Page 8 of 10 FirstFirst ... 678910 LastLast
Results 281 to 320 of 362
  1. #281
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Re: Who Has cat cams 3652's??? I need your help!!!!URGENT
    what is the epc in the dash? and why is not idling now?
    BetaAlphaTau member #19
    INAEngineering.Com - Most powerful 4 cyl Audi
    tkrace.com Fastest and most powerful 20v 4 cyl VW 715whp 9.14@164mph
    rawtekinc.com custom exhaust systems
    1.Fidanza flywheel machined for sprung hub 100$
    2.1.8t head amb ported to large port spec with supertech valves $$$$
  2. #282
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    I would say your MAF may have just took a crap, but you don't have a MAF. Guess you need a VAG COM!!!
    When you say not idling do you mean you start it and it will die or it is just running really crappy at idle?
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
  3. #283
    Nov 24 2004
    2004 A4 qT
    MOntreal
    it's hard to start and when it starts when I let go the gas it dies....I am just looking through the bentley now The epc is indeed connected with the tb...I don't have a vag com because this stupid computer doesn't have a com port and I have to get the usb cable..I have to hook me up with a real rosstech cable
  4. #284
    Apr 24 2005
    Sounds like the throttle body may have just went bad. Mine went bad once. I had a code that said something about the throttle body to confirm it. Mine was weird though, the car would go into boost and then fall on its face (the throttle was closing) then it would work fine then it would do it everytime. Then right before it went the car was idling a little high at like 1300rpm and was real rich.
    You really need to get a VAC COM hooked to the car and that will tell you everything.
    Maybe try unplugging the throttle body and then plug it back in to be sure for some reason it isnt getting a bad connection.
    ~David~
  5. #285
    Nov 24 2004
    2004 A4 qT
    MOntreal
    anyone know a junkyard that has a b6 tiptronic..Right by the brake booster there is a the brake booster pressure sensor and i need it to wire the vacuum pump
  6. #286
    Nov 24 2004
    2004 A4 qT
    MOntreal
    After checking the wiring diagrams I found out how the vacuum pump works...There is a pressure sensor behind the firewall in all tiptronic cars, but that pressure sensor does not turn the pump on, it tells the ecm when the pressure in the booster is low to turn the pump on..It is too complicated even impossible to make this work the factory way...I have to source an aftermarket vacuum switch and rewire the pump, it's the easiest way
  7. #287
    AZ Content Team Four Rings diagnosticator's Avatar
    Aug 26 2005
    Yes, an adjustable pressure switch* wired to actuate the vac pump as needed is the way to go here. I recommend you use a relay in the power supply for the pump motor, the switch will be connected to actuate the relay control terminals "85" and "86", contacts with the motor + connected to the "87" terminal and the motor negative grounded near the motor mounting. The "30" relay terminal is connected via a fuse to a positive buss connection or the battery + post.
    * with a pressure set point at the appropriate absolute pressure to turn on the pump motor at the desired pressure increasing, then off again at the set point selected, decreasing. The pressure switch will have some hysteresis that is different for increasing or decreasing pressure, but that is a requirement so that the pump doesn't cycle on/off constantly when the actual pressure is near the set point pressure setting. Either the ON or the OFF set point can be precisely selected, but not both at the same time, as determined by the specifications of the pressure switch used.
    I might have a suitable pressure switch on hand in my hardware inventory, I can check and let you know if I have one available.
  8. #288
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Quote Originally Posted by 20vturbo View Post
    What can be wrong in the assembling of the head??The guy that did it did several vw heads, the head on the autoextreme car is done by him...I can't possibly see anything other than a valve lock not beeing fully in??
    Do you have any ideeas??
    It is not uncommon.
    Regardless, I want you to put smaller fuel injectors (quiet ones) in and see if the noise goes away.
    With the extent that we are pushing these motors, you can not jump to conclusions and cut corners. Bad things will happen. I have seen too many people on these forums in the past couple of years cut corners (even the slightest) and ultimately had a blown motor. I know how much you've worked on this and I don't want to see that happen to you.
    /end of my comments. I think I've beat this horse enough...
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
  9. #289
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    * with a pressure set point at the appropriate absolute pressure to turn on the pump motor at the desired pressure decreasing, then off again at the set point selected, increasing. The pressure switch will have some hysteresis that is different for increasing or decreasing pressure, but that is a requirement so that the pump doesn't cycle on/off constantly when the actual pressure is near the set point pressure setting. Either the ON or the OFF set point can be precisely selected, but not both at the same time, as determined by the specifications of the pressure switch used.
    If using a 5 pin relay I would suggest using 87 for main power and 30 to the motor, this way the center pin(87a) is not hot all the time when the relay is not activated by the switch. Using 30 as the main power is fine if using a 4 pin relay since there wont be an extra pin that is hot all the time. For pins 85/86 I would suggest running one of them to a key power source and the other one to a switch as a ground source to activate the relay. This why the switch part of the relay doesn't have constant power while the car is off.
  10. #290
    Aug 26 2005
    That is a good tip, thanks for posting that!
  11. #291
    Nov 24 2004
    2004 A4 qT
    MOntreal
    There sia switch on summitt specific for vacuum pumps Would that work?
  12. #292
    Aug 26 2005
    If the switch is intended for vac pumps to boost brake booster vacuum, then probably yes. What are the specific specs given?
  13. #293
    Nov 24 2004
    2004 A4 qT
    MOntreal
    http://store.summitracing.com/partde...5&autoview=sku
    This is it I think it turns on at 5inhg and shuts off at 25inhg
  14. #294
    Aug 26 2005
    That will work. It is a switch screwed into a cast aluminum tee fitting, provided as an assembly.
  15. #295
    Senior Member Four Rings B6Lovin's Avatar
    Jun 29 2007
    2003 A4 1.8TQM 3076R
    Cary, NC
    if all else fails, physically inspect your throttle body... do you have the q7 TB or the .:R32? (the q7 has a plastic butterfly, the R has a metal one)
    my q7 body literally broke in half... caused a lot of the same symptoms you're having
    Audizine's Quickest/Fastest 1.8L B6 A4 (lol)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
  16. #296
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Quote Originally Posted by B6Lovin View Post
    the one with the plastic flap
  17. #297
    Nov 24 2004
    2004 A4 qT
    MOntreal
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 8E0 UNI 518 BT
    Component and/or Version: 1.8L R4/630 *G 0003
    Software Coding: 0016701
    Work Shop Code: WSC 78901
    2 Faults Found:
    17939 - Camshshaft Timing Adjustment: Open Circuit
    P1531 - 004 - No Signal/Communication
    17695 - Shareware Version. To Decode all DTCs Turbocharger diverter valve Open circuit
    P1287 - 004 - Please Register/Activate
    Both of them because the plugs are disconnected....Although the car runs on 3 the check engine didn't pop and no flashing cel
    I just got these now Car runs like a subaru
    I ahd 10 codes b4 that i saved in the vag com but I don't know where they are
  18. #298
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    So you have a open curcuit for the tens. that you don't have plugged in?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
  19. #299
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Tuesday, 19 May 2009, 22:04:40
    10 Faults Found:
    17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
    P1237 - 004 - No Signal/Communication - Intermittent
    17647 - Shareware Version. To Decode all DTCs
    P1239 - 004 - Please Register/Activate - Intermittent
    17648 - Shareware Version. To Decode all DTCs
    P1240 - 004 - Please Register/Activate - Intermittent
    17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
    P1238 - 004 - No Signal/Communication - Intermittent
    17939 - Shareware Version. To Decode all DTCs
    P1531 - 004 - Please Register/Activate - Intermittent
    17766 - Shareware Version. To Decode all DTCs
    P1358 - 004 - Please Register/Activate - Intermittent
    17769 - Cylinder 3 Ignition Circuit: Open Circuit
    P1361 - 004 - No Signal/Communication - Intermittent
    17772 - Shareware Version. To Decode all DTCs
    P1364 - 004 - Please Register/Activate - Intermittent
    17763 - Shareware Version. To Decode all DTCs
    P1355 - 004 - Please Register/Activate - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 002 - Lower Limit Exceeded - Intermittent
    these are the ones stored from b4...What's up with the fuel injectors??
  20. #300
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Quote Originally Posted by dirtybrd View Post
    correct the tenssioner and the solenoid for the diverter valve..Those came back
    what bugs me is that it is running on 3 but the cel won't flash nor come on..And I still have the no idle issue
    Tomorrow I remove the plugs for inspection and the tb
    I still claim a victory---no cam positioning sensor code so far
  21. #301
    Nov 24 2004
    2004 A4 qT
    MOntreal
    may be that's why my injectors are so loud, may be they're shot
  22. #302
    Nov 24 2004
    2004 A4 qT
    MOntreal
    How did you do that???and it didn't go in the motor?
  23. #303
    Jun 29 2007
    Cary, NC
    id pull that bitch off and check it.
    no clue how it happened. had to have been a defect, or the fact that q7 throttle bodies were probably never designed to be slammed open and shut so often under such great force. (or a combination of those things and others)
    i caught it before half of the thing came off and went in the motor. it cracked right along the center "pin" all the way down both sides and separated into two pieces. it was clinging by a thread... i might have been 15 minutes of hard driving away from another engine
    The Awesome™
  24. #304
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Stef sorry you know I have been unavilable for the last 2 weeks...now catching up.
    Nah because MKV R32's are running around turbo now and they use the plastic throttle flaps.
    Whatever the case Stef pull off that throttle body and tell me if the flap is cracked.
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
  25. #305
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Quote Originally Posted by Issam@034 View Post
    yeah but that throttle is from a q7, r32's have the metal flap, q7's plastic
  26. #306
    Mar 21 2006
    Lakeland, FL.
    Are you sure you have the correct impedance injectors?
    I'm back bitches!
  27. #307
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    Probably would have received a code for that, assuming the car even started.
  28. #308
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Chris how did you get so much rep all of the sudden?
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  29. #309
    Mar 21 2006
    Lakeland, FL.
    Because I'm on here everyday all day long!
    I'm back bitches!
  30. #310
    Nov 24 2004
    2004 A4 qT
    MOntreal
    the injectors are correct
    Those injector and coil pack codes were there because I did a compression test and when I primed the engine with oil I cranked while they were disconnected...
  31. #311
    Mar 21 2006
    Lakeland, FL.
    Ok.
    I'm back bitches!
  32. #312
    Dec 03 2005
    connecticut
    1) physically check the throttle body for cracks and/or breakage
    2) clear the codes and drive the car. let everything adapt and then check codes again to determine what the true 'issues' are.
    3) don't forget a throttle body adapt before driving the car
    -Doug
  33. #313
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Yes I want to check the tb and do a compression test again just to get some thoughts out of my mind, the problem is that is raining right now and I have no cover over my drive way...
    Yesterday I cleared the codes and started the car but it won't hold idle and was like running on 3, sounded like a subaru
    Can I do the tb adapt with my shareware version of the vag??Where do I find it? I tried yesterday but could not find it
  34. #314
    Mar 21 2006
    Lakeland, FL.
    I'm back bitches!
  35. #315
    Dec 03 2005
    connecticut
    check your PM
    -Doug
  36. #316
    Nov 24 2004
    2004 A4 qT
    MOntreal
    I removed the spark plugs they are black which is normal but 2 were wet with gas
  37. #317
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    Cars being worked on
    Fort Collins, CO
    Check to see if you are getting spark on those wet plugs
  38. #318
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Quote Originally Posted by CO AVANT View Post
    tonight when I get back..I am pretty much sure they are fouled
  39. #319
    Jun 29 2007
    Cary, NC
    side note - im assuming you finally got to talk to doug? if not he's been trying to get ahold of you.
    x2 on what stef said, i thought the r's had a metal flapper.
    still sounds like what happened to my old TB. it was cracked and leaking a LOT of air through at idle, made my car dump fuel and idle really low/rough if it even idled at all. also throttle tip-in would usually stall the car... it ran like shit, and progressively got worse to where the car didn't idle at all and i had to consistently be doing something with the throttle to keep it alive.
    The Awesome™
  40. #320
    Nov 24 2004
    2004 A4 qT
    MOntreal
    I just found my fuckin boost and boost control problem Major leak on the bottom chamber of the wastegate...I have a leak where the line screws in with those crush washers, must be because of the powdercoating, and there is another leak along the shaft of the valve, there should be an o ring there I think...
