Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 801 to 840 of 911
  1. #801
    Senior Member Three Rings MikeyB3's Avatar
    May 16 2008
    Is it me, or does the inlet side of that turbo look gargantuan?
  2. #802
    Senior Member Four Rings shorterthanrich's Avatar
    May 24 2009
    2000 S4 Nogaro Blue, 1996 Ford Exploder
    Boston
    Quote Originally Posted by MikeyB3 View Post
    It's pretty beefy, but its also an optical illusion. For one, its larger than normal because of the anti-surge compressor housing. Secondly, that Tial turbine housing has tiiiny external dimensions, since its stainless steel vs. cast iron. It's just a lot thinner, making it seem even smaller compared to the compressor housing. It's still a .60 a/r compressor housing for the 63mm wheel.
    That said, the compressor housing IS for a 63mm wheel, so its not exactly small :-D. It should basically be a very similar size as 770s compressor cover, since they use a GT2860 compressor cover, if I'm not mistaken (which I may be)
    FREE BEER, click: Pintley - Tap Into Your Tastes!
    My iPhone/Android App
    2000 S4 Nogaro Blue VAST/DxC Stage "GT"
    GTX2863 Build Thread
  3. #803
    Senior Member Three Rings zdriver's Avatar
    Jan 17 2010
    Boston, MA
    Soo sick! If you end up needing another set of hands give me a call
  4. #804
    Jun 14 2007
    Connecticut
    Sweet Rich!!!! Can't wait to see your reactions with the car on these turbos. I'm up in the air with what I want to do later on this year or next. Let me know if you need anything like a file flashed, logs, place to stay, whatever the hell. haha
    VAST Performance Stage 3 B5 S4 | Videos
  5. #805
    Active Member Two Rings DarkSideGTI's Avatar
    Feb 05 2008
    SL,UT
    Looks like 3" inlets to me compared to the downpipes.
    2004 Big Turbo R32
  6. #806
    Nov 10 2009
    Somerville, MA/Palo Alto, CA
    Quote Originally Posted by zdriver View Post
    +1
  7. #807
    May 24 2009
    Boston
    Quote Originally Posted by DarkSideGTI View Post
    Correct! The turbo inlet is huge due to the ported shroud.
  8. #808
    Senior Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Quote Originally Posted by shorterthanrich View Post
    I plan to start pulling the motor during this upcoming week, and have it out by the weekend. I'll remove the old kit, clean up some oily things, and get this installed. Its not too much work, so I don't expect the car to be down for too long...
    I plan on buying turbos wednesday. let's have an install race! I'll take Frankie, you get Dave. Loser buys Leo's and beer.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
  9. #809
    May 24 2009
    Boston
    Quote Originally Posted by wdbdy2000s4 View Post
    Haha oh no, I feel like I've been here before. Another race to the finish.
    That said, no matter who has to buy the Leo's and beer, we all win. You're on!
  10. #810
    May 24 2009
    Boston
    Will do, man! Thanks for all of your help so far, too. I'll probably need some flashing action at some point...
    Hopefully these turbos will be awesome, and they'll be added to the list of turbos for you to consider doing next year, heh. All of the technical specs suggest that they'll be great, but we'll see.
  11. #811
    Senior Member Three Rings 2380S4's Avatar
    Jul 16 2008
    01 S4 08 328XI 90 Turbo Grand Prix
    Windy City!!!!!!
    Looking forward to see how these perform!!
    I'll be following this!
    GT2868/RS 2.8 motor build in progress!
    PM for powder coating!
  12. #812
    May 24 2009
    Boston
    This is what we did Saturday:
    So, the motor's out, old turbos and manifolds are off. I'm replacing some cam seals and probably a cam tensioner to hopefully get rid of some pesky oil leaks. The passenger's side are done, and the valve cover gaskets will be replaced this week, too. I'm concerned my front main seal is leaking, and I so don't feel like dealing with that.
    At any rate, things are looking pretty good for a decent turn around time! The remaining to-do list off the top of my head is:
    -Replace Passenger Valve Cover Gaskets
    -Replace Driver's side Cam Tensioner
    -Replace Driver's side Cam Seals
    -Replace Driver's side Valve Cover Gaskets
    -Maybe replace front main seal?
    -Reinstall timing components and front accessories
    -Replace Oil Level Sensor
    -Delete some vacuum lines (off the turbo inlets)
    -Maybe build a spider hose replacement because I hate the stock setup?
    -Maybe pull off transmission to see what's up with my clutch pedal vibration at high RPMs...
    -Install new turbos, manifolds, wastegates, and downpipes
    -Reinstall everything
    -Driiiiiiiive
    I'm sure I'm forgetting some things, but I feel good about where is stands now.
  13. #813
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    What's your current best time for a motor pull? Dave's is probably like 37 minutes? lol
    Quick work, hopefully the GTXs and kit bolt up without drama.
  14. #814
    May 24 2009
    Boston
    Quote Originally Posted by Matt Danger View Post
    My record from the time the car's on the lift until the engine is out, and the car's out of the shop is 3.5 hours with friends helping, which we did yesterday. Dave's record is, I believe 1 hour and 37 minutes, hah, and he averages around 2-3 hours casually if someone else is helping. Crazy.
    So far only a few modifications have been necessary. The passenger side exhaust manifold was just nicking the corner of the head, but it only took a few minutes to file down the corner. There also seemed to be a burr on one of the v-bands connecting the driver's side turbo to the manifold, and again, some quick filing took care of that. Test fitting the wastegates went well, and the v-bands are much healthier than my old set, so I'm hopeful there.
  15. #815
    Oct 08 2008
    MA
    Call me whenever you head down to work on it. I enjoy drinking while you use the engine bay as a jungle-gym.
  16. #816
    Veteran Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    phil, rich, come down tonight.
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    i know, i got problems. and the cure is more B5s!!!
    going to start selling 3 Stage 3 S4s pretty soon ...
  17. #817
    May 24 2009
    Boston
    hahaha, I wish there was a picture of me doing that.
    Will do! The next things are simple, mostly one person jobs, but when the car goes back in maybe I'll bring my kegerator down to the shop so you can drink as much as you want, haha.
  18. #818
    Sep 14 2009
    s.e. mass
    You make the switch to Tial wastegates? I'm about to ditch mine I was provided...
    Nice progress, I'm getting there as well... need to pay Dave a visit for some of the odds/ends I'm missing and get crankin'!
  19. #819
    May 24 2009
    Boston
    All of the cam seals as well as the driver's side cam tensioner are done. I also have all the old silicon pulled up out of the valve cover valleys. Sweet!
    I have to say, working on the passenger side head made me feel kind of sick...hah. It reminds me too much of last year replacing the head... it was the exact same month last year, too. :: shudders ::
    What do you guys think about making a spider hose out of heater core hose? 5/8" hose? Is heater core hose corroded by oil?
    The remaining list... somehow it seems just as long as it did before, even though I spent a few hours on it last night.
    The List:
    -Check to make sure I didn't screw up any oil valleys with silicon on the passenger side head
    -Delete some vacuum lines (off the turbo inlets, and across the fuel rail)
    -Delete one of the green check valves
    -Build a spider hose replacement out of heater core hose because I hate the stock setup
    -Driiiiiiiive
  20. #820
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L, 2012 Golf TDI w/Tech
    Potomac, MD
    I used heater hose for my Catch Can. I just recently got my hands on some 3/4" fuel line from Summit Racing and switched that. It will handle the oil a lot better than the heater hose.
  21. #821
    Jan 17 2010
    Boston, MA
    I used mostly fuel line and some heater hose, no issues over 10k miles
  22. #822
  23. #823
    Senior Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    --2001 s4 **
    nj
    This is AWESOME!
    Timing is Everything
    //J-Fonz tuned b5 s4
  24. #824
    Active Member Two Rings mushasho's Avatar
    Dec 09 2007
    Northern MA
    Just the thought of what this translates into once you're done... it might be more than you expected...
    1995 ^ VEMS ^ RS2 EM ^ 60lb FI ^ T04E ^ Stromung Gen4/Gen3 DP ^ EDU 6Speed ^ EFI Express 1.8T Coils ^ Samcos ^ 18" OEM CH ^ Pirelli P7 ^ 29971/Bilstein ^ IGOR CamberPlates ^ Clear Corner ^ SB DXD STG4 ^ Auto Meter 5703 A-Pillar Boost Gauge ^ HRSB ^ A6 HID ^ Euro Lenses ^
  25. #825
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    Mother of god
    StrictlyEuros ::: Web
    J-Fonz Tuning
  26. #826
    Jul 16 2008
    Windy City!!!!!!
    Wow that's pretty impressive!
  27. #827
    May 24 2009
    Boston
    Quote Originally Posted by Max@034 View Post
    Any good stuff over the weekend?
    Yes! I wasn't able to spend a ton of time at the shop, but I made my new custom spider hose with DxCs expertise. There were so many opportunities for leaks with my old one, but now I'm pretty confident that it'll be completely leak free on that end. I'll post up pictures soon, but if you'd like one just like what we built, PM DxC. I also took care of a few more odds and ends, but that's about it. I think I'll replace the front main seal today and put all of the timing components back on tonight so I can finally bolt up the new turbo kit!
    Quote Originally Posted by mushasho View Post
    Haha, YES! I did a ridiculous amount of research before I decided to pull my motor, and that was one of the convincing charts, as well as plotting our motor for these turbos. I should be very happily in the efficiency range, and its possible to see a similar top end as what EvilEvo has, though I don't want to get my hopes up. Not to mention I have a single disk clutch, and my single fuel pump will start to run out. But, in the future I can easily upgrade those two things and theoretically support a whole bunch more power! Sweet!
    Like I said, I'm really hoping for something in the 525-550whp range, which these turbos are beyond capable of producing on paper. Many people are reporting DiscoPotato spool, too...and with this tial housing instead of that other terrible one that I had...I'm looking forward to better spool across the board...
  28. #828
    Dec 09 2007
    Northern MA
    pick up the phone... I'm calling you... never mind,.. you just did...
  29. #829
    Jan 17 2010
    Boston, MA
    Damn, hadnt seen that yet! Impressive stuff
  30. #830
    May 24 2009
    Boston
    Yeah man, I'm pumped about it. How's your car running?
  31. #831
    Dec 09 2007
    Northern MA
    A more detailed map of the this turbo...(and a shameless bump for the 1st GTX build)
  32. #832
    Jan 17 2010
    Boston, MA
    Running so strong, unfortunately got an offer I couldn't refuse and sold it on Sunday : /
  33. #833
    Nov 16 2006
    Boston
    i srsly almost dropped a chevy 2500 truck on your engine which is why i sent you a cell phone pic. come clean it up/finish it up man ... at this pace it will be here for a year
    1999 Black A4 Avant
  34. #834
    May 24 2009
    Boston
    Quote Originally Posted by DxC View Post
    Sorry man, I've been working till 9 almost every night and on Sundays. I'll be there all day tomorrow and Sunday hopefully.
  35. #835
    May 24 2009
    Boston
    Alright - motor's all timed back up, accessories re-mounted.
    -Delete stupid unnecessary vacuum lines (off the turbo inlets, and across the fuel rail)
    -Delete two green check-valves and some more vac lines
    -Install new turbos, manifolds, waste-gates, and downpipes
    -Driiiiiiiive
    The list is looking much shorter... If I actually find more time for the car, it could be ready to go in this weekend...and then I'll be out of town for the next 4 weekends...brutal.
  36. #836
    Dec 09 2007
    Northern MA
    43minutes before midnight... Devotion!
    Sent from my NexusHD2 using Tapatalk
  37. #837
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    How did I miss this, pretty interesting turbo selection...
    What psi are you planning to run ?
    Anything under 24 t 25 psi, there wont be much differences with than running regular 28rs. These turbos are crafted to run over 30 psi to outperform regular cast wheels.
    then again you had 2560's...
    I'm in for pleasenat results ahead
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
  38. #838
    May 24 2009
    Boston
    Quote Originally Posted by GURUMAN View Post
    Hey Guru - happy to have you in the thread.
    I'm planning to run whatever it takes to make real power. I'm figuring somewhere around 30 PSI given my fueling (single Bosch 044)...
    Anything is going to feel better than those garbage turbos that I had. Tiny compressor wheel + giant turbine housing = slow.
    Anyway, I'm willing to run whatever it takes. I'm hoping for the best in the low 30s, and as I gain some cash over time, perhaps upgrade to a twin 044 setup and a clutch that can hold more power
    That said, I'm still hoping to put down decent power and run comfortably in the 11s on my street setup. I won't be devastated if I don't, but I think its a reasonable goal.
  39. #839
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    Don't stop at 30psi. We just made 420awhp on 93+meth with one GTX3071R on a pretty bone stock 1.8T. 37psi was the most we cranked it out, smooth as butter with that boost. These turbos need that high boost to make the power
  40. #840
    May 24 2009
    Boston
    Quote Originally Posted by Clint@R.A.I. View Post
    Crazy! I'm not really accustomed to running such high boost... What components should I consider keeping an eye on, modifying, or upgrading in order to handle mid 30s and above?
