts in a row, now you have to fill them. or else...
    looks good though, i know a ton of people will find this useful. you know how many times people make 'how hard is an auto to manual swap?' thread.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    '00 A4
    NH
    curious to know if the pilot bearing is the same.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    many thanks for the shoutout... pm me if you have any questions pop up or you can call me if you still have my number.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by zrowcool View Post
    think I lost your number, heading to the yard in about 45 mins to pick some items up too! PM me
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by Euro-Tuner View Post
    same as?
    Quote Originally Posted by ghost6303 View Post
    Yea I just figured if I am going to get A LOT of pictures, they all wont fit in one post because there is like a limit. I want this thread to be something people can easily reference.
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    08 GLI,08 Jeep, 99 MK3 jetta VR6
    Palm Beach,Fl
    Good luck. Your write up looks very detailed oriented I am looking forward to see how this comes out.
    034 Stage 3 BT, Unitronics,H&R,etc,etc
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Calabria View Post
    The B5 S4 6 speed has a horrible 2nd gear ratio, it drops way too much for a 1.8t setup. The 2.8 5 speed is a good choice if the car is only used as a daily driver and most of that on the fwy.
    Taller gears tends to mean more time spent getting thru the gear and this means slower acceleration.
    Dec 05 2007
    Will be keeping an eye on this thread as it progresses. Good luck Biketsai. We all know how Murphy's law likes to stick it's face around the corner with these cars.
    I hate it when my car acts like a little bitch, treating me like the bitch
    Senior Member Three Rings werewolves182's Avatar
    Jul 01 2008
    Towson/Annapolis, MD
    Just like you said, I was under the impression the 2.8 manual trans had taller gears then the 1.8. This is why I used it when I converted to manual. Are the gears only taller when paired to the 1.8 manual rear differential through? I used the trans and rear end from a 2.8 for my swap and have noticed 5th gear at 80mph sits around 3600rpm.
    Jul 01 2008
    The pilot bearing used is not actually a pilot bearing per say, its an alternator bearing that I found to have the exact inner and outer dimensions (15id, 43od) needed to be used as a pilot bearing that is retained by the flywheel. This overcomes the previous issue with the different cranks.
    Jul 07 2004
    socal
    Quote Originally Posted by werewolves182 View Post
    Yes the 2.8 has taller gearing and the 2.8 manual uses the same 3.889 rear end as the 1.8t manual. There is about a 400 rpm difference between the 2 at that speed in 5th gear.
    Site Moderator Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The 2.8 gearing is approx 7-10% taller than the 1.8.
    Jim - Moderator
    I Do Werk.
    New Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by biketsai View Post
    -$? Shifter box with knob and shifter surround
    -$?Clutch hardline that runs from the clutch master cylinder to slave cylinder
    -$? Brake/Clutch Pedal
    -$?Slave cylinder
    -$? Clutch master cylinder
    -$? 5spd driveshaft
    -$? (6) Driveshaft to bellhousing bolts (dealer)
    "?" Indicates parts I still need to acquire
    Give me a call Chris... I'll set you up with all that stuff (Phone # in sig)
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Mar 09 2004
    nw michigan.
    80 mph drops from 3500 to 3300 rpm with the 2.8 trans swap. In the S4 it is 3050 rpm.
    The gearing change does vary slightly with the 2.8 trans compared to the 1.8. For example, it is 12% taller in second, 10% taller in third, 9% taller in fourth, and 7% taller in fifth.
    Mike mentioned the gear drop into second. That is usually ok with an S4 but a big turbo 1.8 can easily fall out of it's powerband. Shifting at 7200 drops the 1.8t trans to 4100 in second, the 2.8 trans to 4000, and the s4 trans to 3400. Even if you revved to 8 grand the s4 trans drops you to 4000 for second.
    Outside of re-spooling a turbo, the place this matters is at the track. If a big turbo A4 is trapping 135 then the 1.8 trans is perfect. If it is going to trap over 140 then it might be better off with the taller trans. Of course, it will take the same percentage more torque to accelerate at the same rate in the taller gears. Same goes for time trialing. If I was banging off the limiter a second before the braking zones on both straights I need to either raise the limiter or get a little more gearing. If I was hitting the limiter towards the middle of the straight there is still time to push that next gear.
    Jim - Moderator
    I Do Werk.
    Jul 07 2004
    socal
    If an A4 1.8t is going to be hitting 140 traps its going to be making power well above 8k and even at that point a 1.8 transmission is going to allow that car to trap those numbers.
    Data I put together for a 1.8t transmission with the higher rev limiters
    1.8t-01A for 4th gear
    7500 rpm = 135 mph
    8000 rpm = 143.3 mph
    8200 rpm = 146.9 mph
    8500 rpm = 152.3 mph
    The B5 S4 4th gear hits 135 mph at 7500 rpm and the B6 S4 trans hits 135 mph at 8300 rpm since it has a very short 4th gear. Both have very tall 2nd gear.
    What I look at is where in the power band the next gear lands, the difference on the 1.8 trans and the B5 S4 transmission is huge for my BAT setup.
    Going into 2nd gear shifting at 8200 rpm
    B5 1.8t 01A transmission = 330hp/350tq at the wheels
    B5 S4 01E transmission = 220hp/280tq at the wheels
    B4 80 01A transmission = 400hp/430tq at the wheels
    Just shows what a huge difference a few hundred rpms will do on a BAT power band
    Jul 01 2008
    Hmmm, given everything you have said about the gearing of the 2.8 trans, now ive got to figure out why im at 3600 in 5th at 80mph with my 2.8 trans and rear end.
    Nov 02 2008
    01 Passat WagonV6 4MO, 05 Golf
    Grapevine,TX.
    Good luck. Wish I was going to be around to help. It's a lot more fun on someone else's car. I will hit you up for leftover parts once I get back :)
    Paul.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by PZ. View Post
    Paul.
    I can't thank you enough for letting me borrow these tools! This thread should be progressing while you are out of town.
    My 5-Speed Swap DIY
    - B6 USP
    Jan 06 2007
    '00 A4
    NH
    Quote Originally Posted by onemoremile View Post
    so if I'm hitting 145 at 7200 rpm in 5th, whats wrong? WTF?!
    Feb 09 2007
    00 S4
    MA
    hmm 190 in and s4's 6th gear huh?
    Active Member Two Rings BumbleBee's Avatar
    Nov 09 2008
    Autobots
    very nice keep us updated. If you have questions let me know ive done this swap before, but your doing the pilot bearing a little different i see.
    "The least likely can be the most dangerous."
    2001 S4 GT28RS - SSP Tuned -
    2004 Audi RS6 - SSP Tuned - 6 Speed Converted Next Step GT30's
    2006 Porsche Cayenne Turbo - SSP Tuned -
    2011 Audi S4
    Senior Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    x2
    2001 Allroad 2.7T 6spd - Stage 3
    SMIC | Jfonz'd | k04's | Bosch 710N (x2) | SSAC 3" DP | Podi Gauge | Skid Plate | ST Coilovers | RS4 Clutch | OEM RS4 Inlets | Custom Paint Matched Lowers
    Jul 07 2004
    socal
    That is normal and nearly ever person I know of with a A4 that tried to top out 5th gear by 7200 hit 145 mph. The numbers are not exact.
    The site I uses shows 158 mph for 5th gear at 7200 rpm for the 1.8t 5 speed.
    http://www.car-videos.net/tools/spee...B1=Recalculate
    Registered Member Two Rings
    Jul 12 2004
    Austin, TX
    Hows the swap going???
    Rob
    Brilliant Black 2000 A4
    H&R|Bilstein|APR|OZ|FMIC|CAI|Borla
    Oct 30 2006
    04 USP A4 1.8t Avant
    Long Island
    Very nice to know I don't have to shift out of 4th until 150mph
    -MilitantGrunt- Audi USA. Certified Audi Technician
    -Brilliant Red B6 A4 Ultrasport 1.8t Avant
    Senior Member Three Rings kevin12's Avatar
    Jun 20 2007
    2001.5 A4 1.8TQ
    South Jersey
    Looking forward to see this finished Chris and definitely plan on using it. I think more and more everyday of doing the swap.
    Kevin
    Old: 99.5 Laser Red A4 2.8Q Tip Totaled RIP
    Current: 01.5 Casa White A4 1.8TQ
    Uni 1+, Intake w/ Blinktek HS, ST Coilovers, Hyperboost DV
    Jun 04 2007
    Austin/DFW, TX
    Just finished day one, details in post #2
    What I did last night:
    very excite!
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    01.5 A4 1.8T and 06 VW Passat 2.0T
    Orlando, FL
    Nice start!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HIDs|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Jul 07 2004
    socal
    Hey Chris now would be the time to upgrade the shift linkage parts to some JHM parts, even if you just do the JHM bushing upgrade it will make it easier to install the linkage brace since the upgrade removes the allen head bolt for a normal bolt and makes it 100 times easier to put in since you just use a 17mm ratchet wrench.
    Jun 04 2007
    Austin/DFW, TX
    Wish I had the money for the upgraded parts, but I am just flat out broke! I got the clutch disk yesterday and the UPS guy took the 6-puck, thanks!
    Now the question is, do I use the auto transmission bolts, or the manual trans bolts.
    My 5-Speed Swap DIY
    - B6 USP
