Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 401 to 440 of 453
  1. #401
    Senior Member Three Rings jibatnes's Avatar
    Jul 07 2011
    Norway
    Late 2005 mod with 50k on it. First follower change for this car.
    Bad pictures, i know. Sorry :)
  2. #402
    Dec 03 2008
    2014 Forester XT, lawn mower
    Castle Rock, Colorado
    Nice. That doesn't even really need to be changed, but might as well. Better safe than sorry.
    JR
    2012 Audi S4 Prestige 6 speed, 034 Stage 1, 034 SC pulley, USP Intake, custom x-pipe exhaust, 034 Trans Mount Insert, 034 Front/Rear Diff Mount Inserts, JHM Stage 3 clutch, JHM LWFW, USP SS clutch line, 034 boost tap, Podi boost gauge
  3. #403
    Established Member Two Rings whoosh's Avatar
    Feb 07 2009
    Belfast, Maine
    My nephews 2006 A4 with 66k miles was checked yesterday and it was bad. Bringing it to the dealer next week!
    The older I get the faster I was.
  4. #404
    Jul 19 2011
    Northern Minneapolis, MN
    2008, just over 75k, first change, the black wasnt
    New one:
    [FONT=Arial Narrow]Corey - BSME
    08 A4 6MT, Quattro, VAST Stg1, JOM C/O's, 034 RSB, BFI Snub - 24.75" FTG, 255/35-18 V12's
    ------------------> Buy my wheels/tires/spacers/bolts! <------------------
  5. #405
    Veteran Member Four Rings jrtrainor's Avatar
    May 07 2011
    2010 A6 3.0T
    San Francisco/CA
    52k apr stage 2 for last 8k, Metal was thin, to the point i could make it flex with my pinky finger and started to fracture from one of the four holes. all is well now with a shiny new part.
    B7 A4, GTX2867R 8.3:1 CR 2.149L motor Build
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    "Call him the Redneck mechanic with the beard of glory"
  6. #406
    Veteran Member Three Rings schmiesus's Avatar
    Jul 25 2011
    BC
    6,000 miles
    2007 A4 S-Line TI Brilliant Black - .......Not Stock
    Bought Not Built, Build!
  7. #407
    Veteran Member Four Rings Tanner's Avatar
    S4 / BRZ
    Markham, ON
    You have a damaged lobe.
    Mike
  8. #408
    Jul 19 2011
    Quote Originally Posted by Tanner View Post
    x2
  9. #409
    May 07 2011
    2010 A6 3.0T
    San Francisco/CA
    Who and how can you tell this?
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  10. #410
    Jul 25 2011
    BC
    i just had the cam shaft replaced. Now I'm pissed!
  11. #411
    Jul 25 2011
    BC
    Sent Audi the picture they're replacing the cam shaft on the 7th
    Thanks boys
  12. #412
    Registered Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Sioux Falls, SD
    Here's a question without making a thread.....I'm at 64k miles, never changed it yet.....What would be some symptoms thats its time to get it changed? Car has been running sluggish lateley, sounds like the engines working harder too.....Prolly time to get it done, does that mean I just bring the TSB to the dealership and they take it out and replace for free? I mean I got no CEL, but I just feel like its gotta be time to change it....Maybe I'm being noobish and wrong in my stupid assumption...clear this idiot in the right direction please Ziners.
    BB DTM B7 A4SOLD
    2015 Daytona Gray S4-Black with black Alacantra, B&O, Technology package, Carbon Atlas Inlays, RSD
    Parts on the car: AG M310 18", RS4 Grille, R8 oil Cap, roc euro intake, H&R Street Performance Coilovers, and awe exhaust with res. DP's
    Also in stable:
    2014 VW TDI SEL Passat
    Soon to be in stable:
    http://www.ebay.com/itm/Audi-RS4-Bas...178&rmvSB=true
  13. #413
    May 07 2011
    2010 A6 3.0T
    San Francisco/CA
    Just unplug the hpfp for a second run your car till code then take it in with everything reconnected and get yourself some freebies
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  14. #414
    Jan 29 2012
    None
    Sioux Falls, SD
    Seriously ?^^^^^^^
    BB DTM B7 A4SOLD
    Also in stable:
  15. #415
    Dec 03 2008
    Quote Originally Posted by Rodmar View Post
    Seriously ?^^^^^^^
    I don't know about all that, but, you should probably just check it yourself. You'll have a very hard time getting the dealer to check it with zero fault codes. But honestly, if you wait til you have fault codes, it's too late. This is kinda like the timing belt. It must be replaced BEFORE something goes wrong.
  16. #416
    Jan 29 2012
    None
    Sioux Falls, SD
    I'll be honest im no tech, and am missin some key tools to check it lol.....i already feel overwhelmed, but I can gauruntee its gotta be time for change
    BB DTM B7 A4SOLD
    Also in stable:
  17. #417
    S4 / BRZ
    Markham, ON
    Rodmar... just go to the dealer, tell them that you want the HPFP checked, if it's deemed okay, you'll cover the labour/parts (might as well replace the cam follower at this point, call it preventative maintenance), however, if they find that there is damage to the lobe/HPFP, then the parts/labour will be handled under warranty. If you get this done at an independent shop and there is damage, keep all parts and then submit a warranty claim to AOA.
    Mike
  18. #418
    May 07 2011
    2010 A6 3.0T
    San Francisco/CA
    Seriously ?^^^^^^^
    Why not. all your doing is unplugging a sensor, your car will begin to idle roughly and finally throw a code for the fuel pump. Forcing audi to open it up and check to see whats wrong. when they do if there is nothing wrong just pay them to put in a new cam follower which will cost you a couple bucks but labor is on them. IF and big IF there is something wrong they will extended warranty replace cam follower, cam and so on.
    Did this with a buddy who was interested in buying a used GTI from a private party, proposed the idea after we pulled the follower and discovered the destroyed cam lobe. Talked to the owner and we all agreed the logic was sound. Engine starved for fuel for a second tossed a code plugged it back in and of course the light disappears but the code is stored. Took it to local dealership and they replaced the cam and hpfp for free.
    now again this is just my .02 but it worked for us. worst case scenario they find nothing wrong and you pay to have them put a new cam follower in.
    But I'm just some dude on the internet don't trust me. I am in no way responsible for your car. You are! so I strongly suggest you do your own research. but this is how I solved a problem I was presented with. An idea not a guarantee.
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  19. #419
    Jan 29 2012
    None
    Sioux Falls, SD
    [QUOTE/]
    But I'm just some dude on the internet don't trust me.[/QUOTE]
    this HAHA
    BB DTM B7 A4SOLD
    Also in stable:
  20. #420
    May 07 2011
    2010 A6 3.0T
    San Francisco/CA
    [QUOTE/]
    this HAHA[/QUOTE]
    It's true haha for all you know I'm a 9 year old with access to a computer. It pays to figure stuff out for yourself. Or at least challenge what is suggested to you.
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  21. #421
    Jan 29 2012
    None
    Sioux Falls, SD
    which is why i asked if serious in hopes others would chime in lol......I don't wanna make mistakes costing $$$$$....
    BB DTM B7 A4SOLD
    Also in stable:
  22. #422
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
  23. #423
    Senior Member Three Rings A42007's Avatar
    Jan 12 2011
    07 A4, 1989 Jeep Cherokee
    Phoenix, AZ
    Just replaced mine, Chipped at 29K and now have 52K on the clock. I drive pretty hard, enough to have already gone through two axles! I expected it to be much worse. Better safe than sorry though.
    Also I am TIP, FWD
    Pics -
    Also My Spark Plugs looked like shit so I changed those as well!
    My Build Thread - http://www.audizine.com/forum/showth...di-07-A4-Build.
    2007 B7 A4 - APR Stage II / Magna Flow Cat Back / 2.5" TP / ST Coilovers / 19x8.5 ET 32 RS6 Reps / Aftermarket Navigation / 235/35 Hankook Ventus V12 Evo's.
  24. #424
    Sep 27 2008
    Phoenix
    First follower used for 37k miles, stage 1 for 20k. 2nd follower used for 20k miles stage 2 for 7k.
  25. #425
    Senior Member Two Rings QuattroTi's Avatar
    Aug 21 2011
    Yamaha 50th Anniversary R6
    South Florida
    Wasn't getting any codes, did it for preventive maintenance.
    2008 A4 Quattro 6MT with ~65,500 miles on the clock; APR Stage 1 at ~50k and Stage 2 at ~55k. No banjo bolt so it was cake. Mobile 1 0w40 for the last 4 oil changes.
    2008 A4 2.0T Quattro 6MT Titanium Package
    APR Stage 2 - RAI TP/DP - AFE ProDry Drop In - 034 Turbo Inlet Hose - Apikol Snub/Transmission Mount - Koni Sport (Yellow) shocks - Eibach Pro springs - 034 Adjustable Control Arms - JHM Solid Short Shifter - Seibon Carbon Fiber Hood - Color Matched Cupra R lip - LLumar 15% tint all around 30% windshield -
  26. #426
    Registered User Three Rings hpfpupgrade's Avatar
    Aug 10 2011
    Auburn, WA
    Nobody has made mention yet but we have an upgrade to the OEM cam follower.
    Here is the link:
    http://hpfpupgrade.com/Products/Show...e+Cam+Follower
    This is a huge upgrade over the OEM unit.
    Thanks,
    John
  27. #427
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 Audi Q5, '91 VW Jetta GL wolfy
    Cleveland OH Area
    Just replaced the cam follower finally while switching my hpfp for an APR one, first time doing it myself. Definitely need to do it more often, think this one had about 35-40k on it which is wayyy to much. Luckily no damage to the original fuel pump!
    '01.5 APR S3 S4 Avant 6 Speed - current
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Audi Q5 2.0T P+ - current
    '05 Ford F250 XLT 4x4 Powerstroke - current
    '91 Jetta GL 1.8 8v manual swap - sold
    '99 SVT Cobra - sold
    '01 Mustang GT - sold
    '88 Mustang LX 5.0 - sold
    '95 Jeep Cherokee Country - sold
  28. #428
    Established Member Two Rings king505's Avatar
    Jan 13 2009
    2005.5 B7 A4 2.0T Q TIP
    84,386miles, Stock, 2005.5, First time follower has been changed, was expecting much worse, happy there was not a hole when I changed this.
  29. #429
    Sep 12 2009
    Edmonton, Canada
    At 198,000 km the car was running fine, but my cam follower was a mess. I was 6,000 km past Audi's warranty, so I contacted Audi Canada to show them that the damage clearly started before the last 6000 km. No dice. I swapped the fuel pump and cam follower, and gave it 7000 km before opening things up again. I assumed the cam lobe was damaged, but was surprised to see the second follower looked pretty good. I swapped it out anyway and gave it another 15,000 km. The third one came out a little more worn, but still had some decent thickness to it. I swapped it again this weekend, and will give the new one 20,000 km. That should be in about 4-5 months. The car is stock.
  30. #430
    FAQ: Official Thread for your Cam Follower(s).
    Just got around to finally looking at mine. Car is a 2006 A4, quattro, tiptronic, and has 74,000 mi. at time of replacement. I've owned it since 65,000 mi. and had no prior maintenance records...
    Looks pretty good, huh? Not at all what I was expecting to see. I replaced my coils and plugs at this time due to misfire issues, and I also changed the fuel filter.
    The day after I swapped followers the car threw a CEL and I about poo'd myself, but it was running awesome. phew, seemingly unrelated.
    P.S. That banjo bolt sucks
  31. #431
    Jul 20 2012
    2016 GMC Yukon SLT
    Oregon City, Oregon
    Just replace my cam follower for the first time. Its a 2008 with 77k miles on it. Its been APR stage 1 since 25k miles. Follower and pump are in perfect condition. Since I was in there I replaced it with the new one I had on the shelf.
  32. #432
    Senior Member Three Rings Kingzilla17's Avatar
    May 05 2011
    Arlington, Texas
    Replaced mines yesterday. 72k and it looked decent. Was not that bad of a job. The bonjo bolt was actually pretty simple for me. I had a harder time removing the high pressure hose for some reason. Next time should be quicker. All liked good. I'll post a pic of the actual follower I took out in a few but here is the "wear"
    06 Arctic White Audi A4 Quattro: |Solo-Werks Coilovers, OEM Bi-Xenon blacked out w/ STi Clear lens & CC mod, Hoen yellow fogs, 18'' Avus wheels, LED reverse lights, Thule Aero roof rack w/ Thule Evolution 1600 box|
  33. #433
    Active Member Two Rings srlbotanical's Avatar
    Mar 14 2014
    Saranac, MI
    2006 2.0T 128K
    I have only had this car for about 6 weeks, and took a gamble. The price was great, but I had no follower history from the PO.
    I changed out the follower the same week I got the car.
    What a relief.
    I think it's safe to say that this is not the original CF on this car.
    2006 AUDI A4 QUATTRO 2.0T - Daily Driver
    1997 JEEP TJ 4.0 Locked on 35's - Trail Rig
  34. #434
    Mar 24 2013
    A7
    Griswold, CT
    Quote Originally Posted by brew_daugus View Post
    Replace your N80 valve and I bet that code goes away. It's easy to install and only costs about $20.
    -Adam
  35. #435
    Senior Member Two Rings esm's Avatar
    Jan 14 2010
    Chicago, IL
    Is there a DIY with pictures to change the follower?
    2017 Audi Q7 3.0T Premium Plus: Vision / Cold Weather / OEM 20" 10-Spoke Wheels / Goodyear Eagle Sport All-Season Run Flats 285x45x20 / Weathertech Mats
    FORMER: 2005.5 A4 Quattro Tip / JHM Stage 2 93oct / JHM HPFP / AWE FMIC / JHM 3" Downpipe-Y adapter / JHM-Fast Intentions S4 Exhaust / RS4 RSB / Bilstein PSS9 Coils / VMR 810 19x8.5 on 245x35x19 Michelin Pilot Super Sports / Adam's AR II Slotted Rotors / Bosch Platinum Sidefire Plugs (Bosch Heat Range 5)
  36. #436
    Senior Member Two Rings bryonm's Avatar
    Jun 02 2013
    Mililani, Hawaii
    What's the best way/tool to get the closest screw to the fire wall
  37. #437
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Was just doing some searching prior to doing this job today, as I have a 2008 and had read that later models don't have the pesky banjo fitting that seems to give so many issues and ran across this DIY. Didn't search through every page of this thread to see if someone had already posted it up, but hopefully it helps someone else out as it answered my question about the banjo and relieved a little anxiety about doing this for the first time today. My car has 81k miles on it and I just bought it, so this is basically the first mechanical item I am going to do with the car. Wil post up pics later of what mine looked like. Happy viewing!
    http://youtu.be/NpUSLl0Qiyc
    Jason - 2012 Glacier A4 Avant - Prestige - S-Line - Titanium
    | APR K04 w/APR V3.1 Files | APR Carbonio | BB HFC | AWE 3" DP | EC FMIC & Crank Pulley | GFB DV+ | H&R SS Coilovers & F&R Sways | SPC Adj. UCA's | 034 Rear Diff& Trans Inserts | ECS Skid Plate | Euro RS4 FBSW w/Extended Paddles | FL S-Line Shift Knob Retro | 3G + MMI Retro | FL Clim Cont Retro |
  38. #438
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Just did mine for the first time using the video linked above. Car is an '08 w/o the banjo fitting so was able to follow the video exactly and it took me (all anal organizing and fumbling aside) about 30 mins. Super easy and was very happy with the results. For reference, the first pic is of the new follower I ordered form JHM for $35.
    http://jhmotorsports.com/shop/catalo...h=21_62_65_255
    [IMG][/IMG]
    [IMG][/IMG]
    The following is a few pics of my follower at 81k miles. As I said, I really had no way to know if it had been done previously (bought the car a week ago), but looking at the condition of this one, I will assume it had been. The black protective finish was worn off the face and the machining worn off the body of the follower, but otherwise it was in really great shape!
    [IMG][/IMG]
    [IMG][/IMG]
  39. #439
    May 14 2014
    93 300zx, 01 MR-S, 07 a4, 99 a4 avant
    Auburn, WA.
    replaced mine a week after getting the car with a 105k on the odometer. Little rough on the follower but the cam looked good.
  40. #440
    Established Member Two Rings redcon1's Avatar
    Oct 22 2009
    '99.5 GTI VR6, '13 Touareg Sport V6/FSI
    South Central PA
    Replaced mine tonight on my 2008 B7 with 123,842 miles. No symptoms of failure but I wanted to have the peace of mind.
    Here it is, not bad at all, and the cam lobe looked great.
    Dave
    2008 A4 Avant S-line/TI
    2013 Touareg Sport V6 FSI
