Results 1 to 8 of 8
    Veteran Member Three Rings Satummoo's Avatar
    May 04 2009
    Boulder, CO
    Car Clicks & Clunks when turning left - Searched and need Help
    Recently, i've noticed that when I am going from a stop to around 15mph while turning left, the front end of the car makes a clicking noise. Now here is some backround about the car:
    Backround
    -I've recently bought the car, and had the timing belt changed right after I bought it. Now I've never noticed the noise until after the timing belt job BUT, I've only driven the car proboly a total of 30 miles before the timing belt after I bought it.
    -The control arms were recently changed (from previous owner at dealer) I don't know how many but I belive on both sides
    Things i've checked through via SEARCH
    -Power Stearing: Aparently a way to check the pump and fluid levels is to turn the stearing wheel all the way left and right when parked. I did this and heard no noise
    -Control Arms: these seem to be the usual culprit but they were aparently changed (and by visual inspection) they seem so but I can't confirm how many were done
    One important thing to note is that the clicking noise increases by the amount of increasing speed. I would imagine this would be a major factor in diagnosing the problem.
    Any insight would be appreciated, I'd like to get this fixed.
    2014 Jetta 1.8t 5spd
    Just OEM+
    Dec 14 2006
    Halifax, NS, Canada
    Re: Car Clicks & Clunks when turning left - Searched and need Help
    u need a new cv joint / axle
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Senior Member Two Rings DonnieD's Avatar
    May 19 2008
    2001.5 Pearl White Audi S4
    Quote Originally Posted by Squarrl View Post
    Agreed.
    Veteran Member Three Rings BSig A4's Avatar
    Dec 26 2007
    Orange County
    hey bud i have the same damn problem!!!
    but i have a b7 and its not the cv joint cause i had just got mine replaced on the side that it makes the noise on it actually started doing it 2 or 3 days after i had gotten the cv replaced and took it to the dealer and i i guess they couldnt find what was wrong is what they told me but im gunna take it back again soon if you find out whats wrong PM me cause i would LOVE to know haha
    Senior Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant, 2014 Honda Pilot Touring 4WD 2007 GSXR 600
    SF Bay Area
    third this...
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Established Member Two Rings DzeticVR's Avatar
    Jul 08 2008
    '98 VR6. '01 SAvant, '88 325is
    Atlanta, GA
    Quote Originally Posted by Jay B7 View Post
    third this...
    yep,, have the same problem,.. thorn cv's =(.. but then i have the passenger side axels in the same condition and it doesnt knock,... anyone know why?
    Manchester United FC
    May 04 2009
    Boulder, CO
    ok, i've been out of town, but have a few more questions:
    -It seems that I just need an outer CV joint + boot. Now, acording to the Raxles.com site, the side that needs to be replaced is opposite to the side you're turning
    " Continues "clicking" sounds on sharp turns usually indicates a worn outer joint.
    Usually the sound is loudest on the joint opposite of the turning direction."
    So I get the noise when I turn left, does this mean I need to replace the passenger side? It seems like the noise is from the driver side though but it's hard to tell.
    Also, should I replace the entire axle or just the outer joint. The price difference is huge but aparently "raxles don't break". Is Inner and outer CV joint and boot breakage a big problem with b5's?
    Also, raxles uses a different type of technology for their axles, if I replace one axle, will it affect suspension geometry?
    Just OEM+
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I run raxles on the front of my sdn and they work fine ,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    2001 S4 Avant TIP STG 0, Vast snub mount, 710N's, AWE boost gage, Tints, more to come...
    Turbo's are the Perfect Drug
