Results 1 to 28 of 28
    Senior Member Three Rings NorCalS4's Avatar
    Mar 16 2009
    Chico, Ca
    How to tell if motor mounts are broken??
    Okay. Here's the story. I took my car to the shop to get the TB done. I also wanted them to look at the drivetrain mounts cuz I am having a drivetrain thud from the rear, which I thought would be a bad rear diff mount and wanted to get it replaced under warranty. They come back and say that my motor mounts are gone, and there "metal to metal". Now,in all the pictures I have seen of B5 S4 motor mounts, the mounts have a metal thing that goes over the rubber and makes the mount looks completely metal (correct me if Im wrong). I dont totally believe that the mounts are broken and just think the tech looked and saw the all metal look of the mount. But I could be wrong.
    So how can I check if the mounts are broken or not?
    and I did search.
    '01.5 Silver S4 6spd
    ~V1 hardwired
    ~AWE Boost gauge in DIY vent pod
    ~ASP DTS
    ~F90BT w/ JL 250/1 & W3 12"
    Feb 22 2008
    B5 a4 sedan&avant, c6 a6 avant,99 Chevy 2500 plow truck, 67 c-10
    ma/ct
    Items for Sale
    Re: How to tell if motor mounts are broken??
    every "broken" audi motor mount ive ever seen leaks fluid. so you should see what looks like used engine oil leaking. if they stoped leaking a purple trail will be left on the mount.
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by AUDIous View Post
    Thanks for the reply and thats what I thought. From my research there should be purple stuff ozzing out.
    Also, is what I mentioned about the mount having a metal cover and looking all metal (with no visible rubber) Correct?
    ~V1 hardwired
    ~ASP DTS
    Senior Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    i seen my mechanic do this...have the hood open and some one stand in front of the car, put the e-brake up and put it in first and press the gas a little bit so the car moves and if the person standing in front of the car sees the motor "jumping" around then broken motor mounts
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    2001.5 s4, 2001 porsche 911 996
    Items for Sale
    uhhh what?
    Current
    '13 black Audi S7
    Sold
    Stage 3 2.7t swapped B7 A4
    Stage 63463 2001.5 Silver S4
    Driver Supply
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by AMC View Post
    uhhh what?
    Any actual info to add?
    ~V1 hardwired
    ~ASP DTS
    Senior Member Two Rings momento1's Avatar
    Feb 04 2008
    AUDI 2002 S4
    Sydney, Australia
    Quote Originally Posted by NorCalS4 View Post
    and I did search.
    do you have a DTS (drivetrain Stabilizer bar)???
    i installed a DTS from AWE and my "thud" from the rear went away...
    CURRENT - Audi 2002 S4 Nogaro Blue Pearl - Stage 3+ 335Hp atw (but something isnt right...)
    PREVIOUS - Audi 2001 S3 Silver - 230Hp atw
    Jun 15 2007
    Items for Sale
    there is no fluid in our motor mounts, just the metal bottom and the material u see on top. no purple fluid or oild fluid.
    Current
    '13 black Audi S7
    Sold
    Driver Supply
    Jan 29 2007
    08 S4 00 S4
    MD
    Items for Sale
    B5 S4 motor mounts are hydraulic.
    08 S4- Stock
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by momento1 View Post
    Not yet. I plan to do a DTS and a rear diff mount. I just got the car and its has an extended warranty and I was just trying to find everything that is broken, so I can get it fixed and get the car in %100 perfect condition before I start modding.
    ~V1 hardwired
    ~ASP DTS
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by mholme View Post
    So they do or do not have fluid in them, ie. visible fluid on mount=broken??
    ~V1 hardwired
    ~ASP DTS
    Jan 29 2007
    08 S4 00 S4
    MD
    Items for Sale
    Yup. Do.
    08 S4- Stock
    Stage 2 Banner Advertiser Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Motor mounts are fluid filled.
    They can fail a number of different ways. It's common that when they fail they leak fluid, however not always. Here's an example of how they can fail without leaking any fluid at all.
    And another example of a failed mount without leaking fluid.
    However, more often than not, the mounts will crack internally and leak a dark purple fluid out of them. It's VERY visible and easy to spot once you locate the motor mount.
    www.purems.com
    San Diego, CA | mike@purems.com | Twitter! | Facebook
    Your Source for everything APR, HRE Wheels, Brembo, TSW, Rotiform, VMR Wheels, Stern, Evolution Racewerks, Clutchmasters, South Bend, Carbonio, VWR, Gruppe M, OSIR, and much more!
    Senior Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Chicago
    Mar 16 2009
    Chico, Ca
    Thanks for all the replies.
    Do the mounts look all metal ie no visible rubber, like in this pic?
    ~V1 hardwired
    ~ASP DTS
    Jan 29 2007
    08 S4 00 S4
    MD
    Items for Sale
    Yes, they do.
    08 S4- Stock
    Jan 11 2007
    Salt Lake City, Utah
    They look just like that pic, but I definitely see grey rubber in that pic. This is how mine failed
    ** GT2860R-7 S4 Build Log--
    FOR SALE:
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)--
    LOOKING FOR:
    --Early Style 2.7t Block "AE"
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by jibberjive View Post
    Thanks for the pic. Me and my audi buddy (99.5 A4 2.8 PES) are gonna jack the car up tomorrow and take a look at the mounts
    ~V1 hardwired
    ~ASP DTS
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    i always found the design of the 2.7t engine mount to be very weak looking, especially the fact that it's only held on by one small screw.
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Jun 15 2007
    Items for Sale
    Yes, they do.
    i feel stupid. ive seeen so many bad motor mounts its not even funny never once did i see them leaking hha and ive hit em with a hammer. ive seen em break at the mottom and at the top
    thats it
    Current
    '13 black Audi S7
    Sold
    Driver Supply
    Mar 16 2009
    Chico, Ca
    Okay crawled under there and took a look. The mounts dont look broken to me, but Im a audi newbie. I took some pics though... but they were of the TRANNY MOUNTS (stupid me)
    Look at my post below
    ~V1 hardwired
    ~ASP DTS
    Mar 16 2009
    Chico, Ca
    ^^ after looking at the pics above mine, I think I took pics of the wrong thing (tranny mounts??). Well , back to the garage to check again
    ~V1 hardwired
    ~ASP DTS
    Mar 16 2009
    Chico, Ca
    I located the motor mounts and indeed the drivers side one is broken, there is some purple fluid leak stains. The passenger almost seems like its leaking but doesnt have leak trails like the drivers. when you look though the lil hole in the metal at the bottom of the mount though, it does look like it just started leaking. Anyways, thanks for the help.
    ~V1 hardwired
    ~ASP DTS
    Feb 02 2009
    Cars other people killed
    capital city wastes
    if u look under the subframe where the lower mount bolt is youll see this black crap, that means they leaked out and suck. you can also tell if you have a stick car because the shifter will move.
    they only break if you drive them a long time with no fluid in them. someone sells mounts that are stock with stock pn numbers on them(good for tech inspection) but are all solid and should only break if you crash.
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by megafreakindeth View Post
    link to the mounts you mentioned?
    ~V1 hardwired
    ~ASP DTS
    Jul 19 2007
    San Diego, CA
    As far as replacement mounts go, these are probably the best available.
    Stern Pro-Mounts
    Competitively priced with RS4's, and come with a lifetime warranty!
    www.purems.com
    Jan 11 2007
    Personally I think you can't beat the value of 034's density line. I got them all
    FOR SALE:
    LOOKING FOR:
    Mar 16 2009
    Chico, Ca
    Yeah, Im think 034 or RS4. Think more towards 034.
    ~V1 hardwired
    ~ASP DTS
