Page 14 of 37 FirstFirst ... 4121314 151624 ... LastLast
Results 521 to 560 of 1461
  1. #521
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    Miami, FL
    Quote Originally Posted by rlarsen View Post
    Not an answer you can use - but you'll get the outside temperature in the non-MMI system... it is not a full screen display, only one on the bottom line.
    I hate to go against you, but that is not true - at least on my car... The temperature on the bottom line of the non-mmi screen is the temperature the climate control unit is set to... Audi does this because the single-zone ac lacks a built in screen, therefore the temperature is displayed on the bottom line on the 'radio' screen.
    Now what I don't know is what do the P+'s w/ the dual zone ac and built in screen show in that same position, I thought it was just blank...
    Quote Originally Posted by Fichtel72 View Post
    Hi Guy´s .. first of all a big hello from Germany .. My name is Markus , i drive a A4 8K Avant ..
    i have also prog. my car with VAG Com .. but now i´m looking for a solution fpr the CH/LH function.
    On my old Cars , it was possible to activate the function .. doesn´t matter if Light sensor is installed or not. On my Touran , on my Seat Alea , on my Golf 4 and so on .. But not on my Audi .. I work for EMC² Germany , so our customer is also Audi in Ingolstadt .. so i went to the devolpers and try to Ask , but they only tell me .. You need an Light switch with Auto function and a Light sensor. But i wont belive it to 100 % .. So i try .. i can successfully activate the LH/CH function on MMI .. but nothing happend .. then i "activate" the Light sensor .. Result : Error Light sensor ! on FIS ..
    Logic :
    if LH/CH is enabled on MMI
    if Lightswitch is on Auto
    if Lighsensor detects : dark
    if remote control is pushes open .. Leaving home will be enabled
    if you leave the car
    if the Switch is on Auto
    if its dark
    if you press the lock button from your rc : lights will be glow as per definable time at mmi.
    Thats the theory ..
    No we have to find a solution to "say" the system , that a Light Sensor is installed , it´s dark and log no error. And Override the Auto Position on the Light Switch ..
    Sorry for my poor english .. i hope you understand my words.
    By the Way , i administrate the biggest german Car Detailing Community http://www.autopflegeforum.eu also known as www.nikella.de
    Regards
    Markus
    I would love to have CH/LH... (I do not have auto lights)
    I thought there was a CH/LH control module that is missing on the non auto lights cars...
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion |
    Bi-Xenon Retrofit | LED Taillight Retrofit | S-Line Front Bumper w/ S4 Alu Splitter | 19" Hartmann HTTRS MA:M | Vogtland Coilovers | APR/Carbonio Intake | Paddle Shifters | Gloss Black MMI surround | Luminics JDM Yellow Fogs | LED Plate Lights | 20% Tint | VAG-Com
  2. #522
    Registered Member One Ring Fichtel72's Avatar
    Feb 22 2010
    Seat Ibiza Sport Edition
    Munich/Bavaria/Germany
    In the past you don´t need an extra Module or Light sensor .. all Cars from VW Bases on the Golf 4 & 5 Platform an they Subbranch like Skoda & Seat , it workt fine without extra Hardware.
    I think it´s nealy the same like the TPS thing .. only one or two missing bits ..
    It was also with the older Audi´s possible , exept the A3 , for these Model you need the other Light switch , than it work t perfect ..
    Regard
    Markus
    A4 Avant 8K , 2.0 TDI 143 PS , Phantom Black , 8x17 10 Spoke Wheels , Aux. Heat , Sun Shades , Xenon with Dynamic Lights , Audi Sound System , Navi 2G MMI High , Sport Seats , Black Leather . Light Package.
    VAG Com Mods : Needle Sweep , Tire Pressure Control , Remove Seat Belt Chime , DLR "winking" disabled , S4 Spash Screen , Battery Level
  3. #523
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Sweden (south)
    My bad
    Do you then have the outside temperature in the DIS, as the the normal MMI has - or do you have no outside temp at all??
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009
    VCDS
    11.11.2 - Beta xx.xx.x (HEX-USB+CAN)
    Dropbox Invite - use this link and we'll both get extra space!
  4. #524
    Oct 27 2009
    Miami, FL
    My bad
    yep - outside temp shows in DIS like normal...
  5. #525
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    So no hope then, to carry out this mod and see outside temp in MMI??
  6. #526
    Oct 27 2009
    Miami, FL
    Quote Originally Posted by jabicho View Post
    nope... the VAG-Com isn't a magic tool... yes, you can do many cool things with it - but you can only do what Audi has programmed.
  7. #527
    Senior Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    On the P+ with LEDs these's a module #55 called Xenon Range, the P- do not have this. Maybe part of the auto-leveling system. I have no idear. Not sure where to plug this thing in at, if you could obtain it plus the wiring, et al.
    Also, P+ have module 36, btw so i'm thinking they can do the seat pos tied to keys mod posted earlier.
  8. #528
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Quote Originally Posted by Cabal_san View Post
    Your correct. 55 controls the adaptive light modules and the auto level and height control. Although the lights have their own controller they fall under 55 and are controlled through it. Yes again 36 is the seat memory module which appears to do more than just the seat as you mentioned.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
  9. #529
    Feb 22 2010
    But you dont need an extra Modul .. for CH/LV are 2 Components needed .. The Light Sensor and the Light Switch with the Auto Position .. than you are able to Prog. it .. We compare the Autoscan Lists , no extra Unit ..
    Regard
    Markus
  10. #530
    Sep 06 2009
    TX
    So for CH/LH (which i still can not figure out what this does!!) alls you need then is this for a P- to upgrade after the switch to bi-Xenon:
    http://cgi.ebay.de/Audi-A4-S4-B8-Rad...item1e58e2279e
    und
    http://cgi.ebay.de/Lichtschalter-Neb...item5885b2e46d
  11. #531
    Feb 22 2010
    Coming Home : I´ve you came home in the Dark , left the Car , the Fog Lights will be glow for 5-30 Seconds (more ore less) .. to "find the way home"
    Leaving Home : The Fog Ligts will be glow , if you press your remote control to open the car and if its dark. .. so find your car.
    The first link you posted is a completly different thing .. but the Second one is the right ..
    Regard
    Markus
  12. #532
    Feb 22 2010
    Regard
    Markus
  13. #533
    Sep 06 2009
    TX
    Would you mind posting something about the "light sensor"?? What is it? ETKA #?
  14. #534
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Isn't the light sensor part of the mirror, not 100%. The first link is to an adaptive cruise control radar sensor.
  15. #535
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by DavidB8 View Post
    The rain/light sensor is part of the mirror - and a retrofit also include a new windscreen, because there need to be a clear view in the black area behind the mirror.
    Rene Larsen
    VCDS
  16. #536
    Sep 06 2009
    TX
    OOPS, mein Deutsch ist nicht sehr gut, es tut mir leid!
    For some reason I saw rad sensor thinking this was sun sensor, bad translation. i need to stop drinking at work!
  17. #537
    Active Member Two Rings Superduke's Avatar
    Nov 23 2009
    Audi A4 Avant 2.0 tdi '10 - Mitsubishi Pajero LWB 3.2 Aut '07
    Netherlands
    DAVIDB8.... Friend..... Mod-man..... Do you know if its possible to change with VAGCOM the blinker-lights at the back of the car? In EU we got the orange pinkers, and I think in America the red-LED-light flashes when u r using the blinkers. Could it be changed? I like the red-blinkers...
    Thnx for researching....
    Mitsubishi Pajero LWB aut.
    KTM SuperDuke990
    Wheelbarrow "Fort"
  18. #538
    Feb 22 2010
    You dont need to 100% the new Windscreen with the new Mirror .. it´s also possible to get the cable set and the Sensor , an build it "somewhere else" ..
    For the Red indicator light you need also other back lights .. in Germany it´s not allowed .. if you import an US Car to Germany , than you may get an special authorization .. But not for German cars ..
    It was the same in the Past .. the US Guy had the third Brake Light .. in Germany not allowed .. Import cars must been modified .. The "German Solution" was two extra Back lights , looks terrible .. Also LED Technic .. no not allowed .. now it´s a Standard ..
    In the past i was stop by the police , because i had in my old Opel complete red back lights , i have to pay 150 Euro and also reconfigure direct back to the old glasses ..
    German "street Law" is crazy .. normally we have a EU Rule .. these rules ar written for the whole EU .. but German Officers are 110% and for example in Italy or Nederlands , the are more tolerant ..
    Okay enough crying Back to Topic ..
    Regard
    Markus
  19. #539
    Registered Member Two Rings christianFSI's Avatar
    Mar 04 2010
    Audi A4 Avant (B8, Ambition) 1.8 TFSI
    Germany
    Hey everyone,
    so does everyone find out, whats the coding for tuning light as parking light?
    Like this
    or this
  20. #540
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Yeah I figured that one out. I have mine active so it looks like the second picture. Module 9 activate Byte 10 bit 0 (change to 1) Then go to byte 2 bit 6 and activate that one (change to 1). And your done. Lights on at half strength and they go to full for use as turn signals.
  21. #541
    Mar 04 2010
    Germany
    Thanks a lot David, i appreciate that very much.....youre the best!
  22. #542
    Feb 22 2010
    Good News ..
    i like to have this way ..
    DLR full Bright with Parking Light .. this is still enabled .. Plus the turning lights ... this way i had it on all my old VW Cars .. does anyone know the coding ?.
    Regards
    Markus
    Regard
    Markus
  23. #543
    Mar 20 2009
    Sweden (south)
    Good News ..
    Regards
    Markus
    Isn't it the code David has found ??
    http://www.audizine.com/forum/showth...-turnsignal%29
    Rene Larsen
    VCDS
  24. #544
    Feb 22 2010
    No , this is for cornering light , (Fog Lights) .. this i have already activated.
    Now i looking for the Indicator/Turning Lights are dimmed on , with DLR and maybe with Xenon on .. also 50% "All the Time" ..
    It Works .. sorry for my question...
    Regard
    Markus
  25. #545
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    I literally answered that question 2 posts above your original post. Just scroll up and you'll see the answer.
  26. #546
    Feb 02 2010
    This one´s for Dvidb8, from your Spanish forum followers:Some of us round here have halogen DRL, not leds, and frankly they look quite dull.So the idea was to change them and use high beams as DRl wirth some "Blueish light" which would look cooler.For using high beams as DRL we need to decrease their intensity, which we finally managed to do, but the problem is taht the original DRL stay on with them, can you see if you can find the way to set high beams alone as DRL? This is what we know until now:
    This is our original coding, Ross Tech seems to be mistaken here, as the correct selection for setting highs as DRl in byte 2 is to choose bit 1 (via front side markers active) .Then we go to module 09:
    Halogen lights:
    Channel 1: Brightness of DRL
    and changed the original value there (100%) to a lower value, because these are 55 w H7 lights as high beams.So we set 33% there, but the problem is that the other lights stay on with them (quite dimmed, but visible) .Please give us a hand, my amigo....regards
  27. #547
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Halogen lights:
    So what happens if you have everything unchecked (Set the value to 00)? Do you have any lights on at all? I can check this on mine but thought I would ask just in case. I have a few items I can look at. I did come across some settings that I haven't looked at yet so I may be able to help I'm just not 100% sure yet. I'll let you know. I hope to get some real time in the car this weekend.
  28. #548
    Feb 02 2010
    Haven´t checked what happens...but I suppose 00 means no light at all...I was hoping there was an option in which to choose the number of lights functioning as DRL or so...
  29. #549
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Well you should be able to do it in the menu you showed. If you uncheck 6 that should turn your lights off then check off 2 for your high beams. Have you tried that?
  30. #550
    Feb 02 2010
    Yes, sure I tried that...I´ve tried everything here and whatever you choose (de-selectiong bit 6 which comes as default) the original DRL are on all the time.The funny thing is that the only coding which coincides is bit 3: fog lights as drl ( with original drl on, of course)...the rest are out of position: for the high beams as drl you have to selet 1, cause bit 2 would set main beams as drl.This is crazy...anyway thanx for trying to help, Davidb8, I understand that there isn´t much you can do since you don´t have halogens...
  31. #551
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    I'll take a look tomorrow. It may be difficult trying to reproduce since I don't have the same bulbs but I may be able to reproduce it using a different combination. The first thing I have to check is if I can turn the DRL's off. If not then I have something to go with. I have mapped some coding to turn the DRL's off but I never checked to see if I could turn something else on. So I don't want to give false hope with out going back through the code and looking but to early to give up.
  32. #552
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    I'm not getting very far on this one. I am guessing that your module programs different because what Ross-Tech has listed works on mine. If I set my coding to 04 I have high beams only on. Of course I have HID so I can't verify anything beyond that. Perhaps another member here can check their settings and see if theirs will code properly or of we are dealing with a coding issue based on headlight type.
    Anyone?
  33. #553
    Active Member Two Rings JEROA4-SL's Avatar
    Jun 01 2009
    A4 B8 S Line Ibis White
    MADRID-------SPAIN
    Codes vag-com 812.4
    Hi,
    Here is the list of activities that until now we have done together in the Spanish forum Audisportiberica.
    The list is in Spanish but as you all know the VAG-COM is in English so do not you shall have no problem.
    I will be updating the list when we get more activations.
    All codes are tested and function to perfection.
    If you have any different activation please tell me. Together we can get a good job.
    Click here:
    1º Test of needles in the instrument panel.
    2º Turn FIS timer in the dashboard.
    3º Turn on the tire pressure and TPMS.
    4º Hidden Menu Enable 2G MMI (MMI High).
    5º Position of the mirror right car when reversing.
    6º Disable seat belt beep.
    7º Perform Auto-Scan to our car with Vag-Com.
    8º Activations with Vag-Com in emergency braking.
    9º On heated exterior mirrors.
    10º Turn Bluetooth Telephony Kit "Basic Plus" (Physcon) for equipment with Concert or Symphony radio with MMI 6.5 ".
    11º On the level of the battery in the MMI for Concert or Symphony radios as standard.
    12º Turn the oil level in the MMI for Concert or Symphony radios as standard.
    13º On ambient light in the MMI for Concert or Symphony radios as standard.
    14º Always on 100% LED lighting
    - SELECT [Module 09]
    - Go to "Secure access" [Enter code: "20113", accept]
    - Go to "Adaptation" [Select "Channel" 3 ", inserting the No. or by pressing" Up "]
    - Choose the percentage of light that we want minimum 5 and maximum 100.
    - Click "Test"
    - After clicking Test confirm with "Save"
    15º Activation of the fog with intermittent turning
    - Go to "Cen. Electrica"
    - Go to [Coding - 07]
    - Long Coding Helper - [Byte 4]
    -Bit 0 - fog lights lit when you turn the blinker
    - [1 = Avtivo]
    - Value of "40" to "41"
    - Click "Test"
    I hope you enjoy it
    Greetings.
    Modd List:
    -Black-Front Grill-S-Line grille emblem-Wheels MAM RS1 Black front Polished 8.5 x19" ET45 5x112
    245/35/19-Bridgestone Potenza-Rieger Window Spoiler-Chrome S4 Mirrors-Installation of rooftop antenna-6000K Xenon HID D3S-LEDS fog bulbs HID WHITE-LEDS Enrollment white bulbs
  34. #554
    Oct 27 2009
    Miami, FL
    Quote Originally Posted by JEROA4-SL View Post
    [B]
    - Click "Test"
    I have never seen this before... My LED DRL's are at 100% all the time unless the headlights are on, during which they are around 50%. Does this allow you to change the brightness of them when the headlights are on?
    If so, MANY people have been waiting for this...
  35. #555
    Jun 01 2009
    MADRID-------SPAIN
    Yes, it is.
    This activation maintains the brightness of the LEDs always intense.
    With this activation when we put the flashing lights or LED junction do not lower the intensity.
    The Leds are always 100% of intensity.
    Grettings
    Modd List:
  36. #556
    Dec 29 2009
    Midwest
    So when my new Prestige comes in I assume the dealership will vag-com my car for free before I pick it up if I ask?? I just want the needle sweep and the DRL's to stay on with turn signal.
  37. #557
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Hmm some of that stuff looks familiar
  38. #558
    Senior Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    Kansas City, KS
    Quote Originally Posted by Quattrolover View Post
    Depends on the dealer. I heard some won't even do it.
    "A man who won´t die for something is not fit to live." - MLK Jr.
    {2009 A4 2.0T quattro, Meteor Gray/Black, Prestige, tiptronic}
    Current: GIAC ECU, Rear debadge, Plate LEDs, Huper Optik 45%, H11 Fogs, Intercooler pipe, H&R Sport Springs, H&R RSB, ST Coilovers
  39. #559
    Oct 27 2009
    Miami, FL
    Quote Originally Posted by hoppy6698 View Post
    Yea - I be very surprised if they did...
  40. #560
    Feb 02 2010
    Yes, just one of my mates dropping in...you see,Davidb8, you´re becoming a legend round here in Europe.Even people in German forums talk about your doings...
