Results 1 to 19 of 19
    Registered Member Two Rings
    Jan 14 2008
    Ticking sound coming from drivers front wheel/suspension area
    I had new tires put on about a week ago (235/40/18 RE-01Rs) and I noticed a ticking/tapping sound at lower speeds coming from the drivers side front. I took the wheel off and checked for any rocks in the tires, loose brake parts and I cleaned the wheel and hub before I put it back on. The noise is less pronounced but its still there. Anyone have a clue? Could it be suspension related? The sound gets faster/slower with the speed of the car.
    Jan 14 2008
    Re: Ticking sound coming from drivers front wheel/suspension area
    I also checked the tire for abrasion in case I was rubbing somewhere and couldnt see anything. I think it might be a brake caliper or suspension issue.
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    That kind of noise is typically associated with wear in the CV joint... does it change at all if you turn left and right? Are your CV boots torn on that side?
    Established Member Two Rings notachance's Avatar
    Sep 08 2007
    2005 B6 Audi S4
    North Jersey
    I get a very similar thing. however recently, ive noticed like a clunking sound when i go forward or reverse slowly. anyone have an idea what it could be?
    I JL 10w7 I
    I V1 Hardwire I
    I 20% 3M Tints I
    I ADR Interface I
    I Clear Corner Mod I
    I Blacked Out Emblems I
    I Stratmosphere Intake I
    I Dice Ipod Connectivity I
    I Milltek Non-Resonated Catback I
    I Front & Rear Hotchkis Sway Bars I
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Quote Originally Posted by notachance View Post
    It could be a lot of things, but whatever it is, you should have the car looked at by a certified technician soon. If it's something like a tie-rod, it could be supremely dangerous if it goes while you're driving.
    Senior Member Three Rings S4fever's Avatar
    Dec 17 2008
    5.0 foxbody mustang
    I was just about to post a thread but ....I have a similar problem right now when i come to a stop i would barely hear a slight click noise on my right front tire.. and when i turn the wheel i hear a slight cracking noise ? any help ?
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Quote Originally Posted by S4fever View Post
    CV joints, tie-rod, control arms, ball joints, brake calipers, wheel bearings; it's hard to say, since there's so much there. I'd get it checked out asap.
    Sep 12 2008
    South Central PA
    i think mine does it because the wheel bearing is bad.
    i just replaced the brakes and checked the suspension and everything. i know my wheel bearing is bad
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Three Rings Veereihen6's Avatar
    Mar 06 2009
    Long Island, NY
    CV joint, or wheel bearing, etc....does it go away when you touch the brake pedal?
    2004 B6 S4 Avant 6MT Moro Blue - mostly stock for now
    1998 VW GTi-VR6 - mmmmm....listen to that VR6 growl! -sold-
    Dec 17 2008
    5.0 foxbody mustang
    so im guessing i shouldnt drive it to the movies tonight ....damn that sucks
    Sep 12 2008
    South Central PA
    Quote Originally Posted by Veereihen6 View Post
    nope, thats why im like 103% sure its my wheel bearing lol
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Sep 12 2008
    South Central PA
    just take it. whats the worse that could happen? your tie rod breaks and you veer off the road into a ditch? just imagine the sympathy sex you could score
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    lol
    Deactivated Two Rings
    Jan 22 2008
    2006 Audi A3 (3.2)
    Sacramento, CA
    I have a very similiar sound from my left front tire area. Its sounds like a metal tapping sound (ting, ting ,ting) at slow speeds (less than 25mph) and then goes away. Happens when going straight or turning.
    If a wheel bearing, should this be covered under a full extended warranty?
    Sep 12 2008
    South Central PA
    Quote Originally Posted by jeeping View Post
    i dont know if they would cover it or not. they might look at it as a normal wear item like brake pads.
    just call and ask
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Sep 12 2008
    South Central PA
    no but seriously. if it was your tie rod you would be able to rotate your tire (like pull with one hand and push with the other) and you would hear it click.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    mmm... usually.
    Dec 17 2008
    5.0 foxbody mustang
    Quote Originally Posted by Dan[FN]Shank210 View Post
    I mean i know i was suppose to change my control arms but i didnt( doing that tmrw ). Its a weird sound when i hit the brakes sounds like maybe a rubber boot but only at slow speeds u could slightly hear it .. and when i turn the wheel all the way to the right it makes a sqeak noise ... not the powersteering noise but something rubbing. All i do know is that i ran into some crrrrrrrrazy potholes and bent my wheels twice in a week hmm...
    Veteran Member Four Rings ALWAYS4UDI's Avatar
    Apr 13 2008
    Here
    http://www.audizine.com/forum/showthread.php?t=269100
    Signature.
