I don't know if this is for the NON Navi - but I've help sicilian2k with some coding too, and on his car he sad that is was on Channel 18 the "hidden menu" was enabled.
Rene Larsen
A4 Avant 3.0 TDI quattro tiptronic MY2009
VCDS 11.11.3 (HEX-USB+CAN)
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
Uncheck the box for "Seatbelt Warning active"
[Do It!]
Enabling Gauge Test/Needle Sweep
This will sweep the gauge needles through their full range automatically when you start the engine.
I thought this was standard on the B8 A4? Anyone know otherwise?
rlarsen... again a trick from audi to make some free money since all is in th car if you don't take the TPMS...
I've tried with a MMI3G... the activation in instruments and abs brakes is the same but don't know where to activat it in the hidden menu of the MMI though,,, its not in car devicel list that is weird or mabe it is under one the listes abrviations but then which one), do you know
I haven't seen the hidden menu of MMI 3G in work yet - so I don't know which menu(s) you should go into.
The best for you is to just 'play around' in the menus
Rene Larsen
Hi. Does anyone know if the VAGCOM can change how the scroll in the multi-function steering wheel works? e.g. at the moment to scroll through songs on MP3 or ipod, you scroll down and then click the wheel to select the song. I would like the song to be automatically selected the moment you scroll down to it.
anyone know if it is possible to make the A/C button that makes the air circulate inside the car stay on using vagcom? everytime the car is shut off and then bak on it turns that function off.
not sure if theres differences between the A/C system with the premium, premium +, and prestige but on my prestige you can turn recirculate automatically on or off.
look for A/C settings in MMI under car or setup then turn it on.
Oooo ok I got it thanks!
Marcus
‘12 Audi A4 Quattro: Premium+, Sport Package, S-Line, B-O, Advanced Key
-Tint: 15% F/R, 50% Windshield
-LED Color Match Fog Lights/Int/Ext, S4 Aluminum Paddles, Pedals & Shifter
-VAG-COM, storage bins, H&R Sport Springs & Plasti-dip valance Coming Soon: 20x9 Vossen CV3 ET 32 , Osir Trunk Spoiler, Custom Blacked-OUT Grille Future: AHHA, Custom Exhaust, GIAC ECU, F/R Parking Assist 4Sale: Spacers F15/R20, iPod AMI Cable, Gloss Black Grille
with the remote windows down code, do the windows always go down all the way and up all the way? my windows sometimes dont go all the way down and all the way up. can i increase the range of the remote?
Not possible.
1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
2nd Ring: 2006 Moro Blue B7 A4 2.0TqMS
3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
4th Ring: TBD
On my car, this setting is available in the MMI by default (no hidden menus or anything), but I'm not sure if it actually works. Are you saying that you have to also manually enable it via VAG-COM to make this feature operable?
I can't get into 07 - Control Head on mine. Anyone got the hidden menu working for a Non Navi 2G MMI?
It is in my MMI and I have it switched on, although I have never seen it activate itself!
Phantom Black B8 S Line 2.0T Fsi quattro
19" 7 Arm Double Spoke Alloy Wheels, Advanced Key, Valcona Leather, B&O Sound System, Electric Folding Mirrors, Electric Rear Sunblind, Cruise Control, Parking System Plus, Bluetooth Low, Interior Light pack,
Mods
Superchips remap, Milltek Turbo Back Exhaust, Front 6000k fogs, Rear LEDs, Rear Number Plate LEDs, R8 Oil Cap
I called my nearest Audi dealer and was told that they aren't allowed to to make any modifications. (which conflicts with what some people have said on this message board but I didn't argue) So now I want to call around to mechanics in the area to see if any of them could do the VAG-COM mods. What is the best way to ask that will make sense to a mechanic? I had some difficulty explaining what I wanted to do to even the Audi dealer so it seems like it might be a hard thing to explain.
BMWBig6: I'm not a verty trusting or mechanically literate person. The list on vagcomlocator.com are random people so if I get one of them to do it I have no recourse if they mess it up, and if I buy one myself to try to do it a) I'd have to spend a long time trying to figure out how to do it and b) I could totally mess it up. =0) but thanks for the suggestions.
I'll be posting up a detailed step-by-step in a few days using the "fully functional" $85 Vag-Com I bought. Just waiting on confirmation regarding which pictures I should/shouldn't post up. It's definitely confusing at first but it's actually not that hard at all. Give me a few days.
This is my first post on this Forum; I ended up here trying to find a solution to my problem (see below). I'm 29, my name is Alessandro and I live in Panama (Rep. of Panama).
I have a 3.0 Tdi Q5 and where I live daytime running lights (DRL) are not required by law. As a result, on the MMI there is no option to turn this function on; It looks as if there is a setting on the VAG-COM that's making Daytime Running Lights not selectable via MMI.
After explaining this issue to my dealer, I was told that this issue could be resolved playing around with the VAG-COM settings, but the technician does not know how . I was told that if I provide them with the codes (or explain how to do it), they can try resolving the problem for me.
The funny part is that they cannot ask Audi by them selves, because this request must be backed up by a letter from the Government stating that local laws have been changed (???)...
In other words, does anyone know how I can, though the VAG-COM, activate an option on the VAG-COM so that DRL option may come back on the MMI Menu?
Maybe it is only available with Audi Sound System (ASS)??
If you have ASS (in Europe the ASS is only available as an extra option), you should have this Subwoofer option in the Sound settings - I don't have it my self, because I have B&O:
u know u are an audi guru. anyway i actually dont have that option in my audi symphony system but that is exactly what i want, how do i enable this option in my stereo?
Marcus
Played a little with a VAG COM yesterday. This is what I did:
- Enabled needle sweep (cool)
- Enabled Lap Timer
- Disabled permanent seatbelt chime
- Enabled VOICE CONTROL IN SPANISH !!! (this one RULEZ)
- etc...
Here's a little compilation of some codes:
Activate Voice Command for the phone
Click Tab: “Electronics 1” Click Module 77: “Telephone” Click “Coding – 07”
Change 00x0x50 (5 = spanish) Click “Do it!” (other languages run from 0 to 9, 0 = off)
Disable Seatbelt Chime
(chimes 4 or 5 times then stops, but NOT permanent anymore)
Click Tab: “Common” Click Module 17: “Instruments” Click “Coding – 07”
Click “Long Coding Helper” Uncheck “Seat belt watrning active”
Click “Transfer coding” Click “Do it!”
Seat Memory
(for electric, non memory seats: key will remember driver’s configuration)
Click Tab: “Electronics 1” Click Module 36: “Seat Mem Drvr” Click Submodule 0 – “Master Cent Elec Box” Change byte 3 – bit 7 (el cuarto desde la izquierda) Click “Do it!”
Or…
module 36 Seat Mem. Drvr (J136), O7, Coding, change Byte 2 bit number 0, to value 1 (checked)
Reverse mirror tilt
(when reverse engaged, passenger mirror tilts down)
module 52 Door Elect, Pass., Long Coding, Byte 4.
If the byte has value 40 (cars without electrically folding mirrors), change it to 4C
Enable Daytime Running Lights (DRL LEDs) STILL TRYING TO FIND OUT HOW TO ACTIVATE THIS
I HAVE MANAGED TO ENABLE THE MENU ON MY SCREEN, BUT NO EFFECT ON THE LEDS…
Module address 09 (Central Electronics) Submodule 0 (Master Cent. Elec. box)
Byte 02 (fourth from the left) - Bit 4 = LEDs DRL
Byte 03 (fourth from the left) - Bit 4 = Uncheck to activate DRL
Enable TPMS for “non TPMS” cars
I MANAGED TO ACTIVATE THE DASH DISPLAY, BUT IT AM STUCK FINDING HOW TO ADD THE TPMS MENU ON MY NON-MMI SCREEN: the third step is missing in my car !!! 1) 07 - Control Head Adaptation – 10 Channel 01 add 16 to the existing value 2) 03 - ABS Brakes Security Access – 16 Coding - 07 (Long coding helper)
Byte 1 - bit 3 set to “1” (xxxx1xxx) 3) 17 - Instruments Coding – 07 (Long coding helper) I CAN’T FIND THIS ONE IN MY CAR !!!
Byte 4 - bit 0 set to “1” [Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)]
- Enabled Lap Timer
- etc...
Seat Memory
Or…
Reverse mirror tilt
About #3 of Enable TPMS for “non TPMS” cars...
If you do an Auto Scan you will get a fault, saying "wrong coding" on the unit you need to enable "Tire Pressure Monitoring (TPMS) installed"
Beside #3 - you have enabled the MMI menu item?? - it should be possible to save the Tire Pressure without #3 - but the entire TPMS system will properly not work, until #3 is enabled.
I'd be surprised if the TPMS worked in the US as the system uses valve tranmitters and I guess they won't be on the wheels.
For the ROW then I don't see why it can't be enabled in software as it's simply using the existing ABS sensors. Perhaps the ROW/US/etc etc setting needs to match the TPMS setting?
I paid for it but it must be frustrating for those without when in theory it's just a case of flipping the right switch to activate it.
I think TPMS with sensors are standard in US cars - so there shouldn't be a need to do it on US cars.
It also seams to be some differences in the coding on different ABS units. On my ABS unit (ending with AH) it was bit 3 I needed to set to 1 - but this is not working on all units.
Rene Larsen
I couldn't make step 3 because such menu was not present after VCDS scanned my car
I have a symphony radio, not MMI (no buttons or knobs around the shift gear)
Is it still possible for me to enable a "MMI item" an a non-MMI vehicle ??
@scottyUK:
I got the USA A5 wheels, got them from a USA seller who was upgrading his A5 to 20", and they came with the TPMS valves
That's why I was curious to mess around with the system
Maybe it is in the [56 - Radio] unit??
Don't you have a CAR menu (see red circle)??
I have no idea if it IS possible - I don't have access to an A4 with your configuration.
I think it is possible to get the TPMS with non MMI direct from Audi - but how it is configured - I don't know.
Rene Larsen
