Page 1 of 31 12311 ... LastLast
Results 1 to 40 of 1204
    Registered Member Four Rings A4ringedONE8T's Avatar
    Feb 17 2005
    Sarasota, FL
    Anthony's (GTRS A4) 1.9l, AEB, 3076R Build Thread
    Parts are starting to roll in and I'm starting to get dirty so the time has come to start documenting the journey!
    The reason for the build ... KABOOM ... CLICK CLICK
    The New Hardware:
    Engine
    AWP Block
    AWP Forged Crank
    JE 83mm 8.5:1 Pistons
    Integrated Engineering 144x20 Rods
    AEB Head
    Supertech Inconel Exhaust Valves - Single Groove
    Supertech SS Nitride Intake Valves - Single Groove
    Supertech Springs and Retainers
    Cat 3653 Cams
    ARP Head Bolts
    ARP Main Studs
    ARP Flywheel Bolts
    ACL Coated Rod Bearings + .001
    ACL Coated Main Bearings + .001
    Turbo
    Forced Performance HTA3076R, .63 a/r, Polished Compressor Housing, 3" 4 bolt Exhaust
    Full Race Tubular Manifold
    Tial 44mm Wastegate
    Full Race Downpipe
    Fifteen52 Custom 3" DP Back Exhaust w/ 3" Splits and Magnaflow 14819 Mufflers
    ER Comp FMIC w/ Fifteen52 Custom Hotside Piping
    Tial Q BOV
    Turbosmart Eboost2 EBC
    Ecode GT30 REVO File w/ 750cc Injectors, 3 BAR MAP Sensor, and VR6 MAF
    Bosch 040 Fuel Pump
    On to the pictures!
    First thing to show today was the dirtiest AEB head I have seen in quite some time!
    Fresh out of the parts cleaner and after a few minutes with a deck cleaner ... still needing a little bit of love
    Dropping the head off the end of the week for the guides and seats to be checked, depending on the outcome it will either be getting some new parts or coming back to start with the install of the new Supertech components!
    Stay tuned, I'll update anything and everything as we go!
    Shawn
    Senior Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    Re: Anthony's (GTRS A4) 1.9l, AEB, 3076R Build Thread
    nice and dirty...wonder what my head looks like...
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Senior Member Four Rings 317ssayzarc's Avatar
    Oct 27 2007
    98.5 A4 2.0T 2001 Golf 1.8T
    Westerly RI
    You can soak the head in diesel for a few hours if you don't have access to a hot tank. The parts washer doesn't do much for cleaning out the oil passages, unless you are soaking it. That head is incredibly dirty LOL!
    And Shawn, this is just friendly advice, please don't take it as anything else. You and whoever can have your own issues, but lets not start that.
    -Jake and my shop is DoWerk Garage
    01' Golf 1.8T - The daily, GT2871R .64 externally gated, Tapp 630cc mafless tune, SB stage 3, Brute rods, ported AEB, 1mm over valves, CAT gold springs, Vmaxx, and countless other tidbits
    Send
    me a pm if you need work done in New England... Fabrication, engine builds, timing belts, brakes, ect
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by 317ssayzarc View Post
    The machine shop is going to hot tank it for me, I cleaned what I could of it. It really doesn't look bad too bad now in person and the ports/passages are pretty clean, I'm just anal so it will be getting some more love. Wasn't aware of the diesel trick, thanks for the heads up
    Oct 27 2007
    Westerly RI
    Quote Originally Posted by A4ringedONE8T View Post
    How'd the journal area of the cam caps look?
    Send
    Senior Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    04 A4 USP & Jeep
    En el cuarto de tu mama, IL
    nice! Wish I had the funds to rebuild......
    Just a B6
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    good lord thats going to be another beast!
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    99 GTRS A4; 00 stgII S4
    Lansing, MI
    wow, my 150k mile head looked alot cleaner than that!!!!, but sounds like a fun project.
    '98 built 1.9 B5 A4 SOLD
    '00 Audi S4 6spd stg II SOLD
    '99 1.8 GTRS powered B5 A4 SOLD
    Feb 17 2005
    Sarasota, FL
    The oil passages in the cam caps are perfect, weren't even gummed up before it went in the parts washer. The seating surfaces are good as well, no nicks, scars, or markings of any kind
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    thats good. just needs a cleaning. mine looked pretty bad too, but the hot tank and sand blasting made it look brand spankin new.
    subscribed.
    USP CLUB MEMBER #71 BetaAlphaTau Member #16
    tumblr
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    Sludge city with that head . It will look good when it comes out of the hot tank and gets resurfaced.
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    399awhp! Lol
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Senior Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Oh who's gettin' this??? lol
    Thanks Shawn!
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by dirtybrd View Post
    399awhp! Lol
    300awhp on pump gas or bust
    Jul 11 2008
    Illinois
    399awhp! Lol
    Oh you know it! hahaha
    Anthony
    Oct 27 2007
    Westerly RI
    Quote Originally Posted by A4natomical View Post
    subscribed.
    Heads should NOT be bead blasted with any sort of media other than baking soda. Everything else gets into the tiny passages in the head and is near impossible to get all of it out. There is actually a head at my machine shop right now from a shop to be unnamed in NY, it was bead blasted and guess what happened
    You may have gotten away lucky, but I very high suggest again blasting a head unless it's soda (in which case you just dunk the head in water).
    Send
    Mar 21 2006
    Lakeland, FL.
    Very true!
    I'm back bitches!
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    I don't know exactly what they used, it could have been baking soda (it was really white)
    I only saw them doing it on another head, they could have just hot tanked mine since it didn't have any sludge build up, only discoloration.
    EDIT: i just pulled out my file w/ all my receipts, and it only lists [hot tank, decking, valve job].
    tumblr
    Senior Member Four Rings B6Lovin's Avatar
    Jun 29 2007
    2003 A4 1.8TQM 3076R
    Cary, NC
    lol
    Audizine's Quickest/Fastest 1.8L B6 A4 (lol)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 21 2006
    Lakeland, FL.
    Baking soda or some Columbian Gold.
    I'm back bitches!
    Senior Member Four Rings Pufftrees's Avatar
    Mar 10 2009
    2004 CBR 1000RR
    New Jersey
    Subscribed!!
    Stage 2 Unitronic Tuned
    Cheap and reliable wont be fast.
    Cheap and fast wont be reliable.
    Reliable and fast wont be cheap.
    -Andrew-
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    03-A4||08-X5||01-///M3
    This is gonna be a BEAST!!!!!
    Keep me posted on that other thing Anthony
    2003 A4 QM EFR 6758 on meth
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    The New Hardware:
    Engine
    AWP Block
    AWP Forged Crank
    AEB Head
    Cat 3653 Cams
    ARP Head Bolts
    ARP Main Studs
    ARP Flywheel Bolts
    Turbo
    Tial 44mm Wastegate
    Full Race Downpipe
    Tial Q BOV
    Bosch 040 Fuel Pump
    Ok a few things
    1. BADASS Build, no rock was left unturned, looks better than mine
    2. Why did you do main studs? Just because?
    3. Full Race doesn't make a DP for the B6 (or they didn't used to), do you mean an 034 downpipe?
    4. Why the ER Comp? Its way overpriced and IMO too small for this setup
    5. Are you looking into other tuning options?
    6. If the Ecode pump flows so much more than the Bosch 040, why bother with the Bosch pump?
    7. Rerouting the WG or dumping it?
    8. Why no V-band out on the 30R?
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
    Feb 17 2005
    Sarasota, FL
    Ok a few things
    1. Do you feel better now about what Anthony is building?
    2. Just because, not too much more than OEM main bolts so why not
    3. This I don't know, Greg is supplying the Full Race products for the build, he knows what we need.
    4. Has t fit under the stock sport bumper, absolutely nothing bigger will fit
    5. The Ecode GT30 file should be more than sufficient
    6. Again Greg and Ecode are handling the tuning/fueling
    7. Open dump
    8. +$175 for V-Band And the downpipe is only available in 4 bolt
    Jul 11 2008
    Illinois
    Ok a few things
    1. Thanks
    2. Shawn's the man to ask. He suggested it and I said why not!
    3. But about the Full Race DP, they make one for the B6, it's on their website I believe.
    4. I don't think it'll be too small and I'm running stock, non-USP front so I needed something to fit behind there.
    5. In the future, maybe. We'll see how the new Eurocode file does.
    6. That's what we are going to be doing. I just need to talk to David or Greg about ordering the parts now.
    7. Open
    8. Full Race DP is 4 bolt.
    Anthony
    Jul 11 2008
    Illinois
    7. Open dump
    Lol
    Looks like we are on the same page!
    Anthony
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by GTRS A4 View Post
    Lol
    And you're surprised about that? You've been a pleasure to work with on getting a parts list together and getting the ball rolling on the build, I wish every customer made it as easy as you have
    Apr 23 2007
    Ok a few things
    is that why you chose that monster i saw today at RAI? LOL that thing was HUGE!!!
    Jul 11 2008
    Illinois
    Nope!
    Probably been over 100 emails in the last couple weeks.
    Anthony
    Sep 14 2006
    Lansing, MI
    almost exactly what i did on my build.
    Oct 29 2005
    Ft. Lauderdale, FL
    7. Open dump
    I love how secretive you guys were trying to be. "Whose going 30R? are you buying it?" lol You love your Revo Shawn, hopefully do the trick
    - Clint
    Feb 17 2005
    Sarasota, FL
    I love how secretive you guys were trying to be. You love your Revo Shawn lol, hopefully do the trick
    It wasn't a secret, we we're just trying to get together the finalized hardware that met Anthony's requirements for both fitment and cost but included everything that was needed (without a ton of overkill)
    Senior Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Dumb question probably, but why not go with a full 2.0 instead of the 1.9?
    -Nick, now GFY
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    For Sale:
    Eurocode FMIC for 1.8T (PM me)
    Rapey Twins
    Jul 11 2008
    Illinois
    I just didn't want it to be a "My 30 series build thread, here's my idea, I may come through with it, I may not" because I wasn't 100% sure I was going to do the turbo too. It's A LOOOT of money. And you know that more than anyone else here since you're going through it yourself.
    But this is something I REALLY want to do with my car and I'm glad that Shawn's helping me with it because I wouldn't have had the slightest clue on some of this stuff. I've already learned SO MUCH by just pulling the motor myself.
    Anthony
    Jul 11 2008
    Illinois
    Quote Originally Posted by Exanimas View Post
    The only difference for me now would be to do a different crank. And that would be another $700.
    Plus, the AWP crank is lighter and forged.
    Anthony
    Feb 17 2005
    Sarasota, FL
    AEG crank is garbage honestly (plus they are getting harder to find, therefore value is going up so to properly do a stroker you should use the FSI crank. At ~$800 bucks depending on the source, the extra 100cc comes at pretty good hit to the wallet. 100cc isn't going to make a noticeable difference in either spool or peak power
    Feb 17 2005
    Sarasota, FL
    The FSI crank is lighter (than the AMB and AEG) and forged as well, just like the AWP
    Mar 09 2008
    is full of crap.
    Boston, MA
    Makes sense. Thanks.
    -Nick, now GFY
    For Sale:
    Rapey Twins
    Jul 11 2008
    Illinois
    Yeah, yeah! That's...what...I...meant??
    Anthony
    Apr 24 2005
    How do you figure?
    The AEG crank has been used in many engines that see double the power this engine will have. Nobody even knows what they can handle because none have broke yet even with engines running 600+whp.
    ~David~
