I would first like to thank http://www.vastperformance.com/ for making this possible, and for all of the support they have given me throughout the ups and downs. Thank you Prince for always running your ass off, and getting everything together in such a short period of time. Thanks for dealing with me as well haha. You know it is bad when you call Vast and you get, "Sup Sam!", other than a hello? How may I help you? :).Everything looks amazing and I hope the install goes well. I would also like to thank Mike at Vast for the tuning. He has been an awesome guy to deal with and makes crazy maps for sure :) I hope we can get this GT file ripping before Waterfest aka 1 week.Hopefully I will get to meet this crew one day, because they are a great bunch of guys and know what I am about about… SPEEED!!! OVER HYPE!!! I would also like to thank my tech Jon. Thank you all for making this happen and I hope to back it up with some numbers :D
2001 Audi a6 2.7TT
Engine: Stock 2.7 – Rev Limit 7350rpms
Rods: Stock
Valve springs: Stock
Cams: rs4
Intake Manifold: Stock
Exhaust Manifold: Stock
Throttle Body: Port and polish ( By Vast )
Turbos: GT2560’s aka gt28r
-ARD inlets
Wastegates: Internal
MAF: going back to Bosch I believe in the future for high psi. 88mm right now Hitachi.
Injectors: #60
Fuel Pump: 255lph
Fuel Pressure Regulator: 3 bar
Intake: Custom rs4 box with k&n filter
ECU Tune: Custom Vast Performance
TCU Tune: Custom Vast Performance (Remap of the TCU race profile for the built trans, stall converter and to take the 7350 rev limit)
Transmission: Fully built, valve body, clutches ect. ect. ( www.517trans.com )
Stall converter: 3250-3500 stall
Intercooler(s): AWE (with custom cut shrouds)
Mounts: 034 snub mount/cage, stern engine mounts, stock tranny mounts
Exhaust: straight pipe to apr cats.
Fuel: 93 octane / meth
The build is going to be done today or tomorrow, if everything goes well. Only thing I will be waiting on is my TCU to show up tomorrow (Friday) or Sat. I have my baseline tune waiting on the server to be uploaded :D I should be able to give you guys some good detailed information once I get the car running. I know a lot of you are out there wondering if it really worth the money? Can it be done on a stock block? What is it going to spool like? ect.. I hope to have the answers to all of these questions VERY shortly. I am hoping this weekend on 9psi adleast :D
GT break-in file – 93octane/meth
-1.25 Bar of boost
-7350 rpm rev limit
-Methanol, ~25deg timing up top
-EGT sensors deleted
-rear o2 sensors deleted
-catalytics deleted
-Secondary air system deleted
Here are a few pics of the turbos, inlets and engine mounts. I will be uploading pics of the trans, engine ect later today as well. Also I would like to note that my tech removed my turbos/trans with out removing the engine. :D This is the second time I saw it done and thought some of you would be interested in that style.
ARD INLETS, STERN ENEGINE MOUNTS, and P/P TB
Front of Drivers side gt2560(gt28r)
Front side again
Side of GT
Hot Side
Audi a6 2.7T 2001 STOCK you could say I was pumped ;P
Thank you for all of the support and haters :D
I hope to have videos within a week!!
