The first evolution was pretty basic with a Garrett T3/T04E, custom exhaust manifold, 3" exhaust, front mounted intercooler, bigger injectors and a reprogrammed ECU. The car never went any good, there was always something that made some issues and in the end the engine had to be filled with a quarter oil every week so it was pretty much done!
The second evolution, the car that never got built haha
Somehow on the way the project got out of track and almost everything got sold.
Evolution 3
Well this is where we are now, pretty much has changed anyway but we are still on the same plan so far haha
ENGINE BLOCK
JE pistons with 8.8 comp, ceramictreated pistonhead, skirt coating and accumulator groove
Total Seal gapless pistonrings
AutoVerdi rods with ARP studs
ARP headstuds and maincap studs
Rodbearings from a diesel engine
OEM mainbearings
New oilpump
Rebuilt oilpan
HEAD
Max ported with raised and widen channels
CatCams camshafts with 12mm (0.47") lift and 280 degree duration
CatCams adjustable inner camgears
Dahlback Racing outer camgear
Solid lifters
Titanium retainers
RaceTech valvesprings
Inconel exhaust and stainless steel intake valves
OEM valveguides
FUEL
Aeromotive Eliminator fuel pump
Aeromotive AFPR
Aeromotive 10 micron filter
034 Motorsport fuelrail
1600cc injectors
AN10 fuel lines
EXHAUST SIDE
Tial 44mm wastegate
Borg Warner S480 turbo
Custom Part Service exhaust manifold
4.5" downpipe and then 3,5" to the back
INTAKE SIDE
Tial 50mm blow of valve
Custom Part Service intake manifold
CHASSI
Yellow Koni Sport shocks (adjusable stiffness)
H&R 40mm lowering springs
Audi S6 front struts
Steal bushings for the front and rear subframe
New OEM bushings for everything else
034 Motorsport engine and transmission mounts
ELECTRONICS
Nira i3+ engine management system
Innovate LC-1 DB digital wideband lambda
034 Motorsport High Output Coil Kit
High Output sparkplug wires
Bosch F6DTC sparkplugs
TRANSMISSION
Modified center differential for constant 50/50 wheeldrive
034 Motorsport adjustable shortshifter
Spec stage 5+ clutch with pressure plate
Spec aluminium flywheel
Redline Heavy ShockProof transmission oil
INTERIOR
Greddy EGT gauge P/H&W
Greddy Boost gauge P/H&W
Audi S steeringwheel
Momo carpets
