Page 1 of 7 123 ... LastLast
Results 1 to 40 of 260
    Active Member Two Rings The Russian's Avatar
    Dec 01 2008
    Boulder, CO
    4.2 swap into 2001 A4
    I know there is already another member doing this swap, but this one is a bit different due to different model V8. BTW this is not a competition of any sort i hope we can both help each-other out with this.
    after months and months of research I took the first step today.
    I have a 2000 A6 4.2L engine with 62k miles. It is the drive by wire engine so it will be virtually a direct plug and play with my 2001 drive by wire chassis because all of the plugs are the same. I have the ECU and the entire wiring harness that came with the complete motor assembly...
    Did the first test fit today to see if it is possible to mount the V8 onto my 5spd trans. IT IS! this means that i am not going to need to modify any of my driveline. Plus for the purpose that I need the 5 speed gearing will me much more usable with this power range, not to mention the 5 speed is a bit more reliable that the 6spd.
    To make it work we used an S4 flywheel spacer so that the crank position sensor lined up with the RS4 flywheel. With that all in place the 5 speed clears the clutch assembly with no interference. I do still have to modify the spacer for a starter bolt hole.
    RS4 Stage 3 performance clutch kit that makes everything work.
    2001 A4 4.2L v8 quattro 5spd: 4.2L V8 swap | Tein SS Coilovers | Straight Piped side exhaust | StopTech Brakes | Custom aluminum radiator | Full Cage | much more...
    1983 Porsche 944: Daily Driver
    2001 Ducati 748: geared down | dry clutch | Termignoni
    Carbon Exhaust
    Veteran Member Four Rings Nebone's Avatar
    2005.5 Audi A4 2.0T Avant
    Cumberland, RI
    Re: 4.2 swap into 2001 A4
    Very nice. You seem to finish projects quick so this should be no exception
    Dolphin Gray 2005.5 Audi A4 2.0T Avant 6MT
    Santorin Blue Pearl Effect 2001.5 Audi A4 1.8T Sedan 5MT
    Unitronic Stage 2+ 386cc
    RI Tires
    Dec 01 2008
    Boulder, CO
    yeha hopefully the extra $2000 i spent on a drive by wire engine rather than the older drive by cable will make this more manageable. Going to get all the parts ordered this week and the plan is to switch the two motors out next monday. I'll put up pics as the come.
    Carbon Exhaust
    Senior Member Three Rings projectb7's Avatar
    Mar 20 2009
    1989 BMW 325i four door waiting for a 3.5 turbo swap. 2007 Chevy Impala
    Albuquerque NM
    Subscribing... This sounds like a cool swap and can't wait for the results. GOOD LUCK!
    Schnell Weg? RICHTIG!
    Ryan
    Senior Member Four Rings JEmm's Avatar
    Apr 27 2009
    00 A4 1.8TQM
    New Jersey/Boston
    sounds awesome! how much power do you expect to have at the wheels?
    -Jeff
    2000 SILVER A4 1.8TQM
    euroaddiction
    N.E.R.D.
    F.T.W.L.T.B.D.W.I.C.T.W.
    Checho: bro the crabs I got from that stripper on friday are more appealing than those wheels.
    Marty: Why do I always have to be the designated d!ck?
    Senior Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Always diggin in deep arent you russian! Cant wait to see a local v8 swapped a4. Pleasse tell me you have plans to turbo it tho... That would be pure sex!
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Nice project!
    Bear in mind, the 40V engine is larger than the 32V - both in terms of width as well as length.
    Are you going to retain aircon?? Because, no room for the electric fan, not in its stock location at any rate.
    Dec 01 2008
    Boulder, CO
    Quote Originally Posted by Siena View Post
    Nice project!
    Yeah I'm going to have to play around with fan ssetups, probably end up putting them infront of the radiator like you did... From what I've measured so far the width should be in the clear and length wise I might need to chop the first firewalls bit but should clear to the radiator, we will find all this out next Monday I guess :)
    Carbon Exhaust
    Senior Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    I wish it was Monday....
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    Wow! Cool to see another V8 going in a B5.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 01 2008
    Boulder, CO
    did some machining today, got a piece made up for the trans spacer that is needed to place a hole for the starter bolts. Machined it down so that its the exact thickness so that there is no strain on any of the other components. Tomorrow, I will get the piece welded on so i can drill the rest of the hole out and then put it on the engine block which will allow me to use the RS4 clutch and flywheel and use my 5spd and stock sensor positions...
    Carbon Exhaust
    Active Member Two Rings STS9king's Avatar
    Apr 27 2009
    Denver
    Is Troy helping you with this?
    1999 A4 Avant: gt3071r, Tapp 630cc software (91 octane mode only), apr exhaust mani (t25), SB stage 4 clutch, 034 track density motor/tranny mounts, wahlbro 255, porsche brakes, h&r sports w/ bilstiens, rs4 wheels, turbo timer, JHM solid linkage and bushings, e-code lights, 3" custom turbo back, Treadstone 666hp core FMIC: 13.7@101mph (6000' altitude)
    (old ride) 01 1.8t jetta: t3/t4 13.3@107mph (6000' altitude)
    Need a realtor in Denver with a fast car?
    Dec 01 2008
    Boulder, CO
    Quote Originally Posted by STS9king View Post
    Troy was supposed to but he quit from 3zero3, so it is mostly me and scott, as part of their sponsorship they are letting me use the facilities and their knowledge lol
    Carbon Exhaust
    Jan 09 2008
    United Kingdom
    You're best off running a single-mass flywheel, that way you won't need the spacer.
    The spacer is 11,2mm thick, that's more forward length you don't want in your already tight engine bay.
    Not much room to move rearwards either, especially if you're running a stock 5-speed propshaft, which is longer than the 6-speed one.
    Dec 01 2008
    Boulder, CO
    yeah, we'll see how it all works out, trying to do it the most cost effective way, and I already had an RS4 clutch kit... the plan is to redo the cooling system anyway so that there is some extra room. Spacer is complete.
    Carbon Exhaust
    Senior Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 1.8TQM 00 A6 Widebody
    Lombard, IL
    You should make somewhat of a DIY, that would be amazing.
    Brilliant Black B5 ..... 15k on Street Built Engine
    Strictly Pleasure/Zero Clearance/Stretch Your Legs
    Alex
    Will work on Audi/VW in Chicagoland
    Senior Member Four Rings McGovs2.7TB5's Avatar
    May 28 2008
    Subscribed. Cant wait to see it person.
    01.5 Brilliant Black S4 avant - JFonz 2+ / Piggies+SSAC / X34 intake / ST coils / Podi Stepper / A8 flat fives
    yeah it's a tip
    Active Member Two Rings Flash's Avatar
    Oct 13 2006
    Earth
    Sweet! Another one. Thanks for sharing with us! Seeing this kind of thing is very inspiring. It makes me want to follow suit after I finish my RX-7.
    Jan 15 2007
    san jose
    this is awsome
    Active Member Two Rings acollicott's Avatar
    Nov 13 2007
    2000 A4 1.8TQM
    Daytona Beach
    Looks awesome
    Dont forget LOTS of pics :D
    00 A4 1.8TQM | Santorin Blue | GIAC | Forge 007P | Pioneer AvicD3 | Southbend Stage III | N75 Race | Swiss Cheese Airbox | Boost Gauge | Sport Suspension | Windows Tinted | HIDs |Custom TI Package |
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    can't believe someone else is doing this. can't wait for the result
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Dec 01 2008
    Boulder, CO
    gone.
    $1700 OBO, 90k miles, new timing belt at 82k miles, driven softly
    Truck bed liner makes it pretty :)
    RS4 clutch and flywheel on the V8 now.
    Carbon Exhaust
    Jan 09 2008
    United Kingdom
    Good work, can't wait to see the mounted pictures.
    Dec 01 2008
    Boulder, CO
    so what a wonderfull way to spend my birthday, sweating and fighting with a V8
    had to pull the trans because it was impossible to attach the motor with it in the car
    after 4 hours of fighting to get it on success!
    in we go
    drive train stabilizer bar to be used as the new transmission mount
    stabilizer mounted.
    wooden motor mounts until i weld some up.
    sitting on its own
    it fits :)
    Carbon Exhaust
    Jan 09 2008
    United Kingdom
    Nice work there!
    Actually, the engine can be fitted to the tranny, without having to pull tranny from the car.
    You just need to undo the 2 front subframe bolts, so the front crossmember drops low enough to allow the V8 rear oil pan projection clear it. Mine went in that way with ease.
    Did you remove the oil pan webbing, and the thick lip at the rear? It's not needed on a manual tranny, and makes future removal and installation easier.
    Active Member Two Rings AWD Mike's Avatar
    Oct 19 2008
    Virginia Beach
    I want to see vids of both V8 B5's .... in car.
    I want to be able to see the powah!
    Then, I will buy one.
    1998 LASER RED AUDI A4 2.8 30V
    Tint | Kenwood| K Sport | Magnaflow | Car Sound | RS4 Grille | VMR 710 | Falken | JHM | Southbend
    Senior Member Three Rings getslideways's Avatar
    May 16 2008
    WA
    did you end up knocking the 2nd firewall at all or were you able so squeeze the motor in there while keeping it in tact?
    i am really excited about these projects hopefully I can pull the trigger on doing this aswell. Props to both of you for paving the way!
    Dec 01 2008
    Boulder, CO
    Nice work there!
    yeah we tried to stab it with the trans in, but for some reason we were having trouble with the last 5mm, could not figure out what was interfering, until after wiggling it around out of the car it finally went in.
    hmmm, how far can you grind the rear lip on the oil pan? because ther would be fantastic if i could make that go away, because it is way too close to the subframe otherwise, do you have a pic of how much you ground down?? don't want to go too far haha
    Quote Originally Posted by getslideways View Post
    there is actually plenty of room behind the motor, so the firewall does not need to be touched.
    Carbon Exhaust
    New Member One Ring
    Sep 20 2008
    Hamilton
    total hard on.. cant wait for a video on youtube :P:P
    Dec 01 2008
    Boulder, CO
    driver side mounted up with a V8 S4 mount, and passenger side motor mount modified to work...
    Carbon Exhaust
    Dec 01 2008
    Boulder, CO
    Motor is sitting entirely on custom mounts...
    Carbon Exhaust
    Senior Member Three Rings Jc61990's Avatar
    Aug 22 2008
    99.5 Audi A4 1.8TQ
    Long Island, New York
    have u considered getting rid of the 1.8 trans and using a 2.8? since its got longer gears it would probly be a lot better for the v8.... ill take the 1.8 trans off your hands too lol :P
    JC | 1999.5 Brilliant Black A4 1.8TQ
    3" 034 Downpipe | 034 HF Cat | Forge 007 | Double Din Swap | S4 Steering Wheel | Burberry Plaid Trim | Bilstein Sports | H&R Race Springs | ECS Coilover Kit
    E-codes | DDM 4500k 55w HID | Samco Hoses | FMIC | GlowShift Elite Boost/Vac | Innovate LC-1 | Auto Tech Pod
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    La Jolla, CA
    No need for the 2.8 trans IMHO
    APR stg 3+, Carbonio, ER FMIC, APR HFC, AMS SS, Milltek Res. Cat-back, Hardwired V1, Street: Work CR Kai 18x8.5, 235/40/18 Dunlop direzza Sport Z1, Project MU Type NS, Track: Work CR Kai 18x8.5 235/40/18 Nitto NT-O1, Project Mu Type HC+, Stasis/Ohlins MS 650F/750R, Stern CA's, Alcon 355 4 pot front, Alcon 300 S4 rear, CM FX 300 with 240 Steel LWFL, Hotchkis F & R anti sway bars, JHM 4:1 center diff mod, Setrab Oil Cooler w/ Thermo Sandwich Plate, 034 rear CA's
    Dec 01 2008
    Boulder, CO
    i'm looking for more power down low because for rallying and the tracks i'd rather be able to pull out of a corner faster than have an extra few MPH for top speed. plus you never really find yourself going above 120, and all the torque out of the corners is just going to be a dream with the 1.8 trans i think.
    Carbon Exhaust
    Senior Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    freaking awesome!!
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Dec 01 2008
    Boulder, CO
    toque mount done, will hopefully get everything hooked up and fire her up next week...
    Carbon Exhaust
    Jun 04 2007
    Austin/DFW, TX
    good work!
    My 5-Speed Swap DIY
    - B6 USP
    Jul 02 2008
    1999.5 A4 1.8T Quattro
    Danbury, CT
    Watching this. Great progress
    Registered Member Three Rings antoanS4's Avatar
    Jul 05 2008
    miami
    Nice build,when do u thing this is gonna be done
    Senior Member Four Rings somebody5788's Avatar
    Aug 13 2008
    Indiana
    Wow the front of that engine looks exactly like a 2.8 almost. Water pump, alternator, timing gears, tensioner, and idler pretty dang close setup.
    -Nic
    2011 Honda CBR250R - gas sipping toy
    2001.5 Audi S4 - APR 93/100 | 710n's | EvoMS intake | RS4 clutch | RS4 Grill | Plasti-Dip'd center console | Podi gauge pod | VDO boost gauge | TSX-R clear lenses
    1994 Suzuki RF900R - It needs some love but it'll get there!
    1994 Jeep Grand Cherokee - rattle canned OD green Zombie Response Vehicle
