Results 1 to 11 of 11
    Senior Member Three Rings NorCalS4's Avatar
    Mar 16 2009
    Chico, Ca
    How long to change motor mounts?
    So, how does it take? Searched around, couldnt really find an answer. From reading a how to, I would estimate about 3-5 hours.
    So how long did it take you or your shop to do?
    '01.5 Silver S4 6spd
    ~V1 hardwired
    ~AWE Boost gauge in DIY vent pod
    ~ASP DTS
    ~F90BT w/ JL 250/1 & W3 12"
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Re: How long to change motor mounts?
    http://www.audizine.com/forum/showthread.php?t=275440
    it doesn't take very long, 2 hours tops. look at the pictures...not many bolts.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Good luck.
    -02 F'in Silver. GT2560/s AWE, ER/s RS3 Wheels, KW/s and every other typical S4 upgrade.
    Mar 16 2009
    Chico, Ca
    Im not doing it. I would but my car is under warranty. Its gettin covered by a warranty and done at a shop. They we're suppose to do it today, but didnt get it done and were trying to say it hard and time consuming. I was telling them its not, that I read the how to and it should be a couple hours tops. Anyways, they got it done before closing, but there is one other lil thing getting done in the morn that will take a half hour.
    ~V1 hardwired
    ~ASP DTS
    Established Member Two Rings armys4's Avatar
    Oct 09 2008
    2001 S4 Wagon, 2000 S4 Sedan
    St Petersburg, Fl
    I just did my passenger side mount and don't see how you get at it from the top. The drivers side seems the same way. If you know how to get at the nut from the top please fill me in.
    2011 A4 Titanium - Grocery getter
    2001 S4 Wagon - Finally got a friggin wagon!
    2000 S4 Sedan - Parts car
    Oct 08 2008
    MA
    Quote Originally Posted by armys4 View Post
    remove the airbox and use a long extension.
    Nov 14 2008
    memphis
    you cant get at it from the top our inlet pipes are in the way the 034 diy is for the 1.8 its not as easy as the diy makes it look cuz its not for our cars if you pull the inlet pipes you might be able to get at the top bolt from the top but i dont see any other way around it
    Oct 09 2008
    St Petersburg, Fl
    the best way i can see doing it is with a ratcheting wrench from the bottom. All the DIY out there are for the A4. Even with the inlet pipes gone the turbo pipes are still in the way.
    Registered Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    me and my boy did it we had it on a lift its hard to get in there but we were taking our time and did it in like 3 hours but def could have did it in 2 so its not that bad
    May 23 2007
    this was my sane way of doing it:
    http://forums.audiworld.com/album.ph...ctureid=204451
    Oct 09 2008
    St Petersburg, Fl
    Quote Originally Posted by bs6x View Post
    That definitely looks like the best way to do it sans removing the engine.
