Page 11 of 37 FirstFirst ... 91011 121321 ... LastLast
Results 401 to 440 of 1461
  1. #401
    Registered Member Two Rings
    Sep 07 2009
    2010 AUDI ALLROAD A4
    GREECE
    Re: Cool VAG-COM codes
    can any one help with those faults ?thanks(A4 allroad 2010 with mmi3g)
    Address 19: CAN Gateway Labels: 8T0-907-468.clb
    Control Module Part Number: 8T0 907 468 Q HW: 8T0 907 468 L
    Component and/or Version: GW-BEM 5CAN-M H10 0095
    Software Coding: 000303
    Work Shop Code: WSC 06335 000 00000
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:36:51
    Address 55: Xenon Range Labels: 8T0-907-357.clb
    Control Module Part Number: 8H0 907 357 A HW: 8H0 907 357
    Component and/or Version: AFS 1 H01 0020
    Software Coding: 0000019
    Work Shop Code: WSC 06334 000 00000
    Additional Info: 8K0941329 AFS-Modul links H01 S001 8K0941329 AFS-Modul rechtsH01 S001
    Fault Codes have been Erased
    1 Fault Found:
    02988 - Left-Hand/Right-Hand Traffic Switchover Active
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 22799 km
    Time Indication: 0
    Date: 2009.11.03
    Time: 16:16:43
    Address 5F: Information Electr. (J794) Labels: Redir Fail!
    Part No SW: 8T1 035 666 A HW: 8T1 035 666
    Component: H-BN-EU H64 0032
    Revision: ******** Serial number: 321CO097561219
    Coding: 01010001000621FD35001F1E00000003
    Shop #: WSC 06335 000 00000
    Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
    Component: E0380 Bedient H08 0100
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 101
    Mileage: 22799 km
    Time Indication: 0
    Date: 2009.11.03
    Time: 16:18:46
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00001000 00000000
  2. #402
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Sweden (south)
    Have you tried to erase the faults - and then see if they come back again??
    I don't have the MY2010 - but a MY2009, and only a normal Avant.
    This is my unit data:
    Address 19: CAN Gateway (J533) has the same data, and coding as your.
    Code:
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0095
       Revision: FB600048    Serial number: xxxxxxxxxxxxxxxx
       Coding: 000303
       Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
    Address 55: Xenon Range has the same data - but a different coding.
    Code:
       Part No SW: 8H0 907 357 A    HW: 8H0 907 357
       Component: AFS 1           H01 0020
       Revision: 00000001    Serial number:
       Coding: 0000020
       Shop #: WSC 06334 000 00000
       Part No: 8K0 941 329
       Component: AFS-Modul links H01 S001
       Component: AFS-Modul rechtsH01 S001
    Address 5F: Information Electr. (J794) - with this one I can't help you because I don't have MMI 3G
    EDIT:
    You can here see what the "Fault Priority:" stands for: http://www.ross-tech.com/vcds/tour/dtc_screen.html
    If "Address 19: CAN Gateway" still has a Fault Priority of 1 after you have tried to erase the fault - you need to contact your dealer, because it is a serious error.
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009
    VCDS
    11.11.2 - Beta xx.xx.x (HEX-USB+CAN)
    Dropbox Invite - use this link and we'll both get extra space!
  3. #403
    Sep 07 2009
    GREECE
    i just fitted the hybrid tv and then i git the error ,i havent recode my tv but it works any idea?
    also my lights are the adaptive with auto leveling DRLED with turning as well do you have the same ?
  4. #404
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by danikas View Post
    Yes, I also have adaptive lights with auto leveling and LED DRLs - so the coding on the same unit type (same part number), should be the same... but I don't think you have a problem with "Address 55: Xenon Range" because the fault has only been there once on November 3. - it is the same with "Address 5F: Information Electr. (J794)" it has also been there once on November 3.
    The fault description from "Address 19: CAN Gateway" is "Control Module Incorrectly Coded" - have you coded anything on this modul??
    If not - then read this thread: http://a6retrofit.tripod.com/article...5hybridtv.html
    Once the hardware is in place and battery power back on, the car needs to be made aware of the new box. Connect VAG COM/VCDS (see www.ross-tech.com), open controller 19 CAN Gateway, then coding or installation list depending on version and flip TV-Tuner checkbox on and save. This makes the car aware the box is there, although it might show and operate without this setting too. You also need to check and adjust coding for box 57 TV Tuner, see the label help in VAG COM. (If you model or car is different than mine some differences might exist in coding, verify the correct changes you need to make in your particular car before doing any software coding.) Then check for any error codes in VAG COM.
    If you erase the faults, then I think Adr. 55 and Adr. 5F will be OK again - and Adr. 19 will be OK after you have coded it correct.
    Rene Larsen
    VCDS
  5. #405
    Sep 07 2009
    GREECE
    thank you very much for your respond, i forgot to update my can gateway to include the tv :(
    however i still get the folowing errors : the tv errors ignore i havent codeit yet (dont have the info )and i havent connect the antenas as yet.
    1 Fault Found:
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 22799 km
    Time Indication: 0
    Date: 2009.11.03
    Time: 16:16:43
    Tuesday,17,November,2009,21:38:31:19623
    VCDS Version: Release 908.1
    Data version: 20091018
    Address 5F: Information Electr. Labels: Redir Fail!
    Control Module Part Number: 8T1 035 666 A HW: 8T1 035 666
    Component and/or Version: H-BN-EU H64 0032
    Software Coding: 010100050006ADFF15011F1E00400003
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 124
    Mileage: 23083 km
    Time Indication: 0
    Date: 2009.11.17
    Time: 21:36:33
    Freeze Frame:
    Bin. Bits: 00001000 00100000
    Tuesday,17,November,2009,21:40:11:19623
    1 Fault Found:
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 23083 km
    Time Indication: 0
    Date: 2009.11.17
    Time: 21:35:25
    Sunday,29,November,2009,20:42:16:19623
    Address 57: TV Tuner Labels: None
    Control Module Part Number: 4F0 919 129 C HW: 4F0 919 129
    Component and/or Version: HybridTV-DVB H06 0390
    Software Coding: 01000000
    Work Shop Code: WSC 00000 000 00000
    5 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:35:27
    00863 - Antenna 1 for TV (R55)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:35:29
    00864 - Antenna 2 for TV (R56)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:35:29
    00865 - Antenna 3 for TV (R57)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:35:29
    00866 - Antenna 4 for TV (R58)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:35:29
    Sunday,29,November,2009,20:43:50:19623
    2 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:43:03
    Freeze Frame:
    Voltage: 12.90 V
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 140
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:43:06
    Freeze Frame:
    Sunday,29,November,2009,20:46:13:19623
    1 Fault Found:
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 23438 km
    Time Indication: 0
    Date: 2009.11.29
    Time: 20:39:13
    Monday,30,November,2009,00:41:01:19623
    Gateway Installation List: 8T0 907 468 Q
    01-Engine ** Status: OK 0000
    02-Auto Trans ** Status: OK 0000
    03-ABS Brakes ** Status: OK 0000
    04-Steering Angle ** Status: OK 0000
    05-Acc/Start Auth. ** Status: OK 0000
    08-Auto HVAC ** Status: OK 0000
    09-Cent. Elect. ** Status: OK 0000
    10-Park/Steer Assist ** Status: OK 0000
    15-Airbags ** Status: OK 0000
    16-Steering wheel ** Status: OK 0000
    17-Instruments ** Status: OK 0000
    19-CAN Gateway ** Status: OK 0000
    1B-Active Steering ** Status: OK 0000
    20-High Beam Assist. ** Status: OK 0000
    3C-Lane Change ** Status: OK 0000
    42-Door Elect, Driver ** Status: OK 0000
    46-Central Conv. ** Status: OK 0000
    47-Sound System ** Status: OK 0000
    52-Door Elect, Pass. ** Status: OK 0000
    53-Parking Brake ** Status: OK 0000
    55-Xenon Range ** Status: Malfunction 0010
    56-Radio ** Status: OK 0000
    57-TV Tuner ** Status: Malfunction 0010
    5F-Information Electr. ** Status: Malfunction 0010
    62-Door, Rear Left ** Status: OK 0000
    72-Door, Rear Right ** Status: OK 0000
  6. #406
    Mar 20 2009
    Sweden (south)
    Here are some descriptions on error code 02988 from "Address 55: Xenon Range":
    http://wiki.ross-tech.com/index.php/02988
    http://wiki.ross-tech.com/index.php/...urist_Solution
    Have you been playing with the "Headlamp converter"?? I thing it should be set to OFF when driving in Greece. (it can be set in MMI)
    Rene Larsen
    VCDS
  7. #407
    Sep 07 2009
    GREECE
    yep !!that was the problem again thank you so much for your reply :)
  8. #408
    Senior Member Three Rings DUBSPORTN's Avatar
    Nov 26 2009
    2010 S4 ICE SILVER, 1990 VW CORRADO VR6 MB QUARTZ BLUE, 2008 MERCEDES E350 SPORT, 1996 VW JETTA VR6
    PSL/FL/South East
    I have a vag-com cable and disabled the seatbelt and the na amber light in the head light on my b8 s4, I am having 2 issues i activated remote windows it will close but not open the windows and when i open the door with lights on can figure out how to turn off the chime.
    1990 VW CORRADO OBD II VR6 QUARTZ BLUE :thumbup:
    2010 AUDI S4 3.0T ICE SILVER PREM PLUS :thumbup:
    2008 MERCEDES E350 SPORT BLACK :thumbup:
    1996 VW JETTA VR6 COOL WHITE
    MY MOTOR WAS RUNNING LIKE A CHAMP AND I STILL SWAPPED IT!?!
  9. #409
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    If you have any issues aftera Vag-com change then the first thing to do is put the settings back to original.
    This follows on from Rule No 1 in Vag-Com usage : "Always document what you had before you start playing".
  10. #410
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
  11. #411
    Senior Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    • Bit 1 Daytime Running Lights via Front Side Marker Lights active
    • Bit 2 Daytime Running Lights via High Beams active
    • Bit 3 Daytime Running Lights via Fog Flights [sic] active
    • Bit 4 Daytime Running Lights via DRL active
    • Bit 6 Daytime Running Lights via Side Marker Lights aktiv [sic]
    • Bit 7 Daytime Running Lights via Tail Lights active
    Anyone know what happens if I try to enable Bit 5 that isn't listed here?
  12. #412
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    Quote Originally Posted by DUBSPORTN View Post
    1) There's a setting in the MMI for the windows.
    2) Only way to turn the "headlight is on" alarm off is to turn the headlight off.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
  13. #413
    Registered User Two Rings
    Dec 29 2006
    montreal
    anyone using the 908.1?
  14. #414
    Senior Member Three Rings Kavan's Avatar
    Jun 12 2009
    Audi S4 2011 3.0T
    Anyway to Vag the system (hence like the tech package) where as your walking away from the car the door auto locks and as you approach the car the doors open? I have the sensor on the door handels as well is there no way you can unlock the doors using the finger sensor on the door? I am shore the car has the feat you must have to enable it ?
  15. #415
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    Quote Originally Posted by Kavan View Post
    No way to autolock when you walk away. Never had to unlock manually. As soon as I touch the handle it unlocks.
    2nd Ring: 2006
    4th Ring: TBD
  16. #416
    Senior Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I've had the car done either or. I'm not sure exactly what's correct. Somebody mentioned that if you previously locked the car from the inside (button press, not the speed lock), when you walk away, it will relock itself. But I find this to be only half-accurate.
    I just force myself to lock it manually everytime. For safety.
    It'd be nice to clarify though, or to activate the auto-lock if it exists.
    The handle unlocking is only for people with Advanced Key.
    Ryan - flickr
  17. #417
    Senior Member Four Rings Alkivar's Avatar
    May 16 2009
    '08 A5 3.2L S-line, '03 Passat GLX 4Motion, '04 GSX-R 600
    Maine aka Canada Jr.
    Quote Originally Posted by xileh View Post
    nothing on the A5... dunno about the A4.
    '08 A5 3.2L S-Line Brilliant Black/Black... Build Thread
    "fuck your woods, fuck your bears, i'm machinegunning everything" - Marty
    "i used to date gold digging polish chicks, the venus fly traps of semen." - Marty
    "Listen, you can attatch F1-style suspension to a giant dildo, but at the end of the day, its still a dildo." - mdzaudi
  18. #418
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I just enabled MMI control of DRL and disabled 'winking'.
    I can't find a place to adjust the LED intensity though, was there ever a place to adjust that?
    Ryan - flickr
  19. #419
    Sep 26 2009
    Montreal
    Ok so 2 things :
    I've done most of the basic Vag mods like blinking DRL, VIM , Windows up down etc.
    But there's two things i either can't find how or just don't know how to do.
    A. Keeping the DRL intensity at the same brightness when the headlights are on.
    B. Having a audible beep when unlocking the doors. It obviously does it when i lock the doors and i read something on A6 retrofits that allows it to double beep when unlocking.
    I just can't find the actual place to change the setting.
    Any help would be appreciated.
    This is for a 2010 S5 Convertible
    2010 S5 Cabriolet Ibis White - ADS , Nav , B&O , Carbon Fiber Trim , S-Tronic
    Retired - 2008 M3 E93 Alpine White - M-Drive , Executive , EDC , 19'', 6MT
    Retired - 2007 335 E92 AW/CR / Sport Package / Premium Package/Navigation / CA / PDC
  20. #420
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Vag Com on MY2010
    Noticed some odities when trying to do some coding. I have a lot of options that don't show installed as in checked off in the settings. I chose to leave them alone since I didn't want to screw my car up. The car knows they are there I know they are there but Vag Com doesn't....
    Got a lot working with no issues, Needle Sweep, Lap Timer, Consumption Menu, Video in Motion, Hidden MMI Menu and seat belt chime disable.
    Windows Eventually figured out. I could put them up but not down. Then I found that you had to enable them via MMI not just VAG. That piece of information could have saved me 30 mins.
    Getting into the hidden menu on the MMI 3G is a pain. Sometimes had to try 2-3 times before it would go in. Now according the instructions you hold down buttons to restart the system.. NOT.. With mine you had to hold them for about 10 seconds then release them. If you just hold them all your going to get is sore fingers.
    Couldn't activate the emergency braking but may not have been braking right so will report back on that.
    Telephone - 77 doesn't exist... And I do have telephone option on the MMI. Used it dozens of times over the last few days. So I have no idea where you do the language changes and so forth.
    Also the DRL on off option on the MMI does nothing. Regardless of where I set it, the lights stay on.
    When I tried to read some modules is came back with something like no records or tags or something for the module yet so it looks like Rosstech has some work to do. Perhaps fixing why the options are showing wrong and doing some upgrading on the tags and so forth.
    One other thing. 1AS really means no TPMS.. Had to try. Very annoyed to find out I could have ordered it on the car even though it doesn't show as an option. The dealer has a bunch of special order items you can get that Audi doesn't tell you about such as TPMS, heated rear seat, rear sunshade...
    Well if anyone figures out how to change the language to English UK instead of English US I'd love to hear about it.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
  21. #421
    New Member Two Rings
    Jun 30 2008
    EU
    Re: Vag Com on MY2010
    DavidB8:
    MMI 3G integrates lots of things that used "to be there", like the Telephone 77 which in MMI 3G is integrated in the 5F module. I don't thing anyone knows how (if?) to change the MMI 3G speech control for example other than via changing MMI language from some menu perhaps?
    My A4/A5 VAG COM codes list:
    http://a6retrofit.tripod.com/articles/a5vagcodes.html
    Friends Audi retrofit site:
  22. #422
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    Quote Originally Posted by DavidB8 View Post
    DRL is on all the time possibly because you have a Canadian spec car, as do I. DRL is mandatory in our country.
    2nd Ring: 2006
    4th Ring: TBD
  23. #423
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Quote Originally Posted by rlarsen View Post
    00010101 from left to right Bit 7 - Bit 0
    Thanks for posting the coding. For some unknown reason my DRL where not working in the '0' or Auto setting. The difference was the coding went to 00010111. There was no option that would turn bit 1 to 0. Thank god for your coding so I was able to do it manually. Of course I didn't notice anything wron until daylight because I was doing it at night and the DRL's were coming on with the Headlights.
    I'll retry the MMI now. Not that I would want to turn them off.
  24. #424
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Quote Originally Posted by local3 View Post
    DavidB8:
    And it would appear Rosstech has no labels for 5F yet. I have started pulling the labels and adaptation channels. I should have them done tonight. I was coding and experimenting for a while so my laptop battery started to get low. I am pulling anything with a redirect error (there are a few) and no labels. Unfortunately the most interesting ones are missing labels:
    5F Information Electri.
    47 Sound System
    56 Radio
    Maybe in the future Rosstech can make their program to build these on the fly from reading the module.
  25. #425
    Mar 20 2009
    Sweden (south)
    47 Sound System
    56 Radio
    If you want to help Ross Tech with the missing label files, you can read what you can do here: Control Module Maps
    Rene Larsen
    VCDS
  26. #426
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Well it would be nice if they just provided an email address in their program instead of forcing my email program. I had to search for their support address and send them all the missing modules and failed redirects that way. My regular email program on my laptop is a secured VPN email that is for work only.
    But I have sent my auto scan and about 5 modules labels and adaptations. Just hope they get it and make use of it. I do feel a but miffed at paying almost $400 for a cable and providing them with the module information though.
  27. #427
    Mar 20 2009
    Sweden (south)
    On the page in the "How can I help?" section is an 'email' link to Sebastian@Ross-Tech.com
    If no one gives Ross Tech informations about new or incomplete units, how should they get these informations?? - they could of course buy all supported VAG models in all kind of configurations, each time something changes - NOT
    Rene Larsen
    VCDS
  28. #428
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    That would be like Microsoft selling an end user a new operating system and saying let us know when you got the operating system working with your mouse, keyboard and monitor. Oh and you have to pay full price.
    At least the tuners here offer a discount to those who give up their cars for development.
    Instead it's pay full price and give us the information or you wont get to use it. WHATEVER.
    When a new model comes out they can simply offer the first person up a discount to run their car. Their staff exist in more than one market so this should be pretty easy to cover. Perhaps a relationship with the local Audi dealer? There are lots of ways this can be done but I guess why change when you can make money off of getting other people to do it for you.
    EDIT- Sorry for the Rant, just been a bad day with the aftermarket world in general. I do think they have done great work and I am happy with their product. I just hate it when people think there is nothing wrong with this or think it can't be improved upon. Hell how about a vag come hat? I don't mind helping and submitting. It just urkes me a little that's all.
  29. #429
    Sep 26 2009
    Montreal
    Ok so 2 things :
    Anyone?
  30. #430
    Nov 06 2009
    Honda CBR1000RR
    Inuvik, NT, Canada
    Quote Originally Posted by youyou View Post
    Ok so 2 things :
    Anyone?
    Can't really help but would like the same answers and willing to poke around. Do you know what module the A6 group found the setting to turn it on or is it that way by default? If we can get the coding from an A6 and the module I'm willing to give it a try. Whats the worst that could happen
  31. #431
    Mar 20 2009
    Sweden (south)
    Ok so 2 things :
    Anyone?
    I don't know any code for A. - but for B. you need to have Anti-Theft-System installed in your car, and here http://a6retrofit.tripod.com/articles/a5vagcodes.html you can read how to do it (look for the "Enabling/disabling doors locked/alarm armed sound" section)
    Rene Larsen
    VCDS
  32. #432
    New Member One Ring
    Dec 22 2009
    OXFORD/OXON/UK
    danikas,
    Where did you get the TV from because I like to do it on mine as I have 3G Nav HIGH Plus with 40G HDD and DVD. I was informed that it is ready prepare but I need to buy TV-Tuner. I have B8 A4, 2010 model
  33. #433
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    Miami, FL
    I think the question is about a tone when the doors are unlocked...
    You can enable/disable the doors locked sound through the MMI but when you unlock the car, there is not sound (with other cars there is usually a double beep)
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion |
    Bi-Xenon Retrofit | LED Taillight Retrofit | S-Line Front Bumper w/ S4 Alu Splitter | 19" Hartmann HTTRS MA:M | Vogtland Coilovers | APR/Carbonio Intake | Paddle Shifters | Gloss Black MMI surround | Luminics JDM Yellow Fogs | LED Plate Lights | 20% Tint | VAG-Com
  34. #434
    Oct 27 2009
    Miami, FL
    I just want to add a code I think all Premium Trim owners will like:
    Enabling Trip Computer on Premium Trip:
    BIG thanks to Cabal_san on AudiWorld for discovering this:
    Check 56-Radio, Byte 9, Bit 6 (Board Settings Active - I believe)
    Check 17-Instruments, Byte 1, Bit 2 (DIS Active)
    Now in you DIS you should see the miles to empty (I already set it to MPG in pic) with a "1" at the top dividing line (just like P+ and Prestige)
    Now on you pseudo MMI, open up the car men. There will be a new entry called instrument cluster or something.
    Within you will see setting to enable a speed limit warning (another perk from this mod) and Trip Computer 1 and 2.
    Trip computer 1 is for the current journey and trip computer 2 is for the lifetime of the car (I believe, some correct me if I'm wrong)
    Within those two menus you will see the displays like Miles to Empty, MPG, ave. MPG, trip time, etc. They are set to "Yes" by default, set all of them to "no"
    You can only have one "display" checked between these two menus (because were do not have the toggle wiper stalk)
    Whichever value is checked will be displayed on the DIS **> If nothing is checked, it will be blank..
    Av. MPG Set to yes
    Hope this helps! Good luck
    btw: My next project is to try to figure out how to enable the Instantaneous Speed display like the P+ and Pres. have...
  35. #435
    Aug 27 2008
    League City, TX
    FYI ** Trip 1 resets if the ignition has been off for more than 2 hrs (I believe) so it is the "current" trip. Trip 2 will not reset unless you do it or perhaps if the battery is removed, etc during service. I use trip 2 for stats for each tank of fuel, not a "lifetime" ** but I have to reset it everytime I fuel up to get that...
    Nice to see you premium trim cars have the trip computers ** if you had the control stalk on the steering wheel it would likely be fully functional (maybe even the digital speedometer)
    Current : 2009 Quartz/Black A4 - 6MT/Sport Pkg/Prem+ : EC Intercooler, 034 turbo inlet hose, Interior LEDs, Lic Plate LEDs, A4L fog grills, B&O Tweeters, Vag-Com tweaks
    Gone : 2001 Ice Silver/Black A4 - 5MT FWD/Prem Pkg
  36. #436
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    I've got a B8 S5 and have a few questions. I know they are different cars but they share a lot of the same coding.
    1) Does this mod work on the S5? And what EXACTLY does it do? If it is what I'm thinking then I believe I would like to activate this feature. My buddy has a feature on his car that when he hits the brakes the rear brake lights flash for a few seconds or so and then stay lit. So if this is similar I may have to do this because I believe it is a feature that gets other peoples attention when you need/want it.
    STG 46 - Comfort System
    STG Coding -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    2) I have changed my LED's to stay on when the turn signals are active. I've noticed that the LED's turn off when the fog lights are turned on in the daytime. Is there a way to keep them at full brightness when the fogs are on?
    2009 S5 Ibis White-Magma Red Interior
    Loaded with stuff
  37. #437
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    Quote Originally Posted by todd1010 View Post
    1) Yes it works.
    2) Not sure. Never noticed that.
    2nd Ring: 2006
    4th Ring: TBD
  38. #438
    May 16 2009
    I activated the emergency braking on mine and it never worked. Went back in to confirm the setting and it did take. Very odd.
    it doesnt happen under normal braking... its an emergency braking thing... you need to be decellerating sharply in order to trigger it.
    some euro guy on another forum mentioned he needed to slam on his brakes while doing at least 35mph in order for it to blink.
    as I cant be behind my car while braking... I figure wtf and left it on anyways. it doesnt seem to affect regular braking behavior in any way.
  39. #439
    Mar 20 2009
    Sweden (south)
    Disable automatic rear window wipe on the Avant, when windscreen wipers are active and the car is reversing:
    [09 – Cent. Elect.]
    [Security Access - 16]
    [Adaptation - 10] -> Channel 19
    change 1 to 0
    Rene Larsen
    VCDS
  40. #440
    Mar 20 2009
    Sweden (south)
    I tried it from a number of different speeds trying to trigger it. I did it somewhere that I could see a reflection. Not a big deal though. if it works it works if not oh well.
    Here you can read some old posts I've posted - I don't know if this can help you with your test:
    http://www.audizine.com/forum/showpo...4&postcount=56
    http://www.audizine.com/forum/showpo...6&postcount=59
    Rene Larsen
    VCDS
