Page 10 of 37 FirstFirst ... 8910 111220 ... LastLast
Results 361 to 400 of 1461
  1. #361
    Senior Member Three Rings eboosted's Avatar
    Jul 17 2009
    lima
    Re: Cool VAG-COM codes
    So has anyone decyphered how to enable Subwoofer control on the non-MMI non:B&O stereos yet?
  2. #362
    Oct 18 2009
    Europe
    I would like to know this as well, but than for a car with B&O system... As I see with an ASS you have an sub option and with a B&O you don't have a separate sub option.
  3. #363
    New Member One Ring
    Jun 07 2009
    Michigan
    My first time posting on this forum. Some of these code edits sounded cool so I decided to head to the dealer to ask for their help (since I don't own the VGACOM).
    Long story short...dealer agreed to help but their diagnostic tool is different from the Ross-tech tool (obviously). So one some of the codes that says uses the "long coding helper", I couldn't edit. Since the dealer software, you need to manually enter the binary coding.
    So my question is...would anyone be able to use their VGA tool and scan their car and jot down the new binary codes after making the mods?
    Specifically for the Remote Windows Down and Gauge Sweep mods.
    I found this from Aerodave on A5OC forum and this is exactly the info that would be helpful...the binary codes:
    (in reference to the 'winking' leds)
    "In cars like mine that "winked" from the factory, this bit is set to 1. (My original coding for Byte 3 was 91 in hex, or 10010001 in binary). Flipping this bit to 0 (in my case, making Byte 3 read 11 in hex, or 00010001 in binary) makes the DRLs stay lit on both sides when signaling. Simple as that."
    Sorry for the long post...any help would be appreciated!
  4. #364
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Sweden (south)
    With this table http://www.ecawa.asn.au/home/jfuller/binary/binary7.htm you can convert your HEX value to binary - and back.
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009
    VCDS
    11.11.2 - Beta xx.xx.x (HEX-USB+CAN)
    Dropbox Invite - use this link and we'll both get extra space!
  5. #365
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    Quote Originally Posted by rlarsen View Post
    Headlight washer - duration of wash:
    [09 – Cent. Elect.]
    [Security Access - 16]
    [Adaptation - 10] -> Channel 6
    change to e.g. 500
    Headlight washer - times of wash and wipe cycles between each automatic activation:
    [09 – Cent. Elect.]
    [Adaptation - 10] -> Channel 26
    change to e.g. 10
    I haven't tried the code my self - yet, but it should help save some wash fluid
    After setting Channel 26 to 99 I'm finding that the first time after starting the car (or ignition on - not sure which) and I use the washers, my lights get blasted
    Looks like 99 isn't such a good option. Maybe I'll try 50 instead
  6. #366
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by scottyuk View Post
    The first one will always be there, it is only the times between you change. The washer is only activated when headlights are on - and if the light switch is set to "Auto" then each time the lights automatic switch from DRLs to headlights the washers will be activated at every first use.
    Rene Larsen
    VCDS
  7. #367
    Senior Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    Kansas City, KS
    Was wondering, would this cable work if you had the right software?
    http://www.amazon.com/Commander-OBDI...070845&sr=1-10
    And if so, what kind of software do we need? :P
    "A man who won´t die for something is not fit to live." - MLK Jr.
    {2009 A4 2.0T quattro, Meteor Gray/Black, Prestige, tiptronic}
    Current: GIAC ECU, Rear debadge, Plate LEDs, Huper Optik 45%, H11 Fogs, Intercooler pipe, H&R Sport Springs, H&R RSB, ST Coilovers
  8. #368
    Active Member Three Rings
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    No, that cable will not work with VAG-COM.
    2009 A5 3.2 6MT | Brillant Black/Black | Prem | Nav | Tech | B&O
  9. #369
    Active Member Two Rings JSitthi's Avatar
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    I've been trying to enable the needle sweep but Bit 0 doesn't exist. Instead I have a drop down box for Bit 2-3. Anyone know why?
  10. #370
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by JSitthi View Post
    And it is on Byte 1 you are trying??
    Could you make a screen dump of the options you are seeing??
    Rene Larsen
    VCDS
  11. #371
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    Yes, but regardless of the byte selected 4) is completely blank. I think options for Bit 2-3 appeared when Byte 0 was selected. I'll take a pic tomorrow afternoon.
    I could actually bypass this if someone gave me the coding to enable needle sweep; I'll just type it in manually. That's what I did for my paddle shifters and they work just fine
  12. #372
    Mar 20 2009
    Sweden (south)
    This is what the Byte 1 options should be:
    Rene Larsen
    VCDS
  13. #373
    Mar 20 2009
    Sweden (south)
    If you change bit 0 in the Binary field - then it should work as well...
    Rene Larsen
    VCDS
  14. #374
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    Here are my options for the same Byte
  15. #375
    Senior Member Two Rings A4DK's Avatar
    May 13 2009
    San Francisco
    You arent accessing the same long coding 8K0-920-980-Aand rlarsen is in 8R0-920-930-A
    The only way to get rid of a temptation is to yield to it. - Oscar Wilde
    2011 S5 6MT - Prestige - Sports diff - Brilliant Red
    Gone but not forgotten.
    2009 A4 2.0TQ - P+ - Sport - Aruba Blue
    2002 A4 1.8T - Executive - Brilliant Black
  16. #376
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    How do I change that?
  17. #377
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by A4DK View Post
    The screen dumb isn't from my own A4 - it is just one I found, which showed the 'right' options.
    It should be OK to just change bit 0 manually. Bit 0 is the last one in the binary string.
    Rene Larsen
    VCDS
  18. #378
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    What version are you using?
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
  19. #379
    Mar 20 2009
    Sweden (south)
    The screen dumb I've found is from a Q5 - my part number for [17 - Instruments] is 8K0 920 930 C, which also has a matching number compered to the one from Q5.
    What the difference in the cluster are I don't know - maybe mine is with color DIS and yours are with red/black DIS??
    Rene Larsen
    VCDS
  20. #380
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by DeMOROlized View Post
    I had a bug in 908.0 which didn't show all options for all units - it is now fixed with 908.1 (the bug wasn't there with the old 805.x versions either)
    Rene Larsen
    VCDS
  21. #381
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    Funny you say that cause I'm using 805.0
    EDIT: Figured it out, just did all the coding myself
  22. #382
    Mar 20 2009
    Sweden (south)
    If you where using 805.0 then this would be the very first version that had the B8 coding help option descriptions - and proberly wasn't compleite.
    Rene Larsen
    VCDS
  23. #383
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    Ah that explains it, thanks.
  24. #384
    Active Member Two Rings audib8nyc's Avatar
    Aug 15 2009
    brooklyn ny
    i have a 09 b8 non b&o what vags should i get i have a small list 1. sweeping needle ... 2. window control by remote....3.daytimes and fogs together .4 now what else ?
  25. #385
    Registered Member Two Rings
    Nov 04 2009
    Europe
    Does anyone know how to disable the automatic sweep of Avant rear wiper when reversing with the front wipers on?
    I did not find it....
  26. #386
    Registered Member One Ring MatriX68X's Avatar
    Nov 16 2009
    Livorno/Italy/Toscana
    Quote Originally Posted by MatriX68X View Post
    Hi
    Excuse the translation but I'm Italian ..
    Let me know if you can turn on cable VAG bar battery status for the owner of MMI without navigation radio Concert ..
    Thanks
    Excuse the translation are Italian ...
    E 'can turn on "Battery Status Bar" on the MY2010 A4 without navigation MMI?
  27. #387
    Nov 17 2009
    RO
    hello,
    i would like to know if it`s possible to activate the right side mirror to tilt down while you are in reverse if the car doesn`t have electric seats ...i have the electric mirrors but they do not fold electronicaly you have to fold them by hand ... can i activate this option via vag com or do you have to have electric seats in order for this to work ...
    have tried with vag com the following procedure :
    Go to module 52 Door Elect, Pass., Long Coding, Byte 4. If the byte has value 40 (cars without electrically folding mirrors), change it to 4C. If the byte has value 50 (cars with folding or folding/dimming mirrors), change it to 5C
    but when i go to module 52 door elect , pass ; coding ; long coding , it does not say mirror tilt or anything , and when i try to change the Byte 4 wich is 41 in my car not 40 it does not work , if i tick the byte 4 check box it changes to 51 and i cannot change that value ...
    some help please ? as i have enabled the gauge test and removed the seatbelt chime without a problem but this just doesn`t seem to work ..
  28. #388
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    Many thanks (sorry I missed that you'd posted)
    A bit annoying that it can't be averted for the first spray
    Cheers for saving me a lot of time trying
  29. #389
    Registered Member Two Rings BBC's Avatar
    Nov 18 2009
    2008 Titanium A3, 2002 Allroad
    Mission Viejo, Ca
    Quote Originally Posted by mav3rick View Post
    hello,
    Tilted position is saved in the seat memory control unit. Without that it will not tilt on its own. Also mirrors on cars without seat memory, have no sensor to feedback thier position to the module if it was installed, so you would have to install all of these to make it work.
  30. #390
    Senior Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Quote Originally Posted by BBC View Post
    Incorrect. Mine works just fine after a quick VAG to 4C. I have a P- without the seat memory controller, so try it again with another value. You might need to double check that you have the knob turned all the way to the right so when you are in reverse, it tilts.
  31. #391
    Senior Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 P+ 6MT, 98 Vr6 Jetta
    Ft Worth, TX
    Quote Originally Posted by Cabal_san View Post
    yup
    you have to have the mirror selector on the passenger mirror for the mirror to tilt down when reversing
    My current rides...
    Audi
    Jetta
  32. #392
    New Member Two Rings
    Jun 30 2008
    EU
    Quote Originally Posted by richyrich0607 View Post
    The bit math is explained after the daytime running lights code in the summary page here:
    http://a6retrofit.tripod.com/articles/a5vagcodes.html
  33. #393
    Jun 30 2008
    EU
    Yes, it is just that without memory the tilt is quite small and non-adjustable (if one adjusts it, it won't remember it).
    My A4/A5 VAG COM codes list:
    Friends Audi retrofit site:
  34. #394
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    Just enabled the hidden menu on the 2G MMI...what can I do with this, it seems useless
  35. #395
    Mar 20 2009
    Sweden (south)
    Here you have a small description: http://www.audizine.com/forum/showpost.php?p=3908186
    Enable Battery Level: http://www.audizine.com/forum/showpost.php?p=4487014
    Rene Larsen
    VCDS
  36. #396
    Senior Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2011 Infiniti G37S Coupe
    South FL, USA
    im confused i thought the 2g mmi hidden menu didnt work?? I have the symphony w/o nav. will the hidden menu work??
    Marcus
    2012 Audi A4 Quattro: Premium Plus, Sport Package, S-Line, B-O, Advanced Key
    -Tint: 15% Sides & Rear, 50% Windshield
    -LED Color Match Fog Lights/Interior/Exterior
    -S4 Aluminum Pedals, S6 Aluminum Pedals and Shifter
    -VAG-COM
    -Spacers F15/R20
    -Under seat storage bins
    Future: Osir Trunk Spoiler, AHHA, OEM Power inverter, Di-Noc, F/R Audi Parking Assist Retrofit, Custom: Blacked-OUT Gloss Grille, GIAC ECU Upgrade
  37. #397
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    I had it working on my 2G and also now on my 3G.
  38. #398
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by B_Boy View Post
    I think JSitthi has MMI high (with nav), therefore it is possible in his A4
    Rene Larsen
    VCDS
  39. #399
    Aug 17 2009
    2009 A4 2.0T
    Bellevue, WA
    Yup. I just got the battery display working. Thanks
  40. #400
    Nov 24 2008
    South FL, USA
    oh i see... :(
    Marcus
    -VAG-COM
    -Spacers F15/R20
