Results 1 to 37 of 37
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    DIY: Motor pull over view with header install pics
    ok this has taken me some time and I know the grammar is going to need to be touched up. I will continue to look over and make it easier to read. Also My camera locked up and I was unable to get out some of my pic's so some of the pic's are going to be reference pic's just to help get you the idea. I made a promise I would do this for someone and I just wanted to get it up on the site so others can offer other tips and mention issues they might have seen that they would like to see covered better in this write up.
    So that being said
    This post is a brief over view of what it takes to pull the motor. I would love to put in more pic's but my flicker acct is just about full and I have other stuff for future projects that Im going to want to use. So unless the AZ guys can open up my pic folder some of you are just going to have to do more reading then looking.
    Keep in mind that taking out the motor is not the hardest thing in the world and Not every ELE connection is pointed out. You kinda have to go common sense on some things. This should help give good pointers and things to look out for. I will leave some pages open for editing so in the future we can fill them in with more hints and info. Once again I have more pic's to add but don't have a host site to do it. So the pic's added are the ones I find more important. Things like pulling out your shifter can be located else where so there is no info on that and other things that most people should know how to do by default. For instance if you can't notice that there is still a plug on the front bumper when you are removing it and that you need to remove the belly pan and the coolant tank to pull the motor then this might be too big for you to handle
    Here are all the places you need to look at to get the front end off the car. Keep in mind the front bumper has several ELE connections and the head light washers. When you are getting ready to remove the front bumper you are going to need to go to the driver side and disconnected the line for the head light washer, Have a washer fluid bottle handy.
    Ok so here is the thing. When you are ready to pull back the core support. This means you have removed the 7 T45 bolts and the T30 side bolts with only the Top 4 T30 bolts left. Here is what I did that worked quite well for me. take out bolt 2. Then take out bolt 1 and move hole 1 in the core support over hole 2 in the body. Or pull the core forward and use the screw to hold the core in place.
    Make sure you keep enough room so you can get to the RAD hose clamps. See that below
    This is not the B6 core support. But is is very close and lets you see what is under you bumper. You can see now where the LONG 8mm bolts go that are in the bumper it self as well as the rest of the lay out mentioned above.
    Ok so you will notice that in this last picture there is the AC condenser right in front of the motor. This can just be swung out of the way. But the AC unit it self will cause an issue for the motor to move too far. So you have some decisions to make. One you can remove the AC unit from the motor. This is not hard but it is also not easy to reinstall. I have just come to the conclusion that it is easiest to just detach the AC lines and drain the AC from the system. //////// NOTE ////// the Ac unit uses a more environment friendly component not the old freon or even R12 that was Bad for the environment. Recharging the AC is almost as easy as it is to empty it. They have several DYS systems that go from 25-85$ I ended up getting some better tools but the small DYS units work well and there SOOOOO simple you would be amazed.
    So you can remove some of the AC lines at this time or you can just swing the AC condenser out of the way.
    Next thing you need to do is to pull out the PSC or the power steering cooler. The PSC is shown in the pic above as the black squiggly tube that is in front of the AC condenser. This is just a long twisting section of tube that runs the power steering fluid threw to cool it. But on our car the lines to the cooler go threw the core support. Best thing to do is to just remove the PSC lines from the PSC. Leave the PSC unit attached to the core support but remove the rubber lines from it.
    To do this locate the lines on the motor side of the core support. You can obviously follow the lines to the PSC from under the car. Just remove these 2 hoses and install small bolts to stop the PS fluid from draining out. At this time it is a good idea to remove the line from the power steering as well
    Now you are ready to pull forward the core support and disconnect the Rad hoses from the RAD. This can stump some of you that may not have done it before. So here is a reference pic of that you are doing
    What you see is the clip that surrounds the rad hose and connects and holds it to the Rad it self. You need to pull this clip ALL THE WAY up. Or you can remove it completely to make sure you are good. This connection is very tight on the rad so expect a fight to get it off. I use some WD40 and spray around the RAD connection to the hose on the inside. Then I use a dead blow hammer and a Flathead screw driver to tap the hose off the RAD. (from the back side) This will make more sense when you see it and try to do it.
    There are 2 hoses connected to the RAD one on the lower driver side (hardest one to get off) and the upper passenger side. be sure to have a bucket or pan to catch the fluid that is coming out. Take off the lower driver side first once the fluid is coming out. Take off the cap from the coolant tank reservoir this will help get the fluid flowing faster
    At this stage you should have a good amount of coolant drained. Before you pull the Core support off you will have to observe all the ELE connections on the core support and take off the hood release cable. This is easy just look where the hood latch is and you will see the cable with a ball on the end. You can just push the entire thing out of the spot you will see its easy. Then just pull the cable out of the way and tuck it in where the ECU box is. As for the rest of the ELE connections They should be obvious at this time. Remove the supporting bolts and start sliding the core support forward making sure to continue to drain the coolant and disconnect the ELE connections
    You should now be at this stage
    REFERENCE pic only
    So now at this time you have removed the entire front of the car and you should be looking at this. Notice the two lines on the driver side. There are red rags stuffed in them with a bolt. If you have a automatic you will have to remove the trans cooler lines that go into the Rad. with a 6 speed this is not an issue
    From here the next thing to do is to You need to remove all the Aux Rad connections. Don't spend too much time looking threw all the hoses. Just take off the ones that either go over or under the frame rail. There is about 5 hoses to disconnect. ONLY TAKE OFF THE ONES THAT GO OVER OR UNDER THE FRAME RAIL. once you start taking off the rest of them you will just see later you didn't need to do that. Leave the Aux rads where they are they don't get in the way.....
    This next little part is to show you what you would have to do if you decided to not take off the AC lines. ITS A PITA
    Now if you don't want to spend the money and refill the system. It is going to take about 1 to 2 more hours. but I will help if you take this route. You need to remove all the Aux connections as usual. But now you need to remove the water pump and remove the driver side motor mount and bracket. To do this you will need to prop up that side of the motor. Then from there you need to take out the 3 bolts that hold in the AC unit and then unscrew the shaft that connects the AC unit to the drive system
    Here is a pic of the AC drive shaft (the black shaft) and the motor mount
    After you remove them you can swing out the AC unit. Then you will be looking at this. Notice that the Water pump is removed and the AC unit is removed as well. Also notice how you can see the drive shaft for the AC still in the spot where the AC drive was. You can remove this I just left it in for refrence
    This brings me to the next step. Notice all the wires on top of the motor. Those wires are from the ECU box and they cover all the ELE system for the entire car. You need to remove them from the ECU box area. Notice in the pic that there are No wires left attached to the back fire wall. You need to remove all the ELE brackets and any ele connection on the rear fire wall
    Those wires come from here
    Also you are going to need to go on the fire wall and remove all the wires from there. Just remove the bracket they are all connected to this is easier. Also on the back fire wall you need to remove the BROWN wires that are all held in place with the 10mm rounded off nut. VIP these are all the ground wires. ///// make sure you make note of how many there are and where they go. ////// if you don't this may prevent the car from starting on reinstall and also my cause damage to any of the needed grounded systems. Also you need to pull the negative ground strap out from the batt area all the way out to the motor area. The starter is grounded to the body just under the passenger side frame RAIL make sure to take this off as well.
    The next thing your going to have to do is to remove the heater hoses. these are located just to the right of the batt. There are 2 of them you need to remove both of them by pulling them off the heater core. This is simple these are compress to release clamps. Squeeze the clamps to move them down the hose. After the just pull them back and stuff them down into the motor compartment.
    Next is dropping the shifter box if you have a 6 speed manual or removing the shifter cable off the trans if its a automatic.
    If it is an automatic its easy there is a ball socket attached to the side of the trans on the driver side. You can't miss it its white in color. Just push it off, its just pressed on fit tight.
    If you have a 6 speed manual, you need to drop the shifter box and remove your shifter.
    The next and last thing you need to do is to disconnect the drive shaft from the trans. Take out the slave cylinder. Don't pull the line off just remove the cylinder from the trans. Now you may need to drop or pull the motor out a little to get the the Allen headed bold that holds this in. Below is a reference pic of the slave cylinder just under the actual unit.
    Thanks for the addition MAtt aka littleredwagen
    So now you should be in a place where you can either drop the motor out of the car or pull the motor out of the car. I have done both. But not too many people have a motor hoist and then again not too many people have access to a lift.
    Now you need to think about what your going to do from here. If you don't have access to a car lift. Then you might want to just get a motor hoist and pull the motor from the front of the car. It comes out REAL easy. So let me touch on that real quick.
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Jul 24 2008
    chicago
    Re: Motor pull over view with header install pic's
    Room for more info and part 2 the second stage of pulling out the motor. The difference between the motor pull and motor drop. Will be covered in this section
    Ok so pulling the motor from the front is almost easy at this time. But once again you need a motor hoist and all the needed support parts. Chain, bolts etc etc. But to help you there are already brackets for you to hook up to
    Some motors will have 4 brackets and some will have 3. There are going to be AT LEAST 2. Just depends on weather the motor has been worked on and how many were used to install the motor on the assembly line. Either way you only really need 2.
    After you have the hoist ready and the top of the motor all set you need to go under the car and take out the last few bolts. (if you are pulling out the motor)
    Below you will see the green bolt. this is for the motor mount remove this NUT and also unplug the motor mount ELE connection (just in case) pay no mind to the blue bolts they need to stay in unless you are dropping the motor
    Then the next obstacle in your way is going to be the 1/2 shafts where they bolt to the trans. You need to remove both sides and they are not easy to get to. You might want to remove the heat shield that is above them. But this also not easy to get to. Here is a look with the motor out
    After you move the 1/2 shafts out of the way (you might not be able to move them till you loosen the motor) you have one more thing left. The cross member for the trans mount.
    You can see Im measuring it to show it has to not just be removed from the body but the trans as well to pull the motor out the front of the car. The other thing that is not in the pic but you need to remove is the other trans mounts. They are just in the top of the pic you can't see them. but you will see that they are holding the trans in place. You need to remove those as well
    With all this removed and the other steps completed. Do your check list
    ground strap from the batt, and the ground line from the starter to the frame removed.
    All the ECU and ELE connections removed from the body
    heater hoses pushed into the motor bay
    all the ELE ground connections off the back of the fire wall
    Is the shifter box dropped and the shifter removed
    drive shaft and 1/2 shafts removed from the trans
    Motor mounts unplugged and motor mount bolt removed
    Make sure to check all the other hoses and little lines still connected to the motor and hook up the hoist to the connections shown eariler and pull the motor up and out, making sure you watch the 1/2 shafts
    ///////////////////////////////////////// part 2 dropping the motor out of the car ////////////////////////
    Now there is the other way to get the motor out of the car and that is to drop the motor out. This is obviously the better way to go if you DON"T have a motor hoist and if you have an actual car lift.
    Now keep in mind that you can't just drop out the motor. You need to have some sort of table or platform to put the motor cradle on. I made a quick table out of wood and an old table I had. Now for the logistics of this you are going to have to figure that out. For me it was easy. If I had to suggest the easiest way to go for the standard DYS, I would say get a motor hoist and pull the motor from the front.
    When you drop the motor you actually are doing more work and in the end you are going to need to get a AWD alignment after you are done. So that just adds one more thing to the cost. I have done a motor drop already and I just marked the bolts and made a guide pin to assure the same locations. The car didn't seem to need an alignment but its always best to do so when messing with the front cradle.
    OK so now you are ready to drop the motor. As you will see in the pic below I have the motor already sitting on my table with wood shims to make sure the motor will come out level. I found it easier to remove the sway bar just before I got the motor all sorted out level wise. That has to go any way so now is a good time to do it.
    Now we need to start removing all the supporting parts. So off to the fender well. Below you will see 3 things that need to be removed.
    1 is the control arm for the steering. This needs to be removed and lowered out of the way. (note) put the bolt back into the steering control arm after you remove it from the up rite.
    2 you will need to pull this grommet out and disconnect the ELE connection.
    3 you will need to remove the brake line. Yes later you will need to bleed the brakes
    After you do that return back up top. Remember this pic? now remove the SUS or suspension bolts shown in the pic. There are going to be little rubber covers over the bolts they have been removed for the sake of the pic
    Ok now that you have removed the bolts GO back into the wheel well and you should be able to pull down on the entire suspension and it will look like this
    OK now go and repeat the same on the other side.
    Now we are in the final stretch. Make sure you have the motor set on the table. Now go to the rear of the sub frame and pull the back bolts. There is a piece that is normally there I removed cause you 6 speed guys don't have it. So this is to make more sense to you
    OK now at this point there are just a few bolts holding the motor in. Now this is going to be obvious at this point in time. so I have removed the bracket (that you will see holds the motor mount and motor to the body) remove the bracket only the blue bolts
    Now with the bracket removed you see the MAIN body bolt location of the last bolt holding the motor in. As you can see in the pic the motor is lowered from the body and you can see the location of the last MAIN body bolt.
    So now you are ready to drop the motor out. Now go back and do your checks before moving the body.
    drive shaft removed from the trans
    brake lines disconnected
    control arm off and out of the way
    Make sure to check all the other hoses and little lines still connected to the motor and hook up the hoist to the connections shown earlier and drop the motor down and out, making sure you watch the side of the motor on the frame rail. Then after that...
    Jul 24 2008
    chicago
    ELE or electric connections
    At no point during the write up did I point out the ELE connections and there locations other then in the ECU case. Why? well there are ELE connections almost every where and on every part. From the bumper to the transmission (reverse switch on the 6 speed). There are ELE connections every where. There are 2 that may stump you. 1 is on the pump for the Aux rads. this is on the driver side just behind the aux rad, On the pump it self. The other one is on the passenger side just behind the Aux rad this is for the secondary air pump. But you will see little ELE connections every where. It can get over whelming at times. So take some pic's and don't be afraid to put tape on the connections and label them. If you take more then a day or 2 to put the car back together you may forget where they went.
    Jul 24 2008
    chicago
    Ok I will have more pic's of the RS4 Vs. the JHM header later. I just wanted to post the pic's of the headers on the car cause its been too long since I have been able to see this.
    Let me tell you something. these are a art piece on there own. but to see the amount of time that went into how the layout of them is its just ridiculous. Every part is taken into consideration. If you measure the pipe length they are all with in the same length. These are truly equal length.
    Here is the other side
    There are a lot of bends and turns to make these work. But there still is just enough room for motor rock just encase. Its hard to tell from this pic but there still is a good amount of room left between the frame rail
    Jul 24 2008
    chicago
    This should about cover all the area I will need to get the info in here with the progress pic's of my header install.
    Im at work right now so I have to get some stuff done. I will get more info up later tonight
    So this is a pic of me looking out for you. Check back later for more info
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    i <3 you
    Mar 09 2005
    Santa Clara, CA
    btw, see if you can find that plug that I can't figure out on my car :o
    Jul 24 2008
    chicago
    Send me a pic. Ill be away from the computer for about 3 hours but. Ill look and see what I can do.
    Feb 26 2008
    b7s4
    excellent post, valuable info for the community
    Senior Member Three Rings RudeBwoi's Avatar
    Jan 05 2005
    My 2000 1.8T, Quattro 5spd
    looks like a non diy for me
    GIAC Stage 1 ::: H&R S4 Coilovers ::: V&S Short Shifter ::: B5 Rs4 Reps ::: Intake ::: N75R ::: Tints ::: 12'' Kicker Square Sub
    Need to sell this A4 asap...SOLD
    Account Terminated Two Rings
    Aug 25 2008
    2006 Audi S4, 1963 VW Microbus
    Northern California
    Removing the AC lines isn't to difficult. The AC system just needs to be properly re-sealed and pressure tested. R134aA is something like $12 a bottle, and you need about 1.75 bottles to do the job. just make sure the system is properly pressure tested, then vacuumed out to clear any air/moisture. Then you simply charge it.
    Senior Member Four Rings V8S4Fun's Avatar
    Jul 21 2008
    05 S4, 95 Jetta
    Taneytown, MD
    Nice Justin...great info as always!
    12.59@112.56
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
    Feb 29 2008
    Very well done Justin
    Senior Member Three Rings Tek4ever's Avatar
    Mar 02 2008
    Silver 2004 S4
    Chicago
    Great job Justin!
    B6 S4 | MT6 | F.I. Full Exhaust | ECS Snub | JHM LW Rotors | JHM Chip | JHM SS | JHM LW Pulley | JHM Stage III Clutch | LW OZ Ultraleggeras | K&N Filter | Uber Cabracco85 MAF MOD
    Senior Member Four Rings beemercer's Avatar
    Aug 14 2008
    05 Jeep GC 5.7 Lmtd. QDII - Oh-One Fat-Body Four-Two
    Central Mass
    Oh wow excellent information .
    RIP Sway
    _________
    JHM
    AMA
    Mar 19 2008
    Too many to list now!
    Eatontown NJ
    I am still wiating for either track numbers or dyno numbers from this mod. Anyone have a clue net gains JUST from the headers?
    AZ Content Team Four Rings 10MPG's Avatar
    Oct 25 2006
    '06 AW S4 // '11 PB A8L
    Bay Area CA
    Quote Originally Posted by B6guy42 View Post
    Good work Justin as always and good luck with the install
    There's a dyno meet @ 034 this weekend and I'm contemplating on whether to get a few pulls in so I can cry after seeing the numbers. The problem is that I don't really have a baseline pull from right before the mods were installed so I'm not sure how I can realistically calculate the gains from the new parts.
    I do have a chart but it was a pull from 2 yrs ago on a mustang dyno from a different facility. The mods are essentially the same as what I had before the header install which includes FI fullback/K&N filter/Revo. The result was a disappointing 244HP/250TQ before the chip and 266HP/260TQ after chip.
    I thought it was interesting considering the stock number was 340 to the crank and even @ a conservative 22% DT loss it should be somewhere around 265HP stock. Not to mention revo chip tuning on a NA engine can yield 22HP/10TQ was a little hard to believe as well for me.
    So that's my story - Anyone want to Paypal me $55 so I can go do a few pulls this weekend?
    Active Member Two Rings Storm33's Avatar
    May 13 2008
    05 B6 S4 MT6
    Ann Arbor, MI
    Way, WAAAY thumbs-up on this, Justin. You rock!
    For the record, I personally wouldn't consider attempting this myself. I was comfortable changing the water pump, alternator and such on an old Corvette but getting under the hood of this Audi is an intimidating experience. It's cramped quarters plus I just don't have time for it like I used to and I'm afraid I'd screw something up.
    2005 B6 S4 MT6
    Silver / Black
    Stage 3 Forum Advertiser Three Rings Dan@JHM's Avatar
    Mar 17 2007
    2007 B7 RS4 - 2001 A6 4.2l w 6-speed
    Lathrop / Stockton, ca
    haha justin is like the super man of the 4.2 s4 section, he really does make my job easy :)
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    NYC and carless
    Quote Originally Posted by Dan@JHM View Post
    the amount hes been strong arming you guys into making so many great products for the 4.2, I figure hes just making it up to you guys a bit by posting a DIY
    2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Senior Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Wow I don't know what to say. This is Very well done, lots of time put into this.
    I can't say that the pull looks any easy to do. But I feel well informed now and would def use this as a guide for many projects.
    Thanks again Justin
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Senior Member Three Rings littleredwagen's Avatar
    Jan 08 2008
    2001.5 S4
    awesome write up. FWIW for the 6spd guys you will have to disconnect the hydraulic lines to the clutch slave cylinder
    -Matt
    2001.5 S4 Imola Yellow
    Past: 2005 S4 Avant 6spd Brilliant Red, 2007 VW GTI, 2004 Jetta GLI 1.8T
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    wow, thanks for taking the time to take pics and post an explanation, this is great stuff
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
    R.I.P. Three Rings
    Nov 09 2008
    B6 S4, 95 VR6 Jetta
    savannah
    Hey Justin, thanks a lot. I will be doing the headers and all the other goodies probably this weekend or soon. I'll write up a review on this DIY. FYI, I have never pulled the motor, so I'll tell you guys how helpful this is or if I can ad stuff to it.
    Justin, do you think you can PM me your # for if I run into kinks or problems while I'm doing this? One more thing, how many hrs did this take you the first time you did this?? Also, is there any specific torques for certain things?
    Jul 24 2008
    chicago
    Quote Originally Posted by littleredwagen View Post
    Thanks Matt. I had a pic of this on my camera but it wasn't cooperating so I never got around to posting that. Thanks for the reminder. The pic sucks I put up but it should help
    Active Member Three Rings
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    Dang dude. You've outdone yourself again with more invaluable information for the community. Thanks for posting man!!!
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Props Justin!
    I haven't been around in a while...craziness has been going on since i've been gone!
    The RIDES:
    04 B6 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts | Few minor weight reductions
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Mar 02 2008
    Silver 2004 S4
    Chicago
    You HAVE been MIA b00t. Welcome back - hope all is okay.
    Senior Member Three Rings c4racer's Avatar
    Dec 23 2007
    2005 S4 Avant - 6MT - SOLD
    San Jose, CA
    Quote Originally Posted by Dr.quattro View Post
    just be careful not to get any dirt inside the system while it is open. Or it might fry the compressor later. BTDT....
    Just seal it all up with some rubber caps or tape or something when you take apart.
    '05 S4 Avant - 6MT - sold
    07 Corvette Z51
    '00 BMW 740i M-sport
    '11 Mazda CX9
    Dec 23 2007
    San Jose, CA
    Quote Originally Posted by Storm33 View Post
    looks just a tad bit harder than a 3rd gen camaro or 4th gen Corvette....
    I probably would go for it if I needed to pull the motor for something. But I would not do it unless I had something else decent to drive for at least a month. Just in case...
    07 Corvette Z51
    '11 Mazda CX9
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    great post. don't think i'll be attempting this one by myself
    Current: 07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t, premium +, black on black, sport, nav
    Old: 03 a4 3.0qms, thermal exhaust, hyperflow, neuspeed sport, neuspeed bilsteins, h-sport (s4) sways, b&m ss, votex lip, s4 blades, rs4 reps, ecodes, rs4 pedals, 35% tint
    Older: 2000 A4 1.8TQ, bilstein/hyperco, apr, blah blah blah
    Aug 25 2008
    Northern California
    It's made me wonder, before charging, with regards to the compressor, I don't think oiling is necessary when the compressor isn't removed. you?
    Quote Originally Posted by c4racer View Post
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Superior, Colorado
    great post, always so informative! Man, I wish I had the balls to try this myself!
    Forum Moderator Four Rings SoCalS4Avant's Avatar
    Jan 24 2008
    B8 A4 Avant, Touareg V8, E30 318
    Pasadena, California
    Quote Originally Posted by oatzel View Post
    We can all go to Ed's house and work on it!
    Justin - great work/write up.
    Dan - Moderator/Wiseguy
    EuroBerge
    Senior Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    wow! thats a lot of shit to go through! Great pics and write up Justin. two thumbs up!
    Sep 27 2008
    Hobart IN
    Thanks for the write up.
    Dec 05 2006
    2 Stroke Street Bikes, MKV GTi, Porsche 997 GT3.
    So. Cal.
    That's just incredible. Lol.
    You are one amazing shadetree mechanic!
