Results 1 to 21 of 21
    Established Member Two Rings sailfast's Avatar
    May 27 2009
    '11 B8 S4 / '83 380 SL /
    New Canaan
    Replacing B7 S4 Grille w/ RS4 Style Mesh, help!
    I would appreciate any advice on how I can replace my stock B7 S4 grille with an RS4 style mesh grille. I know it can be done but my attempts have failed. I bought a replacement from Eurosport Garage (don't ever buy anything from them!) and was assured it would fit. Well, it didn't and their explanation is because all the '08 B7 S4 have S-line bumpers which will not accommodate a grille swap.
    I have also inquired directly with Audi and they also tell me that you can't fit a mesh grille to my car. Yet, there are pictures on previous threads with the mesh grille on an '08 B7 S4.
    Can someone please tell me what direction to head. Many thanks!!!
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    Re: Replacing B7 S4 Grille w/ RS4 Style Mesh, help!
    Do you have the standard S4 bumper or the DTM bumper? If you aren't sure, you'll need to post a picture for more help.
    If you have the standard S4 bumper, you CAN swap in the RS4 grille. If this is the bumper you have, your dealer/shop is full of crap or flat out lied to you if they said an RS4 grille won't fit.
    If you have the DTM bumper, the RS4 grille will only fit with a lot of cutting and glueing.
    So, judging from the fact that you said it didn't fit, I'd have to say that you have the DTM bumper. That means you can only use DTM, 25th Anniversary, or any grille made to fit a standard A4........or you got lied to and they didn't even try to install it.
    '13 S4: P+, DSG, Ice Silver, Black/Black Alcantara, Nav, SD, B&O, Carbon
    Akebono Ceramics, AWE Boost Gauge, AWE/GIAC Stage 2 + DSG, AWE Touring Exhaust & Res DP's, BO Grille, CR-15, Deval CF Lip & Diffuser, Ecodes, Eurocode Alu Kreuz & Sways, Euro Visors, Folding Mirrors, H&R OE, Hoen Xenonmatch Fogs, Ocarbon Dash Trim, Retrofit Labs Signals, Roc-Euro Intake, TSW Bathurst 19x9.5 et39 & Michelin PSS, Underseat Bins, Warning Triangle
    May 27 2009
    New Canaan
    Thanks. This is obviously not the whole bumper but should hopefully give you enough to see what I'm dealing with. Ignore the vertical chrome strips between the grille foils. They were an earlier attempt at enhancement but with nothing to back them, they started to fall off so I removed them all.
    Your input will be very welcome.
    May 27 2009
    New Canaan
    Here's a better picture. Audi broke the rings during their while attempting to fit the replacement grille I purchased from eurosport. BTW - the eurosport grill definitely does not fit. the lower portion of the grill is half the height of what you see here.
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta, GA
    Items for Sale
    Don't know if this will help, but it will give you an idea on how to swap them out.
    http://www.audizine.com/forum/showthread.php?t=287499
    The Beatings Will Continue Until Morale Improves!!!!
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Quote Originally Posted by SLYCAT View Post
    hell no. do not listen to this post. this is not what you need to do.
    you have an s-line bumper, so the RS4 grille is a direct swap for your S4 grille. Many people on here have done this. I have swapped grilles, only i did a blackout one instead of the RS4 grille.
    All you have to do is remove the front bumper following one of the many DIY's found on this site, and on the inside of the bumper you will find about a dozen screws that hold the grille in place. Remove, switch, reassemble, and its done.
    2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    May 27 2009
    New Canaan
    Quote Originally Posted by whartung View Post
    Thanks. Sorry if you just got this quick reply. I didn't hit post and moved on so I don't think you got it.
    Why is Audi so adamant that the RS4 grille will not fit??? Can you please point me to one of the DIYs on the site for the swap. Also, I would love to see what you did for the blackout grille, as I might go that direction instead. Do you have a link?
    Thanks
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by sailfast View Post
    Thanks
    Like other members before me have said. The Rs4 grille WILL fit.
    The grille you ordered from Eurosport must have not been a Rs4 grille.
    Order the correct grille and you will not have an issue.
    You can also order the blacked out version of the s4 grille which is the route I had gone on my s4.
    May 27 2009
    New Canaan
    Looks great. I think I am going to go with BO vs. RS4. You and Whartung have convinced me.
    Feb 01 2007
    Here
    http://www.audizine.com/forum/showthread.php?t=234915
    Thread I started a while back after I did my swap. It should have most of the information you need to make your decision and swap out your grille.
    The one thing to keep in mind is that the pictures of my completed grille look a little funny because I mounted my bumper wrong, so the gap in between the hood and the bumper is about half an inch larger than it should be. But that's just me being anal.
    Established Member Two Rings btek's Avatar
    Jul 12 2004
    Socal
    in case you want to view another example of an rs4 grille, I did it to my S4 as well.
    http://www.audizine.com/forum/showthread.php?t=270970
    Carlos
    2013 CTS-V Wagon
    Gone but not forgotten
    08 S4 Avant
    (FI Res CB, RS4 Black Grille, Fog light grille mod, Hoen Fogs,V1, JHM Goodies!)
    05 X5 4.8is (BMW buyback (aka lemoned))
    02 Allroad (sold)
    05 Elise (sold)
    98 Supra Turbo (sold)
    Dec 20 2007
    Philly Area, PA
    For a bit of clarification......it seems everyone here (myself included) has made the assumption that the grille you purchased is OEM.
    Since I've never heard of Eurosport Garage, and I have a hard time believing your dealership has never seen an S4 with an RS4 grille, I did a little research and found that they are an eBay-only company. Chime in if I'm off base here, but are you sure the grille isn't some cheap aftermarket knockoff? It is certainly possible that it is made wrong and/or the seller really has no experience with Audi. Looking at their auctions, it seems most if not all them are titled A4/S4. They make no distinction between different models.
    Since you said it's too short, I'm guessing that is really an A4 only grille (or DTM/25th), which would also make it a 3rd party part, and that they assumed the A4 and S4 use the same grille.
    Do you have any pictures of the grille or a link to the original auction? It would be nice to have that information here so someone else could avoid this confusion in the future.
    May 27 2009
    New Canaan
    You are absolutely correct. They seem to be an eBay only company and don't know what they are talking about. They are impossible to contact. I will post a picture of the grille later. If anyone reading this thread has a B6 A4 and would like to buy an RS4 mesh grille on a fire sale, pls let me know
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    how'd the dealer break your rings? were they trying to pull the grill off without removing the bumper
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    May 27 2009
    New Canaan
    They tried taking the rings off the current grill for replacement on the new grille before they took the grille off the car. I guess they just tried to pry them off.....
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    All the OEM Audi grilles come with rings.
    Senior Member Three Rings RudeBwoi's Avatar
    Jan 05 2005
    My 2000 1.8T, Quattro 5spd
    that blackout grille looks really good MOF
    GIAC Stage 1 ::: H&R S4 Coilovers ::: V&S Short Shifter ::: B5 Rs4 Reps ::: Intake ::: N75R ::: Tints ::: 12'' Kicker Square Sub
    Need to sell this A4 asap...SOLD
    Established Member Two Rings magnitude's Avatar
    Oct 03 2011
    Norway
    Can someone please tell me where I can purchase this grill??? I can only find the identical grill but without the chrome parts. I REALLY want this grill so hope someone knows!
    Feb 09 2007
    E46 BMW M3, Porsche 996 Turbo
    I think he put the chrome stipes in himself. Its a standard S4 grill with what looks like some type of chrome tubing glued into the gaps - hard to explain but i've seen it before on a Dodge Caravan
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Items for Sale
    Quote Originally Posted by AmanV View Post
    Are you talking about the license plate cover? There are several different kinds...just find the part number for the one in the picture above and order it. Hell, its probably already listed on ECS Tuning.
    A few mods here and there
    Established Member Two Rings HeimlichkeitB7's Avatar
    Jun 12 2010
    Here is my RS4 conversion. I have the rs4 bumper too, but the grille is from ECS (phantom black grille)...expensive but worth it. Do it the right way first.
