Results 1 to 13 of 13
    Oct 11 2008
    2002 Audi A4 1.8T Tip
    Connecticut
    Exclamation Slow response: Possible bad Turbo
    So my car just hit 67k and I've been noticing a decrease in the amount of acceleration from my car. No codes are being thrown but I am wondering if my turbo is starting to go. I've been noticing it when I attempt to accelerate from 2k in any gear. For the 1.8T when do the turbo's usually go. Any ideas what could be wrong or what I should do. Thanks.
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    Re: Slow response: Possible bad Turbo
    no, not a bad turbo.. that's probably a mix of turbo lag and other stuff... have u changed ..oil filter, sparkplugs, fuel filter, lately?, i had something similar.. i allignemnt my body throttle.. and it gives a better response.. search on how to allign it.. i dont recall all the steps.
    OEM is sexy.
    May 19 2008
    2003 A4 1.8TQ, 2006 Cadillac CTS
    Bakersfield, CA
    allignment:turn key on but don't start the engine. floor the throttle for 5 seconds. with peddle still floored turn key off then release the throttle peddle. leave key in for 2 minutes.
    check your plugs to make sure they aren't loose. a loose plug gives you poor response and your having to mash the peddle more.
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Could be your cat getting clogged and you're not boosting as much as you should be.
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    If your turbo was failing it would start making the infamous dentist drill noise and you would know. I would start with the plugs like stated above, then air filter, and perhaps a boost leak check.. good luck
    Established Member Two Rings Danyl's Avatar
    Nov 26 2008
    03 Audi A4 Manual
    Milwaukee
    [QUOTE=dr. brian;3667441]allignment:turn key on but don't start the engine. floor the throttle for 5 seconds. with peddle still floored turn key off then release the throttle peddle. leave key in for 2 minutes.
    Is that true sounds a little funny!
    03 1.8TQM APR 93 1+
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    [QUOTE=Danyl;3668349]
    Quote Originally Posted by dr. brian View Post
    Yes.
    Manual throttle body adaptation:
    "The Throttle is "Drive By Wire" and adapts to your particular driving style. Do a TBA Throttle body adaption).
    1. Get in your car, it doesn't matter if you close the door or not.
    2. Turn the key to the on position, the position just before the starter turns over.
    3. Press the gas pedal to the floor with the key in the "on" position.
    4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position(don't remove the key), then release the gas pedal.
    5. Wait 2 mins. for a full alignment. During this time you may hear very faint noises and clicks. I
    only heard one sitting in my car, if I got out and popped the hood I might hear more.
    6. Drive the car as you always do.
    Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so
    I noticed a big change after erasing my history. It is not hard to do this, just follow the
    instructions - Key on, pedal down, 5 sec, key off pedal up, wait 2 minutes.
    Keep the key in for the entire thing. "
    -Matt
    FCDT Member #1
    Nov 26 2008
    03 Audi A4 Manual
    Milwaukee
    I think i'll try that. Anything to make faster :)
    03 1.8TQM APR 93 1+
    Oct 11 2008
    Connecticut
    yea the car recently had a oil change and new filter placed in. I haven't replaced the fuel filter or the spark plugs but it may be time. I will check my plugs and see if they are corroded but for not I will re-align my throttle body and see if it makes a good difference. thanks guys.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I'd do a boost leak check, you might have a leak or failing DV.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 27 2011
    Spring Hill, TN
    2002 Audi A4 1.8T acceleration and trembling issues
    Found your thread and I am also having similar issues. Did you ever figure out what what causing the lag? Sometimes i'll be at an intersection and have to turn quickly only to find my car having to build up momentum and then it goes...not very safe when stuck in those situations. I have had my fuel filter changed, oil filter changed (along with oil change), replaced N75 valve changed, new spark plugs...and still same result. I also think that my turbo might be going bad and I have found oil at the bottom of the turbo.
    On a side note, I also have trembling when the car shifts from 1st to 2nd gear and sometimes 3rd. When this first happened, Audi told me it was a cracked CVG joint and needed a new transmission. Thankfully I had a third party warranty that covered the $7000 cost and Audi put in a Brand new transmission at 104,000 miles. The car ran fine (despite the lack of acceleration) until a few months ago when I started noticing small jitters again like before...now its has gotten worse and Audi tells me that everything checks out fine and that it is normal for that type of transmission to do that...I am not buying it..
    Any thoughts?
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Hey guys... One thing I always stress is maintenance! Luckily we have all of your maintenance needs in stock. Click here for the B6 platform!
    Hubert
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 800.877.7033 x 101
    Email: hubert@europaparts.com
    Facebook: Like Us on Facebook
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2003 A4 Avant 1.8tQ0A3, '72 Nova
    The Cheese State
    Items for Sale
    Quote Originally Posted by dirtybrd View Post
    This.
    The turbo's actual function is fairly binary- if it is making boost it is OK.
    '03 A4 Avant 1.8tQ0A3GT2871R
    Function > Form
