Four Rings
Re: Followaar:Official Thread for your Cam Follower(s).
^^Yes!! That is the lesson learned here!!
'05 A4 2.0T Quattro MT APR Stage 3
2008 APR Holiday Giveaway Winner!! Thanks APR!!
FRRG Southern Ring
Xbox Live ID: Sqzn2zz
Four Rings
Hyphy you are just gangsta!! thats why your name is Hyphy!
FRRG Southern Ring
Senior Member
Four Rings
*edited to keep this thread on topic*
Nick
Nick
instagrams - tehcapo
Senior Member
Four Rings
Nick
Four Rings
 Originally Posted by Hyphy
HAHAHAHA....i had too....
or this!!
 LOL! (That's not me either!)
Liar!! The name says it!! lol
Ok, really back on topic. Sent Mike at APR a message, he is the mechanical engineer over there so hopefully he will shine some light.
FRRG Southern Ring
Senior Member
Four Rings
Alrighty- let us know what's up..
Nick
Four Rings
FRRG Southern Ring
Four Rings
05.5 B7 A4 6sp AWD Quartz Gray 179,000mi I like to drive!
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
Four Rings
well my buddy just text me and told me that my APR fuel pump is shot!! FML!! Guess im going to have to run the autotech one for now. Leaving work now and going to his work to see whats up. Ill post up later and let everyone know whats up. Dang this sucks! $1K down the drain :(
FRRG Southern Ring
Four Rings
Awww man i'm very sorry to hear this!!!!!
vizi
Senior Member
Four Rings
Nick
Four Rings
For BT people it looks you now need the following spare parts handy at all times!
1.Cam Follower
2.HPFP
vizi
friend of mine said they installed an APR pump on a GTI (fsi) this week.. he said the pumps are definitely not new, it was even dirtyer than the stock pump being removed.. and there was a core charge on top of that..
Guess it depends how much or little the previous used pump was used before they "upgraded" it.. I will follow this thread
Four Rings
Ok, so i have my car back now, running my Autotech pump and everything seems fine. Had to replace my MAF sensor as well. Ill have to give APR a call and see if they can do anything about the pump. Im thinking it was something internally so ill see whats up. When i got my fuel pump from them it was nice and clean. I mean everything cant be perfect must have had a defective part or something. Im not too worried about it, Im just glad that i had a spare one to use, i would be on stock mode right now and i would have not been a happy camper. lol
So yeah lessons learned, if you have a BT definately keep an extra follower around, think ill go ahead and order KMD's follower since its like crazy big and just have it as a stand by. Hope this doesnt scare anyone away from getting a BT, this just happend to me cause i didnt keep a close eye on my follower. Especially with the HPFP it wears out quickly!
FRRG Southern Ring
Four Rings
Well I wouldn't say you neglected the follower or your fault, I mean this is still kinda all new territory when it comes to BT's and these cars.
Yea ive gotton 100k+ miles from mine in stock form (not upgraded) but to know the limits on the upgraded pump is still new territory..... Now being it is new territory yes you should have checked it sooner, but i don't think anyone expected it to go THIS soon....JMO
vizi
Four Rings
^^Yeah i feel you, but i now know to keep a more closer eye on it. So we will see how many miles the new one holds up.
FRRG Southern Ring
Four Rings
Sorry, I just found this thread while browsing for potential 2.0T problems.
Can somebody clarify 2 things, quickly?
1. How long does it take to check (and/or replace) the follower? I see the steps and 150 pictures (haha!) but I can't really guess as to the time it'd take. Doing it every oil change seems crazy if it takes an hour or more.
2. If buying a bone stock 06 A4 2.0TQM, should I be worried about this thing at 70k miles or so? I read that this is prevalent on all the cars... stock through stage 3.
I'm thinking I love my 1.8T and how simple it is. :)
Senior Member
Four Rings
1. Your first time, it should take you a good hour. After that you will know how to do it in a faster/more efficient way. It's not a big deal (checking it wise) if you are completely stock. But, once you hit the mod bug, it's extremely recommended to check it as often as you change your oil...It will save you"$X,XXX".
2. At 70k miles, yes, it will be one of those 'things' that you wanna keep up to date (if you will).
If you really do like your 1.8, why not just keep it? Our motors are shitty. Well, not our motors, but our fueling system is..
edit: Hope this helps..and thanks for looking!
Nick
Senior Member
Four Rings
1.Cam Follower
2.HPFP
Yup. You will need to have these on hand. Thanks Vizi
Nick
Four Rings
I actually am forced to keep this next car very stock. I'm moving to a place that resembles the surface of the bloody moon. My car now is low, on 19's, and I fear it will be destroyed in my new home.
I just bought a house and I'm after something practical... I've been looking at other B6's, but I've considered the B7 as well (better fuel economy, no 'need' to chip it).
The most I would ever do to this car is a chip... and I'll resist that (perhaps indefinitely). Should I still be concerned? I am cool with checking the follower... but I don't want to deal with too much else. By and large, the 1.8T is a reliable motor. I'm hoping the 2.0T is the same. The 1.8T has quirks... sounds like the 2.0T does as well. I just don't want any horrifying surprises.
Thoughts?
Senior Member
Four Rings
Thoughts?
In that case, the b7 would be right for you. Not too many cases that i have seen. Just normal minor little bumps in the road such as the DV, PCV, Cam follower...With the chip on the b7 you will/should be okay (no surprises). Just have that little "responsibility" light go off in your head every oil change and you'll be one happy camper! Let me know if there is anything else, that I or whoever can help w/...
Nick
Nick
Four Rings
Thanks a million Nick. I'll see what happens with my B6. I feel better about the B7 already. All this reading tonight made me leery... but you read a lot more about the bad than the good when you're in a forum. I should check out the chatterbox thread where fun things are happening. :P
Four Rings
^^Word on the street is that KMD's follower doesn't have the same diamond-like coating on it that the OEM does, and therefore it will actually wear quicker than the OEM. But, it's thicker so supposedly it takes longer to wear all the way through it. To me this means the KMD will just take more beatings, but all that beat up metal looks like more potential for scarring on the cam lobe.
'06 2.0T S-line Tip
Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, APR 91 & 100, E-code testpipe, 18" Wed'sSports w/ Toyo R888 (track), 19" Tenzo-R's w/ 265/30 all corners (street), Stern upper arms, upgraded stereo crap, Huper tint, RS4 grill, catch can, headache, backache, walletache
Three Rings
I had mine checked at my 55k serving last week and I fell prey to it also like Sal B7 did out of warranty...
My follower completely was gone also. Chipped at 20k for past 35k miles....
My car actually went in 034 Motorsports today to get the revised oem camshaft and hpfp because of damage caused
hopefully should be all good by this afternoon
Pics:
Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
Senior Member
Four Rings
stock cam follower and FP blew?
Three Rings
both my hpfp and my camshaft got damaged to the point of replacement
Senior Member
Four Rings
i meant to ask, previous to it being damaged was everything stock?
Senior Member
Four Rings
Three Rings
Senior Member
Four Rings
oh ok sorry to hear must be a expensive fix
Senior Member
Four Rings
ouch...
Nick
Senior Member
Four Rings
Mine just got replaced as well. I have 600miles left of Factory warranty. I got good news and bad news. My good news was that the parts were in stock. The bad news was that I needed a new camshaft/follower etc.
Three Rings
034 motorsports installed the revised camshaft, hpfp, and a new cam follower.
the car is running strong like it never has before! i love it. lol
and yes it was a expensive fix
Three Rings
Guess I'll have to change it then....WHAAAAAA!!!!
Senior Member
Three Rings
one quick question here as i attempt to take off my FP, how the heck are you guys able to even gain access to the high pressure output compression fitting? theres just no easy way to get a crescent or 17mm wrench in there..im stuck
Four Rings
Dang bro, sorry to hear!! I was lucky and got to it before my cam got damaged. Going to send my APR HPFP back to APR along with my stock FP internals and Mike is going to switch the parts for me and test it to make sure its all good. Running my autotech pump right now. Good thing i had a spare!
Glad you got it up and running and running awesome!
FRRG Southern Ring
Three Rings
^ yeah thanks. just need to pick up the 034 HFC now
and everyone make sure you get this shit checked out, it sucks if it you have this issue
Senior Member
Four Rings
Hey guys so you guys with stock FP take a look at this http://www.audizine.com/classifieds/...?product=18209
Senior Member
Three Rings
YAAAY, just pulled the FP today. whew, only had a bad follower, no lobe issues or FP wear. but the follower did have a gaping hole in it.
old follower-
new follower-
FP-
Are the 2008 B7 affected by this cam follower issue? Is there a date/vin range that we know of?
- You may not post replies
- You may not edit your posts
Forum Rules
