Page 13 of 37 FirstFirst ... 3111213 141523 ... LastLast
Results 481 to 520 of 1461
  1. #481
    Senior Member Two Rings Banan's Avatar
    Mar 28 2009
    -10 A4 allroad
    Sweden
    Thanks for the info B8_Jim! Now if only my cable could arrive any time soon =)
    2010 A4 allroad 2.0TFSI S tronic
  2. #482
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    Miami, FL
    Quote Originally Posted by B8_Jim View Post
    I tried a while back to get the battery meter working with my '09 non Nav symphony without success (maybe I did it wrong, but...)
    Last night I was poking around and found you can enable it by going to 56 - Radio, Adaptation, then select "Car menu Options 1". Ross-Tech has some help for the values ** you should be able to add 16 to what you now have to enable the battery menu under "CAR". I went from 65519 to 65535 and it enabled the battery level meter. Looks like 65535 should enable everything, Ambiance lighting, Adaptive cruise, etc that I don't have, but so far nothing seems wrong ** the menus for things I don't have just don't show up.
    awesome!
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion |
    Bi-Xenon Retrofit | LED Taillight Retrofit | S-Line Front Bumper w/ S4 Alu Splitter | 19" Hartmann HTTRS MA:M | Vogtland Coilovers | APR/Carbonio Intake | Paddle Shifters | Gloss Black MMI surround | Luminics JDM Yellow Fogs | LED Plate Lights | 20% Tint | VAG-Com
  3. #483
    Oct 24 2008
    N/A
    Thanks! Gonna try that later today
  4. #484
    Senior Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Jim, I'd rep you if it weren't for the forum update
    OEM+ 2009 Meteor Gray - Light Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards
    VAG-COM'd • H&R OE Sports • Eurocode IC Pipe • OEM Avant Dual Exhaust • Lamin-X'd • Smoked Ambers
  5. #485
    Active Member Two Rings Cujo007's Avatar
    Jan 18 2010
    B8 3.2 & Jetta VR6
    Hey im in Northern NJ (Wayne)
    In search of someone who can VAG COM my 09 B8
    Seatbelt Chime remove
    Needle Sweep
    DRL with turn Signal
    Thanks
    '09 A4 3.2 Prestige Brilliant Black / Black
  6. #486
    Active Member Two Rings Superduke's Avatar
    Nov 23 2009
    Audi A4 Avant 2.0 tdi '10 - Mitsubishi Pajero LWB 3.2 Aut '07
    Netherlands
    Is there a possibility to activate the underseat LEDs when the doors are closed? I like the look of my LED interior and want to activate them while I'm driving. Is it possible via VAGcom?
    Mitsubishi Pajero LWB aut.
    KTM SuperDuke990
    Wheelbarrow "Fort"
  7. #487
    Jan 18 2010
    B8 3.2 & Jetta VR6
    When driving a loaner Q7 i noticed while driving the lights were on underneath the seat/foot area. It really looked nice so perhaps there is a code for this
  8. #488
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by Cujo007 View Post
    It is not possible on a B8 - you need the extended lighting pack, which only the A6 (4f), A8 and Q7 has.
    You will also get lights on the inside of the doors with the extended pack, and the dimmning are controled in MMI.
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009
    VCDS
    11.11.2 - Beta xx.xx.x (HEX-USB+CAN)
    Dropbox Invite - use this link and we'll both get extra space!
  9. #489
    Nov 23 2009
    Netherlands
    Quote Originally Posted by rlarsen View Post
    I have got the extended light pack, but they only shine when the doors are open! I want them to shine when I'm driving! And most of time I'm driving with the doors closed so I hope there's a VAGcom-code for...
    KTM SuperDuke990
    Wheelbarrow "Fort"
  10. #490
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by Superduke View Post
    No, you don't have the extended lighting pack - only the 'normal' one
    The light I talk about on the inside of the doors, are like the photo below, and it can be controlled with MMI (the dimming level), so it will light up while driving together with the lights under the seats, and in the front Foot Well
    Rene Larsen
    VCDS
  11. #491
    Jan 18 2010
    B8 3.2 & Jetta VR6
    Damn thats too bad - I really liked the way it looks
  12. #492
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    I spent a lot of time trying just about every value on the MMI to see if I could get anything to work and nothing made a difference, so I know the MMI is not the key to making something like that work. It has to be in a control module and per Rene most likely an optional module we don't have.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
  13. #493
    Nov 23 2009
    Netherlands
    Thats f*cking amazing!!! Beautyful!!!!! I don't have that at all!!!
    KTM SuperDuke990
    Wheelbarrow "Fort"
  14. #494
    Mar 20 2009
    Sweden (south)
    The MMI menu item "Extended integier lighting" can be activated in e.g. the hidden menu, but it will only be greyed out.
    It is this menu item that controls the lights on A6, A8 and Q7
    Rene Larsen
    VCDS
  15. #495
    Nov 23 2009
    Netherlands
    I didn't knew about this package! Not in the dealer list here in EU I suppose!
    KTM SuperDuke990
    Wheelbarrow "Fort"
  16. #496
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Well I have found if you have the incorrect value in the MMi it will grey out an option. So I tried every value just to make sure.
  17. #497
    Mar 20 2009
    Sweden (south)
    No, it is not direct mentioned - only as "Lighting package".
    On B8s it is the small package, and on A6 and above it is the extended version.
    Rene Larsen
    VCDS
  18. #498
    Jun 18 2009
    coventry united kingdom
    Extended lighting pack....i like that...any part numbers? I cant find them on ETKA!!!
    Way Too Impatient
  19. #499
    Mar 20 2009
    Sweden (south)
    You need to find the units used on e.g. the A6 (4F) if you want to retrofit it on a B8 - and the coding - and find a dealer who WILL help you with the removel of the component protection.
    Rene Larsen
    VCDS
  20. #500
    Senior Member Four Rings Alkivar's Avatar
    May 16 2009
    '08 A5 3.2L S-line, '03 Passat GLX 4Motion, '04 GSX-R 600
    Maine aka Canada Jr.
    I just want footwell lighting that can be turned on when the doors are CLOSED. Is that too much to ask in a $50,000 car?
    '08 A5 3.2L S-Line Brilliant Black/Black... Build Thread
    "fuck your woods, fuck your bears, i'm machinegunning everything" - Marty
    "i used to date gold digging polish chicks, the venus fly traps of semen." - Marty
    "Listen, you can attatch F1-style suspension to a giant dildo, but at the end of the day, its still a dildo." - mdzaudi
  21. #501
    Nov 23 2009
    Netherlands
    Quote Originally Posted by Alkivar View Post
    Me too!!! Only in € instead of $!
    KTM SuperDuke990
    Wheelbarrow "Fort"
  22. #502
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    You've got an Audi and not some ricer that's covered in LEDs.
  23. #503
    Senior Member Four Rings hender's Avatar
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    lol scotty--these guys are talking about the existing footwell lights (the dim blue ones) being on while you ride. not adding 50 LEDs under the seat.
    sweet multi-spoke stock 17"s | 20% tint | crackfiller | few scratches where I closed the garage door on the bumper | 4x4 ride height | matte black hood | di-noc CF interior trim | plasti-dipped parts | pirated vag-com | 50lbs of sound equipment | couple of small stone chips on the hood | APR stg 1 | RS-Mesh Grille
  24. #504
    Nov 23 2009
    Netherlands
    Quote Originally Posted by hender View Post
    Correct Hender! They are under the seats and foorpedals!
    KTM SuperDuke990
    Wheelbarrow "Fort"
  25. #505
    May 16 2009
    Scotty let me give you a perfect example of why this is useful...
    on my trip down to florida in December, my girlfriend dropped her cellphone to the floor on the passenger side at night... with the map light on she still wasnt getting enough light to see down there. So I pulled over to the side of the road, as soon as she opened her door and the footwell light came on, she was able to see the phone and pick it up...
    I shouldn't have to stop the car, force her to open the door in order to see to pick something up off the floor. In almost every other car i've owned I could turn on floor lighting with the dome light.
  26. #506
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    Does anybody know if it´s possible to see outside temperature in the MMI screen? Don´t know why but mine only shows the inside temperature (climate unit).It would be nice not to be telling everybody inside my car all the time about how hot/cold is outside...
  27. #507
    Oct 27 2009
    Miami, FL
    Question:
    Is there a way to have VCDS scan and report all coding and adaptations? This way, I can track changes that the car makes to itself...
  28. #508
    Senior Member Three Rings inNout's Avatar
    Jul 22 2009
    IL
    I must be blind.. i went through the first 10 pages and cand find it.
    1. What's the instruction for having the LED DRLS at full brightness with headlight on?
    2. How/What button on the key do you have to press to have the windows roll up / down?
    2010 B8 2.0T + Advan, APR, Eisenmann, Bastuck, Eurocode, KW, OSIR + IND & WheelSto
  29. #509
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Quote Originally Posted by inNout View Post
    Lock button rolls them up and unlock rolls them down. When I did mine they didn't work right away. I had to make them available via the MMI for some reason.
  30. #510
    Jul 22 2009
    IL
    Quote Originally Posted by DavidB8 View Post
    Do you have to hold the button?
    What MMI screen do you have to go into?
  31. #511
    Oct 27 2009
    Miami, FL
    yes you have to hold the button...
    the menu is located inside the CAR menu - I think it is called windows....
  32. #512
    Mar 20 2009
    Sweden (south)
    Here is a handy tool (web page) for those who want to know what or how there control unit is coded (or what the new code will be)
    http://obd.netloonies.com/
    The upper part of the tool is for Long Coding - and the bottom part is for a coding value, which contains values which are summarized.
    Rene Larsen
    VCDS
  33. #513
    Oct 27 2009
    Miami, FL
    thanks!
  34. #514
    Feb 02 2010
    Quote Originally Posted by jabicho View Post
    Can anybody tell me something about this? any clues??
  35. #515
    Oct 27 2009
    Miami, FL
    it is most likely not possible...
  36. #516
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    I have to side with Nputer on this one, most likely not something that can be done. They system would be capable of it but the sending ECU would need to be configured to send it to the MMI and the MMI would need programing to display it.
    Usually the first tip off to a lot of us with some of the unknown or inactivated features is that another model has it. It doesn't always mean we can to but it gives a basis for you to start the research. You'll find almost all the mods and tricks found and done are based on an already available know feature or another car in the Audi family that has it like the recent ambiance light.
    I recommend you check on some other models. If you hit one that has it then we start from there, like what modules they have and if VCDS has noted the feature in the software for that model giving us a starting point to search for it.
    Sorry not the answer your looking for but maybe you can research it a bit and see what you find.
  37. #517
    Mar 20 2009
    Sweden (south)
    Not an answer you can use - but you'll get the outside temperature in the non-MMI system... it is not a full screen display, only one on the bottom line.
    Rene Larsen
    VCDS
  38. #518
    New Member Two Rings
    Feb 05 2009
    chicago, il
    how to use...
    sorry, i'm new to the whole vag com thing. but how do i go about trying to use these codes and modify my cars settings? i tried to look but there isnt anything that clearly explains it.
    any help would be greatly appreciated! i have a b8 a4. thx.
  39. #519
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    Take a read of www.ross-tech.com and you'll see how you can access the codes and modify them with the software.
  40. #520
    Registered Member One Ring Fichtel72's Avatar
    Feb 22 2010
    Seat Ibiza Sport Edition
    Munich/Bavaria/Germany
    Hi Guy´s .. first of all a big hello from Germany .. My name is Markus , i drive a A4 8K Avant ..
    i have also prog. my car with VAG Com .. but now i´m looking for a solution fpr the CH/LH function.
    On my old Cars , it was possible to activate the function .. doesn´t matter if Light sensor is installed or not. On my Touran , on my Seat Alea , on my Golf 4 and so on .. But not on my Audi .. I work for EMC² Germany , so our customer is also Audi in Ingolstadt .. so i went to the devolpers and try to Ask , but they only tell me .. You need an Light switch with Auto function and a Light sensor. But i wont belive it to 100 % .. So i try .. i can successfully activate the LH/CH function on MMI .. but nothing happend .. then i "activate" the Light sensor .. Result : Error Light sensor ! on FIS ..
    Logic :
    if LH/CH is enabled on MMI
    if Lightswitch is on Auto
    if Lighsensor detects : dark
    if remote control is pushes open .. Leaving home will be enabled
    if you leave the car
    if the Switch is on Auto
    if its dark
    if you press the lock button from your rc : lights will be glow as per definable time at mmi.
    Thats the theory ..
    No we have to find a solution to "say" the system , that a Light Sensor is installed , it´s dark and log no error. And Override the Auto Position on the Light Switch ..
    Sorry for my poor english .. i hope you understand my words.
    By the Way , i administrate the biggest german Car Detailing Community http://www.autopflegeforum.eu also known as www.nikella.de
    Regards
    Markus
