Results 1 to 12 of 12
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    CV axle tightening question/torque specs
    I was wondering what you guys normally do when you tighten up the bolts that connect the CV axles to the transmission. If you have the front end up in the air, the axle just spins when you try to tighten it, what do you do for that? Also, anyone know the torque specs on the bolts for the 12pt. bolts that connect the axle to the tranny?
    TIA
    Chris
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Three Rings P3RryaudiA4's Avatar
    Oct 15 2007
    2000 Audi A4 quattro
    Brocktron Ma
    Re: CV axle tightening question/torque specs
    put the car in gear, that will hold it while you tighten it, idk the spec i just did it by feal
    Jun 04 2007
    Austin/DFW, TX
    Tried that before, didnt work.
    My 5-Speed Swap DIY
    - B6 USP
    Oct 15 2007
    Brocktron Ma
    hmm that could be a problem, is the other end inside the wheel bearing housing?
    Mar 23 2008
    Queens Ny
    im having this same problem !
    Oct 15 2007
    Brocktron Ma
    you can have someone hold the breaker bar on the axle bolt, but it shouldnt move while its in gear, unless you on a lift and the other wheels are off the ground. i did mine just a few weeks ago and eveything worked fine. sorry man dont know what else to tell you.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You can get some truck ramps so you can lower the wheel down on it. That or just gets someone to hold the brakes while you tighten the bolt.
    Jun 04 2007
    Austin/DFW, TX
    Ding ding, I will give that a try! Thanks Mike
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    When I replaced both of my front axles I keep one side of the car on the ground. Put the car in gear tighten the bolt, put the car in neutral and move the wheel, back in gear so on and so on.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Feb 27 2005
    North Wales, PA
    Items for Sale
    air tools FTW. otherwise I have a precision 2x4 lumber to wedge between the seat and break pedal.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Yeah man, I just use my air tools to put them on, No spinning axles, and there tight as shit.
    May 22 2008
    01 TT 225
    St Clair Shores, MI
    Agreed, air tools FTW.
    13 S4 Monsoon Gray - 6spd l sports diff l Nappa l Atlas
    01 TT 225
    98 A4 1.8Bt
