Page 10 of 10 FirstFirst ... 8910
Results 361 to 362 of 362
  1. #361
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Re: Who Has cat cams 3652's??? I need your help!!!!URGENT
    Quote Originally Posted by dirtybrd View Post
    Just throw on an MBC and see if that fixes it, after the new TB of course.
    That or use the n75...In that case if the boost drops i will know the ecu is trying to do that
    BetaAlphaTau member #19
    INAEngineering.Com - Most powerful 4 cyl Audi
    tkrace.com Fastest and most powerful 20v 4 cyl VW 715whp 9.14@164mph
    rawtekinc.com custom exhaust systems
    1.Fidanza flywheel machined for sprung hub 100$
    2.1.8t head amb ported to large port spec with supertech valves $$$$
  2. #362
    Nov 24 2004
    2004 A4 qT
    MOntreal
    I just redid my vacuum lines to use the vacuum pump...Now I have to find a place to fit the pump and do the electrical
    SOOOO
    1....I am thinking where to put the vacuum switch, I would like to have it in the booster but I don't feel like making a hole in the booster, so I see this little pluged nipple on the booster check valve that is not used and I wondering if I can ran a line from there to bring a vacuum signal to the switch...
    2....The electrical part I am thinking of running it the negative way, meaning that the pump will allways have positive connected to and the switch will send a negative signal via the relay..Is that ok?
    Say what you have to say people
