Results 1 to 26 of 26
    Mar 06 2008
    06 A4 2.0 Avant S-Line
    ottawa, Ontario, Canada
    Auto transmission - Hesitate on take off - No time in first gear problem
    I am just wondering if anyone else has experienced the same issue and what your resolution was.
    This happens on an intermittent basis (car in "D"), when I come to a rolling stop or a full stop. After the stop, I either take my foot off the brake and let the car begin to roll, or take my foot off the brake and gently depress the gas pedal.
    In both cases, instead of the car beginning to move forward, it seems to hesitate for a second or slightly more than a second. During that time, it seems to build a few hundred revs. Then all of a sudeen the car pops into gear and lurches forward, from which point everything is fine.
    And it seems in all of these cases, the car wants to spend absolutely no time in first gear. It just goes in second.
    Even though I know that first gear is short on these cars, my vehicle seems to spend almost no time in first gear ever.
    comments would be appreciated.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Auto transmission - Hesitate on take off - No time in first gear problem
    are you talking about turbo lag?
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    it's in drive. so theres no point for it stay in 1st. it lags cos its either dropping back down to 1st or shifting into 2nd. + turbo lag
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member One Ring CthulhuAudi's Avatar
    Jan 07 2005
    98 2.8 tip stock
    Aurora, Illinois
    any trans leaks? i had a issue like that after a trans cooler line came loose on my B5. it was worse on hard stops for me. try coming to a stop slower than normal, that usually helped it go all the way down to first. untill you can get it fixed of course.
    Established Member Two Rings 2LOW4NYC's Avatar
    Apr 05 2009
    Quote Originally Posted by rezadue View Post
    this has happened to me 3 times . i did nothing about it
    Oct 15 2006
    From a couple to a few...
    Arlington, VA
    i had the hesitation kind of problem with my b5. turned out it was my o2 sensor popping off. my b6 tip hasn't had to deal with this yet.
    '02 A4 1.8TQ Tip Avant
    Pioneer AVH-4201NEX
    '03 A4 1.8TQMS
    APR Snub Mount/TIP/TB Hose, 034 SD MM/RSB/End Links/HFC, Milltek Exhaust, Forge 007P DV, Valeo HD w/ SMFW, Bilstein/H&R, B6S4 F+R Brakes, Hawk HPS, TT386, Revo Stage II, STE PPD
    S4 Side Blades, Aero Wipers, RS4 Pedals, OEM HID, DIY Plasti-Dip Grill, Pioneer AVH-4201NEX
    '04 A4 3.0Q Tip Cabriolet
    B5S4 Front Brakes, Hawk HPS, Dension BT & AuxIn
    '04 Suzuki SV650
    Cabrio air wasn't enough...
    Veteran Member Three Rings snosk8tr123's Avatar
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    it has happened to me before. but wasn't a big deal
    s-line titanium + plate filler + ecs smoked sidemarkers + GIAC 91 octane + Koni Coilovers + e-code test pipe + DMH electronic exhaust cutout + forge dv + bov spacer + tint + LED city light + LED license plate bulb + Yellow PIAA fogs + White Nokya Headlights + European rewiring of lights + Clear corner and blacked out housing + Red LED door lights and foot well lights + debadged + Black audi rings + Light smoke taillights + VMR vent boost gauge + DOPE sticker (+50 whp)
    Senior Member Three Rings ChampionV63.2's Avatar
    Jan 28 2009
    C230 Kompressor
    SOUTH FLORIDA
    If your car is NOT quattro then you have a CVT. The CVT does have a tendancy to hesitate and it is considered normal. IF your car is quattro, I have no idea?
    Chip/Custom Cat-back Exhaust w 2.25" piping w/ x-pipe and Thermal R&D mufflers/Stasis Coilovers/RS4 Sway/VMR V718's/15%Tint/Phantom Black Front Filler, Grille and Rear Diffuser/LED License Plate and Interior/CC Mod/Ziza City Lights/Ziza Yellow Fogs/Spoiler/Vag'd/S4 Mirrors/Carbon/K&N Drop In/Pioneer AVIC X120BT/Alpine REF 6.5 Components//JL Audio W6/JL 550.1 & 300.4/JL ZR Components/Laminix tails, etc...My Car is For Sale, Check the Classifieds
    Mar 06 2008
    Thanks for the prompt replies. But it is not turbo lag. I am quite familiar with tuyrbo lag. This either feels like the brakes are grabbing, which I don't think is the case, or ECU not allowing the car to engage in first. It just seems to cycle fron N to first and second immediately.
    As for quattro or not, it is a quattro and that has no bearing on the issue IMHO.
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    This is a common complaint on the A4 auto tranny. A search will find many of us complaining about it.
    1st to 2nd shift is premature (1500-1800RPM). Audi service managers shrug and say "Its normal." any time I bring it up.
    Audi should correct this with a transmission module reflash, but in that typical Audi attitude we have all come to love, they simply stick you with the problem and turn their backs.
    Welcome to the Audi world, where you are oooohhhh.... number 234,345,232 from the top of their important customer list.
    I have learned to launch in S, then just bump it to D when rolling.
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Mar 06 2008
    RVT,
    Thanks for the reply. In a way I am glad to know I am not the only one with this issue.
    I did speak with the service manager today and booked an appointment to have it looked at. He sounded sympathetic and said he would try to research the problem before I took the car in. I will update once I have taken the car in next week.
    I did suggest to the service manager that a flash of the ECU might be needed to at least make it try to re-learn my driving habit. He said he would consider it. It sounds like no one has had a fix performed for this issue though.
    Apr 18 2008
    Jacksonville, FL
    Sounds like your issue from a stop could be something with your torque converter not grabbing soon enough.
    OR
    k, watch the gear number indicator. our trannys don't like to downshift to first from second unless they absolutely have to - kick over to TIP once and find out why. first is extremely short. anyway, when you "pop" off the line, your speed/rpm is probably not low enough to automatically drop to first under deceleration. when you hit the go pedal, it realizes it's too low in the RPM range to comfortably accelerate in 2nd, so it drops down to 1st, then applies the power. i recommend driving around in TIP for a bit and trying it out to see if that's what you feel. force the shifts just like that. you'll see that whenever you're coming to a stop and you downshift from 2nd to 1st when you have ANY speed above about 3 mph, the car will jerk quite noticeably when 1st engages. sadly, normal.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Jan 13 2009
    Quote Originally Posted by minameismud View Post
    OR
    I'll certainly be interested in hearing what the OP get from his Stealership, but I have to say that for my issue your possible explanation is way off the mark. Mine (and many others ) is directly related to the programmed shifting pattern in the Transmission Control Module. This is not a stop to start issue that would point to the Torque converter, but a rolling shift from 1st to 2nd(and ONLY 1st to 2nd). It is a quite scary feeling to pull to in traffic and have the car temporarily "stall" while suddenly deciding to shift gears withing the first ten feet of roll(1500RPM).
    Complaints to the dealer showed no concern whatsoever, even with complete acknowledgment of the problem. All I got was "sorry, that's how it is".
    I'd love to shove this problem down their throats, because it is a completely scary feeling everyday. No car owner should have this fear built in and normal for a car.
    Vince
    Established Member Two Rings cgmiller63's Avatar
    Jul 01 2008
    2006 Audi A4
    Southern California
    I have the same issue and was told it was normal for the CVT tranny coupled with turbo lag. It mostly happends during warmer weather. This is the only thing I dislike about the car.
    - Celia
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2012 A6 3.0T, 1990 944 S2
    Items for Sale
    ^it is from a stop and it is likely the torque converter. I have the same thing. The solution comes from really learning how to 'beat' the lag with your right foot. you could probably use two feet and avoid it as well.
    And it starts all over again
    Mar 06 2008
    In may case, it happens both when I come to a rolling stop AND when I come to a full stop and wait to turn.
    And it certainly is scary, because there are times when I am getting ready to make a left turn, and I press the gas pedal, whether softly or with authority, only to have the car wait a full second or so and then lurch forward into the turn while cars are coming at me. And now they are closer than expected because of the hesitation.... This could seriously cause a problem for one of us someday.
    Established Member Two Rings sider1681's Avatar
    Oct 18 2008
    2005 Audi A4 3.2L
    Manchester, NH
    This has become a normal experience with myself as well, but it's not any type of turbo lag, I have a 3.2 and no turbo. It's still annoying though, and it seems like every day there's another stop sign going up in my neighbor hood. i've just gotten used to it, i just push he peddle harder and it goes, or most of the time I don't even stop...
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I thinking its something to do with the torque converter too.
    Yes I have this problem sometimes when rolling on a right/left turn or on a hill and I tap the gas quickly and at about 30%+ load.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Senior Member Three Rings ryan_sn's Avatar
    Jun 01 2008
    2016 Audi S3 Daytona Grey
    Ontario, Canada
    I've had this problem for a while now. I'm actually gonna bring it to Audi in May and see if they do anything about it. Doubt they will though.
    2007 Audi A4 2.0TQ Quartz Grey
    2012 A4 Quattro 2.0TQ Monsoon Grey
    Present:
    Senior Member Two Rings Rosinbag's Avatar
    Jan 27 2009
    TX
    I had a lame pause, too...until I got the APR flash. Before the flash, the car was so slow it was kind of scary.
    The Rosinbag
    '13 All Road P+
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Items for Sale
    is this your first turbo car? this is not a problem when you are braking and sometimes hard the car doesn't switch to a lower gear as you slow... sometimes it holds a gear as you slow and when you press on the accelerator it takes a while to boost up to push the car. maybe i'm wrong about everything AFTER I said "this is not a problem" but it really is just a characteristic of our cars.
    Established Member Two Rings cloaked's Avatar
    Jun 11 2008
    West Hollywood
    Lightbulb Re: Auto transmission - Hesitate on take off - No time in first gear problem
    I experienced the same stall/lag issue, my car was a lease return so it was well kept. I test drove it and spent too much time hard on the throttle giving it the beans instead of checking for it's city driving habits had I done this I wouldn't have bought this car. This car has some major flaws in stock form I would even call it unsafe for my driving style and general unsafe features. I find it hard to believe that people buy these cars and leave them bonestock that's crazy. I felt I would be a sitting duck if I didn't do something quick with the power and delivery. So I tried GIAC which wasn't for me then installed APR. now I'm running an APR plus 2, it's great to have options. If the B-7 has the same issues as the B6 well I'm going to leave this alone.
    Established Member Two Rings 377Z's Avatar
    Aug 25 2008
    Chicago, IL
    I have a 2004 3.0Q tip and I have a similar problem when moving. Rolling in traffic, then giving it a sudden 1/2 to 3/4 throttle leaves the car confused for a second, as if its like "really? You want to go, NOW? Alright, I'll pick up my shit,"
    Whats worse, is that this soggy response contrasts SHARPLY with the strange behavior from a dead stop: it actually lurches/lunges forward for an instant at tip in. Even with a smooth & fairly slow application of throttle, it feels as if the throttle is momentarilly 'goosed' open, causing the car to jump forward. It may sound great in comparison to the lag, but its really noticeable in heavy traffic and very tiresome to have your neck snapped around, particularly for passengers. Plus, the uninitiated think the driver is a ham-fisted retard.
    Personally, I think the problem is a combination of several things:
    1) Wacky DBW tuning where it is not 1:1 in certain situations. Probably set up to make the car feel more powerful than it is for the unwashed masses. The dead spots where the response is soggy are probably the easy way out for emissions testing. Its monkey business that reminds me of the 1979-1984 Eldorados with the 4100 motors: they had a much shorter than normal pedal travel--it fooled people into thinking the car was stronger than it was (until they went to floor it & realized they were almost there already).
    2) Clumsy shift mapping. There is some wacky shift strategies going on in there, and the no time in 1st is a direct result of this. I noticed it in the Q7 loaner we had last time--very annoying because the 1-2 shift actually takes LONGER than the time it spends in 1st gear. On my own car, I also notice in many situations the trans shifts too soon/too late. I wish there was an aftermarket software that cracked the maps, I'd love to try my hand at enhancing them. Fortunately, at least we can switch around between several 'pre-fabbed' strategies with the VAG com; still waiting for my cable.
    Guys, next time you drive your car try to duplicate the situation that causes the hesitation, but before getting on it, flick the shifter into tip mode. Odds are, you are in 2nd, and when you gas it the trans goes down to 1st, then back into 2nd. Putting it into tip mode will (at least on my B6) keep the trans in 2nd, instead of wasting time shifting down to 1st only to almost immediately shift into 2nd actually spending more time shifting than going in the first couple seconds. If putting it in tip mode makes it go away, its simply the shift strategy.
    3) Lazy shifts. Great for the unwashed masses, since most just want a smooth ride. Why they didn't tune it to have smooth shifts at lesser throttle applications, and have higher line pressures/firmer & faster shifts at higher throttle applications is beyond me (and yes, it is possible to do that). Here again I'd love to get the transmission manual & look into how it regulates line pressures, and which accumulators correspond with which shifts, etc & do my own R&D on a home shift kit but IIRC the manual is some $800, with no guarantee of result. Still thinking about that one, but odds are it won't happen.
    Couple a lazy DBW setup with a lazy shift & a shift strategy that doesn't know whether its coming or going, and, well, we all know the outcome. Personally, I'll be happy if I can just get rid of the damn 'lunge.'
    2007 Volvo S60R
    2005 A4 2.0T Quattro
    1998 Ford Explorer Sport 4X4
    Active Member Two Rings mak1avel1's Avatar
    Jun 17 2015
    Tbilisi, Georgia
    Can almost dead rubber mounts lead Harsh and Delayed Shifting?
    May 17 2011
    Northeaster PA
    This is a long dead thread. but we have the same thing with our car. it's definitely the mapping, not turbo lag. I have less of an issue with it than my wife. My throttle application is easier for the computer to understand. My wife tends to jab it a bit and it leaves the computer searching for a solution. It is total bullshit. The car just sits for a couple seconds deciding if it really wants to drop to first, then first grabs hard. I completely agree with 3777Z's comments about the mapping. It reminds me of the tricks Detroit use to pull to make the little econobox feel more powerful than it was rather than give linear control. I have no need of more power from this car but if a tune would smooth out the mapping I'd be all for it.
    2006 A4 Avant
    replaced wrecked 04 A6 Avant
    replaced tired 98 A4 1.8tqm
    Oct 07 2015
    Montreal/Quebec/Canada
    I have a 2007 s-line with 6 speed tiptronic, I bought use at 53000km and every once in awhile it does it at a stop sign, on a complet stop when I guive gas to go and it hesitate approx 1 or 2 sec. they told me it was normal and it never got worst. I now have 189000km and it's still the same.
