Results 1 to 12 of 12
    Stage 2 Banner Advertiser Four Rings Doc@tirerack's Avatar
    Oct 06 2006
    South Bend, IN
    How old can a tire be and still be safe ?
    Not too long ago, the tv "show" 20/20 did a piece on replacement tires, and how some shops have installed tires that are approaching ten years of age (from date of manufacture) without discussing the issue with the customer.
    We have received hundreds of emails and many more phone calls regarding the issue, including many customers "demanding" the tires they receive from us be less than 12 months old in extreme cases. Below is our take on the issue, perhaps it may help those that are concerned .
    (more to the point)
    http://www.tirerack.com/tires/tirete...jsp?techid=183
    (background info)
    http://www.tirerack.com/tires/tirete...jsp?techid=138
    Doc Horvath
    The Tire Rack
    800-428-8355, ext 4665
    please do not PM me, but send email direct to me at Doc@TireRack.com
    Support Audizine !!
    Click on the Tire Rack banner ad or reference >DOC / Audizine< when ordering !
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: How old can a tire be and still be safe ?
    Good information, thanks.
    Veteran Member Three Rings Whatset's Avatar
    Dec 02 2008
    JKU, 986
    Left of center
    Nice Doc - I just learned about the 4 digit code from a friend. Any reason why 3 matching and 1 not (4 months older) is of any concern? They are all from 08.
    Oct 06 2006
    South Bend, IN
    I would not be concerned with tires from differnent batches like yours, so long as they are in the same 12 months of production (sometimes manufacturers will "tinker" with a tire over time, so we'd like to have the tires be pretty close in age across the set to avoid any potential issues)
    Doc Horvath
    The Tire Rack
    Support Audizine !!
    Senior Member Three Rings CRAIG1MACK's Avatar
    Mar 10 2009
    2002 Audi A4 Quattro 3.0L 6mt
    Huntsville, AL
    cool, thanks.
    looks like i'll be replacing my motorcycle tires. 14 yrs, but only 6k miles. I wrecked from the front skidding out (didn't seem warrented) and thought the tires could be the culprit.
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    I work at a tire store, And we are not allowed to Air up or work on any tire
    over 9 years of age. And anything over 6 is with extreme caution.
    Customers sometimes don't understand the rubber will only last so long even if you
    don't have many miles on them. We've even had a customer recently tell us "You full of ****, Making it up."
    lol.
    Not sure if I saw it in there, Didn't really read much.
    But what happens over time is the rubber breaks down, and air "seeps" through the rubber and layers of steel.
    Causing Separation of the tire/layers. Never drive on these tires.
    Good article to read up on....
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Established Member Two Rings AltitudeImola's Avatar
    Jul 14 2009
    '00 Imola Sedan RIP, '03 BMW 325xiT
    Denver, Colorado
    most tires actually have oils in the rubber that get released to maintain the tire as it heat cycles so if the tires are not driven on they are often in worse shape than if they are driven regularly
    Established Member Two Rings craiglou's Avatar
    Sep 28 2010
    suzuki gsxr 1000
    florida
    Cool How old can a tire be and still be safe
    good topic,learned a lot from this information.
    Jul 18 2011
    Angola, IN
    Thumbs up
    Hi,
    Nice post! I've done researching about the age of a common tire. yes! it's true a typical tire i think it's about 12 months of production and i believe it's still safe to use that car parts. Anyways, nice post!, it gives me an idea when am i going to replace my tire since my car that i bought is almost 20 years old and so far it is good although my tire needs to be replaced again since this is my fourth time to replace my tire LOL!. Nice post again!
    Jun 06 2011
    4105 Feathers Hooves Drive Pat
    If the car tire is still in good condition, I think that would be a good reason to sell it. But if you overused the tire I don't think anyone would buy that. No one would buy that. Plus, consider the price you'd be giving to the buyers.
    98.5 A4 1.8TMQ
    I just realized my other set of wheels with Blizzak ws-15 have 15th week of 1997 manufacture date. These came with the car when I got it in 2006. Don't know when they were mounted. Even though they've only been used maybe 4 days out of the year past 4 years, I suppose it's safe to say they're not safe to run on anymore.
    98.5 A4 1.8tqm
    Oct 06 2006
    South Bend, IN
    Quote Originally Posted by southpaw10 View Post
    You'll just have to inspect the tires frequently (maybe every other month) to check for cracks in the sidewall or inbetween threads that will indicate a problem. Since most snow tires aren't in use but for a few months out of the year, its not as big of a danger as older tires used for "daily" use with many more miles travelled each year.
    Doc Horvath
    The Tire Rack
    Support Audizine !!
