Results 1 to 11 of 11
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Hard to Fill Gas Tank SOLVED
    I brought this up several months ago but never followed up on it. Things finally came to a head the other day when it took 10 minutes just to get a half tank of gas in my car.
    I did some searching on the net and found a lot of posts that mentioned the carbon canister. I thought I'd have a go at running some tests on the EVAP system. It turns out that the filter for the leak detection pump had become plugged up and would not let air flow back through the canister.
    I've got a replacement filter on order, but for now I've put a bit of hose in where the filter used to be.
    If anyone is interested I could do more of a write up, let me know...
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Aug 06 2008
    San Diego
    Re: Hard to Fill Gas Tank SOLVED
    i had the same problem and the guys at the dealer told me to replace this hose that goes from the top of the charcoal canister to the leak detection pump. swapped it out and it took me maybe 15 mins and it is all better! the hose replaced this huge cylinder that once i took off i couldn't even blow through. Before i replaced the hose it would only fill about two gallons before the pump would click off. i will post up the part number tomorrow if i can find it.
    ::: Cars owned ::: 2004.5 Stonehenge Gray Passat Tip ::: 2006 United Gray MKV GTI 6MT ::: 2000 Nogaro Blue S4 6MT ::: 2005.5 Moro Blue S4 6MT ::: 2010 Ibis A4 2.0TQ 6MT P- Sport ::: 2017 Scuba A4 P+ Tech Sport 19" (Current) ::: 2001 Nogaro Blue S4 (Current) :::
    Apr 11 2008
    Pasadena, CA
    My plugged one says : 8E0 201 801 D
    Let me know if they are the same.
    The Avant Garde
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Thanks for the update. I was thinking about this thread the other day..
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Quote Originally Posted by ...Mark... View Post
    wow you must be clairvoyant
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Apr 11 2008
    Pasadena, CA
    I added a discussion of this and some EVAP system things I learned to the Wiki for the B6 S4: http://www.audizine.com/wiki/index.p...EVAP_Emissions
    The Avant Garde
    Apr 17 2009
    2004 S4, 2007 Ford Edge
    Oceanside Ca
    Where are all these parts located? I've been having a hard time filling my tank recently and would like to try this out. Pics would be much appreciated.
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by 40valve View Post
    Stop using those big words, you're making me think to hard while i'm trying to goof off at work.
    Not that you would know anything about that... http://www.audizine.com/forum/showthread.php?t=283059
    Apr 11 2008
    Pasadena, CA
    Quote Originally Posted by zimdbw74 View Post
    Canister and LDP filter are together. Look under the butt of your car and you'll see a round cover held in place by three cap nuts. Undo the cover and voila, canister!
    Check my wiki post (see above) for more detailed troubleshooting and information on the connections. I'll put up pics when I put in the new filter, it got dark on me last night so I was in a hurry.
    The Avant Garde
    Apr 17 2009
    Oceanside Ca
    Thanks man appreciate it.
    Stage 3 Forum Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 23 2005
    Lathrop, CA
    Thanks for sharing. I love the tech posts.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
