Results 1 to 40 of 44
    Established Member Two Rings slow&low's Avatar
    Mar 15 2008
    Spokane, WA
    Are you throwing a CEL P0441? I have the fix!!!
    So here is the story. A year ago I did the vacuum hose/check valve removal as per the DIY. As soon as I did it I my check engine light came on. I scanned it with Vagcom but since it was a evap code I really didn't care. My gas mileage was fine and the car performed flawlessly. Well after a year of staring at a check engine light I decided to fix it. I know in the DIY it says to vent the N80 valve directly into the engine bay and you won't throw a code but on my car that was false. I went to NAPA today and bought a check valve (part # 2-939 distributor check valve) and installed it . I ran a vacuum hose from the N80 valve to the back of the intake manifold port. It wasn't being used any more since the vacuum delete. I put the check valve inline on the hose, started up my car and no more CEL. I can't believe I waited a year to do this.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Re: Are you throwing a CEL P0441? I have the fix!!!
    Do you have a pic? or other pics for reference? I have no clue what you're tlaking about.
    Thanks.
    And glad you got it fixed
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Pics brotha! I think this might apply for most engines....
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    how long is your vacuum hose?
    Jan 06 2009
    Just for the record, driving with a CEL on makes the ECU stay in open loop therefore your gas mileage will be affected as the ECU isn't utilizing feedback from sensors.
    This is true for most vehicle ECUs so it is most likely true for ours.
    B6 2.7t BEL -- F21s, ER ICs, etc -- Tuned by Bische --
    B7 2.0t
    Veteran Member Four Rings Pufftrees's Avatar
    Mar 10 2009
    '15 a3, stg3+ b4s4
    New Jersey
    Moar pix!
    Stage 3 AWE/J-Fonz Retuned B5 S4
    Cheap and reliable wont be fast.
    Cheap and fast wont be reliable.
    Reliable and fast wont be cheap.
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 qT
    MOntreal
    are you talking about the valve near the ac lines on the pass side???I routed that line into the turbo intake, no cel
    BetaAlphaTau member #19
    Mar 15 2008
    Spokane, WA
    Quote Originally Posted by 20vturbo View Post
    Yep
    Mar 15 2008
    Spokane, WA
    To clarify, the N80 is the purge valve for the gas tank. I will try to get a picture up later.
    Mar 15 2008
    Spokane, WA
    Quote Originally Posted by BOPOH View Post
    About 2 feet as I routed it along the firewall
    Mar 15 2008
    Spokane, WA
    [QUOTE=adam_a4;3946411]Just for the record, driving with a CEL on makes the ECU stay in open loop therefore your gas mileage will be affected as the ECU isn't utilizing feedback from sensors.
    This is true for most vehicle ECUs so it is most likely true for ours.[/QUOTE
    I am already getting 380-400 miles to the tank. If what you say is true, I'll get even better than that. Sounds like a win for me!
    Oct 08 2007
    Columbus, OH
    picture update?
    Oct 08 2007
    Columbus, OH
    ok i tried that thing and so far i got no codes here is my pictures how i did it
    my N80 valve with check valve from AutoZone
    and here is where i put in TIP right by the turbo with yellow tape
    hope it works for you, ENJOY
    Oct 08 2007
    Columbus, OH
    code came up again P0441-002
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2016 A3 Monsoon Grey PP S-Line
    Orlando, Florida USA
    Items for Sale
    update?
    GONE: 2016 Monsson Grey A3 S-Line Premium Plus S-Tronic
    Stance SC1 19x9.5 et40 Brushed Titanium, Solowerks
    Coilovers, Pure CF Rear Wing, CF Side mirrors, RS3 Pedals,
    Neuspeed Power Module.
    NEW: 05 Porsche 911 White / Black Interior 6 Speed manual
    BC Racing Coilovers, FABSpeed Exhaust & Intake
    Mar 15 2008
    Spokane, WA
    update. It didn't work. The next day I threw the code again. Only this time it said it detected reverse flow. So I moved the hose to the TIP just like BOPAH did. I figured that would always provide the suction the valve needs to see. Lo and behold I threw another check engine light. Haven't hade a chance to see what code but 100% it id P0441. will solve this but I can only work on this on the weekends
    Oct 08 2007
    Columbus, OH
    i dont know what exactly is going on, but i erased that code last night and still haven't got it back. I think it depends on how you driving, i remember it came up when i was on WOT, but during regular driving its not coming on, so im keeping that set up for now.
    Apr 04 2007
    PHX, AZ
    I am getting this CEL code on my 3.0 too. It started because I decided to fill up the gas tank with the engine on.
    I have reset the ECU by disconnecting the battery for about 20 minutes, and the CEL will go off for about 3 days, and then it is back on again. I am tired of looking at it, so this thread was a huge tease!
    Any Audi techs out there willing to let us know how to cure this code?
    Oct 08 2007
    Columbus, OH
    wait, so that's the code that ECU trows at you when you gas cap is broken? so why did it come back 3 days later, did you fill it while it was running again?
    Dec 28 2006
    2003 A4. 2018 MB GLA250
    Western Maryland
    Items for Sale
    Quote Originally Posted by BSIXER View Post
    Typically you get this code when there is a vacuum leak somewhere in the Evap system. Your issue may be as simple as the gas cap failing to seal properly.
    A4 Motoza tuned Frankenturbo F21L mixed flow turbo / Bosch 550's / 3" MAF / TyrolSport SMIC / 034 HFC / TT 2.5" DP / Borla Exhaust / Eibach ProKit Springs / Koni Yellows / H-Sport Sway Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi
    A5 Mods to come: Little stuff so far. 20/25mm spacers / H&R OE Sport springs / 35% tint / Neuspeed Power Module / black window trim / RS grille.
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by slow&low View Post
    Just a thought: Are you sure you installed the check valve with the flow going in the right direction?
    Oct 08 2007
    Columbus, OH
    n80 pushes it out right or is it sucking in? i figure that is vapors from gas tank so they need to be sucked out, that why i connected it to TIP the way so check valve lets turbo to suck vapors. i was just reading your post N80 link
    Oct 08 2007
    Columbus, OH
    reading it again made me think, you know how we closed few ports/nipples(suction?) on intake manifold, what if you connect N80 straight to one of those ports/nipples that way i'll be like it was designed(or atleast somewhat close to original design), what do you think?
    Dec 28 2006
    Western Maryland
    Items for Sale
    The N80 is an on/off valve that the ECU controls by cycling it rapidly on/off (duty cycle). The check valve prevents the manifold boost from pressurizing the gas tank. You may be able to hook the line to the TIP and get enough vacuum. Depending upon the model year of your car the N80 has been hooked up several different ways. Mine has a connection to the TIP and another from the "Y" just after the N80 that ultimately attaches to the intake manifold. both lines are protected with a check valve.
    Mar 15 2008
    Spokane, WA
    Mine is just the opposite. It usually comes on after coming to a stop at a red light.
    Mar 15 2008
    Spokane, WA
    Yes, I put it back on the same way it came off. Almost impossible for me to have a vacuum leak. Already did the check valve removal, and all hose that remained was replaced with brand new hose. Hell I might try it backwards just for sh.ts and giggles.
    Mar 15 2008
    Spokane, WA
    That is exactly what I did at first, threw code 2 days later saying reverse flow detected. I will figure this out if it kills me. I am so tired of looking at the check engine light.
    Apr 04 2007
    PHX, AZ
    I only filled the tank once with the engine running, and never have again. But for some reason the CEL keeps coming back with this code. Maybe I need a new gas cap.
    Dec 19 2007
    York, PA
    necro bump...whatever came of this??
    Apr 04 2007
    PHX, AZ
    I never figured it out either...audi techs, please chime in!
    Dec 19 2007
    York, PA
    fuuuuuuuuuuuuuuuuuuu
    Apr 04 2007
    PHX, AZ
    dddgggggggggggge
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    Why does everybody feel the need to remove the evap system. Does nobody care about the world anymore? You will not gain anything from doing this, besides a cleaner engine bay which nobody cares about in the world except you.
    Quattro is my anti-drug
    Mar 15 2008
    Spokane, WA
    Wow, talk about bringing a thread back. I ended up buying all the hoses off a wrecked car and put everything back on. I wish I had never taken it off. The crazy thing is looking at it all, I still don't understand how everything works. The way things are hooked up stock make absolutely no sense to me, but if it keeps my check engine light off, so be it. One thing I did do though is tuck and re-route all the hoses so they are not visible. The engine bay looks super clean now. I just went down to orielly's and bought 10 feet of 3 different diameters of vacuum hose and now you can't see it any more. I wish I really understood the system though. It is frustrating to look at it and still not get it.
    Dec 19 2007
    York, PA
    lol...alright...thanks
    Registered Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Quote Originally Posted by adam_a4 View Post
    Never heard of this before in my life. Working at dealers for about 10 years.
    Gcc's blacksheep
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Quote Originally Posted by schmally View Post
    Yeah, I posted a thread about this last night...doesn't appear to be true.
    Apr 04 2007
    PHX, AZ
    Can you please diagnose the P0441 code for us and tell us what the dealership does to fix it?
    Dec 19 2007
    York, PA
    ^did you read this thread? it answers your ?
    Apr 04 2007
    PHX, AZ
    Quote Originally Posted by n7plus1 View Post
    Yeah, but the pics don't work anymore, and I have no idea where the vac lines need to go. Is there a detailed write up with pics?
