Results 1 to 40 of 49
    Senior Member Three Rings Silver Bullitt's Avatar
    Aug 01 2008
    is really messy.
    P0741 Torque Converter (I searched already)
    F$ck a duck!
    Anyone ever have this CEL code go off and NOT need a new TC?
    I know my input and output seals leak a little...could I just be low on fluid?
    Also where is the selniod located? Is it under the hood near the center of the firewall?
    Just trying to figure out if I need to give up on Audi :( as I also need control arms, a CV boot replaced, the input and output shaft seals replaced and the secondary water pump replaced. All in all if I truly need a new TC then I am looking at about $4500.
    P.s. the only symptoms I have besides the CEL are that when I accellerate the car seems to vibrate very mildly.
    P.p.s My wife is going to kill me as she was against this purchase to begin with :)
    Registered Member Two Rings hosmer79's Avatar
    Jul 16 2008
    2001.5 Audi S4
    W.S., MA
    Re: P0741 Torque Converter (I searched already)
    I got the same error right after buying mine. Didn't fix it right away and never really noticed any problems with it. I had to get it fixed eventually just to pass Massachusetts state inspection otherwise I think I would have let it go a bit longer. From what I've been told and understand it's not really hurting anything driving it like this.
    $4500 is that a dealer price? I was able to get mine fixed with an Audi TC for $1600. I'd shop around for some prices on it. Not that it's like a $300 fix but then again what is on these cars?
    The CV boot you should just do yourself. I'm terrible at working on cars for most things but I was bale to replace my axle and also do a boot repair.
    Best of luck to you though.
    Two is greater than one!
    2001.5 S4 Santorin Blue 124K
    GIAC - Darintake - Drop in K&N - 710n's
    http://i94.photobucket.com/albums/l9...orums/Sig2.jpg
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    517 trans = $550
    VAST = $900
    are you guys insane? and labor is about 12 hrs.. book..
    Lurker
    Aug 01 2008
    is really messy.
    No $4500 would be the ball park for the TC, CV boot, Control Arms, Secondary H2O and Input/output seals. (I have been quoted $2200 for all but the TC and am guessing another $2000 for the TC)
    I am probably going to do the CV boot, Control arms and Secondary H20 pump myself. Unless I need a new TC then the whole thing may have to go. That is why I am hoping that it is something like the selnoid or just low on fluid due to the leak mentioned above. I have eaven read that a K&N can throw this code by fouling the MAF.
    Any thoughts on that? Seems unlikely to me...but I did just throw a K&N in about 1000 miles ago.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    torque converter seal or else the TC solenoid.
    those have been the only found problems to the code.
    ALSO. a solenoid has only been documented once on the the forum.
    Most of the time it's the TC seal.
    Lurker
    Aug 01 2008
    is really messy.
    Quote Originally Posted by mrpeterparker View Post
    What is the location of the selnoid?
    I ask becasue the CEL came on whule I was camping 60mi into the wilderness. So try and clear the light I disconected the baqttery and when I plugged it back in there was a nasty buzzing sound coming from a cylinder shaped....well I dont know what. It was near the firewall more on the drivers side, right up top. Buzzed for about 2 minutes then quieted down.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    IIRC the solenoid is inside the tranny... but that sounds weird..
    search for TC solenoid.. it's somewhere on AZine
    Lurker
    May 06 2009
    01S4, looking for a second
    indy
    It is. Behind the filter, maybe? Saw a picture of it once, but can't for the life of me remember where it is...
    Aug 01 2008
    is really messy.
    Why do I have a feeling I will soon be riding my bike a lot?
    I really don't want to get rid of my Avant but...$4500?
    Shit.
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    I got the code last year... The only thing the seal does is lock the TC to give better MPG on cruising. You hardly notice/miss is.
    I tried to refill the tranny = waste of time and money since it made no difference.
    So then I pulled the motor+tranny and let "ACE Converter" rebuild the tranny for $400. Then while the motor is out, might as well do piggies and put k04's in there, right.
    For sale: 2000 S4 Silver, K04, FMIC, Piggies, MBC, SSP tune & Rebuilt TIP.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    shameless plug if i may ....
    but does anyone need/want AWE Stg3 fueling kit for their tiptronic? I need to sell mine and take that money and put it towards a new TC + install
    Lurker
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    '16 S3
    Norcal
    Items for Sale
    Why not learn to do the work yourself? With the transmission out of the vehicle, most shops wouldn't charge much for labor since its on the bench and doesnt need to be removed. Everything else you mentioned can be done pretty easily at home. Not like 15 minutes, but even a few days work is worth paying $4500!!!
    The Best Things in Life Are Free... Or Heavily Discounted!
    May 26 2008
    Riverside, CA
    Quote Originally Posted by Raacerx View Post
    +1
    There are tons of write ups (DIY) to follow...
    Aug 01 2008
    is really messy.
    Quote Originally Posted by Silver Bullitt View Post
    Yeah my plan is to do most of it myself. But I can not do the TC myself. So 2000-2500 for that and another 750-1000 for the parts for the other jobs I need to do on my own will be a tough sell. Hopefully it will all work out though.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    wecome to the TC seal club, my stg 3 car works well with a 517 trans shop tc and rebuild/upgraded trans. What realy sucks is my new stock avant i bought this may has the tc seal code pop up two weeks ago, so back to get 517 tc for that car. I have plans in the next year to year and a half to do a 6 speed convertion to it so I am keeping it stock engine untill them,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    2001 S4 Avant TIP STG 0, Vast snub mount, 710N's, AWE boost gage, Tints, more to come...
    Turbo's are the Perfect Drug
    Aug 01 2008
    is really messy.
    But I don't want to join this club!
    OK so I found the little print out that I got from the scan. Curious if this changes anyones minds about the TC...I doubt it but here goes anyway
    Definition:
    Torque Converter Clutch Circuit performance or stuck on
    Open or short Circuit condition
    Probable cause:
    1-Poor Electrical Connection
    2- Failed torque converter clutch solenoid
    3- blocked oil passage
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    yep my S4 had that code last year. i was told they couldnt repair it since it might ruin the rest of the transmission. so my warranty company and i payed 3500 for a brand new transmission. i paid 1350 of it
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Senior Member Two Rings BLK01S4's Avatar
    May 18 2004
    Miami BiSH!
    That sound you heard was probably the air injection pump.
    Stage III Tip Mods "Stuff"
    Fastest Tiptronic ET: 12.259@118.25mph
    Aug 01 2008
    is really messy.
    Quote Originally Posted by BLK01S4 View Post
    That buzzing?
    Is that a normal sound? Just pressurizing or something?
    Thanks
    Aug 19 2008
    DFW
    anyone have a picture of the air injection pump? im throwing a code for it
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2001 Stg 3 Giac s4, 2000 Stg1 S4 APR, 2000 Stg2 S4 revo. All silver
    Huntington Beach
    Yes, the buzzing is your SAI Pump going bad. its for emmisions
    2000 silver B5 S4 k04 stg 3 - sitting in my garage
    2002 silver b5 s4 stage 2 revo - totaled
    2001.5 silver apt stg 2 b5 s4. - sold
    2011 ctsv 730whp - daily
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Quote Originally Posted by lonestar22 View Post
    look a your engine on the drivers side near the fire wall you will see it,
    Aug 01 2008
    is really messy.
    I think this might be it...not sure though
    http://www.autoanything.com/Parts/Pa...control-73-981
    Aug 01 2008
    is really messy.
    Oh and this link talks about rebuilding it.
    http://forums.audiworld.com/showthre...i+pump+rebuild
    Pics dont work for me but...maybe for you?
    another
    http://forums.vwvortex.com/zerothrea...ostid=58564875
    Aug 01 2008
    is really messy.
    In the shop right now
    Never have I hoped for an electrical problem more than I am right now.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    good luck man.. we're all interested in knowing.
    Lurker
    Aug 01 2008
    is really messy.
    Well son of a beeznatch....
    Just got the call. The mechanic is not positive but suspects that it is the torque converter as it has known problems.
    I told him go ahead and repair the tranny/differential leaks and clear the codes. A gamble I know but it is still possible that will take care of it (very very very small chance).
    Maybe an extended warranty is a good idea.
    Registered Member Two Rings cdc's Avatar
    Jan 04 2008
    Menifee, CA
    I had to replace the torque converter on mine. Only ended up costing me less than $500 as I did the work myself and got a amazing deal on the torque converter.
    Aug 01 2008
    is really messy.
    Quote Originally Posted by cdc View Post
    Not too bad......How difficult was the replacement and how did you go about doing it? Oh yeah and where did you get that TC?
    Aug 01 2008
    is really messy.
    Aw frick!
    So I had the transmission and differential leaks repaired and the light went off.
    Stayed off past 30 miles......40 miles....50 miles....then boom around 60 it popped back on!
    Drives me crazy. No performance issues, no limp, no surging, no fluctuating rpms....just some damned code telling me to spend money. :)
    Like my cat meowing for food/attention in the morning.
    Just wanted to give the update. I think I will be taking it to a tranny shop to see what they think......I still think that anyone who has had problems should start a class action lawsuit. For how rare it is supposed to be to have TC failures it sure seems common.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    wait... so you DIDN'T replace the Tc yet?
    of course it didn't fix it...
    Lurker
    Aug 01 2008
    is really messy.
    No I was in the denial stage. Still am :)
    Maybe it is just the solenoid!? right??? Little chance?
    Shit.
    How high does the car need to be to drop the tranny?
    Aug 01 2008
    is really messy.
    This is where I am at FYI
    My mech said the same this this guys did (as you can see my my elated response)
    http://www.audizine.com/forum/showth...erter+solenoid
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    it sux either way man, I am saving $ up to to the job in my stock avant still....
    Senior Member Two Rings supersweet's Avatar
    Dec 16 2008
    Santa cruz, Ca
    i guess ive just joined the club.. this F_ING sucks ...
    __________________________________________________ _______
    STage 2 +(TIP)--APR chip--A.W.E Twin 1---JHM PiGGies---A.W.E s-Flow---JHM FMIC-- ECS Race N75--ECS 12.5 spacers--A.W.E boost gauge---APR SNUB---
    Aug 01 2008
    is really messy.
    Done and done. Now I am poor and poor. Oh well.
    Senior Member Three Rings ColinGruenfeld's Avatar
    Oct 24 2006
    Stage III Tiptronic B5 S4
    Colorado
    Check out my ads or PM me - I have a full TIP tranny with 100K miles on it (pulled in good condition - no codes or slipping) for $500 plus shipping. If I can find a buyer for the tranny, I would split up the TQ.
    Audacity - The Nogaro 2000 S4
    STAGE 3 PJ K04's + IPT Tranny/TC + This and that
    Full Stage III TIPTRONIC
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    you're selling your IPT trans?
    *tip .. link your for sale thread in your signature =P
    Lurker
    Aug 01 2008
    is really messy.
    No, it is done and I am poor becasue I put a new one in. Thanks for the heads up though. :)
    Aug 01 2008
    is really messy.
    So...I made the mechanic give me my old TC. I was thinking of beating it with a ball-peen hammer or throwing it into the Puget Sound to help create an artificial reef :)
    Is it worth anything? Do places like 517 buy these to rebuild and sell? Just curious.
