Results 1 to 14 of 14
    Senior Member Three Rings PoormansA4's Avatar
    Mar 26 2009
    Wildomar,CA
    Coil Pack Wiring Harness Replacement, 1.8T
    anyone ever done this? how hard it is? is there a DIY?
    thanks
    For sale
    wiring harness 01 1.8t
    map sensor
    stock injectors
    fuel rail
    stock FPR
    brand new front and back rotors (quattro)
    Jun 30 2008
    Erie, Pennsylvania
    Re: Coil Pack Wiring Harness Replacement, 1.8T
    There was a TSB for some of the VW's that had the 1.8T which included directions:
    http://www.squarewave.com/army/andre...b.97-04-02.pdf
    Veteran Member Two Rings
    Mar 15 2004
    Just one of the coils or the whole thing?
    2001.5 A4 1.8tqms
    Pectel SQ6 ECU
    2.0 built motor w/ AEB head
    GT3071r w/ Full-Race Manifold
    725cc Injector Dynamics
    Startup Racing Contest Suspension 600/700
    Mar 26 2009
    Wildomar,CA
    O that TSB is perfect, should be somewhat close to mine, and for the whole harness not just one.
    thanks
    For sale
    map sensor
    stock injectors
    fuel rail
    stock FPR
    Awaiting Confirmation Two Rings
    Aug 22 2007
    2000 A4 1.8T
    Bristow, VA
    Depending on which harness you use, its not too difficult. I used the ECS piece and although it took most of the day the job itself was quite easy, just time consuming. The ECS harness is not a direct fit so I had to splice into 4 wires.
    Mar 26 2009
    Wildomar,CA
    where did you see it on ecs I couldnt find it, was just gonna go to the stealership its like 55$
    For sale
    map sensor
    stock injectors
    fuel rail
    stock FPR
    Mar 26 2009
    Wildomar,CA
    There is a coil pack harness available for the MKIV GTI, Jetta and TT but unfortunately not for the B5 1.8T. You may be able to use the MKIV harness and cut and splice to repair what you need. I do have this harness in stock. The part number is 1J0971658L and the price is $55.72.
    so this is what the stealership tells me, guess im gonna have to do some project
    For sale
    map sensor
    stock injectors
    fuel rail
    stock FPR
    New Member One Ring cesar333's Avatar
    Jun 26 2011
    Do you remember which 4 wires you had to splice into? I have an 05 audi A4 1.8t and hit a road block with this harness. Any help would be apprciated.
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Phoenix, Arizona area
    A bunch of the B6 1.8t owners have posted about doing the 034 replacement harness on their cars. Nice part is that after install that if you had to replace the harness again it was just plug and play.
    Poorman - I think I just saw you pulling out of a parking spot at Albertsons here in Wildomar yesterday.
    Registered Member Two Rings isco6's Avatar
    Jan 05 2011
    2003 A4 1.8t 2006 Jetta 2.5 1958 type one ragtop 1986 porsche 944s 16 candles
    tehachapi california
    Did you ever find the four wires to splice. Thank you for any advice.
    All truths are easy prove one they are found.The important thing is to find them!
    Gallelo
    Senior Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    This is where I got most of my reference from while I'm planning my coil pack change. Hopefully everyone will find this helpful when doing either a replacement or ICM delete.
    Audigeeks: AEB to ATW+ Coilpack Conversion (ICM Delete) Project
    Audizine Post with links for parts
    There is a huge push to goto FSI coil packs. Either from the GTI (06F XXX XXX) or A4 (07K XXX XXX). Many have found that the GTI packs are cracking on the plug tubes. The A4 ones don't have the plastic plug tube covers, so they are working out better.
    A lot of more information HERE
    Mar 15 2008
    Syracuse, NY
    034 just came out with a complete kit for the S4 2.7t if anyone is interested
    http://www.034motorsport.com/engine-...s-p-22156.html
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    x10000 on the 034 kit. I installed it on my car. It looks great and easy to install. got rid of misfires as well.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
