Page 19 of 19 FirstFirst ... 9171819
Results 721 to 757 of 757
  1. #721
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    Quote Originally Posted by speeding-g60 View Post
    i have never readjusted mine, but then iagain i dont get much mileage haha. solid lifters take a fair bit of time to set up initially, from scratch. but once you are there, it is there.
    right now i am clearancing this ported AEB head for the BIG IE solid cams. the intake cam needs cleared for all lobes going into and out of the lifter bore, as well as underside of the cam caps. lift is the name of the game. i dont know if the exhaust cam needs anything yet, one stick at a time.
    i dint have to do any clearancing with my CAT solid lifter cams, and its exhaust cam is even larger than the IE cam is. so i think i will be good on it.
    Yeah, and I imagine that the consequences of a misadjustment are a little more severe when you're spinning at 11,000 as opposed to a street vehicle between 7000-8000.
  2. #722
    Veteran Member Three Rings chris164935's Avatar
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Very interesting progress with this thing! I have an SEM manifold on the way right now. What throttle body/TPS (brand, size, etc.) are you using with your SEM manifold? Looks like it was a direct bolt-on?
    Also, any specs you can provide on the IE solid lifter cams or is that still hush-hush?
    "You know you have a bad idea when Ford guys are making fun of you."
    "The Internet is dead."
    FS: Bullseye Power S372 1.10AR Divided T4 W/ Standard Cover.
  3. #723
    Senior Member Three Rings speeding-g60's Avatar
    May 19 2009
    PNW
    Chris, here is a link to the next motor.... it has cam stuff in it. http://www.audizine.com/forum/showth...er-motor-build
    as far as the TB, i run a standard BBK/Summit 75mm unit made for a Ford mustang, with a standard Ford TPS and no IAC. all run by the Autronic SM4. and it is a direct fit, i sent SEM the TB i was going to use and they made the necessary adjustments for it. then i had to make the bracketry to hold the cable. done.
    BetaAlphaTau Member number 366
    603 AWHP / 438 wtq. 32 psi. Integrated Engineering off the shelf 2.0L stroker motor.
    First and ONLY 9 second 4cyl Audi in NORTH AMERICA!!!!!! 9.90 @ 141 with 1.49 60'
    http://speeding-g60.com/
  4. #724
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    So, they drilled the holes to mount your specific throttle body? The one I am getting is already tapped for an 80mm throttle body. I just want to make sure I can get a throttle body that will bolt on. I am going to be using Autronic SM2; so DBW is not an option.
  5. #725
    May 19 2009
    PNW
    uncorrected dyno last night. 742 awhp / 572 tq @ 40 psi.
    corrected 716 AWHP / 552 tq.
  6. #726
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    Just seen this on motorgeeks. I'll say it again. shit is bananas.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  7. #727
    Active Member Two Rings RudeJude518's Avatar
    Oct 10 2010
    Albany, NY
    Very very niiiiice
    Xbox Gamertag: Ya uraHERB soi
    Call of Duty when I can find time between work and taking care of the new baby.
  8. #728
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Murrieta
    Nice numbers, can't wait to see what it will do at the track.
  9. #729
    Jun 21 2005
    B6 Avant
    Milton, Ontario, Canada
    Frickin' insane.
  10. #730
    May 19 2009
    PNW
  11. #731
    Oct 06 2004
    Minnesota
    Love it Richard.
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
  12. #732
    May 19 2009
    PNW
    done a ton of shit since i last posted here.
    dogbox is done and in the car with sintered iron discs in the twin.... added a Wavetrac diff to the front while i was at it. why not, right?
    bought a lift for the garage since i am done working on the ground anymore, trans R&R especially.
  13. #733
    May 19 2009
    PNW
    yesterday, Justin came down to Speeding-G60 Race Team HQ today and we spent the whole day redoing the entire boost piping, utilizing Linder Power Systems custom couplers.
    we welded onto the turbo compressor outlet, the A2W intercooler inlet and outlet, even cut off and welded on to the throttle body.
    it was a longish day of fabrication and welding, and it looks kick ass. i had a MESS of little horseshoe shaped niblets of aluminum pipe laying around when i was done from the constant nibbles and cuts, etc.
    THANKS JUSTIN!!!!!
    had a fat 3 lb Rib-Eye lunch and beers along the way. when welder comes to you, then feed him you must!
    and this is the coupler and how it works.
  14. #734
    May 19 2009
    PNW
    redid the WG SS hardlines.
    while moving stuff around, i found a lil cut on one of the slicks so i had to get 4 new ones.
    installed the new turbo finally, and put on the 1.25 A/R hotside. old turbo turns out was only a 63mm unit, new turbo is billet 67mm. also added a line to log backpressure to the ECU, we can tune for changes at the dyno/track.
    just going to start with the 1.25 housing....
    but i needed to clean it up a lil, for some reason these BW turbos are kinda rough in the hotside inlet. lay on gasket, scribe some marks, and get to grinding.
    Left to Right 1.25 ****> 1.10 ****> 1.00
    Billet is cool and shiny and stuff
    i already ported this housing long ago.
    fair bit of material to get out of there
    almost done
    VIOLA!!!!! should flow much better now....
  15. #735
    May 19 2009
    PNW
    got and installed an Autronic CDI 500r (from Kevin "lugnuts" Black) and Bosch Motorsports coil setup with 034 wires.
    also, built new steering stuff and TIG'd new steering arms.
  16. #736
    May 19 2009
    PNW
    i have been busy, and am not really doing too much on the car forums anymore. i still am, but nowhere near as much as i used to. i put that stuff up on my FB and my FB racecar page anymore, and my own website.
    but i cant wait to run this car again this year!!!!! its going to haul serious freakin ASS!!!!!!
  17. #737
    Active Member Two Rings bmx_a4's Avatar
    Aug 19 2008
    Sheridan, WY
    All of it is looking way awesome! Those couplers are pretty bad ass.
    2000 Santorin A4 1.8TQM,
    Test pipe/turbo back exhaust/Eibach springs/clear corners/Single mass flywheel/APR Turbo Inlet Pipe
    Soon to come : IE Rods/JE pistons/FMIC/maybe even a turbo/wheels/get some head....work done
    I own a camera
  18. #738
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    This thing is so amazing. Every time I see it I hate myself for being so lazy with my project.
    That dogbox setup looks incredible. Is it custom?
    I've been looking around for a bit, but haven't really be sure what plug wires to go with for my car. Are they the ones you switched to? http://www.034motorsport.com/ignitio...oil-p-429.html
  19. #739
    May 19 2009
    PNW
    THANKS!!!! i try. the dogbox was custom made for my own gear ratios, determined by my Tuner Kevin Black. based on things like weight, tire size, power, power band, etc.
    got a set for an I-5 that are unterminated and longer so i can put the coil further away.
    but i blew an FSI coil on the dyno that night, on my first try @ 40psi. it popped at around 375 awhp/375 tq, and i put a backup set of 115r's in and it went fine for 737 awhp/568 tq. got home, discussed the CDI, and bought it when Kevin said he had it lined up and ready to go. i dont want to be popping coilpacks on the track.
  20. #740
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    You wont regret these with proper Magnecor wires - trust me
    A4 B7 1.8T 20v Quattro Project
    powered by ToM's Garage and Etuners
    Mike
  21. #741
    Senior Member Three Rings EvilBunny's Avatar
    Oct 23 2009
    84GLi,06 M3, 08 stolen stereo,'10 ninja
    hawaii
    effin beautiful as always bro...
    when we due for a visit from you in the islands here?
    :HOMEGROWNMOTORSPORTS:: 1:5.2 VulcanWorks CarpeDiemSTS808 1.8l20vAEB3651UnitronicFerrera630cc3071rSEM80mmA/W034Southbend.IE484/391::DIY::-1984JettaGLi
    ..missing the mainland..
  22. #742
    May 19 2009
    PNW
    i dunno when i go back....
    got some more work in. NHRA oil retention device. and i got the A2W piping tagged and put back in.
    oil retention catch pan....
    piping tagged
    retention pan installed.
  23. #743
    Aug 19 2008
    Sheridan, WY
    Every time I look at this thread, it makes me smile. You're doing some awesome work man!
    I own a camera
  24. #744
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Any updates?
    Also, for your motor's main bearings, are you running channeled bearings on the bottom and smooth bearings on the caps or is one of your top bearings channeled too? Basically, Are you running 4 smooth and 6 channeled main bearings? If so, which cap do you have a complete channel on?
  25. #745
    Oct 23 2009
    hawaii
    :beer::beer::beer::beer::thumbup::thumbup:
    Sent from my SPH-D710 using Tapatalk
  26. #746
    May 19 2009
    PNW
    Chris, i run a complete channeled setup on #3 main.
    and i did some more stuff.... i changed the VC up because i went to an Autronic CDI and plug wires with Bosch Motorsports coil. i wanted a cleaner run for the plug wires, so i whipped up a different VC. also eliminated a couple of the breather ports, i dont need that many i dont think. dont ever get a drop in the catch can now so.... also, redesigned the catch can, but its still getting built.
    also, i got the dogbox in, and did some no-clutch, no boost (not even piped in) quick shifts. i cant wait!
  27. #747
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    SIIIICCCccccck
    Did you see how the camera twitched just a tiny bit @ 53 seconds!!! Too much sound energy..
    love it.
  28. #748
    May 19 2009
    PNW
    had a freaking TERRIFIC EVENING ON THE DYNO!!!!!! driving into the trailer tops ALL.
    but, got some good solid data... and ended up 759AWHP/554 tq @ 38 psi, that is more power (22 hp) and less tq (14 ft) but with 2 psi less.
    changes were old turbo had cast 63mm wheel and 1.10 hotside. new turbo has 67mm billet wheel and 1.25 hotside. we did log all of the runs for backpressure and will be looking into that as well.
    pass 4
    pass 5
    then us being us, we deciding to forego 800 AWHP in favor of a 4 gear bash clutchless shifting. and its gonna be sofaking BADASS!!!!!! 3 days! we even turned the boost down in each gear, specially the 1-2 transition. 3-4 was pretty much as it will run.
    pass 6
    and yess, that is a 40 psi gauge. it holds right where the tuner Kevin Black says to hold it.
  29. #749
    Active Member Two Rings The*Fall*Guy's Avatar
    Sep 13 2009
    98 B5Q 28rs(SOLD) 2001Jetta
    Illegal Alientown PA
    Sick shit duder :eek:
  30. #750
    Senior Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    08 Rabbit, 2000 A4 VR6T Avant, 2004 R32 Turbo
    Buffalo, NY
    So are you gonna go fast yet?
    :-p
  31. #751
    Feb 08 2011
    Murrieta
    Nice numbers, cant wait to hear how things go at the track.
  32. #752
    Oct 23 2009
    hawaii
    go get some aaron!!
    Sent from my SPH-D710 using Tapatalk 2
  33. #753
    May 19 2009
    PNW
    ran a new best. even with sun directly in my eyes....
    but 9.78 makes this car the quickest Audi 4cyl Quattro drag car in the world at this point in time. not bad for a random guy who build a car in his garage at home, i dont think.
    and we were running less boost on the track than we were on the dyno, as well.
  34. #754
    Active Member Three Rings jaychen's Avatar
    Feb 19 2011
    Brisbane
    Congrats mate
    Just want seat time again, that's all.
  35. #755
    Oct 23 2009
    hawaii
  36. #756
    May 19 2009
    PNW
  37. #757
    Oct 23 2009
    hawaii
    lol fukn sick dude. btw..you need a tan there pasty man.
    beers and hawaiian sun usually do the trick.
