Page 1 of 7 123 ... LastLast
Results 1 to 40 of 273
    Senior Member Two Rings A4GY's Avatar
    May 22 2005
    1998 Audi A4 2.0T Quattro and 1998 Lexus GS400
    Littleton, CO
    My little 1998 A4 2.0L GT35R built TIPTRONIC
    371whp/313ftlbs at the wheels on 91oct pump with 25psi. Dyno sheet and video on page 6. E85 and/or C16 tune coming soon!
    1998 Audi A4 Quattro
    Engine:
    -JE Forged Pistons-8.5:1
    -JE Pins and Premium Ring set, End Gap set
    -Carrillo Forged Rods with ARP hardware
    -Forged Crankshaft
    -High-Performance-German Main Bearings
    -High-Performance- German Rod Bearings
    -Main Bearing Girdle w/ Oil Scraper Installed
    -ARP Main Bearing Studs
    -Special 2.0 Liter Steel Head Gasket
    -Modified Aluminum Oilpan
    -Additional Deck Cooling
    -RS4 motor mounts
    -Power stearing cooler
    -ECS magnetic oil drain plug
    3zero3 Motorsports Built Tiptronic Transmission:
    -Custom calibrated valve body
    -Hi Energy friction plates and laser cut, surface treated 1008 steel plates.
    -7 friction disk "C" clutch pack
    -New one way clutches (sprags)
    -Heat treated Planetary splines
    -Cryogenic treated input shaft and planetaries
    -Heat treated Sun shell
    -Redesigned Lube system
    -Revised Lock up system
    -Custom High Stall Torque Conveter
    Turbo:
    -Anodized Black Evolution Raceworks FMIC with 800hp Garret core
    -GT35R
    -Customer intake manifold by Chris Tap
    -034efi high flow fuel rail
    -034efi fuel pressure guage
    -Aeromotive adjustable FPR
    -1000cc injectors
    -Customer equal length exhaust manifold by Jay Thorton
    -4 inch biag air MAF housing
    -Tial 38mm wastegate
    -Cat cams
    -Adjustable cam gear
    -Custom Eurodyne/Chris Tapp software with 93oct/C16
    -Bosh 044 fuel pump
    -Turbo Smart dueal stage boost controller
    -NGK BKR7E spark plugs
    -Larger MAHLE oil filter
    -Fuel Race custom downpipe 3inch
    -034efi/Borla exhaust 3inch
    Suspension:
    -H&R Ultra Low Coilovers (600front/625rear)
    -Gutted and pulled fenders
    Brakes:
    -Stoptech 332x32 floating slotted front rotors
    -Stoptech 4 piston ST-40 front calipers
    -Power Slott rear rotors
    -Stoptech stainless break lines front and rear
    -AXXIS Ultimate brake pads front and rear
    Wheels and Tire:
    -18x8 et35 OZ Superleggera Wheels
    -225/40/18 Kumho Ecsta tires
    Exterior:
    -OEM S4 front bumper
    -OEM RS4 front grill
    -In-pro clear side markers
    Interior:
    -Greddy Turbo Timer IV
    -Innovate LC1 + db guage wide band
    -Stewart warren boost guage
    -MB Quart speakers
    Oct 06 2004
    Minnesota
    Re: My little 1998 A4 2.0L GT35R built TIPTRONIC
    WOW. This looks interesting. Keep us updated!
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    May 22 2005
    Littleton, CO
    She is pretty much done. Drove her for a day and blew the stock tranny lol. Transmission is in the mail on its way back to me from ipt should be back on road in the next two or three weeks.
    Oct 06 2004
    Minnesota
    Sent you a PM. Do you have any videos from the first couple pulls? :-)
    R135
    246
    May 22 2005
    Littleton, CO
    sadly i do not but i will be headed to the dyno to finish up the tune and will have video of that and will post video of some runs on the road on the way to the dyno lol
    Senior Member Three Rings kevin12's Avatar
    Jun 20 2007
    2001.5 A4 1.8TQ
    South Jersey
    Wow this insane, especially on a tip! Definitely some major funds. Hope to see up and running soon
    Old: 99.5 Laser Red A4 2.8Q Tip Totaled RIP
    Current: 01.5 Casa White A4 1.8TQ
    Uni 1+, Intake w/ Blinktek HS, ST Coilovers, Hyperboost DV
    May 22 2005
    Littleton, CO
    Quote Originally Posted by kevin12 View Post
    thanks me too def been a long process!
    Senior Member Four Rings audi til I die's Avatar
    Mar 04 2008
    LML/Allison
    Compton Hills, IL
    Wait... so you had the 35r running and you drove it with the stock tip??? lol. You must've not wanted it at all. Very interesting and props for taking on this project I'm afraid of putting a 28 series turbo just cuz it's a tip but I'm sure that built tranny is more than what I'd want to pay. If you'd like to PM me a ballpark just so I can keep this idea out of my head feel free to do so. lol.
    BTW I love the background to your parts pics. BULLS FTMFW forever
    This is my troll account.
    "One day you will figure out that skinny jeans are just not that cool" - Thomas@TAI-VW
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    '00 A4
    NH
    why not a 44mm WG on that manifold?
    also, how does your hot side piping match up to your turbo outlet? Mine looks like the silicone wants to rip.
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    What do you mean by "Custom Tune"? I know CTapp has 2 distributers in the US. One in NY and the other in CO. Is his distributer able to do custom tunes for you, or did he give you an off the shelf tune and you are just having him tweek it for you? Thanks!
    BTW, that build is bad ***
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    you cant tweak NDBW (96-99.5) cars CTAPP only offers a 1000cc or 630cc file for us. Only way to custom tune is SEM
    May 22 2005
    Littleton, CO
    Quote Originally Posted by audi til I die View Post
    Knew that it would blow just didnt think it would blow right away lol. . The total parts cost with shipping is aprox $5560 for the built tip trans
    May 22 2005
    Littleton, CO
    Quote Originally Posted by Euro-Tuner View Post
    no real reason on going with the 38mm over the 44mm just pretty much went with what Chris Tapp suggested....
    your talking about the intercooler pipeing right? mine seems to fit just fine I can get a picture if you like.
    May 22 2005
    Littleton, CO
    the software I am running is the exact same tune that Chris ran is his shop A4.
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    I didn't know full-race made a 38mm WG...
    Im excited to see this thing run, but I have a feeling the tiptronic might kill the power
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
    May 22 2005
    Littleton, CO
    not a full race manifold just have a full race down pipe. manifold was made by jay thorton
    Active Member Two Rings STS9king's Avatar
    Apr 27 2009
    Denver
    I know Ctapp has a dealer in NY (arnold) but CO???? who and where? I live in denver and have not heard of this dealer. Please inform! and nice project.
    1999 A4 Avant: gt3071r, Tapp 630cc software (91 octane mode only), apr exhaust mani (t25), SB stage 4 clutch, 034 track density motor/tranny mounts, wahlbro 255, porsche brakes, h&r sports w/ bilstiens, rs4 wheels, turbo timer, JHM solid linkage and bushings, e-code lights, 3" custom turbo back, Treadstone 666hp core FMIC: 13.7@101mph (6000' altitude)
    (old ride) 01 1.8t jetta: t3/t4 13.3@107mph (6000' altitude)
    Need a realtor in Denver with a fast car?
    Dec 05 2007
    ^ http://www.eurodyne.ca/dealers/ There is one user on this forum board (B5 A4) I know of whom has CTapp from the CO distributer. To the OP, pardon the thread jack.
    May 22 2005
    Littleton, CO
    Quote Originally Posted by STS9king View Post
    Its my friend Alex in highlands ranch.
    Schnell Motorsports
    303-726-1095
    Mar 04 2008
    LML/Allison
    Compton Hills, IL
    Quote Originally Posted by A4GY View Post
    Wow, you sound like a determined man. lol. I'm very curious to see how the tranny plays out. Haven't heard anything but good shit about IPT. What boost you planning on running when it's all said and done? I have a left knee problem and I'm skeptical on getting a MT since it swells up when I drive on it too long so tip builds catch my interest
    May 22 2005
    Littleton, CO
    aprox 20psi on pump (91oct) and aprox 35psi on c16 (116 octane)
    Apr 27 2009
    Denver
    ^^^^^^^^Thanks alot for the info..... And, A4guy, lets meet up, I wanna check out that build! I have a build of my own underway as we speak!
    May 22 2005
    Littleton, CO
    always down to meet up. the car is currently at 3zero3 until the trans is done being put in
    May 22 2005
    Littleton, CO
    im curious to see how it compare to the manual car out there. think it should do just fine especially considering the converter stall has been raised to around 3500prm
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    wow! this build is insane. At what rpm would you see boost? Won't the tip automatically shift up once it touches redline?
    TEAM|AXION
    Apr 27 2009
    Denver
    with the chip tune, they can change when the car shifts if its a tip. The apr stg 3 auto cars shift like 500 above redline.
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    Wow, I am excited to see this thread, I think Mike has mentioned your car before to me. I too have the IPT VB and I need some inspiration to go bigger without killing my car!!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    what are your rough power goals. i have a friend that blew his IPT tip tranny in 3K miles with a 3071. hope you do better. this will DEFINITELY be a record on a TIP trans LOL (if it can take it)
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Looking forward to seeing what the IPT transmission can do.
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
    Senior Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Ya! a local build. Would love to do some pulls against the 35r tip compared to my soon to be 35r manual trans! Still havent decided yet on what trans tho...
    Jan 06 2007
    '00 A4
    NH
    that's be great so we can compare, I'll do the same...
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    01.5 A4 1.8T and 06 VW Passat 2.0T
    Orlando, FL
    wow indeed!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HIDs|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    May 22 2005
    Littleton, CO
    Quote Originally Posted by speedydragon View Post
    wish i could give you a good answer on this. but i have not been able to run anyting more then 14psi before i blew the stock tranny lol. with the ecu tune and tcu tune the shift point will be higher then stock redline.
    May 22 2005
    Littleton, CO
    Quote Originally Posted by biketsai View Post
    yeah mike is a good guy he has helped me a lot i have even purcahsed some parts through him.
    thanks again mike!
    May 22 2005
    Littleton, CO
    Quote Originally Posted by 4inchMAF View Post
    we est the hp to be aprox 675hp at crank on c16 at aprox 33psi.
    we told ty at ipt the hp estimates and he said its no problem and is also giving me a 12k mile one year warranty (only company willing to warranty a tip trans build) so i feel pretty confident.
    May 22 2005
    Littleton, CO
    Quote Originally Posted by Issam@034 View Post
    Me too and thanks again for the parts help 034 rocks!
    May 22 2005
    Littleton, CO
    Quote Originally Posted by jrock View Post
    that would be cool! have i met you before? either way let me know when your done on your build!
    May 22 2005
    Littleton, CO
    probably wont be down at the shop until early next week will try to remember to bring my cam!
    also as a side note that i forgot to mention. i had my fmic made as a clone to mike hoods fmic before they started producing them for "off the shelf" so my pipes may be a little different? maybe mike can chime in or you can contact him. will try to get pictures still though!
    Oct 02 2007
    Lone Tree, Colorado
    Think I talked to you a year ago or so trying to check out your ride as I noticed that you were building it for a 35r, but never really met. I sure will let you know as we will be a couple of the very few with such a setup out here! Surprise considering the amount of Audi's in CO!
    Active Member Two Rings fotograf's Avatar
    Jul 23 2008
    '98 A4 avant aka: Project Slow
    Fort Collins, CO
    That had to be a LONG time ago. We haven't hit up D&B in over a year! I'd love to see it when it's done!
